path: root/drivers/usb/class/cdc-acm.h
2014-05-27USB: cdc-acm: use BIT macroOliver Neukum
Converting the header to BIT for readability. No functional change. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-27USB: cdc-acm: fix broken runtime suspendJohan Hovold
The current ACM runtime-suspend implementation is broken in several ways: Firstly, it buffers only the first write request being made while suspended -- any further writes are silently dropped. Secondly, writes being dropped also leak write urbs, which are never reclaimed (until the device is unbound). Thirdly, even the single buffered write is not cleared at shutdown (which may happen before the device is resumed), something which can lead to another urb leak as well as a PM usage-counter leak. Fix this by implementing a delayed-write queue using urb anchors and making sure to discard the queue properly at shutdown. Fixes: 11ea859d64b6 ("USB: additional power savings for cdc-acm devices that support remote wakeup") Reported-by: Xiao Jin <jin.xiao@intel.com> Cc: <stable@vger.kernel.org> # v2.6.27 Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-03cdc-acm: add TIOCMIWAITOliver Neukum
This implements TIOCMIWAIT for TIOCM_DSR, TIOCM_RI and TIOCM_CD Disconnect is handled as TIOCM_CD or an error. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-12USB: cdc-acm - blacklist IMS PCU deviceDmitry Torokhov
The IMS PCU (Passenger Control Unit) device used custom protocol over serial line, so it is presenting itself as CDC ACM device. Now that we have proper in-kernel driver for it we need to black-list the device in cdc-acm driver. Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2011-12-09USB: cdc-acm: Fix potential deadlock (lockdep warning)Havard Skinnemoen
Rework the locking and lifecycle management in the cdc-acm driver. Instead of using a global mutex to prevent the 'acm' object from being freed, use the tty_port kref to keep the device alive when either the USB side or TTY side is still active. This allows us to use the global mutex purely for protecting the acm_table, while use acm->mutex to guard against disconnect during TTY port activation and shutdown. The USB-side kref is taken during port initialization in probe(), and released at the end of disconnect(). The TTY-side kref is taken in install() and released in cleanup(). On disconnect, tty_vhangup() is called instead of tty_hangup() to ensure the TTY hangup processing is completed before the USB device is taken down. The TTY open and close handlers have been gutted and replaced with tty_port_open() and tty_port_close() respectively. The driver-specific code which used to be there was spread across install(), activate() and shutdown(). Reported-by: Dave Jones <davej@redhat.com> Cc: Alan Cox <alan@linux.intel.com> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Havard Skinnemoen <hskinnemoen@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-11USB: cdc_acm: Fix oops when Droids MuIn LCD is connectedErik Slagter
The Droids MuIn LCD operates like a serial remote terminal. Data received are displayed directly on the LCD. This patch fixes the kernel null pointer oops when it is plugged in. Add NO_DATA_INTERFACE quirk to tell the driver that "control" and "data" interfaces are not separated for this device, which prevents dereferencing a null pointer in the device probe code. Signed-off-by: Erik Slagter <erik@slagter.name> Signed-off-by: Maxin B. John <maxin.john@gmail.com> Tested-by: Erik Slagter <erik@slagter.name> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-13USB: cdc-acm: re-write read processingJohan Hovold
Kill rx tasklet, which is no longer needed, and re-write read processing. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-13USB: cdc-acm: remove unused drain-delay codeJohan Hovold
The drain-delay code is no longer used, so remove it. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: cdc-acm: make bitfields unsignedRandy Dunlap
Fix usb/class sparse warnings: drivers/usb/class/cdc-acm.h:128:34: error: dubious one-bit signed bitfield drivers/usb/class/cdc-acm.h:129:24: error: dubious one-bit signed bitfield Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: cdc_acm: Silence "It is not a modem." error for pbLua devicesJulian Calaby
The pbLua console port is known to not be a modem, so it is unnecessary to be told this when it is plugged in. Add NOT_A_MODEM quirk to tell the driver that we know this already and hence not to warn us, and mark the pbLua console port. Signed-off-by: Julian Calaby <julian.calaby@gmail.com> Cc: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: cdc-acm: Update to new autopm APIOliver Neukum
Update cdc-acm to the async methods eliminating the workqueue Signed-off-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-08-07USB: fix oops on disconnect in cdc-acmOliver Neukum
This patch fixes an oops caused when during an unplug a device's table of endpoints is zeroed before the driver is notified. A pointer to the endpoint must be cached. this fixes a regression caused by commit 5186ffee2320942c3dc9745f7930e0eb15329ca6 Therefore it should go into 2.6.31 Signed-off-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: support for cdc-acm of single interface devicesOliver Neukum
This implement support in cdc-acm for acm devices another popular OS can handle - adds support for autodetection of devices that use one interface - autodetection of endpoints - add a quirk for surpressing a setting that OS doesn't use - autoassume that quirk for single interface devices Signed-off-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11tty: cdc_acm add krefsAlan Cox
Now we have a port structure begin using the fields and kref counts Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11tty: Update cdc_acmAlan Cox
The CDC ACM driver uses the tty layer correctly so needs conversion. Start by adding and initializing the port structures. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-13usb: cdc-acm: drain writes on closeDavid Brownell
Add a mechanism to let the write queue drain naturally before closing the TTY, rather than always losing that data. There is a timeout, so it can't wait too long. Provide missing locking inside acm_wb_is_avail(); it matters more now. Note, this presumes an earlier patch was applied, removing a call to this routine where the lock was held. Slightly improved diagnostics on write URB completion, so we can tell when a write URB gets killed and, if so, how much data it wrote first ... and so that I/O path is normally silent (and can't much change timings). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-13usb: cdc-acm: stop dropping tx buffersDavid Brownell
The "increase cdc-acm write throughput" patch left in place two now-obsolete mechanisms, either of which can make the cdc-acm driver drop TX data (nasty!). This patch removes them: - The write_ready flag ... if an URB and buffer were found, they can (and should!) always be used. - TX path acm_wb_is_used() ... used when the buffer was just allocated, so that check is pointless. Also fix a won't-yet-matter leak of a write buffer on a disconnect path. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Engraf <david.engraf@netcom.eu> Acked-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21USB: additional power savings for cdc-acm devices that support remote wakeupOliver Neukum
this patch saves power for cdc-acm devices that support remote wakeup while the device is connected. - request needs_remote_wakeup when needed - delayed write while a device is autoresumed - the device is marked busy when appropriate Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: increase cdc-acm write throughputDavid Engraf
the following patch uses 16 write urbs and a writsize of wMaxPacketSize * 20. With this patch I get the maximum througput from my linux system with 20MB/sec read and 15 MB/sec write (full speed 1 MB/sec both) I also deleted the flag URB_NO_FSBR for the writeurbs, because this makes my full speed devices significant slower. Signed-off-by: David Engraf <david.engraf@netcom.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: autosuspend for cdc-acmOliver Neukum
Here we go. This patch implements suspend/resume and autosuspend for the CDC ACM driver. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27USB: cdc-acm: export parsed capabilities through sysfsOliver Neukum
this patch exports the attributes cdc-acm knows about a device through sysfs. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: cdc-acm: add a new special case for modems with buggy firmwareOliver Neukum
this fixes the "duplicated text" bug. There's a modem that cannot cope with large transfers and more than one urb in flight. This patch adds a special case to the driver. Signed-off-by: Oliver Neukum <oliver@neukum.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: Converting cdc acm to a ring queueDavid Kubicek
this patch by David converts the sending queue of the CDC ACM driver to a queue of URBs. This is needed for quicker devices. Please apply. Signed-Off-By: Oliver Neukum <oliver@neukum.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/usb/class/cdc-acm.c | 229 ++++++++++++++++++++++++++++++-------------- drivers/usb/class/cdc-acm.h | 33 +++++- 2 files changed, 185 insertions(+), 77 deletions(-)
2005-06-27[PATCH] USB: fix acm trouble with terminalsOliver Neukum
This patch fixes lost LF when ACM device is used with getty/login/bash, in case of a modem which takes calls. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Oliver Neukum <oliver@neukum.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
