path: root/drivers/usb/atm/ueagle-atm.c
2006-01-31[PATCH] USBATM: allow isochronous transferDuncan Sands
While the usbatm core has had some support for using isoc urbs for some time, there was no way for users to turn it on. While use of isoc transfer should still be considered experimental, it now works well enough to let users turn it on. Minidrivers signal to the core that they want to use isoc transfer by setting the new UDSL_USE_ISOC flag. The speedtch minidriver gets a new module parameter enable_isoc (defaults to false), plus some logic that checks for the existence of an isoc receive endpoint (not all speedtouch modems have one). Signed-off-by: Duncan Sands <baldrick@free.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] USBATM: remove .ownerDuncan Sands
Remove the unused .owner field in struct usbatm_driver. Signed-off-by: Duncan Sands <baldrick@free.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] USBATM: add flags fieldDuncan Sands
Have minidrivers and the core signal special requirements using a flags field in struct usbatm_data. For the moment this is only used to replace the need_heavy_init bind parameter, but there'll be new flags in later patches. Signed-off-by: Duncan Sands <baldrick@free.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: remove .owner field from struct usb_driverGreg Kroah-Hartman
It is no longer needed, so let's remove it, saving a bit of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: Eagle and ADI 930 usb adsl modem driver fixmatthieu castet
More care on loading firmware, take into account fw->size can't be zero. Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: Eagle and ADI 930 usb adsl modem drivermatthieu castet
A driver for USB ADSL modems based on the ADI eagle chipset using the usb_atm infrastructure. The managing part was taken from bsd ueagle driver, other parts were written from scratch. The driver uses the in-kernel firmware loader : - to load a first usb firmware when the modem is in pre-firmware state - to load the dsp firmware that are swapped in host memory. - to load CMV (configuration and management variables) when the modem boot. (We can't use options or sysfs for this as there many possible values. See https://mail.gna.org/public/eagleusb-dev/2005-04/msg00031.html for a description of some) - to load fpga code for 930 chipset. The device had 4 endpoints : * 2 for data (use by usbatm). The incoming endpoint could be iso or bulk. The modem seems buggy and produce lot's of atm errors when using it in bulk mode for speed > 3Mbps, so iso endpoint is need for speed > 3Mbps. At the moment iso endpoint need a patched usbatm library and for this reason is not included in this patch. * One bulk endpoint for uploading dsp firmware * One irq endpoint that notices the driver - if we need to upload a page of the dsp firmware - an ack for read or write CMV and the value (for the read case). If order to make the driver cleaner, we design synchronous (read|write)_cmv : -send a synchronous control message to the modem -wait for an ack or a timeout -return the value if needed. In order to run these synchronous usb messages we need a kernel thread. The driver has been tested with sagem fast 800 modems with different eagle chipset revision and with ADI 930 since April 2005. Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
