path: root/drivers/spi/spi-xilinx.c
2013-11-15tree-wide: use reinit_completion instead of INIT_COMPLETIONWolfram Sang
Use this new function to make code more comprehensible, since we are reinitialzing the completion, not initializing. [akpm@linux-foundation.org: linux-next resyncs] Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13) Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-17spi: bitbang: Let spi_bitbang_start() take a reference to masterAxel Lin
Many drivers that use bitbang library have a leak on probe error paths. This is because once a spi_master_get() call succeeds, we need an additional spi_master_put() call to free the memory. Fix this issue by moving the code taking a reference to master to spi_bitbang_start(), so spi_bitbang_start() will take a reference to master on success. With this change, the caller is responsible for calling spi_bitbang_stop() to decrement the reference and spi_master_put() as counterpart of spi_alloc_master() to prevent a memory leak. So now we have below patten for drivers using bitbang library: probe: spi_alloc_master -> Init reference count to 1 spi_bitbang_start -> Increment reference count remove: spi_bitbang_stop -> Decrement reference count spi_master_put -> Decrement reference count (reference count reaches 0) Fixup all users accordingly. Signed-off-by: Axel Lin <axel.lin@ingics.com> Suggested-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Acked-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-01Merge remote-tracking branch 'spi/topic/pdata' into spi-nextMark Brown
2013-08-29Merge remote-tracking branch 'spi/topic/rspi' into spi-pdataMark Brown
Conflicts: drivers/spi/spi-rspi.c
2013-08-29spi: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-08-09spi/bitbang: Drop empty setup() functionsMark Brown
Now that the bitbang core does not require a setup() function we can drop the check in the altera, nuc900 and xilinx drivers. Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-17spi/xilinx: signedness issue checking platform_get_irq()Dan Carpenter
In xilinx_spi_probe() we use xspi->irq to store negative error codes so it has to be signed. We weren't going to use the upper bit any way so this is fine. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-15spi/xilinx: Simplify irq allocationMichal Simek
Use devm_request_irq() for irq allocation which simplify driver code. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-15spi/xilinx: Use of_property_read_u32 for reading value from nodeMichal Simek
It simplifies driver probing. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-15spi/xilinx: Clean ioremap callingMichal Simek
devm_ioremap_resource() automatically checks that struct resource is initialized. Also group platform_get_resource() and devm_ioremap_resource() together. And remove mem resource from struct xilinx_spi. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-15spi/xilinx: Remove CONFIG_OF from the driverMichal Simek
dev.of_node is in struct device all the time. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-15spi/xilinx: Refer to platform device as pdev in probe() and remove()Mark Brown
This is a more traditional name and makes things a bit clearer when referring to actual struct devices as we do frequently during probe(). Signed-off-by: Mark Brown <broonie@linaro.org> Acked-by: Michal Simek <michal.simek@xilinx.com>
2013-07-15spi/xilinx: Remove remains of of_platform device registrationMark Brown
In the past there used to be a separate platform device type for device tree systems so the probe and removal functions were split into generic and bus sections. Since this is no longer the case simplify the code (and remove some unprototyped exports) by factoring everything into the bus probe() and remove(). Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-15spi/xilinx: Convert to devm_ioremap_resource()Mark Brown
Saves code and reduces the possibility of error. Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-10spi/xilinx: Revert master->setup function removalMichal Simek
master->setup() must be initialized to be able to successfully run spi_bitbang_start() and satisfy if/else logic there. "spi: convert drivers to use bits_per_word_mask" (sha1: 24778be20f87d5aadb19624fc768b3159fa43efc) Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-26Merge remote-tracking branch 'spi/topic/xilinx' into spi-nextMark Brown
2013-06-26Merge remote-tracking branch 'spi/topic/bpw' into spi-nextMark Brown
2013-06-10spi: spi-xilinx: cleanup a check in xilinx_spi_txrx_bufs()dan.carpenter@oracle.com
'!' has higher precedence than comparisons so the original condition is equivalent to "if (xspi->remaining_bytes == 0)". This makes the static checkers complain. xspi->remaining_bytes is signed and from looking at the code briefly, I think it might be able to go negative. I suspect that going negative may cause a bug, but I don't have the hardware and can't test. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-04spi: spi-xilinx: Remove redundant platform_set_drvdata()Sachin Kamat
Setting platform data to NULL is not necessary. Also fixes the following sparse warning: drivers/spi/spi-xilinx.c:508:35: warning: Using plain integer as NULL pointer Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-04spi: spi-xilinx: Add run run-time endian detectionMichal Simek
Do not load endian value from platform data and rather autodetect it. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-04spi: spi-xilinx: Remove ISR race conditionPeter Crosthwaite
The ISR currently consumes the rx buffer data and re-enables transmission from within interrupt context. This is bad because if the interrupt occurs again before the ISR exits, the new interrupt will be erroneously cleared by the still completing ISR. Simplified the ISR by just setting the completion variable and exiting with no action. Then just looped the transmit functionality in xilinx_spi_txrx_bufs(). Signed-off-by: Peter Crosthwaite <peter.crosthwaite@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-05-29spi: convert drivers to use bits_per_word_maskStephen Warren
Fill in the recently added spi_master.bits_per_word_mask field in as many drivers as possible. Make related cleanups, such as removing any redundant error-checking, or empty setup callbacks. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-12-07spi: Remove HOTPLUG section attributesGrant Likely
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Bill Pemberton has done most of the legwork on this series. I've used his script to purge the attributes from the drivers/gpio tree. Reported-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-10-25drivercore: Add helper macro for platform_driver boilerplateGrant Likely
For simple modules that contain a single platform_driver without any additional setup code then ends up being a block of duplicated boilerplate. This patch adds a new macro, module_platform_driver(), which replaces the module_init()/module_exit() registrations with template functions. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Reviewed-by: Magnus Damm <magnus.damm@gmail.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
2011-06-06spi: reorganize driversGrant Likely
Sort the SPI makefile and enforce the naming convention spi_*.c for spi drivers. This change also rolls the contents of atmel_spi.h into the .c file since there is only one user of that particular include file. v2: - Use 'spi-' prefix instead of 'spi_' to match what seems to be be the predominant pattern for subsystem prefixes. - Clean up filenames in Kconfig and header comment blocks Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Linus Walleij <linus.walleij@linaro.org>
