This is the 4.4.12 stable release
commit 1ff7760ff66b98ef244bf0e5e2bd5310651205ad upstream.
We clamp frame_len_words to a maximum of 4096, but do not actually
limit the number of words written or read through the DATA registers
or the length added to spi_message::actual_length. This results in
silent data corruption for commands longer than this maximum.
Recalculate the length of each transfer, taking frame_len_words into
account. Use this length in qspi_{read,write}_msg(), and to increment
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit ea1b60fb085839a9544cb3a0069992991beabb7f upstream.
Each transfer can specify 8, 16 or 32 bits per word independently of
the default for the device being addressed. However, currently we
calculate the number of words in the frame assuming that the word size
is the device default.
If multiple transfers in the same message have differing
bits_per_word, we bitwise-or the different values in the WLEN register
field.
Fix both of these. Also rename 'frame_length' to 'frame_len_words' to
make clear that it's not a byte count like spi_message::frame_length.
commit 66ec246eb9982e7eb8e15e1fc55f543230310dd0 upstream.
Certain Intel Sunrisepoint PCH variants report zero chip selects in SPI
capabilities register even they have one per port. Detection in
pxa2xx_spi_probe() sets master->num_chipselect to 0 leading to -EINVAL
from spi_register_master() where chip select count is validated.
Fix this by not using SPI capabilities register on Sunrisepoint. They don't
have more than one chip select so use the default value 1 instead of
detection.
Fixes: 8b136baa5892 ("spi: pxa2xx: Detect number of enabled Intel LPSS SPI chip select signals")
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
commit b920cc3191d7612f26f36ee494e05b5ffd9044c0 upstream.
Rockchip_spi_set_cs could be called by spi_setup, but
spi_setup may be called by device driver after runtime suspend.
Then the spi clock is closed, rockchip_spi_set_cs may access the
spi registers, which causes cpu block in some socs.
Fixes: 64e36824b32 ("spi/rockchip: add driver for Rockchip RK3xxx")
Signed-off-by: Huibin Hong <huibin.hong@rock-chips.com>
Add new sysfs 'num_chipselect' file to expose the maximum number
of chipselects a SPI master can support.
This allows to create a script in user space which automatically
creates a new spidev instance for every chipselect on a bus.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Use sysfs new_id file to enable spidev at runtime. new_id file accepts
bus number and chip select in 'B.C' format.
With reference to the last ML discussion here[1] regarding the solution
for spidev with device trees. This patch adds support to load spidevB.C
via sysfs new_id file as suggested by Greg.
[1] http://thread.gmane.org/gmane.linux.kernel.spi.devel/20331/focus=20369
Suggested-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
[fixed error handling]
This is the 4.4.5 stable release
Calculate and update max speed from bus clock for SoCs
using DSPI IP.
The bus clock factor's are taken from the data sheets
of respective SoCs.
Acked-by: Stefan Agner <stefan@agner.ch>
(cherry picked from commit 9419b2006cf47c75985ea51d36ddc51346d29efd)
commit 70f340df24518d36eeaefb6652d492f250115c19 upstream.
The non-DT platform that uses this driver (actually the AVR32) was taking a bad
branch for determining if the IP would use gpio for CS.
Adding the presence of DT as a condition fixes this issue.
Fixes: 4820303480a1 ("spi: atmel: add support for the internal chip-select of the spi controller")
Reported-by: Mans Rullgard <mans@mansr.com>
Signed-off-by: Cyrille Pitchen <cyrille.pitchen@atmel.com>
[nicolas.ferre@atmel.com: extract from ml discussion]
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Tested-by: Mans Rullgard <mans@mansr.com>
commit 2f538c017e1a8620d19553931199c6d6a6d31bb2 upstream.
Occasionally the setup function will be called multiple times. Only request
the gpio the first time otherwise -EBUSY will occur on subsequent calls to
setup.
Reported-by: Joseph Bell <joe@iachieved.it>
Signed-off-by: Michael Welling <mwelling@ieee.org>
spi-linus
Fix parent-device reference leak due to SPI-core taking an unnecessary
reference to the parent when allocating the master structure, a
reference that was never released.
Note that driver core takes its own reference to the parent when the
master device is registered.
Fixes: 49dce689ad4e ("spi doesn't need class_device")
Signed-off-by: Johan Hovold <johan@kernel.org>
Cc: stable@vger.kernel.org
We use the spi_lock spinlock to protect against races between the device
being removed and file operations on the spidev. This means that in the
removal path all references to the device need to be done under lock as
in removal we dropping references to the device.
Reported-by: Vegard Nossum <vegard.nossum@oracle.com>
DSPI instances in Vybrid have a different amount of chip selects
and CTARs (Clock and transfer Attributes Register). In case of
DSPI1 we only have 2 CTAR registers and 4 CS. In present driver
implementation CTAR offset is derived from CS instance which will
lead to out of bound access if chip select instance is greater than
CTAR register instance, hence use single CTAR0 register for all CS
instances. Since we write the CTAR register anyway before each access,
there is no value in using the additional CTAR registers. Also one
should not program a value in CTAS for a CTAR register that is not
present, hence configure CTAS to use CTAR0.
'spi/fix/mediatek' and 'spi/fix/pl022' into spi-linus
When submitting an identical spi_message multiple times via spi_sync
the spi_message.frame_length does not get reset to 0 in __spi_validate
before adding up all spi_transfer.len resulting in
frame_length > actual_length on all but the first spi_sync call.
Signed-off-by: Martin Sperl <kernel@martin.sperl.org>
Handle EPROBE_DEFER explicitly so that we ensure that we get the DMA
channel specified in the device tree, instead of depending on the DMA
controller getting probed before us.
Signed-off-by: Rabin Vincent <rabin.vincent@axis.com>
With a 64-bit resource_size_t, we get a build warning on bcm63xx_spi_probe:
drivers/spi/spi-bcm63xx.c:565:16: warning: format '%x' expects argument of type 'unsigned int', but argument 3 has type 'resource_size_t {aka long long unsigned int}' [-Wformat=]
As we are printing a resource, we can just use the %pr format
specifier that pretty-prints the address and avoids the warning.
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
When only one device is present, it is not necessary to specify
cs_gpios, as the CS line can be controlled by the hardware
module.
Without this patch, older device tree bindings used before
37457607 "spi: mediatek: mt8173 spi multiple devices support"
would cause a panic on boot. This fixes the crash, and
re-introduces backward compatibility.
Signed-off-by: Nicolas Boichat <drinkcat@chromium.org>
Acked-by: Leilk Liu <leilk.liu@mediatek.com>
Commit ca5d24854210 ("spi: Add THIS_MODULE to spi_driver in SPI core")
adds the new __spi_register_driver() function, but keeps the kerneldoc
for the spi_register_driver() function in place and forgets to add the
description for the new owner parameter.
Signed-off-by: Thierry Reding <treding@nvidia.com>
'spi/topic/txx9' into spi-next
'spi/topic/omap-uwire', 'spi/topic/owner', 'spi/topic/pxa' and 'spi/topic/pxa2xx' into spi-next
'spi/topic/mtk', 'spi/topic/oc-tiny' and 'spi/topic/octeon' into spi-next
spi-next
'spi/topic/bfin-sport', 'spi/topic/bfin5xx' and 'spi/topic/bitbang' into spi-next
'spi/topic/au1550', 'spi/topic/bcm2835' and 'spi/topic/bcm2835aux' into spi-next
'spi/fix/omap2-mcspi', 'spi/fix/ti-qspi' and 'spi/fix/xilinx' into spi-linus
Extend the pxa2xx_spi_acpi_get_pdata() so that it can create platform data
also on platforms that do not support ACPI or if CONFIG_ACPI is not set.
Now it is expected that "pxa2xx-spi" platform device is either created with
explicit platform data or has an ACPI companion device.
However there is only little in pxa2xx_spi_acpi_get_pdata() that is really
dependent on ACPI companion and it can be reworked to cover also cases
where "pxa2xx-spi" device doesn't have ACPI companion and is created
without platform data.
Do this by renaming the pxa2xx_spi_acpi_get_pdata(), moving it outside of
CONFIG_ACPI test and changing a few runtime tests there to support non-ACPI
case. Only port/bus ID setting based on ACPI _UID is dependent on ACPI and
is moved to own function inside CONFIG_ACPI.
Purpose of this to support non-ACPI case for those PCI enumerated compound
devices that integrate both LPSS SPI host controller and integrated DMA
engine under the same PCI ID and which are registered in MFD layer instead
of in spi-pxa2xx-pci.c.
LPSS SPI in Intel Broxton is otherwise the same than in Intel Sunrisepoint
but it supports up to four chip selects per port and has different FIFO
thresholds. Patch adds support for two Broxton SoC variants.
SPI capabilities register located in private registers space of newer
Intel LPSS SPI host controllers tell in register bits 12:9 which chip
select signals are enabled.
Use that information for detecting the number of chip selects. For
simplicity we assume chip selects are enabled one after another without
disabled chip selects between. For instance CS0 | CS1 | CS2 but not
CS0 | CS1 | CS3.
Intel LPSS SPI host controllers in upcoming Intel platforms can have up
to 4 chip selects per port. Extend chip select control in
lpss_ssp_cs_control() by adding a code that selects the active chip
select output prior to changing the state. Detection for number of
enabled chip select signals will be added by another patch.
Rename a few defines that are specific to Intel LPSS SPI private
registers with LPSS prefix. It makes easier to distinguish them from
common defines.
Suggested-by: Robert Jarzmik <robert.jarzmik@free.fr>
LS1043a and LS2080A in the Layerscape family also support DSPI, make
DSPI selectable for these hardwares.
Signed-off-by: Yuan Yao <yao.yuan@freescale.com>
there's no need to call pm_runtime_get_sync()
followed by pm_runtime_put(). We should, instead,
just call pm_runtime_put_sync() and pm_runtime_disable().
Signed-off-by: Felipe Balbi <balbi@ti.com>
Some users have reported that in polled mode the driver fails randomly
to read the last word of the transfer.
The end condition used for the transmissions (in polled and irq mode)
has been the TX_EMPTY flag. But Lars-Peter Clausen has identified a delay
from the TX_EMPTY to the actual end of the data rx.
I believe that this race condition has not been detected until now
because of the latency added by the IRQ handler or the PCIe bridge.
This bugs affects setups with low latency access to the spi core.
This patch replaces the readout logic:
For all the words, except the last one, the TX_EMPTY flag is used (and
cached).
If !TX_EMPY or is the last word. The status register is read and the
RX_EMPTY flag is used.
The performance is not affected: there is an extra read of the
Status Register, but the readout can start as soon as there is a word
in the buffer.
Reported-by: Edward Kigwana <ekigwana@scires.com>
Initial-fix-by: Lars-Peter Clausen <lars@metafoo.de>
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
An spi_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Acked-by: Jonathan Cameron <jic23@kernel.org>
Add spi_register_driver helper macro that adds THIS_MODULE to
spi_driver for the registering driver. We rename and modify
the existing spi_register_driver to enable this.
SPI controllers may need to be properly setup before chip selects
can be used. Therefore, wait until the spi controller has a chance
to perform their setup procedure before trying to use the chip
select.
This also insures that the chip selects pins are in a good
state before asseting them which otherwise may cause confusion.
Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
Tested-by: Grygorii Strashko <grygorii.strashko@ti.com>
Tested-by: Ivan Khoronzhuk <ivan.khoronzhuk@linaro.org>
The offset 0x60 is the offset of the data register defined as DW_SPI_DR in the
header file. Use it.
mt8173 IC spi HW has 4 gpio group, it's possible to support
max <= 4 slave devices, even mtk spi HW is not congruent to spi core.
1. When a device do a spi_message transfer, spi HW should know
which pad-group this device is on, and then writes pad-select
register.
2. Mtk pad-select register just selects which MISO pin HW will
receive data. For example, pad-select=1(select spi1 pins), HW just
receives data from spi1 MISO, but it still send waveform to all 4
group cs/clk/mosi. If cs pin in other groups is still spi mode,
after spi1 is selected(by active cs pin), devices on other group
will also be selected.
Signed-off-by: Leilk Liu <leilk.liu@mediatek.com>
controller_data is related with device, so move to master->setup
function.
mtk_spi_config() and mtk_spi_prepare_message() both initialize
spi register, so remove mtk_spi_config() and init all register
in mtk_spi_prepare_message().
When building docs with make htmldocs, warnings about not having
a description for the return value are reported, i.e:
warning: No description found for return value of 'spi_register_driver'
Fix these by following the kernel-doc conventions explained in
Documentation/kernel-doc-nano-HOWTO.txt.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi into spi-doc
