path: root/drivers/tty/serial/nwpserial.c
2015-12-13serial: remove NWP serial supportArnd Bergmann
The NWP serial driver is no longer needed, as the two users of this hardware have migrated to a much faster generation hardware, see https://en.wikipedia.org/wiki/QPACE2 for the replacement. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Krill <ben@codiert.org> Cc: linuxppc-dev@lists.ozlabs.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-08serial: Fix build failure caused by missing header filePranith Kumar
Fix build failure caused by missing header file: drivers/tty/serial/nwpserial.c: In function 'wait_for_bits': drivers/tty/serial/nwpserial.c:53:3: error: implicit declaration of function 'udelay' [-Werror=implicit-function-declaration] Signed-off-by: Pranith Kumar <bobby.prani@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09serial: treewide: Remove empty implementations of enable_ms()Alexander Shiyan
Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-27tty: serial: nwpserial: drop uart_port->lock before calling ↵Viresh Kumar
tty_flip_buffer_push() The current driver triggers a lockdep warning for if tty_flip_buffer_push() is called with uart_port->lock locked. This never shows up on UP kernels and comes up only on SMP kernels. Crash looks like this (produced with samsung.c driver): ----- [<c0014d58>] (unwind_backtrace+0x0/0xf8) from [<c0011908>] (show_stack+0x10/0x14) [<c0011908>] (show_stack+0x10/0x14) from [<c035da34>] (dump_stack+0x6c/0xac) [<c035da34>] (dump_stack+0x6c/0xac) from [<c01b59ac>] (do_raw_spin_unlock+0xc4/0xd8) [<c01b59ac>] (do_raw_spin_unlock+0xc4/0xd8) from [<c03627e4>] (_raw_spin_unlock_irqrestore+0xc/0) [<c03627e4>] (_raw_spin_unlock_irqrestore+0xc/0x38) from [<c020a1a8>] (s3c24xx_serial_rx_chars+0) [<c020a1a8>] (s3c24xx_serial_rx_chars+0x12c/0x260) from [<c020aae8>] (s3c64xx_serial_handle_irq+) [<c020aae8>] (s3c64xx_serial_handle_irq+0x48/0x60) from [<c006aaa0>] (handle_irq_event_percpu+0x) [<c006aaa0>] (handle_irq_event_percpu+0x50/0x194) from [<c006ac20>] (handle_irq_event+0x3c/0x5c) [<c006ac20>] (handle_irq_event+0x3c/0x5c) from [<c006d864>] (handle_fasteoi_irq+0x80/0x13c) [<c006d864>] (handle_fasteoi_irq+0x80/0x13c) from [<c006a4a4>] (generic_handle_irq+0x20/0x30) [<c006a4a4>] (generic_handle_irq+0x20/0x30) from [<c000f454>] (handle_IRQ+0x38/0x94) [<c000f454>] (handle_IRQ+0x38/0x94) from [<c0008538>] (gic_handle_irq+0x34/0x68) [<c0008538>] (gic_handle_irq+0x34/0x68) from [<c00123c0>] (__irq_svc+0x40/0x70) Exception stack(0xc04cdf70 to 0xc04cdfb8) df60: 00000000 00000000 0000166e 00000000 df80: c04cc000 c050278f c050278f 00000001 c04d444c 410fc0f4 c03649b0 00000000 dfa0: 00000001 c04cdfb8 c000f758 c000f75c 60070013 ffffffff [<c00123c0>] (__irq_svc+0x40/0x70) from [<c000f75c>] (arch_cpu_idle+0x28/0x30) [<c000f75c>] (arch_cpu_idle+0x28/0x30) from [<c0054888>] (cpu_startup_entry+0x5c/0x148) [<c0054888>] (cpu_startup_entry+0x5c/0x148) from [<c0497aa4>] (start_kernel+0x334/0x38c) BUG: spinlock lockup suspected on CPU#0, kworker/0:1/360 lock: s3c24xx_serial_ports+0x1d8/0x370, .magic: dead4ead, .owner: <none>/-1, .owner_cpu: -1 CPU: 0 PID: 360 Comm: kworker/0:1 Not tainted 3.11.0-rc6-next-20130819-00003-g75485f1 #2 Workqueue: events flush_to_ldisc [<c0014d58>] (unwind_backtrace+0x0/0xf8) from [<c0011908>] (show_stack+0x10/0x14) [<c0011908>] (show_stack+0x10/0x14) from [<c035da34>] (dump_stack+0x6c/0xac) [<c035da34>] (dump_stack+0x6c/0xac) from [<c01b581c>] (do_raw_spin_lock+0x100/0x17c) [<c01b581c>] (do_raw_spin_lock+0x100/0x17c) from [<c03628a0>] (_raw_spin_lock_irqsave+0x20/0x28) [<c03628a0>] (_raw_spin_lock_irqsave+0x20/0x28) from [<c0203224>] (uart_start+0x18/0x34) [<c0203224>] (uart_start+0x18/0x34) from [<c01ef890>] (__receive_buf+0x4b4/0x738) [<c01ef890>] (__receive_buf+0x4b4/0x738) from [<c01efb44>] (n_tty_receive_buf2+0x30/0x98) [<c01efb44>] (n_tty_receive_buf2+0x30/0x98) from [<c01f2ba8>] (flush_to_ldisc+0xec/0x138) [<c01f2ba8>] (flush_to_ldisc+0xec/0x138) from [<c0031af0>] (process_one_work+0xfc/0x348) [<c0031af0>] (process_one_work+0xfc/0x348) from [<c0032138>] (worker_thread+0x138/0x37c) [<c0032138>] (worker_thread+0x138/0x37c) from [<c0037a7c>] (kthread+0xa4/0xb0) [<c0037a7c>] (kthread+0xa4/0xb0) from [<c000e5f8>] (ret_from_fork+0x14/0x3c) ----- Release the port lock before calling tty_flip_buffer_push() and reacquire it after the call. Similar stuff was already done for few other drivers in the past, like: commit 2389b272168ceec056ca1d8a870a97fa9c26e11a Author: Thomas Gleixner <tglx@linutronix.de> Date: Tue May 29 21:53:50 2007 +0100 [ARM] 4417/1: Serial: Fix AMBA drivers locking Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-20tty: nwpserial: Pass correct pointer to free_irq()Lars-Peter Clausen
free_irq() expects the same pointer that was passed to request_irq(), otherwise the IRQ is not freed. The issue was found using the following coccinelle script: <smpl> @r1@ type T; T devid; @@ request_irq(..., devid) @r2@ type r1.T; T devid; position p; @@ free_irq@p(..., devid) @@ position p != r2.p; @@ *free_irq@p(...) </smpl> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15TTY: switch tty_flip_buffer_pushJiri Slaby
Now, we start converting tty buffer functions to actually use tty_port. This will allow us to get rid of the need of tty in many call sites. Only tty_port will needed and hence no more tty_port_tty_get in those paths. Now, the one where most of tty_port_tty_get gets removed: tty_flip_buffer_push. IOW we also closed all the races in drivers not using tty_port_tty_get at all yet. Also we move tty_flip_buffer_push declaration from include/linux/tty.h to include/linux/tty_flip.h to all others while we are changing it anyway. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15TTY: switch tty_insert_flip_charJiri Slaby
Now, we start converting tty buffer functions to actually use tty_port. This will allow us to get rid of the need of tty in many call sites. Only tty_port will needed and hence no more tty_port_tty_get in those paths. tty_insert_flip_char is the next one to proceed. This one is used all over the code, so the patch is huge. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-10-31tty: Add export.h for EXPORT_SYMBOL/THIS_MODULE to exportersPaul Gortmaker
With module.h being implicitly everywhere via device.h, the absence of explicitly including something for EXPORT_SYMBOL went unnoticed. Since we are heading to fix things up and clean module.h from the device.h file, we need to explicitly include these files now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-22TTY: serial, fix includes in some driversJiri Slaby
linux/tty_flip.h is included in linux/serial_core.h. But this may (and will) change in the future. Then we would get build errors such as: .../tty/serial/max3107.c: In function ‘put_data_to_circ_buf’: .../tty/serial/max3107.c:149:2: error: implicit declaration of function ‘tty_insert_flip_string’ So fix all the drviers which call tty flip buffer helpers to really include linux/tty_flip.h. And also make sure that those include linux/tty.h when operating with struct tty_struct. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-13tty: move drivers/serial/ to drivers/tty/serial/Greg Kroah-Hartman
The serial drivers are really just tty drivers, so move them to drivers/tty/ to make things a bit neater overall. This is part of the tty/serial driver movement proceedure as proposed by Arnd Bergmann and approved by everyone involved a number of months ago. Cc: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Rogier Wolff <R.E.Wolff@bitwizard.nl> Cc: Michael H. Warfield <mhw@wittsend.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
