path: root/drivers/spi/spi_bfin5xx.c
2008-02-26Update the i.MX31 Kernel to 2.6.232.6.23-mx31ads-2008022618072.6.23-mx31-200802261807Justin Waters
This is the result of a brute-force attempt to update the kernel to 2.6.23. Now that we have a git tree, our effort will be a little nicer in the future. Signed-off-by: Justin Waters <justin.waters@timesys.com>
2007-06-11Blackfin SPI driver: fix bug SPI DMA incomplete transmissionBryan Wu
SPI writes intermittently drop bytes at end of DMA transfer http://blackfin.uclinux.org/gf/project/uclinux-dist/tracker/?action=TrackerItemEdit&tracker_item_id=3205 http://blackfin.uclinux.org/gf/project/uclinux-dist/tracker/?action=TrackerItemEdit&tracker_item_id=2892 Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-06-11Blackfin SPI driver: tweak spi cleanup function to match newer kernel changesMike Frysinger
Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Cc: David Brownell <dbrownell@users.sourceforge.net>
2007-05-21Blackfin SPI: cleanup according to David Brownell's reviewBryan Wu
a) platorm_driver_probe(...) instead of platform_driver_register(&driver); b) set bfin_spi_enable and bfin_spi_disable static c) Why is the width flag a u32? d) maybe use dev_dbg() instead of pr_debug() Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Blackfin: blackfin on-chip SPI controller driverWu, Bryan
This patch implements the driver necessary use the Analog Devices Blackfin processor's SPI Port. Signed-off-by: Bryan Wu <bryan.wu@analog.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
