path: root/drivers/spi/spi_txx9.c
2007-08-31spi: correct name for spi_txx9Atsushi Nemoto
Correct the name of the spi_txx9 driver (and their in-tree user) instead of MODULE_ALIAS workaround. This would be preferable in the long term. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-31SPI driver hotplug/coldplug fixesDavid Brownell
Update various SPI drivers so they properly support - coldplug through "modprobe $(cat /sys/devices/.../modalias)" - hotplug through "modprobe $(MODALIAS)" The basic rule for platform, SPI, and (new style) I2C drivers is just to make sure that modprobing the driver name works. In this case, all the relevant drivers are platform drivers, and this patch either (a) Changes the driver name, if no in-tree code would break; this is simpler and thus preferable in the long term. (b) Adds MODULE_ALIAS directives, when in-tree platforms declare devices using the current driver name; less desirable. Most systems will link SPI controller drivers statically, but there's no point in being needlessly broken. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Jean Delvare <khali@linux-fr.org> Acked-by: Andrei Konovalov <akonovalov@ru.mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17spi_txx9 controller driverAtsushi Nemoto
This is a driver for SPI controller built into TXx9 MIPS SoCs. This driver is derived from arch/mips/tx4938/toshiba_rbtx4938/spi_txx9.c. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
