S3 sleep invokes the shutdown callback of the sh-sci driver, which
suspends the clocks until they are reactivated by a call to startup.
However, before the latter is invoked, sci_set_termios may be called on
the port by uart_resume_port. In such cases it will endlessly wait for
the TEND bit to raise, which will never happen since the clocks are
disabled.
This patch ensures that clocks are enabled when ports registers are
manipulated within sci_set_termios.
Signed-off-by: Alexandre Courbot <gnurou@gmail.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into common/serial-rework
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6:
tty: update MAINTAINERS file due to driver movement
tty: move drivers/serial/ to drivers/tty/serial/
tty: move hvc drivers to drivers/tty/hvc/
The serial drivers are really just tty drivers, so move them to
drivers/tty/ to make things a bit neater overall.
This is part of the tty/serial driver movement proceedure as proposed by
Arnd Bergmann and approved by everyone involved a number of months ago.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Rogier Wolff <R.E.Wolff@bitwizard.nl>
Cc: Michael H. Warfield <mhw@wittsend.com>
