path: root/drivers/tty
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-04-19tty/n_gsm: fix bug in CRC calculation for gsm1 modeMikhail Kshevetskiy
Problem description: gsm_queue() calculate a CRC for arrived frames. As a last step of CRC calculation it call gsm->fcs = gsm_fcs_add(gsm->fcs, gsm->received_fcs); This work perfectly for the case of GSM0 mode as gsm->received_fcs contain the last piece of data required to generate final CRC. gsm->received_fcs is not used for GSM1 mode. Thus we put an additional byte to CRC calculation. As result we get a wrong CRC and reject incoming frame. Signed-off-by: Mikhail Kshevetskiy <mikhail.kshevetskiy@gmail.com> Acked-by: Alan Cox <alan@linux.intel.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19serial/imx: read cts state only after acking cts change irqUwe Kleine-König
If cts changes between reading the level at the cts input (USR1_RTSS) and acking the irq (USR1_RTSD) the last edge doesn't generate an irq and uart_handle_cts_change is called with a outdated value for cts. The race was introduced by commit ceca629 ([ARM] 2971/1: i.MX uart handle rts irq) Reported-by: Arwed Springer <Arwed.Springer@de.trumpf.com> Tested-by: Arwed Springer <Arwed.Springer@de.trumpf.com> Cc: stable@kernel.org # 2.6.14+ Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-12tty: fix typo in descripton of tty_termios_encode_baud_rateUwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-10treewide: remove extra semicolonsJustin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-07Merge branch 'sh-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: select ARCH_NO_SYSDEV_OPS. sh: fix build error in board-sh7757lcr.c sh: landisk: Remove whitespace sh: landisk: Remove mv_nr_irqs sh: sh-sci: Fix double initialization by serial_console_setup serial: sh-sci: prevent setup of uninitialized serial console dma: shdma: add checking the DMAOR_AE in sh_dmae_err
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-04-04tty: fix endless work loop when the buffer fills upLinus Torvalds
Commit f23eb2b2b285 ('tty: stop using "delayed_work" in the tty layer') ended up causing hung machines on UP with no preemption, because the work routine to flip the buffer data to the ldisc would endlessly re-arm itself if the destination buffer had filled up. With the delayed work, that only caused a timer-driving polling of the tty state every timer tick, but without the delay we just ended up with basically a busy loop instead. Stop the insane polling, and instead make the code that opens up the receive room re-schedule the buffer flip work. That's what we should have been doing anyway. This same "poll for tty room" issue is almost certainly also the cause of excessive kworker activity when idle reported by Dave Jones, who also reported "flush_to_ldisc executing 2500 times a second" back in Nov 2010: http://lkml.org/lkml/2010/11/30/592 which is that silly flushing done every timer tick. Wasting both power and CPU for no good reason. Reported-and-tested-by: Alexander Beregalov <a.beregalov@gmail.com> Reported-and-tested-by: Sitsofe Wheeler <sitsofe@yahoo.com> Cc: Greg KH <gregkh@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-31Merge branch 'master' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into sh-latest
2011-03-31sh: sh-sci: Fix double initialization by serial_console_setupNobuhiro Iwamatsu
The driver is initialized in a state with an unknown value by serial_console_setup. And initialization fails. This is caused by the initialization by sci_console_init. This function does not seem to be necessary for the present sh-sci driver. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-31serial: sh-sci: prevent setup of uninitialized serial consoleAlexandre Courbot
Commit 906b17dc089f7fa87e37a9cfe6ee185efc90e0da introduced a condition where the kernel will crash unless a earlyprintk parameter is specified. Without this parameter, sci_console_init is called during early console setup without any port being initialized, and the kernel crashes a little bit later when uart_set_options attemps to invoke set_termios on a port with an ops member equal to NULL. This patch just checks in sci_console_init that the port is properly initialized, and aborts the early console setup if it is not. Signed-off-by: Alexandre Courbot <gnurou@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-30apbuart: Depend upon sparc.David S. Miller
It absolutely needs to be able to get at pdev_archdata members which are sparc specific. Signed-off-by: David S. Miller <davem@davemloft.net> Reported-by: Stephen Rothwell <sfr@canb.auug.org.au>
2011-03-30sparc32,leon: Fixed APBUART frequency detectionDaniel Hellstrom
The UARTs may be located on different APB buses, thus have different UART clock frequency. The system frequency is not the same (but often) as the UART frequency, rather the APB bus frequency that the APBUART is located at has the same frequency, so this looks at the "freq" property instead. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-30sparc32, leon: APBUART driver must use archdata to get IRQ numberDaniel Hellstrom
See Commit id 1636f8ac2b08410df4766449f7c86b912443cd99 (sparc/of: Move of_device fields into struct pdev_archdata), this patch is similar to 19e4875fb21a69fbf620e84769a74d189c69c58d (of/sparc: fix build regression from of_device changes) Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-29drivers: Final irq namespace conversionThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-25Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: kdb: add usage string of 'per_cpu' command kgdb,x86_64: fix compile warning found with sparse kdb: code cleanup to use macro instead of value kgdboc,kgdbts: strlen() doesn't count the terminator
2011-03-25kgdboc,kgdbts: strlen() doesn't count the terminatorDan Carpenter
This is an off by one because strlen() doesn't count the null terminator. We strcpy() these strings into an array of size MAX_CONFIG_LEN. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2011-03-24lib, arch: add filter argument to show_mem and fix private implementationsDavid Rientjes
Commit ddd588b5dd55 ("oom: suppress nodes that are not allowed from meminfo on oom kill") moved lib/show_mem.o out of lib/lib.a, which resulted in build warnings on all architectures that implement their own versions of show_mem(): lib/lib.a(show_mem.o): In function `show_mem': show_mem.c:(.text+0x1f4): multiple definition of `show_mem' arch/sparc/mm/built-in.o:(.text+0xd70): first defined here The fix is to remove __show_mem() and add its argument to show_mem() in all implementations to prevent this breakage. Architectures that implement their own show_mem() actually don't do anything with the argument yet, but they could be made to filter nodes that aren't allowed in the current context in the future just like the generic implementation. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Reported-by: James Bottomley <James.Bottomley@hansenpartnership.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23drivers/tty/bfin_jtag_comm.c: avoid calling put_tty_driver on NULLJulia Lawall
put_tty_driver calls tty_driver_kref_put on its argument, and then tty_driver_kref_put calls kref_put on the address of a field of this argument. kref_put checks for NULL, but in this case the field is likely to have some offset and so the result of taking its address will not be NULL. Labels are added to be able to skip over the call to put_tty_driver when the argument will be NULL. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression *x; @@ *if (x == NULL) { ... * put_tty_driver(x); ... return ...; } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Torben Hohn <torbenh@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22tty: stop using "delayed_work" in the tty layerLinus Torvalds
Using delayed-work for tty flip buffers ends up causing us to wait for the next tick to complete some actions. That's usually not all that noticeable, but for certain latency-critical workloads it ends up being totally unacceptable. As an extreme case of this, passing a token back-and-forth over a pty will take two ticks per iteration, so even just a thousand iterations will take 8 seconds assuming a common 250Hz configuration. Avoiding the whole delayed work issue brings that ping-pong test-case down to 0.009s on my machine. In more practical terms, this latency has been a performance problem for things like dive computer simulators (simulating the serial interface using the ptys) and for other environments (Alan mentions a CP/M emulator). Reported-by: Jef Driesen <jefdriesen@telenet.be> Acked-by: Greg KH <gregkh@suse.de> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-18Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (62 commits) powerpc/85xx: Fix signedness bug in cache-sram powerpc/fsl: 85xx: document cache sram bindings powerpc/fsl: define binding for fsl mpic interrupt controllers powerpc/fsl_msi: Handle msi-available-ranges better drivers/serial/ucc_uart.c: Add of_node_put to avoid memory leak powerpc/85xx: Fix SPE float to integer conversion failure powerpc/85xx: Update sata controller compatible for p1022ds board ATA: Add FSL sata v2 controller support powerpc/mpc8xxx_gpio: simplify searching for 'fsl, qoriq-gpio' compatiable powerpc/8xx: remove obsolete mgsuvd board powerpc/82xx: rename and update mgcoge board support powerpc/83xx: rename and update kmeter1 powerpc/85xx: Workaroudn e500 CPU erratum A005 powerpc/fsl_pci: Add support for FSL PCIe controllers v2.x powerpc/85xx: Fix writing to spin table 'cpu-release-addr' on ppc64e powerpc/pseries: Disable MSI using new interface if possible powerpc: Enable GENERIC_HARDIRQS_NO_DEPRECATED. powerpc: core irq_data conversion. powerpc: sysdev/xilinx_intc irq_data conversion. powerpc: sysdev/uic irq_data conversion. ... Fix up conflicts in arch/powerpc/sysdev/fsl_msi.c (due to getting rid of of_platform_driver in arch/powerpc)
2011-03-17Merge branch 'for-linus' of git://codeaurora.org/quic/kernel/davidb/linux-msmLinus Torvalds
* 'for-linus' of git://codeaurora.org/quic/kernel/davidb/linux-msm: (46 commits) msm: scm: Check for interruption immediately msm: scm: Fix improper register assignment msm: scm: Mark inline asm as volatile msm: iommu: Enable HTW L2 redirection on MSM8960 msm: iommu: Don't read from write-only registers msm: iommu: Remove dependency on IDR msm: iommu: Use ASID tagging instead of VMID tagging msm: iommu: Rework clock logic and add IOMMU bus clock control msm: iommu: Clock control for the IOMMU driver msm: mdp: Set the correct pack pattern for XRGB/ARGB msm_fb: Fix framebuffer console msm: mdp: Add support for RGBX 8888 image format. video: msmfb: Put the partial update magic value into the fix_screen struct. msm: clock: Migrate to clkdev msm: clock: Remove references to clk_ops_pcom msm: headsmp.S: Fix section mismatch msm: Use explicit GPLv2 licenses msm: iommu: Enable IOMMU support for MSM8960 msm: iommu: Generalize platform data for multiple targets msm: iommu: Create a Kconfig item for the IOMMU driver ...
2011-03-17Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (289 commits) davinci: DM644x EVM: register MUSB device earlier davinci: add spi devices on tnetv107x evm davinci: add ssp config for tnetv107x evm board davinci: add tnetv107x ssp platform device spi: add ti-ssp spi master driver mfd: add driver for sequencer serial port ARM: EXYNOS4: Implement Clock gating for System MMU ARM: EXYNOS4: Enhancement of System MMU driver ARM: EXYNOS4: Add support for gpio interrupts ARM: S5P: Add function to register gpio interrupt bank data ARM: S5P: Cleanup S5P gpio interrupt code ARM: EXYNOS4: Add missing GPYx banks ARM: S3C64XX: Fix section mismatch from cpufreq init ARM: EXYNOS4: Add keypad device to the SMDKV310 ARM: EXYNOS4: Update clocks for keypad ARM: EXYNOS4: Update keypad base address ARM: EXYNOS4: Add keypad device helpers ARM: EXYNOS4: Add support for SATA on ARMLEX4210 plat-nomadik: make GPIO interrupts work with cpuidle ApSleep mach-u300: define a dummy filter function for coh901318 ... Fix up various conflicts in - arch/arm/mach-exynos4/cpufreq.c - arch/arm/mach-mxs/gpio.c - drivers/net/Kconfig - drivers/tty/serial/Kconfig - drivers/tty/serial/Makefile - drivers/usb/gadget/fsl_mxc_udc.c - drivers/video/Kconfig
2011-03-17Merge branches 'defcfg', 'drivers' and 'cyberpro-next' of ↵Linus Torvalds
master.kernel.org:/home/rmk/linux-2.6-arm * 'defcfg' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6647/1: add Versatile Express defconfig ARM: 6644/1: mach-ux500: update the U8500 defconfig * 'drivers' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6764/1: pl011: factor out FIFO to TTY code ARM: 6763/1: pl011: add optional RX DMA to PL011 v2 ARM: 6758/1: amba: support pm ops ARM: amba: make amba_driver id_table const ARM: amba: make internal ID table handling const ARM: amba: make probe() functions take const id tables ARM: 6662/1: amba: make amba_bustype non-static ARM: mmci: add dmaengine-based DMA support ARM: mmci: no need for separate host->data_xfered ARM: mmci: avoid unnecessary switch to data available PIO interrupts ARM: mmci: no need to call flush_dcache_page() with sg_miter API ARM: mmci: avoid reporting too many completed bytes on fifo overrun ALSA: AACI: make fifo variables more explanitory ALSA: AACI: no need to call snd_pcm_period_elapsed() for each period ALSA: AACI: use snd_pcm_lib_period_bytes() ALSA: AACI: clean up AACI announcement printk ALSA: AACI: fix channel mask selection ALSA: AACI: fix number of channels for record ALSA: AACI: fix multiple IRQ claiming * 'cyberpro-next' of master.kernel.org:/home/rmk/linux-2.6-arm: VIDEO: cyberpro: remove unused cyber2000fb_get_fb_var() VIDEO: cyberpro: remove useless function extreg pointers VIDEO: cyberpro: update handling of device structures VIDEO: cyberpro: add support for video capture I2C VIDEO: cyberpro: make 'reg_b0_lock' always present VIDEO: cyberpro: add I2C support VIDEO: cyberpro: select lowest multipler/divisor for PLL
2011-03-17Merge branches 'stable/hvc-console', 'stable/gntalloc.v6' and ↵Linus Torvalds
'stable/balloon' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/hvc-console' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/hvc: Disable probe_irq_on/off from poking the hvc-console IRQ line. * 'stable/gntalloc.v6' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: gntdev: fix build warning xen/p2m/m2p/gnttab: do not add failed grant maps to m2p override xen-gntdev: Add cast to pointer xen-gntdev: Fix incorrect use of zero handle xen: change xen/[gntdev/gntalloc] to default m xen-gntdev: prevent using UNMAP_NOTIFY_CLEAR_BYTE on read-only mappings xen-gntdev: Avoid double-mapping memory xen-gntdev: Avoid unmapping ranges twice xen-gntdev: Use map->vma for checking map validity xen-gntdev: Fix unmap notify on PV domains xen-gntdev: Fix memory leak when mmap fails xen/gntalloc,gntdev: Add unmap notify ioctl xen-gntalloc: Userspace grant allocation driver xen-gntdev: Support mapping in HVM domains xen-gntdev: Add reference counting to maps xen-gntdev: Use find_vma rather than iterating our vma list manually xen-gntdev: Change page limit to be global instead of per-open * 'stable/balloon' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: (24 commits) xen-gntdev: Use ballooned pages for grant mappings xen-balloon: Add interface to retrieve ballooned pages xen-balloon: Move core balloon functionality out of module xen/balloon: Remove pr_info's and don't alter retry_count xen/balloon: Protect against CPU exhaust by event/x process xen/balloon: Migration from mod_timer() to schedule_delayed_work() xen/balloon: Removal of driver_pages
2011-03-17Merge branches 'aaci', 'mmci-dma', 'pl' and 'pl011' into driversRussell King
2011-03-17Merge branch 'master' of ↵Paul Mundt
2011-03-16Merge remote branch 'rmk/for-linus' into for-linusDavid Brown
* rmk/for-linus: (1557 commits) ARM: 6806/1: irq: introduce entry and exit functions for chained handlers ARM: 6781/1: Thumb-2: Work around buggy Thumb-2 short branch relocations in gas ARM: 6747/1: P2V: Thumb2 support ARM: 6798/1: aout-core: zero thread debug registers in a.out core dump ARM: 6796/1: Footbridge: Fix I/O mappings for NOMMU mode ARM: 6784/1: errata: no automatic Store Buffer drain on Cortex-A9 ARM: 6772/1: errata: possible fault MMU translations following an ASID switch ARM: 6776/1: mach-ux500: activate fix for errata 753970 ARM: 6794/1: SPEAr: Append UL to device address macros. ARM: 6793/1: SPEAr: Remove unused *_SIZE macros from spear*.h files ARM: 6792/1: SPEAr: Replace SIZE macro's with SZ_4K macros ARM: 6791/1: SPEAr3xx: Declare device structures after shirq code ARM: 6790/1: SPEAr: Clock Framework: Rename usbd clock and align apb_clk entry ARM: 6789/1: SPEAr3xx: Rename sdio to sdhci ARM: 6788/1: SPEAr: Include mach/hardware.h instead of mach/spear.h ARM: 6787/1: SPEAr: Reorder #includes in .h & .c files. ARM: 6681/1: SPEAr: add debugfs support to clk API ARM: 6703/1: SPEAr: update clk API support ARM: 6679/1: SPEAr: make clk API functions more generic ARM: 6737/1: SPEAr: formalized timer support ... Conflicts: arch/arm/mach-msm/board-msm7x27.c arch/arm/mach-msm/board-msm7x30.c arch/arm/mach-msm/board-qsd8x50.c arch/arm/mach-msm/board-sapphire.c arch/arm/mach-msm/include/mach/memory.h
2011-03-16Merge branch 'remove' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'remove' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6629/2: aaec2000: remove support for mach-aaec2000 ARM: lh7a40x: remove unmaintained platform support Fix up trivial conflicts in - arch/arm/mach-{aaec2000,lh7a40x}/include/mach/memory.h (removed) - drivers/usb/gadget/Kconfig (USB_[GADGET_]LH7A40X removed, others added)
2011-03-16Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits) tty: serial: altera_jtaguart: Add device tree support tty: serial: altera_uart: Add devicetree support dt: eliminate of_platform_driver shim code dt: Eliminate of_platform_{,un}register_driver dt/serial: Eliminate users of of_platform_{,un}register_driver dt/usb: Eliminate users of of_platform_{,un}register_driver dt/video: Eliminate users of of_platform_{,un}register_driver dt/net: Eliminate users of of_platform_{,un}register_driver dt/sound: Eliminate users of of_platform_{,un}register_driver dt/spi: Eliminate users of of_platform_{,un}register_driver dt: uartlite: merge platform and of_platform driver bindings dt: xilinx_hwicap: merge platform and of_platform driver bindings ipmi: convert OF driver to platform driver leds/leds-gpio: merge platform_driver with of_platform_driver dt/sparc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: move of_bus_type infrastructure to ibmebus drivercore/dt: add a match table pointer to struct device dt: Typo fix. altera_ps2: Add devicetree support ...
2011-03-16Merge branch 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: BKL: That's all, folks fs/locks.c: Remove stale FIXME left over from BKL conversion ipx: remove the BKL appletalk: remove the BKL x25: remove the BKL ufs: remove the BKL hpfs: remove the BKL drivers: remove extraneous includes of smp_lock.h tracing: don't trace the BKL adfs: remove the big kernel lock
2011-03-16Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (76 commits) pch_uart: reference clock on CM-iTC pch_phub: add new device ML7213 n_gsm: fix UIH control byte : P bit should be 0 n_gsm: add a documentation serial: msm_serial_hs: Add MSM high speed UART driver tty_audit: fix tty_audit_add_data live lock on audit disabled tty: move cd1865.h to drivers/staging/tty/ Staging: tty: fix build with epca.c driver pcmcia: synclink_cs: fix prototype for mgslpc_ioctl() Staging: generic_serial: fix double locking bug nozomi: don't use flush_scheduled_work() tty/serial: Relax the device_type restriction from of_serial MAINTAINERS: Update HVC file patterns tty: phase out of ioctl file pointer for tty3270 as well tty: forgot to remove ipwireless from drivers/char/pcmcia/Makefile pch_uart: Fix DMA channel miss-setting issue. pch_uart: fix exclusive access issue pch_uart: fix auto flow control miss-setting issue pch_uart: fix uart clock setting issue pch_uart : Use dev_xxx not pr_xxx ... Fix up trivial conflicts in drivers/misc/pch_phub.c (same patch applied twice, then changes to the same area in one branch)
2011-03-15drivers/serial/ucc_uart.c: Add of_node_put to avoid memory leakJulia Lawall
Add a call to of_node_put in the error handling code following a call to of_find_compatible_node or of_find_node_by_type. This patch also substantially reorganizes the error handling code in the function, to that it is possible first to jump to code that frees qe_port and then to jump to code that also puts np. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ local idexpression x; expression E,E1,E2; statement S; @@ *x = (of_find_node_by_path |of_find_node_by_name |of_find_node_by_phandle |of_get_parent |of_get_next_parent |of_get_next_child |of_find_compatible_node |of_match_node |of_find_node_by_type |of_find_node_with_property |of_find_matching_node |of_parse_phandle )(...); ... if (x == NULL) S <... when != x = E *if (...) { ... when != of_node_put(x) when != if (...) { ... of_node_put(x); ... } ( return <+...x...+>; | * return ...; ) } ...> ( E2 = x; | of_node_put(x); ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Timur Tabi <timur@freescale.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-15Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into devel-stable Conflicts: arch/arm/mm/Kconfig
2011-03-14pch_uart: reference clock on CM-iTCDenis Turischev
Default clock source for UARTs on Topcliff is external UART_CLK. On CM-iTC USB_48MHz is used instead. After VCO2PLL and DIV manipulations UARTs will receive 192 MHz. Clock manipulations on Topcliff are controlled in pch_phub.c v2: redone against the linux-next tree v3: redone against linux/kernel/git/next/linux-next.git snapshot Signed-off-by: Denis Turischev <denis@compulab.co.il> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-12Merge branch 'master' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/tglx/linux-2.6-tcc into devel-stable
2011-03-11Merge branch 'next-exynos4' into for-nextKukjin Kim
2011-03-10Merge branch 'for-rmk' of git://git.pengutronix.de/git/imx/linux-2.6 into ↵Russell King
devel-stable
2011-03-10ARM: 6764/1: pl011: factor out FIFO to TTY codeLinus Walleij
This piece of code was just slightly different between the DMA and IRQ paths, in DMA mode we surely shouldn't read more than 256 character either, so factor this out in its own function and use for both DMA and PIO mode. Tested on Ux500 and U300. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-03-10ARM: 6763/1: pl011: add optional RX DMA to PL011 v2Linus Walleij
This adds an optional RX DMA codepath for the devices that support this by using the apropriate burst sizes instead of pulling single bytes. Includes portions of code written by Russell King during a PL08x hacking session. This has been tested on U300 and Ux500. Tested-by: Jerzy Kasenberg <jerzy.kasenberg@tieto.com> Tested-by: Grzegorz Sygieda <grzegorz.sygieda@tieto.com> Tested-by: Marcin Mielczarczyk <marcin.mielczarczyk@tieto.com> Signed-off-by: Per Forlin <per.friden@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-03-10xen/hvc: Disable probe_irq_on/off from poking the hvc-console IRQ line.Konrad Rzeszutek Wilk
This fixes a particular nasty racing problem found when using Xen hypervisor with the console (hvc) output being routed to the serial port and the serial port receiving data when probe_irq_off(probe_irq_on) is running. Specifically the bug manifests itself with: [ 4.470693] BUG: unable to handle kernel NULL pointer dereference at 0000000000000008 [ 4.470693] IP: [<ffffffff810a8c65>] handle_IRQ_event+0xe/0xc9 ..snip.. [ 4.470693] Call Trace: [ 4.470693] <IRQ> [ 4.470693] [<ffffffff810aa645>] handle_percpu_irq+0x3c/0x69 [ 4.470693] [<ffffffff8123cda7>] __xen_evtchn_do_upcall+0xfd/0x195 [ 4.470693] [<ffffffff810308cf>] ? xen_restore_fl_direct_end+0x0/0x1 [ 4.470693] [<ffffffff8123d873>] xen_evtchn_do_upcall+0x32/0x47 [ 4.470693] [<ffffffff81034dfe>] xen_do_hypervisor_callback+0x1e/0x30 [ 4.470693] <EOI> [ 4.470693] [<ffffffff8100922a>] ? hypercall_page+0x22a/0x1000 [ 4.470693] [<ffffffff8100922a>] ? hypercall_page+0x22a/0x1000 [ 4.470693] [<ffffffff810301c5>] ? xen_force_evtchn_callback+0xd/0xf [ 4.470693] [<ffffffff810308e2>] ? check_events+0x12/0x20 [ 4.470693] [<ffffffff81030889>] ? xen_irq_enable_direct_end+0x0/0x7 [ 4.470693] [<ffffffff810ab0a0>] ? probe_irq_on+0x8f/0x1d7 [ 4.470693] [<ffffffff812b105e>] ? serial8250_config_port+0x7b7/0x9e6 [ 4.470693] [<ffffffff812ad66c>] ? uart_add_one_port+0x11b/0x305 The bug is trigged by three actors working together: A). serial_8250_config_port calling probe_irq_off(probe_irq_on()) wherein all of the IRQ handlers are being started and shut off. The functions utilize the sleep functions so the minimum time they are run is 120 msec. B). Xen hypervisor receiving on the serial line any character and setting the bits in the event channel - during this 120 msec timeframe. C). The hvc API makes a call to 'request_irq' (and hence setting desc->action to a valid value), much much later - when user space opens /dev/console (hvc_open). To make the console usable during bootup, the Xen HVC implementation sets the IRQ chip (and correspondingly the event channel) much earlier. The IRQ chip handler that is used is the handle_percpu_irq (aaca49642b92c8a57d3ca5029a5a94019c7af69f) Back to the issue. When A) is being called it ends up calling the xen_percpu_chip's chip->startup twice and chip->shutdown once. Those are set to the default_startup and mask_irq (events.c) respectivly. If (and this seems to depend on what serial concentrator you use), B) gets data from the serial port it sets in the event channel a pending bit. When A) calls chip->startup(), the masking of the pending bit, and unmasking of the event channel mask, and also setting of the upcall_pending flag is done (since there is data present on the event channel). If before the 120 msec has elapsed, any IRQ handler (Xen IRQ has one IRQ handler, which checks the event channels bitmap to figure which one to call) is called we end up calling the handle_percpu_irq. The handle_percpu_irq calls desc->action (which is NULL) and we blow up. Caveats: I could only reproduce this on 2.6.32 pvops. I am not sure why this is not showing up on 2.6.38 kernel. The probe_irq_on/off has code to disable poking specific IRQ lines. This is done by using the set_irq_noprobe() and then we do not have to worry about the handle_percpu_irq being called before the IRQ action handler has been installed. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-09n_gsm: fix UIH control byte : P bit should be 0Eric Bénard
* the GSM 07.10 specification says in 5.4.3.1 that 'both stations shall set the P bit to 0' thanks to Alan Cox for finding this explanation in the spec * without this fix, on Telit & Sim.com modems, opening a new DLC randomly fails. Not setting PF bit of the control byte gives a reliable behaviour on these modems. Signed-off-by: Eric Bénard <eric@eukrea.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-07serial: msm_serial_hs: Add MSM high speed UART driverMayank Rana
This driver supports UART-DM HW on MSM platforms. It uses the on chip DMA to drive data transfers and has optional support for UART power management independent of Linux suspend/resume and wakeup from Rx. The driver was originally developed by Google. It is functionally equivalent to the version available at: http://android.git.kernel.org/?p=kernel/experimental.git the differences being: 1) Remove wakelocks and change unsupported DMA API. 2) Replace clock selection register codes by macros. 3) Fix checkpatch errors and add inline documentation. 4) Add runtime PM hooks for active power state transitions. 5) Handle error path and cleanup resources if required. CC: Nick Pelly <npelly@google.com> Signed-off-by: Sankalp Bose <sankalpb@codeaurora.org> Signed-off-by: Mayank Rana <mrana@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-07tty_audit: fix tty_audit_add_data live lock on audit disabledXiaotian Feng
The current tty_audit_add_data code: do { size_t run; run = N_TTY_BUF_SIZE - buf->valid; if (run > size) run = size; memcpy(buf->data + buf->valid, data, run); buf->valid += run; data += run; size -= run; if (buf->valid == N_TTY_BUF_SIZE) tty_audit_buf_push_current(buf); } while (size != 0); If the current buffer is full, kernel will then call tty_audit_buf_push_current to empty the buffer. But if we disabled audit at the same time, tty_audit_buf_push() returns immediately if audit_enabled is zero. Without emptying the buffer. With obvious effect on tty_audit_add_data() that ends up spinning in that loop, copying 0 bytes at each iteration and attempting to push each time without any effect. Holding the lock all along. Suggested-by: Alexander Viro <aviro@redhat.com> Signed-off-by: Xiaotian Feng <dfeng@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-04serial: sh-sci: fix deadlock when resuming from S3 sleepAlexandre Courbot
S3 sleep invokes the shutdown callback of the sh-sci driver, which suspends the clocks until they are reactivated by a call to startup. However, before the latter is invoked, sci_set_termios may be called on the port by uart_resume_port. In such cases it will endlessly wait for the TEND bit to raise, which will never happen since the clocks are disabled. This patch ensures that clocks are enabled when ports registers are manipulated within sci_set_termios. Signed-off-by: Alexandre Courbot <gnurou@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-02powerpc/pseries: Reduce HVCS driver insanityBenjamin Herrenschmidt
The HVCS driver, for those who don't know, is a driver for the "server" side of the IBM virtual terminal mechanism allowing Linux partitions to act as terminal servers under IBM PowerVM hypervisor. It's almost never used on the field at the moment. However, it's part of our configs, and in its current incarnation, will allocate the tty driver & major (with 64 minors) and create a kernel thread whether it's used or not, ie, whether the hypervisor did put a virtual terminal server device node in the partition or not (or whether running on a pseries machine or not even). This in turns causes modern distro's udev's to start trying to open all those 64 minors at boot, which, since they aren't linked to anything, causes the driver to spew errors in the kernel log for each of them. Not nice. This moves all that initialization to a function which is now only called the first time a terminal server virtual IO device is actually probed (that is almost never). There's still a _LOT_ of cleanup that can be done in this driver, some simple (almost all printk's statements in there shall either just be removed or in some case turned into better written & more informative messages, including using the dev_* variants etc...). This is left as an exercise for whoever actually cares about that driver. One could also try to be smart and dispose of all the tty related resources when the last instance of the VIO server device is removed (Hotplug anybody ?). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-02drivers: remove extraneous includes of smp_lock.hArnd Bergmann
These were missed the last time I cleaned this up globally, because of code moving around or new code getting merged. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-03-01tty: serial: altera_jtaguart: Add device tree supportTobias Klauser
Advertise the possibility to use this driver with device tree if CONFIG_OF is set. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
