There are two SPI controllers exported by PCI subsystem for Intel Quark X1000.
The SPI memory mapped I/O registers supported by Quark are different from
the current implementation, and Quark only supports the registers of 'SSCR0',
'SSCR1', 'SSSR', 'SSDR', and 'DDS_RATE'. This patch is to enable the SPI for
Intel Quark X1000.
This piece of work is derived from Dan O'Donovan's initial work for Intel Quark
X1000 SPI enabling.
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Signed-off-by: Weike Chen <alvin.chen@intel.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
Pull slave-dmaengine updates from Vinod Koul:
"For dmaengine contributions we have:
- designware cleanup by Andy
- my series moving device_control users to dmanegine_xxx APIs for
later removal of device_control API
- minor fixes spread over drivers mainly mv_xor, pl330, mmp, imx-sdma
etc"
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (60 commits)
serial: atmel: add missing dmaengine header
dmaengine: remove FSLDMA_EXTERNAL_START
dmaengine: freescale: remove FSLDMA_EXTERNAL_START control method
carma-fpga: move to fsl_dma_external_start()
carma-fpga: use dmaengine_xxx() API
dmaengine: freescale: add and export fsl_dma_external_start()
dmaengine: add dmaengine_prep_dma_sg() helper
video: mx3fb: use dmaengine_terminate_all() API
serial: sh-sci: use dmaengine_terminate_all() API
net: ks8842: use dmaengine_terminate_all() API
mtd: sh_flctl: use dmaengine_terminate_all() API
mtd: fsmc_nand: use dmaengine_terminate_all() API
V4L2: mx3_camer: use dmaengine_pause() API
dmaengine: coh901318: use dmaengine_terminate_all() API
pata_arasan_cf: use dmaengine_terminate_all() API
dmaengine: edma: check for echan->edesc => NULL in edma_dma_pause()
dmaengine: dw: export probe()/remove() and Co to users
dmaengine: dw: enable and disable controller when needed
dmaengine: dw: always export dw_dma_{en,dis}able
dmaengine: dw: introduce dw_dma_on() helper
Instead of one port we have 3 ports and all of them can take advantage of
the shared DMA controller.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Mark Brown <broonie@linaro.org>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
That field has been deprecated in favour of getting the necessary
information from ACPI/DT.
However, we still need to deal systems that are PCI only (no ACPI to back
up). In order to support such systems, we allow the DMA filter function and
its corresponding parameter via pxa2xx_spi_master platform data. Then when
the pxa2xx_spi_dma_setup() doesn't find the channel via ACPI, it falls back
to use the given filter function.
Suggested-by: Arnd Bergmann <arnd@arndb.de>
There is no need to unset driver data pointer at removal stage.
Signed-off-by: Mark Brown <broonie@linaro.org>
SPI PXA2XX core layer has dependency on common clock framework
to obtain information on host supported clock rate. Thus, we
setup the clock device in the PCI glue layer to enable PCI mode
host pass in the clock rate information.
Signed-off-by: Chew, Chiau Ee <chiau.ee.chew@intel.com>
Acked-by: Kweh, Hock Leong <hock.leong.kweh@intel.com>
Similar to CE4100, BayTrail LPSS SPI can be PCI enumerated
as well. Thus, the functions are renamed from ce4100_xxx
to pxa2xx_spi_pci_xxx to clarify that this is a generic
PCI glue layer. Also, added required infrastructure to
support SPI hosts with different configurations.
This patch is based on Mika Westerberg's previous work.
Don't use DEFINE_PCI_DEVICE_TABLE macro, because this macro
is not preferred.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
The function returns 0 on success and negative errno in case of failure.
Fix this.
In case of error, the function platform_device_register_full()
returns ERR_PTR() and never returns NULL. The NULL test in the
return value check should be replaced with IS_ERR().
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
The spi-pxa2xx-pci glue driver had to implement pxa_ssp_request()/free() in
order to support the spi-pxa2xx platform driver. Since the ACPI enabled
platforms can use the same platform driver we would need to implement
pxa_ssp_request()/free() in some central place that can be shared by the
ACPI and PCI glue code.
Instead of doing that we can make pxa_ssp_request()/free() to be available
only when CONFIG_ARCH_PXA is set. On other arches these are being stubbed
out in preference to passing the ssp_device from the platform data
directly.
We also change the SPI bus number to be taken from ssp->port_id instead of
platform device id. This way the supporting code that passes the ssp can
decide the number (or it can set it to the same as pdev->id).
Instead of open-coding all the error management in the driver we can take
advantage of the pcim_* interfaces that release the resources automatically.
We also use platform_device_register_full() to register the platform device
because it allows us to create and register the platform device at one go,
simplifying the error management.
This a preparatory step for getting rid of pxa_ssp_request()/free() which
we will do in the next patch.
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Bill Pemberton has done most of the legwork on this series. I've used
his script to purge the attributes from the drivers/gpio tree.
Reported-by: Bill Pemberton <wfp5p@virginia.edu>
This patch converts the drivers in drivers/spi/* to use module_pci_driver()
macro which makes the code smaller and a bit simpler.
Convert static struct pci_device_id *[] to static DEFINE_PCI_DEVICE_TABLE
tables.
We are clipping down the presence of module.h, since it was
everywhere. If you really need it, you better call it out,
as per this changeset.
Sort the SPI makefile and enforce the naming convention spi_*.c for
spi drivers.
This change also rolls the contents of atmel_spi.h into the .c file
since there is only one user of that particular include file.
v2: - Use 'spi-' prefix instead of 'spi_' to match what seems to be
be the predominant pattern for subsystem prefixes.
- Clean up filenames in Kconfig and header comment blocks
