Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
Checking if tty->index is in bounds is not needed. The tty has the
index set in the initial open. This is done in get_tty_driver. And it
can be only in interval <0,driver->num).
So remove the tests which check exactly this interval. Some are
left untouched as they check against the current backing device count.
(Leaving apart that the check is racy in most of the cases.)
All num, magic and owner are set by alloc_tty_driver. No need to
re-set them on each allocation site.
pti driver sets something different to what it passes to
alloc_tty_driver. It is not a bug, since we don't use the lines
parameter in any way. Anyway this is fixed, and now we do the right
thing.
Acked-by: Tilman Schmidt <tilman@imap.cc>
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
My main concern here was the line that said:
copy_count = min_t(unsigned short,count,SCABUFSIZE);
"count" is an unsigned int here so the cast to unsigned short
truncates the upper bits. So if count is 0x10000 then copy_count is
0 and the loop never exits.
"count" comes from skb->len in hdlcdev_xmit().
The other min_t() changes are just cleanups.
As planned by Arnd Bergmann, this moves the following drivers from
drivers/char/ to drivers/tty/ as that's where they really belong:
amiserial
nozomi
synclink
rocket
cyclades
moxa
mxser
isicom
bfin_jtag_comm
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Jiri Slaby <jslaby@suse.cz>
