path: root/drivers/spi/spi-sirf.c
2013-09-01Merge remote-tracking branch 'spi/topic/sirf' into spi-nextMark Brown
2013-08-29spi: Use dev_get_drvdata at appropriate placesAxel Lin
Use dev_get_drvdata() instead of platform_get_drvdata(to_platform_device(dev)). Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-08-26spi/sirf: fix the misunderstanding about len of spi_transferQipan Li
the unit of len of spi_transfer is in bytes, not in spi words. the old codes misunderstood that and thought the len is the amount of spi words. but it is actually how many bytes existing in the spi buffer. this patch fixes that and also rename left_tx_cnt and left_rx_cnt to left_tx_word and left_rx_word to highlight they are in words. Signed-off-by: Qipan Li <Qipan.Li@csr.com> Signed-off-by: Barry Song <Baohua.Song@csr.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-08-23spi: sirf: fix error return code in spi_sirfsoc_probe()Wei Yongjun
Fix to return a negative error code from the error handling case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-08-14spi/sirf: simplify use of devm_ioremap_resourceJulia Lawall
Remove unneeded error handling on the result of a call to platform_get_resource when the value is passed to devm_ioremap_resource. Move the call to platform_get_resource adjacent to the call to devm_ioremap_resource to make the connection between them more clear. A simplified version of the semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression pdev,res,n,e,e1; expression ret != 0; identifier l; @@ - res = platform_get_resource(pdev, IORESOURCE_MEM, n); ... when != res - if (res == NULL) { ... \(goto l;\|return ret;\) } ... when != res + res = platform_get_resource(pdev, IORESOURCE_MEM, n); e = devm_ioremap_resource(e1, res); // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Barry Song <Baohua.Song@csr.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-08-06spi: sirf: use DMA if both buffer address and length are alignedBarry Song
this patch enables DMA support for SiRFSoC SPI driver, if both buffers and length are aligned with DMA controller's hardware limitation, use generic SiRF generic dmaengine driver. for PIO, SiRF SPI controller actually is using rx to trigger rx, that means if we write any word to tx fifo, we will get a word from rx fifo. for DMA, we use two different channel for tx and rx, and issue them both for every transfer. Signed-off-by: Barry Song <Baohua.Song@csr.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-15spi: sirf: add missed spi mode_bits that SiRFSoC hardware supportsQipan Li
Missing this will cause some user cases fail when they want to change spi transfer mode. Signed-off-by: Qipan Li <Qipan.Li@csr.com> Signed-off-by: Barry Song <Baohua.Song@csr.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-26Merge remote-tracking branch 'spi/topic/sirf' into spi-nextMark Brown
2013-06-03spi: sirf: avoid uninitialized-use warningArnd Bergmann
24778be20 "spi: convert drivers to use bits_per_word_mask" removed the "default" statement in the spi_sirfsoc_setup_transfer switch, causing a new warning: drivers/spi/spi-sirf.c: In function 'spi_sirfsoc_setup_transfer': arch/arm/include/asm/io.h:90:2: warning: 'rxfifo_ctrl' may be used uninitialized in this function [-Wmaybe-uninitialized] asm volatile("str %1, %0" ^ drivers/spi/spi-sirf.c:364:19: note: 'rxfifo_ctrl' was declared here u32 txfifo_ctrl, rxfifo_ctrl; ^ The compiler has correctly identified that this case may happen, but since we know that things are horribly broken if bits_per_word is ever something other than the values we tested, calling BUG() is an appropriate action and tells the compiler that execution will not continue afterwards. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-05-29spi: convert drivers to use bits_per_word_maskStephen Warren
Fill in the recently added spi_master.bits_per_word_mask field in as many drivers as possible. Make related cleanups, such as removing any redundant error-checking, or empty setup callbacks. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-20spi: sirf: fix the issue while transferring more than 256 wordsQipan Li
currently, spi irq handler only does rx processing and fetching data from rx fifo when "FRM_END" irq happens. FRM_END indicates one transfer completes. if rx size is less than 256, it works well. but the problem is that spi rx fifo size is only 256 bytes, then if data size of one frame is more than 256, before FRM_END comes, rx fifo will be filled with RXFIFO_OFLOW overflow interrupt, it will make us lose some data due to fifo overflow. Explicitly we need do fetch work from device rx fifo in irq handler not only in "FRM_END" irq but also in "THD_REACH" irq. THD_REACH means rx fifo has come to its threshold and will come to overflow if we don't take data from it in time. In this patch, we fix this issue. we take data from rx fifo when either FRM_END or RX_THD_REACH irq comes, we put data into tx fifo when either TX_FIFO_EMPTY or TX_THD_REACH irq comes. Signed-off-by: Qipan Li <Qipan.Li@csr.com> Signed-off-by: Zhiwu Song <Zhiwu.Song@csr.com> Signed-off-by: Barry Song <Baohua.Song@csr.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-13spi/sirf: Let device core handle pinctrlMark Brown
Since commit ab78029 (drivers/pinctrl: grab default handles from device core) we can rely on device core for handling pinctrl so remove devm_pinctrl_get_select_default() from the driver. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Barry Song <baohua.song@csr.com>
2013-04-23spi/sirf: fix MODULE_DEVICE_TABLEArnd Bergmann
This fixes building the spi-sirf driver as a loadable module, which uses an incorrect MODULE_DEVICE_TABLE, by changing the reference to the correct symbol. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-05spi/sirf: add support for new SiRFmarco SMP SoCBarry Song
the driver is also compatible with SiRFmarco except SiRFprimaII, so simply add "sirf,marco-spi" to OF match table. Signed-off-by: Barry Song <Baohua.Song@csr.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2013-02-05spi/sirf: use clk_prepare_enable and clk_disable_unprepareBarry Song
Convert clk_enable/clk_disable to clk_prepare_enable/clk_disable_unprepare calls as required by common clock framework. Signed-off-by: Barry Song <Baohua.Song@csr.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2013-02-05spi: remove check for bits_per_word on transfer from low level driverLaxman Dewangan
The spi core make sure that each transfer structure have the proper setting for bits_per_word before calling low level transfer APIs. Hence it is no more require to check again in low level driver for this field whether this is set correct or not. Removing such code from low level driver. The txx9 change also removes a test for bits_per_word set to 0, and forcing it to 8 in that case. This can also be removed now since spi_setup() ensures spi->bits_per_word is not zero. if (!spi->bits_per_word) spi->bits_per_word = 8; Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2013-01-25spi: Convert to devm_ioremap_resource()Thierry Reding
Convert all uses of devm_request_and_ioremap() to the newly introduced devm_ioremap_resource() which provides more consistent error handling. devm_ioremap_resource() provides its own error messages so all explicit error messages can be removed from the failure code paths. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-07spi: Remove HOTPLUG section attributesGrant Likely
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Bill Pemberton has done most of the legwork on this series. I've used his script to purge the attributes from the drivers/gpio tree. Reported-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-05-19SPI: PRIMA2: use the newest APIs of PINCTRL to fix compiling errorsBarry Song
Fix the compiling errors: drivers/spi/spi-sirf.c: In function 'spi_sirfsoc_probe': drivers/spi/spi-sirf.c:563: error: implicit declaration of function 'pinmux_get' drivers/spi/spi-sirf.c:563: warning: assignment makes pointer from integer without a cast drivers/spi/spi-sirf.c:568: error: implicit declaration of function 'pinmux_enable' drivers/spi/spi-sirf.c:602: error: implicit declaration of function 'pinmux_disable' drivers/spi/spi-sirf.c:603: error: implicit declaration of function 'pinmux_put' make[3]: *** [drivers/spi/spi-sirf.o] Error 1 Signed-off-by: Barry Song <Baohua.Song@csr.com> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-03-09SPI: add CSR SiRFprimaII SPI controller driverZhiwu Song
CSR SiRFprimaII has two SPIs (SPI0 and SPI1). Features: * Master and slave modes * 8-/12-/16-/32-bit data unit * 256 bytes receive data FIFO and 256 bytes transmit data FIFO * Multi-unit frame * Configurable SPI_EN (chip select pin) active state * Configurable SPI_CLK polarity * Configurable SPI_CLK phase * Configurable MSB/LSB first Signed-off-by: Zhiwu Song <zhiwu.song@csr.com> Signed-off-by: Barry Song <Baohua.Song@csr.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
