path: root/drivers/spi/spi.c
2012-03-15spi: remove redundant variable assignmentGuennadi Liakhovetski
The status variable is guaranteed to be 0 at that location anyway. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-03-10spi: release lock on error path in spi_pump_messages()Dan Carpenter
We should release the lock here and enable IRQs before returning. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> [grant.likely: move unlock above dev_err() call] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-03-09spi: Mark spi_register_board_info() __devinitMark Brown
Some systems have SPI devices located on plugin modules which are enumerated at runtime as devices. The drivers for these plugin modules need to register their SPI devices at probe() time so want to be able to call spi_register_board_info() but that function is currently marked as __init rather than __devinit so this usage isn't legal. Change the annotation to __devinit to handle this. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-03-09spi/doc: spi_master_put must be followed up by kfreeUwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-03-07spi: create a message queueing infrastructureLinus Walleij
This rips the message queue in the PL022 driver out and pushes it into (optional) common infrastructure. Drivers that want to use the message pumping thread will need to define the new per-messags transfer methods and leave the deprecated transfer() method as NULL. Most of the design is described in the documentation changes that are included in this patch. Since there is a queue that need to be stopped when the system is suspending/resuming, two new calls are implemented for the device drivers to call in their suspend()/resume() functions: spi_master_suspend() and spi_master_resume(). ChangeLog v1->v2: - Remove Kconfig entry and do not make the queue support optional at all, instead be more agressive and have it as part of the compulsory infrastructure. - If the .transfer() method is implemented, delete print a small deprecation notice and do not start the transfer pump. - Fix a bitrotted comment. ChangeLog v2->v3: - Fix up a problematic sequence courtesy of Chris Blair. - Stop rather than destroy the queue on suspend() courtesy of Chris Blair. Signed-off-by: Chris Blair <chris.blair@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Tested-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-12-13spi: Fix device unregistration when unregistering the bus masterLaurent Pinchart
Device are added as children of the bus master's parent device, but spi_unregister_master() looks for devices to unregister in the bus master's children. This results in the child devices not being unregistered. Fix this by registering devices as direct children of the bus master. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-10-31spi: Add export.h for THIS_MODULE/EXPORT_SYMBOL to spi.cPaul Gortmaker
This uses both EXPORT_SYMBOL and THIS_MODULE, both which come from the export.h file now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-06-06spi: reorganize driversGrant Likely
Sort the SPI makefile and enforce the naming convention spi_*.c for spi drivers. This change also rolls the contents of atmel_spi.h into the .c file since there is only one user of that particular include file. v2: - Use 'spi-' prefix instead of 'spi_' to match what seems to be be the predominant pattern for subsystem prefixes. - Clean up filenames in Kconfig and header comment blocks Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2011-05-20spi: Use void pointers for data in simple SPI I/O operationsMark Brown
Currently the simple SPI I/O operations all take pointers to u8 * buffers to operate on. This creates needless type compatibility issues and the underlying spi_transfer structure uses void pointers anyway so convert the API over to take void pointers too. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-25spi / PM: Support dev_pm_opsMark Brown
Allow SPI drivers to use runtime PM and other dev_pm_ops features by implementing dev_pm_ops for the bus. The existing bus specific suspend and resume functions will be called if a driver does not provide dev_pm_ops allowing for transition to the new model. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-12-22drivers/spi/spi.c: don't release the spi device twiceSebastian Andrzej Siewior
This was fixed by David Lamparter in v2.6.36-rc5 3486008 ("spi: free children in spi_unregister_master, not siblings") and broken again in v2.6.37-rc1~2^2~4 during the merge of 2b9603a0 ("spi: enable spi_board_info to be registered after spi_master"). Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: David Lamparter <equinox@diac24.net> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-22spi: fixed odd static string conventions in core codeLinus Walleij
This patch removes convention of passing a static string as a parameter to another static string. The convention is intended to reduce text usage by sharing the common bits of the string, but the implementation is inherently fragile (a change to one format string but not the other will nullify any possible advantage), it isn't necessarily a net win depending on what this compiler does, and it it reduces code readability. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> [grant.likely@secretlab.ca: removed dev_dbg->dev_err hunk] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-21spi: enable spi_board_info to be registered after spi_masterFeng Tang
Currently spi_register_board_info() has to be called before its related spi_master be registered, otherwise these board info will be just ignored. This patch will remove this order limit, it adds a global spi master list like the existing global board info listr. Whenever a board info or a spi_master is registered, the spi master list or board info list will be scanned, and a new spi device will be created if there is a master-board info match. Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-02of/spi: Fix OF-style driver binding of spi devicesSinan Akman
This patch adds the OF hook to the spi core so that devices can automatically be registered based on device tree data. This fixes a problem with spi devices not binding to drivers after the cleanup of the spi & i2c binding code. Signed-off-by: Sinan Akman <sinan@writeme.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-09-01spi: free children in spi_unregister_master, not siblingsDavid Lamparter
introduced by 49dce689 ("spi doesn't need class_device") and bad-fixed by 350d0076 ("spi: fix double-free on spi_unregister_master"), spi_unregister_master would previously device_unregister all of the spi master's siblings (instead of its children). hilarity ensues. fix it to unregister children. Signed-off-by: David Lamparter <equinox@diac24.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-08-14Merge branch 'next-spi' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-spi' of git://git.secretlab.ca/git/linux-2.6: spi/amba_pl022: Fix probe and remove hook section annotations. spi/mpc5121: change annotations for probe and remove functions spi/bitbang: reinitialize transfer parameters for every message spi/spi-gpio: add support for controllers without MISO or MOSI pin spi/bitbang: add support for SPI_MASTER_NO_{TX, RX} modes SPI100k: Fix 8-bit and RX-only transfers spi/mmc_spi: mmc_spi adaptations for SPI bus locking API spi/mmc_spi: SPI bus locking API, using mutex Fix trivial conflict in drivers/spi/mpc512x_psc_spi.c due to 'struct of_device' => 'struct platform_device' rename and __init/__exit to __devinit/__devexit fix.
2010-07-30of/spi: call of_register_spi_devices() from spi core codeAnatolij Gustschin
Move of_register_spi_devices() call from drivers to spi_register_master(). Also change the function to use the struct device_node pointer from master spi device instead of passing it as function argument. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-06-28spi/mmc_spi: SPI bus locking API, using mutexErnst Schwab
SPI bus locking API to allow exclusive access to the SPI bus, especially, but not limited to, for the mmc_spi driver. Coded according to an outline from Grant Likely; here is his specification (accidentally swapped function names corrected): It requires 3 things to be added to struct spi_master. - 1 Mutex - 1 spin lock - 1 flag. The mutex protects spi_sync, and provides sleeping "for free" The spinlock protects the atomic spi_async call. The flag is set when the lock is obtained, and checked while holding the spinlock in spi_async(). If the flag is checked, then spi_async() must fail immediately. The current runtime API looks like this: spi_async(struct spi_device*, struct spi_message*); spi_sync(struct spi_device*, struct spi_message*); The API needs to be extended to this: spi_async(struct spi_device*, struct spi_message*) spi_sync(struct spi_device*, struct spi_message*) spi_bus_lock(struct spi_master*) /* although struct spi_device* might be easier */ spi_bus_unlock(struct spi_master*) spi_async_locked(struct spi_device*, struct spi_message*) spi_sync_locked(struct spi_device*, struct spi_message*) Drivers can only call the last two if they already hold the spi_master_lock(). spi_bus_lock() obtains the mutex, obtains the spin lock, sets the flag, and releases the spin lock before returning. It doesn't even need to sleep while waiting for "in-flight" spi_transactions to complete because its purpose is to guarantee no additional transactions are added. It does not guarantee that the bus is idle. spi_bus_unlock() clears the flag and releases the mutex, which will wake up any waiters. The difference between spi_async() and spi_async_locked() is that the locked version bypasses the check of the lock flag. Both versions need to obtain the spinlock. The difference between spi_sync() and spi_sync_locked() is that spi_sync() must hold the mutex while enqueuing a new transfer. spi_sync_locked() doesn't because the mutex is already held. Note however that spi_sync must *not* continue to hold the mutex while waiting for the transfer to complete, otherwise only one transfer could be queued up at a time! Almost no code needs to be written. The current spi_async() and spi_sync() can probably be renamed to __spi_async() and __spi_sync() so that spi_async(), spi_sync(), spi_async_locked() and spi_sync_locked() can just become wrappers around the common code. spi_sync() is protected by a mutex because it can sleep spi_async() needs to be protected with a flag and a spinlock because it can be called atomically and must not sleep Signed-off-by: Ernst Schwab <eschwab@online.de> [grant.likely@secretlab.ca: use spin_lock_irqsave()] Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Matt Fleming <matt@console-pimps.org> Tested-by: Antonio Ospite <ospite@studenti.unina.it>
2010-04-28spi: spi_device memory should be released instead of device.Roman Tereshonkov
The memory for dev variable is allocated as a part of spi_device structure memory which the dev belongs to. Thus when the memory is released the right pointer is used. Signed-off-by: Roman Tereshonkov <roman.tereshonkov@nokia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-04-28spi: release device claimed by bus_find_device_by_nameRoman Tereshonkov
In success case the function bus_find_device_by_name calls get_device. In our context put_device should be called to decrease the device count usage. Signed-off-by: Roman Tereshonkov <roman.tereshonkov@nokia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-09-23spi: handle TX-only/RX-onlyDavid Brownell
Support two new half-duplex SPI implementation restrictions, for links that talk to TX-only or RX-only devices. (Existing half-duplex flavors support both transfer directions, just not at the same time.) Move spi_async() into the spi.c core, and stop inlining it. Then make that function perform error checks and reject messages that demand more than the underlying controller can support. Based on a patch from Marek Szyprowski which did this only for the bitbanged GPIO driver. Cc: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23spi: prefix modalias with "spi:"Anton Vorontsov
This makes it consistent with other buses (platform, i2c, vio, ...). I'm not sure why we use the prefixes, but there must be a reason. This was easy enough to do it, and I did it. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Jean Delvare <khali@linux-fr.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Samuel Ortiz <sameo@openedhand.com> Cc: "John W. Linville" <linville@tuxdriver.com> Acked-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23spi: add support for device table matchingAnton Vorontsov
With this patch spi drivers can use standard spi_driver.id_table and MODULE_DEVICE_TABLE() mechanisms to bind against the devices. Just like we do with I2C drivers. This is useful when a single driver supports several variants of devices but it is not possible to detect them in run-time (like non-JEDEC chips probing in drivers/mtd/devices/m25p80.c), and when platform_data usage is overkill. This patch also makes life a lot easier on OpenFirmware platforms, since with OF we extensively use proper device IDs in modaliases. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Jean Delvare <khali@linux-fr.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18spi: fix spi_write_then_read() commentJiri Pirko
Buffer needs not be dma-safe, not rx data length. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18spi: move more spi_setup() functionality into coreDavid Brownell
Move some common spi_setup() error checks into the SPI framework from the spi_master controller drivers: - Add a new "mode_bits" field to spi_master - Use that in spi_setup to validate the spi->mode value being requested. Setting this new field is now mandatory for any controller supporting more than vanilla SPI_MODE_0. - Update all spi_master drivers to: * Initialize that field * Remove current spi_setup() checks using that value. This is a net minor code shrink. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18spi: move common spi_setup() functionality into coreDavid Brownell
Start moving some spi_setup() functionality into the SPI core from the various spi_master controller drivers: - Make that function stop being an inline; - Move two common idioms from drivers into that new function: * Default bits_per_word to 8 if that field isn't set * Issue a standardized dev_dbg() message This is a net minor source code shrink, and supports enhancments found in some follow-up patches. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13spi: spi_write_then_read() bugfixesDavid Brownell
The "simplify spi_write_then_read()" patch included two regressions from the 2.6.27 behaviors: - The data it wrote out during the (full duplex) read side of the transfer was not zeroed. - It fails completely on half duplex hardware, such as Microwire and most "3-wire" SPI variants. So, revert that patch. A revised version should be submitted at some point, which can get the speedup on standard hardware (full duplex) without breaking on less-capable half-duplex stuff. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: <stable@kernel.org> [2.6.28.x, 2.6.29.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06spi: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16spi: core and gpio expanders use subsys_initDavid Brownell
Make the SPI external GPIO expander drivers register themselves at subsys_initcall() time when they're statically linked, and make the SPI core do its driver model initialization earlier so that's safe. SOC-integrated GPIOs are available starting very early -- often before initcalls start to run, or earily in arch_initcall() at latest -- so this improves consistency, letting more subsystems rely on GPIOs being usable by their own subsys_initcall() code. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16spi: simplify spi_write_then_read()Vernon Sauder
Modify spi_write_then_read() to use one transfer. This speeds up all callers, and is a minor code shrink. Signed-off-by: Vernon Sauder <Vernon.Sauder@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-15spi: bugfix spi_add_device() with duplicate chipselectsDavid Brownell
When reviewing a recent patch I noticed a potential trouble spot in the registration of new SPI devices. The SPI master driver is told to set the device up before adding it to the driver model, so that it's always properly set up when probe() is called. (This is important, because in the case of inverted chipselects, this device can make the bus misbehave until it's properly deselected. It's got to be set up even if no driver binds to the device.) The trouble spot is that it doesn't first verify that no other device has been added using that chipselect. If such a device has been added, its configuration gets trashed. (Fortunately this has not been a common error!) The fix here adds an explicit check, and a mutex to protect the relevant critical region. [akpm@linux-foundation.org: make the lock local to spi_add_device()] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25spi: split up spi_new_device() to allow two stage registration.Grant Likely
spi_new_device() allocates and registers an spi device all in one swoop. If the driver needs to add extra data to the spi_device before it is registered, then this causes problems. This is needed for OF device tree support so that the SPI device tree helper can add a pointer to the device node after the device is allocated, but before the device is registered. OF aware SPI devices can then retrieve data out of the device node to populate a platform data structure. This patch splits the allocation and registration portions of code out of spi_new_device() and creates two new functions; spi_alloc_device() and spi_register_device(). spi_new_device() is modified to use the new functions for allocation and registration. None of the existing users of spi_new_device() should be affected by this change. Drivers using the new API can forego the use of spi_board_info structure to describe the device layout and populate data into the spi_device structure directly. This change is in preparation for adding an OF device tree parser to generate spi_devices based on data in the device tree. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David Brownell <dbrownell@users.sourceforge.net>
2008-07-24spi: make spi_board_info.modalias a char arrayGrant Likely
Currently, 'modalias' in the spi_device structure is a 'const char *'. The spi_new_device() function fills in the modalias value from a passed in spi_board_info data block. Since it is a pointer copy, the new spi_device remains dependent on the spi_board_info structure after the new spi_device is registered (no other fields in spi_device directly depend on the spi_board_info structure; all of the other data is copied). This causes a problem when dynamically propulating the list of attached SPI devices. For example, in arch/powerpc, the list of SPI devices can be populated from data in the device tree. With the current code, the device tree adapter must kmalloc() a new spi_board_info structure for each new SPI device it finds in the device tree, and there is no simple mechanism in place for keeping track of these allocations. This patch changes modalias from a 'const char *' to a fixed char array. By copying the modalias string instead of referencing it, the dependency on the spi_board_info structure is eliminated and an outside caller does not need to maintain a separate spi_board_info allocation for each device. If searched through the code to the best of my ability for any references to modalias which may be affected by this change and haven't found anything. It has been tested with the lite5200b platform in arch/powerpc. [dbrownell@users.sourceforge.net: cope with linux-next changes: KOBJ_NAME_LEN obliterated, etc] Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-21Driver Core: add ability for class_find_device to start in middle of listGreg Kroah-Hartman
This mirrors the functionality that driver_find_device has as well. We add a start variable, and all callers of the function are fixed up at the same time. The block layer will be using this new functionality in a follow-on patch. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06spi core: stop updating dev->power.power_stateDavid Brownell
Don't update dev->power.power_state any more in the SPI core. The only reason to update this scheduled-to-be-removed field was to make the already-removed /sys/devices/.../power/state files work better. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Remove inclusions of <linux/autoconf.h>Ralf Baechle
Nothing should ever include this file. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: "Mike Frysinger" <vapier.adi@gmail.com> Acked-by: "Bryan Wu" <cooloney.lkml@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-24spi: use class iteration apiDave Young
Convert to use the class iteration api. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Acked-by: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-12-05spi: simplify spi_sync() calling conventionMarc Pignat
Simplify spi_sync calling convention, eliminating the need to check both the return value AND the message->status. In consequence, this corrects misbehaviours of spi_read and spi_write (which only checked the former) and their callers. Signed-off-by: Marc Pignat <marc.pignat@hevs.ch> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-05SPI: use mutex not semaphoreDavid Brownell
Make spi_write_then_read() use a mutex not a binary semaphore. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14spi: fix double-free on spi_unregister_masterAtsushi Nemoto
After 49dce689ad4ef0fd1f970ef762168e4bd46f69a3, device_for_each_child iteration hits the master device itself. Do not call spi_unregister_device() for the master device. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Acked-by: David Brownell <david-b@pacbell.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16spi doesn't need class_deviceTony Jones
Make the SPI framework and drivers stop using class_device. Update docs accordingly ... highlighting just which sysfs paths should be "safe"/stable. Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12Driver core: change add_uevent_var to use a structKay Sievers
This changes the uevent buffer functions to use a struct instead of a long list of parameters. It does no longer require the caller to do the proper buffer termination and size accounting, which is currently wrong in some places. It fixes a known bug where parts of the uevent environment are overwritten because of wrong index calculations. Many thanks to Mathieu Desnoyers for finding bugs and improving the error handling. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-31spi device setup gets better error checkingDavid Brownell
This updates some error reporting paths in SPI device setup: - Move validation logic for SPI chipselects to spi_new_device(), which is where it should always have been. - In spi_new_device(), emit error messages if the device can't be created. This is LOTS better than a silent failure; though eventually, the calling convention should probably change to use the <linux/err.h> conventions. - Includes one previously-missing check: SPI masters must always have at least one chipselect, even for dedicated busses which always keep it selected! It also adds a FIXME (IDR for dynamic ID allocation) so the issue doesn't live purely in my mailbox. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-21spi.c:scan_boardinfo() mustn't be __init_or_moduleAdrian Bunk
WARNING: drivers/built-in.o(.text+0x889735): Section mismatch: reference to .init.text:scan_boardinfo (between 'spi_register_master' and '__unregister') Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17use mutex instead of semaphore in SPI core/init codeMatthias Kaehlcke
The SPI core/init code uses a semaphore as mutex. Use the mutex API instead of the (binary) semaphore. Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Acked-by: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-04SPI dynamic busid generation bugfixDavid Brownell
Fix SPI dynamic bus ID assignment to start at 2^15-1 rather than a negative number. Valid bus ids are supposed to be positive, and are (now) stored in an 's16' value. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08SPI kerneldocDavid Brownell
Various documentation updates for the SPI infrastructure, to clarify things that may not have been clear, to cope with lack of editing, and fix omissions. Also, plug SPI into the kernel-api DocBook template, and fix all the resulting glitches in document generation. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-27[PATCH] drivers/spi/: fix section mismatchesAdrian Bunk
WARNING: drivers/built-in.o - Section mismatch: reference to .init.text:spi_register_master from .text between 'spi_bitbang_start' (at offset 0x84e11a) and 'bitbang_work' WARNING: drivers/built-in.o - Section mismatch: reference to .init.text:spi_alloc_master from .text between 'butterfly_attach' (at offset 0x84e681) and 'at25_remove' WARNING: drivers/built-in.o - Section mismatch: reference to .init.text:spi_new_device from .text between 'butterfly_attach' (at offset 0x84e7e4) and 'at25_remove' Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
