Add support for the UART device present in Broadcom TruManage capable
NetXtreme chips (ie: 5761m 5762, and 5725).
This implementation has a hidden transmit FIFO, so running in single-byte
interrupt mode results in too many interrupts. The UART_CAP_HFIFO
capability was added to track this. It continues to reload the THR as long
as the THRE and TSRE bits are set in the LSR up to a specified limit (1024
is used here).
Signed-off-by: Stephen Hurd <shurd@broadcom.com>
Signed-off-by: Michael Chan <mchan@broadcom.com>
Cc: stable <stable@vger.kernel.org>
As protocol driver, IFX SPI driver initiate to setup SPI master with default
SPI word size as 16 bit/word, however, SPI master may not adopt this default
value due to SPI controller's capability, it might choose an available value by
itself and set it to spi_device.bits_per_word. In order to keep align with
Controller, IFX driver should make use of this value during SPI transfer,
but the default one.
Signed-off-by: Chen Jun <jun.d.chen@intel.com>
Signed-off-by: channing <chao.bi@intel.com>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The setting of uart line control configuration in s3c24xx_serial_resetport
is can be removed since the 'set_termios' call will overwrite any ULCON
register setting which s3c24xx_serial_resetport does.
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
When shut down SPI port, it's possible that MRDY has been asserted and a SPI
timer was activated waiting for SRDY assert, in the case, it needs to delete
this timer.
The correct device id for this card is 0x0022
Signed-off-by: Matt Schulte <matts@commtech-fastcom.com>
tty/8250: pbn_b0_8_1152000_200 is supposed to be an 8 port definition
In case of error, function of_clk_get() returns ERR_PTR()
and never returns NULL. The NULL test in the return value
check should be replaced with IS_ERR().
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Acked-by: Tony Prisk <linux@prisktech.co.nz>
Fix the following warning when building with W=1 option:
drivers/tty/serial/mxs-auart.c: In function 'mxs_auart_tx_chars':
drivers/tty/serial/mxs-auart.c:272:10: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
With the patch "serial: mxs-auart: fix the wrong RTS hardware flow control" the
mainline mxs-uart driver now sets RTSEN only when hardware flow control is
enabled via software. It is not possible any longer to set RTS manually via
software. However, the manual modification is a valid operation.
Regain the possibility to set RTS via software and only set RTSEN when hardware
flow control is explicitly enabled via settermios cflag CRTSCTS.
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
Reviewed-by: Huang Shijie <b32955@freescale.com>
omap-for-v3.8/fixes-for-merge-window-v2
We need to move this file to allow ARM multiplatform configurations
to build for omap2+. This can now be done as this file now only
contains platform_data.
cc: Russell King <linux@arm.linux.org.uk>
cc: Alan Cox <alan@linux.intel.com>
cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
cc: Govindraj.R <govindraj.raja@ti.com>
cc: Kevin Hilman <khilman@ti.com>
cc: linux-serial@vger.kernel.org
Reviewed-by: Felipe Balbi <balbi@ti.com>
Pull trivial branch from Jiri Kosina:
"Usual stuff -- comment/printk typo fixes, documentation updates, dead
code elimination."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
HOWTO: fix double words typo
x86 mtrr: fix comment typo in mtrr_bp_init
propagate name change to comments in kernel source
doc: Update the name of profiling based on sysfs
treewide: Fix typos in various drivers
treewide: Fix typos in various Kconfig
wireless: mwifiex: Fix typo in wireless/mwifiex driver
messages: i2o: Fix typo in messages/i2o
scripts/kernel-doc: check that non-void fcts describe their return value
Kernel-doc: Convention: Use a "Return" section to describe return values
radeon: Fix typo and copy/paste error in comments
doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c
various: Fix spelling of "asynchronous" in comments.
Fix misspellings of "whether" in comments.
eisa: Fix spelling of "asynchronous".
various: Fix spelling of "registered" in comments.
doc: fix quite a few typos within Documentation
target: iscsi: fix comment typos in target/iscsi drivers
treewide: fix typo of "suport" in various comments and Kconfig
treewide: fix typo of "suppport" in various comments
Pull ARM SoC updates from Olof Johansson:
"This contains the bulk of new SoC development for this merge window.
Two new platforms have been added, the sunxi platforms (Allwinner A1x
SoCs) by Maxime Ripard, and a generic Broadcom platform for a new
series of ARMv7 platforms from them, where the hope is that we can
keep the platform code generic enough to have them all share one mach
directory. The new Broadcom platform is contributed by Christian
Daudt.
Highbank has grown support for Calxeda's next generation of hardware,
ECX-2000.
clps711x has seen a lot of cleanup from Alexander Shiyan, and he's
also taken on maintainership of the platform.
Beyond this there has been a bunch of work from a number of people on
converting more platforms to IRQ domains, pinctrl conversion, cleanup
and general feature enablement across most of the active platforms."
Fix up trivial conflicts as per Olof.
* tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (174 commits)
mfd: vexpress-sysreg: Remove LEDs code
irqchip: irq-sunxi: Add terminating entry for sunxi_irq_dt_ids
clocksource: sunxi_timer: Add terminating entry for sunxi_timer_dt_ids
irq: versatile: delete dangling variable
ARM: sunxi: add missing include for mdelay()
ARM: EXYNOS: Avoid early use of of_machine_is_compatible()
ARM: dts: add node for PL330 MDMA1 controller for exynos4
ARM: EXYNOS: Add support for secondary CPU bring-up on Exynos4412
ARM: EXYNOS: add UART3 to DEBUG_LL ports
ARM: S3C24XX: Add clkdev entry for camif-upll clock
ARM: SAMSUNG: Add s3c24xx/s3c64xx CAMIF GPIO setup helpers
ARM: sunxi: Add missing sun4i.dtsi file
pinctrl: samsung: Do not initialise statics to 0
ARM i.MX6: remove gate_mask from pllv3
ARM i.MX6: Fix ethernet PLL clocks
ARM i.MX6: rename PLLs according to datasheet
ARM i.MX6: Add pwm support
ARM i.MX51: Add pwm support
ARM i.MX53: Add pwm support
ARM: mx5: Replace clk_register_clkdev with clock DT lookup
Pull ARM SoC Header cleanups from Olof Johansson:
"This is a collection of header file cleanups, mostly for OMAP and
AT91, that keeps moving the platforms in the direction of
multiplatform by removing the need for mach-dependent header files
used in drivers and other places."
Fix up mostly trivial conflicts as per Olof.
* tag 'headers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (106 commits)
ARM: OMAP2+: Move iommu/iovmm headers to platform_data
ARM: OMAP2+: Make some definitions local
ARM: OMAP2+: Move iommu2 to drivers/iommu/omap-iommu2.c
ARM: OMAP2+: Move plat/iovmm.h to include/linux/omap-iommu.h
ARM: OMAP2+: Move iopgtable header to drivers/iommu/
ARM: OMAP: Merge iommu2.h into iommu.h
atmel: move ATMEL_MAX_UART to platform_data/atmel.h
ARM: OMAP: Remove omap_init_consistent_dma_size()
arm: at91: move at91rm9200 rtc header in drivers/rtc
arm: at91: move reset controller header to arm/arm/mach-at91
arm: at91: move pit define to the driver
arm: at91: move at91_shdwc.h to arch/arm/mach-at91
arm: at91: move board header to arch/arm/mach-at91
arn: at91: move at91_tc.h to arch/arm/mach-at91
arm: at91 move at91_aic.h to arch/arm/mach-at91
arm: at91 move board.h to arch/arm/mach-at91
arm: at91: move platfarm_data to include/linux/platform_data/atmel.h
arm: at91: drop machine defconfig
ARM: OMAP: Remove NEED_MACH_GPIO_H
ARM: OMAP: Remove unnecessary mach and plat includes
Pull ARM updates from Russell King:
"Here's the updates for ARM for this merge window, which cover quite a
variety of areas.
There's a bunch of patch series from Will tackling various bugs like
the PROT_NONE handling, ASID allocation, cluster boot protocol and
ASID TLB tagging updates.
We move to a build-time sorted exception table rather than doing the
sorting at run-time, add support for the secure computing filter, and
some updates to the perf code. We also have sorted out the placement
of some headers, fixed some build warnings, fixed some hotplug
problems with the per-cpu TWD code."
* 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (73 commits)
ARM: 7594/1: Add .smp entry for REALVIEW_EB
ARM: 7599/1: head: Remove boot-time HYP mode check for v5 and below
ARM: 7598/1: net: bpf_jit_32: fix sp-relative load/stores offsets.
ARM: 7595/1: syscall: rework ordering in syscall_trace_exit
ARM: 7596/1: mmci: replace readsl/writesl with ioread32_rep/iowrite32_rep
ARM: 7597/1: net: bpf_jit_32: fix kzalloc gfp/size mismatch.
ARM: 7593/1: nommu: do not enable DCACHE_WORD_ACCESS when !CONFIG_MMU
ARM: 7592/1: nommu: prevent generation of kernel unaligned memory accesses
ARM: 7591/1: nommu: Enable the strict alignment (CR_A) bit only if ARCH < v6
ARM: 7590/1: /proc/interrupts: limit the display of IPIs to online CPUs only
ARM: 7587/1: implement optimized percpu variable access
ARM: 7589/1: integrator: pass the lm resource to amba
ARM: 7588/1: amba: create a resource parent registrator
ARM: 7582/2: rename kvm_seq to vmalloc_seq so to avoid confusion with KVM
ARM: 7585/1: kernel: fix nr_cpu_ids check in DT logical map init
ARM: 7584/1: perf: fix link error when CONFIG_HW_PERF_EVENTS is not selected
ARM: gic: use a private mapping for CPU target interfaces
ARM: kernel: add logical mappings look-up
ARM: kernel: add cpu logical map DT init in setup_arch
ARM: kernel: add device tree init map function
Pull ARM OMAP serial updates from Russell King:
"This series is a major reworking of the OMAP serial driver code fixing
various bugs in the hardware-assisted flow control, extending up into
serial_core for a couple of issues. These fixes have been done as a
set of progressive changes and transformations in the hope that no new
bugs will be introduced by this series.
The problems are many-fold, from the driver not being informed about
updated settings, to the driver not knowing what the intentions of the
upper layers are.
The first four patches tackle the serial_core layer, allowing it to
provide the necessary information to drivers, and the remaining
patches allow the OMAP serial driver to take advantage of this.
This brings hardware assisted RTS/CTS and XON/OFF flow control into a
useful state.
These patches have been in linux-next for most of the last cycle;
indeed they predate the previous merge window. They've also been
posted to the OMAP people."
* 'omap-serial' of git://git.linaro.org/people/rmk/linux-arm: (21 commits)
SERIAL: omap: fix hardware assisted flow control
SERIAL: omap: simplify (2)
SERIAL: omap: move xon/xoff setting earlier
SERIAL: omap: always set TCR
SERIAL: omap: don't read back LCR/MCR/EFR
SERIAL: omap: serial_omap_configure_xonxoff() contents into set_termios
SERIAL: omap: configure xon/xoff before setting modem control lines
SERIAL: omap: remove OMAP_UART_SYSC_RESET and OMAP_UART_FIFO_CLR
SERIAL: omap: move driver private definitions and structures to driver
SERIAL: omap: remove 'irq_pending' bitfield
SERIAL: omap: fix MCR TCRTLR bit handling
SERIAL: omap: fix set_mctrl() breakage
SERIAL: omap: no need to re-read EFR
SERIAL: omap: remove setting of EFR SCD bit
SERIAL: omap: allow hardware assisted IXANY mode to be disabled
SERIAL: omap: allow hardware assisted rts/cts modes to be disabled
SERIAL: core: add throttle/unthrottle callbacks for hardware assisted flow control
SERIAL: core: add hardware assisted h/w flow control support
SERIAL: core: add hardware assisted s/w flow control support
drivers/tty/serial/omap-serial.c
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull TTY/Serial merge from Greg Kroah-Hartman:
"Here's the big tty/serial tree set of changes for 3.8-rc1.
Contained in here is a bunch more reworks of the tty port layer from
Jiri and bugfixes from Alan, along with a number of other tty and
serial driver updates by the various driver authors.
Also, Jiri has been coerced^Wconvinced to be the co-maintainer of the
TTY layer, which is much appreciated by me.
All of these have been in the linux-next tree for a while.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
Fixed up some trivial conflicts in the staging tree, due to the fwserial
driver having come in both ways (but fixed up a bit in the serial tree),
and the ioctl handling in the dgrp driver having been done slightly
differently (staging tree got that one right, and removed both
TIOCGSOFTCAR and TIOCSSOFTCAR).
* tag 'tty-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (146 commits)
staging: sb105x: fix potential NULL pointer dereference in mp_chars_in_buffer()
staging/fwserial: Remove superfluous free
staging/fwserial: Use WARN_ONCE when port table is corrupted
staging/fwserial: Destruct embedded tty_port on teardown
staging/fwserial: Fix build breakage when !CONFIG_BUG
staging: fwserial: Add TTY-over-Firewire serial driver
drivers/tty/serial/serial_core.c: clean up HIGH_BITS_OFFSET usage
staging: dgrp: dgrp_tty.c: Audit the return values of get/put_user()
staging: dgrp: dgrp_tty.c: Remove the TIOCSSOFTCAR ioctl handler from dgrp driver
serial: ifx6x60: Add modem power off function in the platform reboot process
serial: mxs-auart: unmap the scatter list before we copy the data
serial: mxs-auart: disable the Receive Timeout Interrupt when DMA is enabled
serial: max310x: Setup missing "can_sleep" field for GPIO
tty/serial: fix ifx6x60.c declaration warning
serial: samsung: add devicetree properties for non-Exynos SoCs
serial: samsung: fix potential soft lockup during uart write
tty: vt: Remove redundant null check before kfree.
tty/8250 Add check for pci_ioremap_bar failure
tty/8250 Add support for Commtech's Fastcom Async-335 and Fastcom Async-PCIe cards
tty/8250 Add XR17D15x devices to the exar_handle_irq override
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pinctrl changes from Linus Walleij:
"These are the first and major pinctrl changes for the v3.8 merge
cycle. Some of this is used as merge base for other trees so I better
be early on the trigger.
As can be seen from the diffstat the major changes are:
- A big conversion of the AT91 pinctrl driver and the associated ACKed
platform changes under arch/arm/max-at91 and its device trees. This
has been coordinated with the AT91 maintainers to go in through the
pinctrl tree.
- A larger chunk of changes to the SPEAr drivers and the addition of
the "plgpio" driver for the SPEAr as well.
- The removal of the remnants of the Nomadik driver from the arch/arm
tree and fusion of that into the Nomadik driver and platform data
header files.
- Some local movement in the Marvell MVEBU drivers, these now have
their own subdirectory.
- The addition of a chunk of code to gpiolib under drivers/gpio to
register gpio-to-pin range mappings from the GPIO side of things.
This has been requested by Grant Likely and is now implemented, it
is particularly useful for device tree work.
Then we have incremental updates all over the place, many of these are
cleanups and fixes from Axel Lin who has done a great job of removing
minor mistakes and compilation annoyances."
* tag 'pinctrl-for-v3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (114 commits)
ARM: mmp: select PINCTRL for ARCH_MMP
pinctrl: Drop selecting PINCONF for MMP2, PXA168 and PXA910
pinctrl: pinctrl-single: Fix error check condition
pinctrl: SPEAr: Update error check for unsigned variables
gpiolib: Fix use after free in gpiochip_add_pin_range
gpiolib: rename pin range arguments
pinctrl: single: support gpio request and free
pinctrl: generic: add input schmitt disable parameter
pinctrl/u300/coh901: stop spawning pinctrl from GPIO
pinctrl/u300/coh901: let the gpio_chip register the range
pinctrl: add function to retrieve range from pin
gpiolib: return any error code from range creation
pinctrl: make range registration defer properly
gpiolib: rename find_pinctrl_*
gpiolib: let gpiochip_add_pin_range() specify offset
ARM: at91: pm9g45: add mmc support
ARM: at91: Animeo IP: add mmc support
ARM: at91: dt: add mmc pinctrl for Atmel reference boards
ARM: at91: dt: at91sam9: add mmc pinctrl support
ARM: at91/dts: add nodes for atmel hsmci controllers for atmel boards
'warnings' into for-next
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/soc
From Kukjin Kim:
Just adding camif gpio setup and clkdev.
* 'next/cam-samsung' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
+ Linux 3.7-rc6
Conflicts due to the 3.7-rc6 sync: arch/arm/mach-highbank/system.c
include/linux/clk-provider.h, resolved as in other branches.
serial_core.c usually does
if (HIGH_BITS_OFFSET)
expr-involving-HIGH_BITS_OFFSET()
at least to avoid generating useless code on 32-bit machines, where
HIGH_BITS_OFFSET is zero. Do that in uart_get_attr_port().
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
This patch add modem power off function in the reboot process according registering
reboot callback to the reboot_notifier_list. Also realizing the spi shutdown function.
Signed-off-by: Bi Chao <chao.bi@intel.com>
We should first unmap the DMA scatter list for receiving data, and
then copy the data from the DMA buffer.
The old code misses unmap the scatter list for RX. This patch fixes it.
Signed-off-by: Huang Shijie <b32955@freescale.com>
Tested-by: Lauri Hintsala <lauri.hintsala@bluegiga.com>
When the DMA is enabled, the Receive Timeout interrupt is very easy to be arised
in the 3M baud rate. The interrupt handler (aka mxs_auart_irq_handle) will call
mxs_auart_rx_chars() to handle the received data. This is not right, we can not
get the correct data from the RXFIFO now, the data have been moved to the
DMA buffer by the DMA engine.
This patch
(1) disables the Receive Timeout Interrupt when the DMA is enabled,
(2) and invoke the mxs_auart_rx_chars() only when the DMA is not enabled.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
Fix gcc warning of mixed data/code:
drivers/tty/serial/ifx6x60.c:516:2: warning: ISO C90 forbids mixed declarations and code
Cc: Russ Gorby <russ.gorby@intel.com>
Cc: Alan Cox <alan@linux.intel.com>
Until now only the Exynos SoCs could use the serial driver via the
device tree. This patch adds compatible properties for the other
supported SoCs as well.
Tested on a s3c2416 based machine.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Certain tty line discipline implementations such slip and bluetooth hci invoke
the serial core uart_write() api in their write_wakeup callback. This leads to
a soft lockup with samsung serial driver since the uart port lock is taken in
the driver's interrupt handler and uart_write() attempts to take the same lock
again.
Fix this issue by releasing the uart port lock before the call to
uart_write_wakeup() in the tx handler. Also move the spin-lock/unlock sequence
from s3c64xx_serial_handle_irq() function into the tx and rx irq handlers so
that this change is applicable to s3c24xx platforms as well.
Reported-by: Kyungmin Park <kyungmin.park@samsung.com>
Reported-by: Hyeonkook Kim <hk619.kim@samsung.com>
Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org>
This patch adds support for EXYNOS5440 SoC which is including
ARM Cortex-A15 Quad cores.
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
cards
Add XR17D15x devices to the exar_handle_irq override: they have the
same extra interrupt register that could fire and never be serviced by
the standard handle_irq.
Add sleep capability to XR17D15X ports
pci_xr17v35x_setup
Add initialization of sampling mode and tx/rx triggers to pci_xr17v35x_setup
Optimization: check for presence of UPF_EXAR_EFR flag before serial_in
set_termios may be invoked before the former data transfer is completed.
Block until the tranfer is done.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
PCIe UARTs
Add support for new devices: Exar's XR17V35x family of multi-port PCIe UARTs.
Acked-by: Alan Cox <alan@linux.intel.com>
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Jiri Slaby <jirislaby@gmail.com>
Acked-by: Tobias Klauser <tklauser@distanz.ch>
Cc: Lucas Tavares <lucaskt@linux.vnet.ibm.com>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Peter Korsgaard <jacmet@sunsite.dk>
Cc: Tony Prisk <linux@prisktech.co.nz>
Acked-by: David Brown <davidb@codeaurora.org>
CONFIG_HOTPLUG is going away as an option so __devinitconst is no
longer needed.
CONFIG_HOTPLUG is going away as an option so __devinitdata is no
longer needed.
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Only we meet the following conditions, we can enable the DMA support for
auart:
(1) We enable the DMA support in the dts file, such as
arch/arm/boot/dts/imx28.dtsi.
(2) We enable the hardware flow control.
(3) We use the mx28, not the mx23. Due to hardware bug(see errata: 2836),
we can not add the DMA support to mx23.
The current mxs-auart driver is used for both mx23 and mx28.
But in mx23, the DMA has a bug(see errata:2836). We can not add the
DMA support in mx23, but we can add DMA support to auart in mx28.
So in order to add the DMA support for the auart in mx28, we should
distinguish the distinguish SOCs.
This patch adds a new platform_device_id table and a inline function
is_imx28_auart() to distinguish the mx23 and mx28.
Allows overriding default methods serial_in/serial_out.
In such platform specific replacement it is possible to use
other regshift, biased register offset, any other manipulation
that is not covered with common default methods.
Overriding default methods may be useful for platforms which got
serial peripheral with registers represented in big endian.
In this situation and assuming that 32 bit operations / alignment
is required then it may be useful to swab words before/after
accessing the serial registers.
Signed-off-by: Noam Camus <noamc@ezchip.com>
The definitions provided by serial_at91.h are only used by the
atmel_serial driver, and the function that uses it is never called
from anywhere in the kernel. Therefore, these definitions are unused
and/or obsolete, and can be removed.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
This is really driver platform data, so move it to the appropriate
directory.
In the previous commit, console write function (serial_console_write)
is changed to disable SCI interrupts while printing console strings.
This introduces possible race cases in the serial startup / shutdown
functions on SMP systems.
This patch fixes the sh-sci in the same way as commit 9ec1882df2
(tty: serial: imx: console write routing is unsafe on SMP, from
Xinyu Chen <xinyu.chen@freescale.com>, 2012-08-27) did.
There could be several consumers of the console,
* the kernel printk
* the init process using /dev/kmsg to call printk to show log
* shell, which opens /dev/console and writes with sys_write()
The shell goes into the normal UART open() and write() system calls,
while the other two go into the console operations. The open() call
invokes serial startup function (sci_startup), which will write to
the SCSCR register (to enable or disable SCI interrupts) without any
locking. This will conflict with the console serial function.
Add spinlock protections in sci_startup() and sci_shutdown() properly.
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi.px@renesas.com>
