path: root/drivers/tty/serial/imx.c
2015-06-08Merge 4.1-rc7 into tty-nextGreg Kroah-Hartman
This fixes up a merge issue with the amba-pl011.c driver, and we want the fixes in this branch as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-24serial: imx: Fix DMA handling for IDLE condition abortsPhilipp Zabel
The driver configures the IDLE condition to interrupt the SDMA engine. Since the SDMA UART ROM script doesn't clear the IDLE bit itself, this caused repeated 1-byte DMA transfers, regardless of available data in the RX FIFO. Also, when returning due to the IDLE condition, the UART ROM script already increased its counter, causing residue to be off by one. This patch clears the IDLE condition to avoid repeated 1-byte DMA transfers and decreases count by when the DMA transfer was aborted due to the IDLE condition, fixing serial transfers using DMA on i.MX6Q. Reported-by: Peter Seiderer <ps.report@gmx.net> Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Tested-by: Fabio Estevam <fabio.estevam@freescale.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-10serial: imx: Constify platform_device_idKrzysztof Kozlowski
The platform_device_id is not modified by the driver and core uses it as const. Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06serial: imx: Remove return value from imx_setup_ufcr()Fabio Estevam
The return value from imx_setup_ufcr() is always 0 and its value is never checked, so better to remove the return value. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06serial: imx: protect Soft Reset of port with lockJiada Wang
Previously Soft Reset (clear of SRST bit in UCR2 register) of UART in startup is not protected by lock, which may have race with console_write, as console_write may occur at anytime even when UART port is shutdown. To avoid this race, protect Soft reset of UART port with spin_lock. Signed-off-by: Jiada Wang <jiada_wang@mentor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-11serial: imx: Add braces to avoid ambiguous 'else'Fabio Estevam
Commit 17b8f2a3fdca29 ("serial: imx: add support for half duplex rs485") introduced the following build warning: drivers/tty/serial/imx.c: In function 'imx_set_termios': drivers/tty/serial/imx.c:1301:7: warning: suggest explicit braces to avoid ambiguous 'else' [-Wparentheses] Add the suggested braces to avoid the build warning. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-07serial: imx: add support for half duplex rs485Uwe Kleine-König
The transmitter is expected to be controlled by the UART's RTS pin. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-07serial: imx: drop support for IRDAUwe Kleine-König
Support for IRDA was added in 2009 in commit v2.6.31-rc1~399^2~2. There are no in-tree users. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-07serial: imx: fix comment about which machines use the i.MX21 typeUwe Kleine-König
2015-03-07serial: imx: reformat and cleanup copyright headerUwe Kleine-König
Fix indention, remove old address of the FSF, remove in-file changelog, mention Freescale. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-07serial: imx: drop members from driver data that are only used during probeUwe Kleine-König
There is no benefit in keeping this information in RAM when it's not used any more, so better use function local variables instead. These members are unused since c0d1c6b0f0dc ("serial: imx: Fix the reporting of interrupts") Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-07serial: imx: remove long dead codeUwe Kleine-König
This if (0) exists since the driver was introduced in commit c49bde83eb6a ([ARM PATCH] 1956/2: Re: Motorola i.MX serial driver) back in 2004. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-07serial: imx: Fix clearing of receiver overrun flagUwe Kleine-König
The writeable bits in the USR2 register are all "write 1 to clear" so only write the bits that actually should be cleared. Fixes: f1f836e4209e ("serial: imx: Add Rx Fifo overrun error message") Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-07serial: imx: Do not store/restore the UBRC registerFabio Estevam
UBRC is a read-only register, so we should not store and restore it inside imx_flush_buffer(). Reported-by: Fugang Duan <B38611@freescale.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Fugang Duan <B38611@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-07serial:imx make of_device_id array constSanjeev Sharma
Make of_device_id array const. Signed-off-by: Sanjeev Sharma <Sanjeev_Sharma@mentor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-02serial: imx: Fix imx_flush_buffer()Fabio Estevam
When running an userspace program that does a 'tcflush(fd, TCIOFLUSH)' call we still see the last received character in the URXD register afterwards. Clear UCR2_SRST bit so that the UART FIFO is flushed properly. Since UCR2_SRST also resets some UART registers, we need to save and restore some of them. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Fugang Duan <B38611@freescale.com> Acked-by: Jason Liu <r64343@freecale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09serial: imx: ignore framing errors when IGNPAR is set.Eric Nelson
When IGNPAR is set in termios->c_iflag, characters with framing errors should be ignored. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Reviewed-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09serial: imx: preserve characters with parity or framing errorsEric Nelson
If IGNPAR/INPCK are clear in termios->c_iflag, characters received with parity or framing errors should be preserved and passed to the upper layers of the tty stack. Specifically, the decision of whether to set the character value to zero should be made by n_tty.c/n_tty_receive_parity_error(). Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Reviewed-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09serial: imx: Support sw flow control in DMA modeJiada Wang
This patch adds Software flow control support in DMA mode. Signed-off-by: Jiada Wang <jiada_wang@mentor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09serial: imx: Fix issue in software flow controlJiada Wang
After send out x_char in UART driver, x_char needs to be cleared by UART driver itself, otherwise data in TXFIFO can no longer be sent out. Also tx counter needs to be increased to keep track of correct number of transmitted data. Signed-off-by: Jiada Wang <jiada_wang@mentor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09serial: imx: Enable UCR4_OREN in startup interfaceJiada Wang
Other than enable Receiver Overrun Interrupt Enable (UCR4_OREN) in start_tx interface, UCR4_OREN should be enabled before enable of Receiver. Signed-off-by: Jiada Wang <jiada_wang@mentor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09serial: imx: start rx_dma once RXFIFO is not emptyRobin Gong
Start rx_dma once RXFIFO is not empty that can avoid dma request lost and causes data delay issue. Signed-off-by: Robin Gong <b38343@freescale.com> Signed-off-by: Fugang Duan <B38611@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09serial: imx: initialized DMA w/o HW flow enabledAnton Bondarenko
DMA mode for UART can be used even w/o HW flow control with RTS/CTS. So it need to be initialized and enabled earlier. Signed-off-by: Anton Bondarenko <anton_bondarenko@mentor.com> Signed-off-by: Jiada Wang <jiada_wang@mentor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09serial: imx: disable TDMAEN in imx_flush_buffer()Dirk Behme
Terminating the DMA, make sure the interrupt is disabled, too. This fixes random kernel Oops due to dma_tx_call() called for invalid transmissions. If we disable the TDMAEN, make sure it's enabled again if a TX DMA is started. Signed-off-by: Jiada Wang <jiada_wang@mentor.com> Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09serial: imx: call imx_dma_tx() again in dma_tx_callbackJiada Wang
Currently in dma_tx_callback(), no matter if there is still remaining data pending in circle buffer or not, DMA transmit will be terminated. This will result in some data never get transmitted. In order to fix this issue, call imx_dma_tx() again in dma_tx_callback, when there is pending data and uart hasn't been stopped. Signed-off-by: Jiada Wang <jiada_wang@mentor.com> Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09Revert "serial: imx: always wake up the processes in the TX callback"Jiada Wang
This reverts commit 2ad28e3efee21a5bbf940c83d1f0395b76bd3efb. Instead of always wake up write_wait process in TX callback, TX callback should call imx_dma_tx() again, and let imx_dma_tx transfer the remaining data in circle buffer. The issue with commit 2ad28e3 is, in case there is remaining data in circle buffer, but no process is waiting on write_wait queue, then as no following uart_write() will be called after uart_write_wakeup(), thus cause data loss. Moreover according to Documentation/serial/driver, uart_write_wakeup() should be called in case the transmit buffer have dropped below a threshold. Signed-off-by: Jiada Wang <jiada_wang@mentor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09serial: imx: use dma_is_txing to synchronize dma_tx_callback and imx_dma_txDirk Behme
To synchronize between dma_tx_callback() and imx_dma_tx() use the same variable, dma_is_txing. This prevents any race between these two functions and ensures that a new DMA can start only after the first has been finished. Before the new DMA can be set up, update the circular buffer logic, first. Therefore, change dma_is_txing after that update, instead of before. While doing this, in dma_tx_callback() extend the locking to dma_unmap_sg() and the update of dma_is_txing. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09serial: imx: unmap scatter gather list in imx_flush_bufferDirk Behme
First, reformat the code to exit immediately. This allows us to add more code in more readable format. In case the TX DMA was still running, remove and disable it's resources. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09serial: imx: unmap sg in case of dmaengine_prep_slave_sg() failureDirk Behme
In case dmaengine_prep_slave_sg() fails, add the missing dma_unmap_sg(). Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Anton Bondarenko <anton_bondarenko@mentor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09serial: imx: TX DMA: clean up sg initializationDirk Behme
Inverting the logic of the if statement for the sg initialization makes the if statement easier and better to read. No functional change. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09serial: imx: remove unneeded imx_transmit_buffer() from imx_start_tx()Dirk Behme
Use imx_start_tx() just to enable the TX interrupt. It's the job of the TX interrupt ISR to fill the transmit buffer, then. If the transmit buffer is empty, the TX interrupt should be executed as soon as the start_tx() enables the interrupt, so there is no reason for the extra imx_transmit_buffer() call, here. Remove it. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Andy Lowe <andy_lowe@mentor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09serial: imx: use locking to stop concurrent access of UCR1Jiada Wang
Several places are accessing the UCR1 register without locking. This probably will cause a race issue when another thread is accessing the same register. Add locking to preventing concurrent access of the UCR1 register. Signed-off-by: Jiada Wang <jiada_wang@mentor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09serial: imx: add CREAD flag supportJiada Wang
Add CREAD flag hanlding in set_termios and UART DMA mode which ignores all received chars when CREAD flag cleared. Signed-off-by: Jiada Wang <jiada_wang@mentor.com> Signed-off-by: Anton Bondarenko <anton_bondarenko@mentor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-11-25serial: imx: Fix warning when building 'allmodconfig'Fabio Estevam
When CONFIG_SERIAL_IMX_CONSOLE=n and CONFIG_CONSOLE_POLL=y we get the following build warning: drivers/tty/serial/imx.c:306:13: warning: 'imx_port_ucrs_save' defined but not used [-Wunused-function] drivers/tty/serial/imx.c:315:13: warning: 'imx_port_ucrs_restore' defined but not used [-Wunused-function] imx_port_ucrs_save/restore are only used under CONFIG_SERIAL_IMX_CONSOLE, so their definitions should be also be protected only by CONFIG_SERIAL_IMX_CONSOLE. This was detected when building 'allmodconfig'. Reported-by: Olof's autobuilder <build@lixom.net> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-06serial: imx: add imx_poll_init()Daniel Thompson
For the console poll usage, .poll_init() will perform deeper hardware initialization to ensure the serial port is always active. Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Huang Shijie <b32955@freescale.com> Cc: linux-serial@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-06serial: imx: clean up imx_poll_put_char()Daniel Thompson
imx_put_poll_char() has been simplified to remove the code to disable interrupts. The present code can corrupt register state when re-entered from FIQ handler. Switch to _relaxed() MMIO functions (which are safe for polled I/O and needed to avoid taking spin locks). Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Huang Shijie <b32955@freescale.com> Cc: linux-serial@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-05serial: imx: Remove unneeded registration messageFabio Estevam
There is no real value in displaying "Serial: IMX driver" in every boot. The uart_register_driver() can fail and even so the "Serial: IMX driver" will be displayed, which is not really helpful. This is particularly annoying when booting multi_v7_defconfig kernel on a SoC that is not a i.MX and even though this message gets displayed. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-05serial: imx: Remove unneeded OOM error messageFabio Estevam
When kzalloc() fails the core MM will already complain about it, so there is no need to have the error message locally. Remove the unneeded error message. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-05serial: imx: Remove unneeded goto labelFabio Estevam
Instead of jumping to 'error_out1' label we can simplify the code and return the error code directly. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-05serial: imx: Fix the reporting of interruptsFabio Estevam
On a imx system with ttymxc0, ttymxc1 and ttymxc4 registered we see the following output from 'cat /proc/interrupts': $ cat /proc/interrupts CPU0 ... 58: 39 GIC 58 2020000.serial 67: 115 GIC 67 21f8000.i2c The only uart irq that appears is ttymxc0, which is the console. As ttymxc1 and ttymxc4 will only have their irq registered at imx_startup(), they are not shown right after probe. Transmitting to ttymxc1 and ttymxc4 will cause their irqs to be registered, but the output shows: $ echo "111111" > /dev/ttymxc1 $ echo "444444" > /dev/ttymxc4 $ cat /proc/interrupts CPU0 ... 58: 150 GIC 58 2020000.serial 59: 1 GIC 59 62: 1 GIC 62 67: 115 GIC 67 21f8000.i2c ,which misses printing the associated device address. In order to fix this, register all the irqs inside the probe function via devm_request_irq(), which will correctly report the serial interrupts associated with their correspondent serial device and also helps simplyfing the code by avoiding the calls to free_irq(). $ echo "111111" > /dev/ttymxc1 $ echo "444444" > /dev/ttymxc4 $ cat /proc/interrupts CPU0 .... 58: 202 GIC 58 2020000.serial 59: 1 GIC 59 21e8000.serial 62: 1 GIC 62 21f4000.serial 67: 115 GIC 67 21f8000.i2c Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-20tty: serial: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-09-28serial: imx: change the wait even to interruptiableHuang Shijie
The wait_event() makes the application hang for ever in the following case: [1] the hardware flow control is enabled. [2] the other end (or the remote end) is terminated, and the TX is still waiting for the hardware flow control signal to become asserted. This patch fixes it by changing the wait_event to wait_event_interruptible. Signed-off-by: Huang Shijie <shijie8@gmail.com> Signed-off-by: Fugang Duan <B38611@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-28serial: imx: terminate the RX DMA when the UART is suspendingHuang Shijie
When the uart port is suspending, the RX data is useless. So in this case, we can terminate the RX DMA right now. Signed-off-by: Huang Shijie <b32955@freescale.com> Signed-off-by: Fugang Duan <B38611@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-28serial: imx: fix throttle/unthrottle callbacks for hardware assisted flow ↵Fugang Duan
control when the 'CTSC' bit is negated. 'CTS' has no function when 'CTSC' is asserted. 0: The CTS pin is high (inactive) 1: The CTS pin is low (active) For throttle, it needs to clear 'CTS' and 'CTSC' bits. For unthrottle, it needs to enable 'CTS' and 'CTSC' bits. The patch just fix the issue. Signed-off-by: Fugang Duan <B38611@freescale.com> Signed-off-by: Huang Shijie <shijie8@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-08serial: imx: clean up imx_poll_get_char()Dirk Behme
Looking at the get_poll_char() function of the 8250.c serial driver, we learn: * poll_get_char() doesn't have to save/disable/restore the interrupt registers. No interrupt handling is needed in this function at all. Remove it. * Don't block in case there is no data available. So instead blocking in the do {} while loop, just return with NO_POLL_CHAR, immediately . Additionally, while the i.MX6 register URXD[7-0] contain the RX_DATA, the upper bits of this register (URXD[15-10]) might contain some control flags. To ensure that these are not returned with the data read, just mask out URXD[7-0]. These changes fix the 'hang' working with kdb: $ echo ttymxc3 > /sys/module/kgdboc/parameters/kgdboc $ echo g >/proc/sysrq-trigger [0]kdb> help ... <hang> Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> Cc: Jiri Slaby <jslaby@suse.cz> Cc: linux-serial@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-08serial: imx: Fix x_char handling and tx flow controlPeter Hurley
The serial core expects the UART driver to transmit x_char (START/STOP chars) even if tx is stopped and before data already in the tx ring buffer if possible. Also, sending x_char must not cause additional data in the tx ring buffer to transmit if tx is stopped. Cause x_char to be transmitted before any other data is sent. Auto-stop tx if the tx ring buffer is empty or tx should be stopped. Only perform one write wakeup if tx ring buffer space is below threshold. x_char handling in DMA mode is still broken; add FIXME. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-11serial: imx: Fix build breakagePeter Hurley
Fix breakage introduced by commit c557d392fbf5badd693ea1946a4317c87a26a716, 'serial: Test for no tx data on tx restart'. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-10serial: Test for no tx data on tx restartPeter Hurley
Commit 717f3bbab3c7628736ef738fdbf3d9a28578c26c, 'serial_core: Fix conditional start_tx on ring buffer not empty' exposes an incorrect assumption in several drivers' start_tx methods; the tx ring buffer can, in fact, be empty when restarting tx while performing flow control. Affected drivers: sunsab.c ip22zilog.c pmac_zilog.c sunzilog.c m32r_sio.c imx.c Other in-tree serial drivers either are not affected or already test for empty tx ring buffer before transmitting. Test for empty tx ring buffer in start_tx() method, after transmitting x_char (if applicable). Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Seth Bollinger <sethb@digi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Cc: stable <stable@vger.kernel.org> # 3.15 Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-29Revert "serial: imx: remove the DMA wait queue"Greg Kroah-Hartman
This reverts commit e2f2786606d49d3aae545c61c04757a64cf7e5f0. Huang reports that this patch is broken and should be reverted. Cc: Huang Shijie <b32955@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
