path: root/drivers/spi/spi-ppc4xx.c
2017-01-17spi/ppc4xx: Use kcalloc() in spi_ppc4xx_of_probe()Markus Elfring
* A multiplication for the size determination of a memory allocation indicated that an array data structure should be processed. Thus reuse the corresponding function "kcalloc". This issue was detected by using the Coccinelle software. * Replace the specification of a data type by a pointer dereference to make the corresponding size determination a bit safer according to the Linux coding style convention. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Mark Brown <broonie@kernel.org>
2017-01-17spi/ppc4xx: Combine substrings for a message in spi_ppc4xx_of_probe()Markus Elfring
The script "checkpatch.pl" pointed information out like the following. WARNING: quoted string split across lines Thus fix the affected source code place. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-09-17spi: bitbang: Replace spinlock by mutexNicolas Boichat
chipselect (in the case of spi-gpio: spi_gpio_chipselect, which calls gpiod_set_raw_value_cansleep) can sleep, so we should not hold a spinlock while calling it from spi_bitbang_setup. This issue was introduced by this commit, which converted spi-gpio to cansleep variants: d9dda5a191 "spi: spi-gpio: Use 'cansleep' variants to access GPIO" Replacing the lock variable by a mutex fixes the issue: This is safe as all instances where the lock is used are called from contexts that can sleep. Finally, update spi-ppc4xx and and spi-s3c24xx to use mutex functions, as they directly hold the lock for similar purpose. Signed-off-by: Nicolas Boichat <drinkcat@chromium.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-10-20spi: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-02-03spi: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-11-12Merge tag 'devicetree-for-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree updates from Rob Herring: "DeviceTree updates for 3.13. This is a bit larger pull request than usual for this cycle with lots of clean-up. - Cross arch clean-up and consolidation of early DT scanning code. - Clean-up and removal of arch prom.h headers. Makes arch specific prom.h optional on all but Sparc. - Addition of interrupts-extended property for devices connected to multiple interrupt controllers. - Refactoring of DT interrupt parsing code in preparation for deferred probe of interrupts. - ARM cpu and cpu topology bindings documentation. - Various DT vendor binding documentation updates" * tag 'devicetree-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (82 commits) powerpc: add missing explicit OF includes for ppc dt/irq: add empty of_irq_count for !OF_IRQ dt: disable self-tests for !OF_IRQ of: irq: Fix interrupt-map entry matching MIPS: Netlogic: replace early_init_devtree() call of: Add Panasonic Corporation vendor prefix of: Add Chunghwa Picture Tubes Ltd. vendor prefix of: Add AU Optronics Corporation vendor prefix of/irq: Fix potential buffer overflow of/irq: Fix bug in interrupt parsing refactor. of: set dma_mask to point to coherent_dma_mask of: add vendor prefix for PHYTEC Messtechnik GmbH DT: sort vendor-prefixes.txt of: Add vendor prefix for Cadence of: Add empty for_each_available_child_of_node() macro definition arm/versatile: Fix versatile irq specifications. of/irq: create interrupts-extended property microblaze/pci: Drop PowerPC-ism from irq parsing of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code. of/irq: Use irq_of_parse_and_map() ...
2013-11-11powerpc: add missing explicit OF includes for ppcdevicetree-for-3.13Rob Herring
Commit b5b4bb3f6a11f9 (of: only include prom.h on sparc) removed implicit includes of of_*.h headers by powerpc's prom.h. Some components were missed in initial clean-up patch, so add the necessary includes to fix powerpc builds. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Tejun Heo <tj@kernel.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: "David S. Miller" <davem@davemloft.net> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-ide@vger.kernel.org Cc: linux-crypto@vger.kernel.org
2013-09-17spi: bitbang: Let spi_bitbang_start() take a reference to masterAxel Lin
Many drivers that use bitbang library have a leak on probe error paths. This is because once a spi_master_get() call succeeds, we need an additional spi_master_put() call to free the memory. Fix this issue by moving the code taking a reference to master to spi_bitbang_start(), so spi_bitbang_start() will take a reference to master on success. With this change, the caller is responsible for calling spi_bitbang_stop() to decrement the reference and spi_master_put() as counterpart of spi_alloc_master() to prevent a memory leak. So now we have below patten for drivers using bitbang library: probe: spi_alloc_master -> Init reference count to 1 spi_bitbang_start -> Increment reference count remove: spi_bitbang_stop -> Decrement reference count spi_master_put -> Decrement reference count (reference count reaches 0) Fixup all users accordingly. Signed-off-by: Axel Lin <axel.lin@ingics.com> Suggested-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Acked-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-26Merge remote-tracking branch 'spi/topic/pdata' into spi-nextMark Brown
2013-05-29spi: convert drivers to use bits_per_word_maskStephen Warren
Fill in the recently added spi_master.bits_per_word_mask field in as many drivers as possible. Make related cleanups, such as removing any redundant error-checking, or empty setup callbacks. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-23spi: use platform_{get,set}_drvdata()Jingoo Han
Use the wrapper functions for getting and setting the driver data using platform_device instead of using dev_{get,set}_drvdata() with &pdev->dev, so we can directly pass a struct platform_device. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-02-20Merge tag 'dt-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull device tree changes from Grant Likely: "All around device tree changes destined for v3.8. Aside from the documentation updates the highlights in this branch include: - Kbuild changes for using CPP with .dts files - locking fix from preempt_rt patchset - include DT alias names in device uevent - Selftest bugfixes and improvements - New function for counting phandles stanzas in a property - constify argument to of_node_full_name() - Various bug fixes This tree did also contain a commit to use platform_device_add instead of open-coding the device add code, but it caused problems with amba devices and needed to be reverted." * tag 'dt-for-linus' of git://git.secretlab.ca/git/linux: (23 commits) Revert "of: use platform_device_add" kbuild: limit dtc+cpp include path gpio: Make of_count_named_gpios() use new of_count_phandle_with_args() of: Create function for counting number of phandles in a property of/base: Clean up exit paths for of_parse_phandle_with_args() of/selftest: Use selftest() macro throughout of/selftest: Fix GPIOs selftest to cover the 7th case of: fix recursive locking in of_get_next_available_child() documentation/devicetree: Fix a typo in exynos-dw-mshc.txt OF: convert devtree lock from rw_lock to raw spinlock of/exynos_g2d: Add Bindings for exynos G2D driver kbuild: create a rule to run the pre-processor on *.dts files input: Extend matrix-keypad device tree binding devicetree: Move NS2 LEDs binding into LEDs directory of: use platform_device_add powerpc/5200: Fix size to request_mem_region() call documentation/devicetree: Fix typos of: add 'const' to of_node_full_name parameter of: Output devicetree alias names in uevent DT: add vendor prefixes for Renesas and Toshiba ...
2013-02-13gpio: Make of_count_named_gpios() use new of_count_phandle_with_args()Grant Likely
This patch replaces the horribly coded of_count_named_gpios() with a call to of_count_phandle_with_args() which is far more efficient. This also changes the return value of of_gpio_count() & of_gpio_named_count() from 'unsigned int' to 'int' so that it can return an error code. All the users of that function are fixed up to correctly handle a negative return value. v2: Split GPIO portion into a separate patch Tested-by: Andreas Larsson <andreas@gaisler.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Rob Herring <rob.herring@calxeda.com>
2013-02-05spi: Remove erroneous __init, __exit and __exit_p() references in driversGrant Likely
Some of the spi driver module remove hooks were annotated with __exit and referenced with __exit_p(). Presumably these were supposed to be __devinit, __devexit and __devexit_p() since __init/__exit for a probe/remove hook has never been correct. They also got missed during the big __devinit/__devexit purge since they didn't match the pattern. Remove then now to be rid of it. v2: purge __init also Reported-by: Arnd Bergmann <arnd@arndb.de> [Arnd set a patch cleaning up one, and then I found more] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-09-01spi: fix comment/printk typos in spiMasanari Iida
Correct spelling typo in drivers/spi Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-05-19spi: By default setup spi_masters with 1 chipselect and dynamics bus numberGrant Likely
Trivial simplification. Instead of requiring spi master drivers to always set the bus number (even when a dynamic number is desired), this patch modifies spi_alloc_master() to initialize num_chipselect to 1 (because there will always be at least one CS) and bus_num to -1 for dynamic allocation. This simplifies the code needed to be written for drivers. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-04-13spi/devicetree: Move devicetree support code into spi directoryGrant Likely
The SPI device tree support code isn't shared by any other subsystem. It can be moved into the core drivers/spi directory and the exported symbol can be removed. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com>
2011-10-25drivercore: Add helper macro for platform_driver boilerplateGrant Likely
For simple modules that contain a single platform_driver without any additional setup code then ends up being a block of duplicated boilerplate. This patch adds a new macro, module_platform_driver(), which replaces the module_init()/module_exit() registrations with template functions. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Reviewed-by: Magnus Damm <magnus.damm@gmail.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
2011-10-24spi: irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-10spi: Convert uses of struct resource * to resource_size(ptr)Joe Perches
Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-06spi: reorganize driversGrant Likely
Sort the SPI makefile and enforce the naming convention spi_*.c for spi drivers. This change also rolls the contents of atmel_spi.h into the .c file since there is only one user of that particular include file. v2: - Use 'spi-' prefix instead of 'spi_' to match what seems to be be the predominant pattern for subsystem prefixes. - Clean up filenames in Kconfig and header comment blocks Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Linus Walleij <linus.walleij@linaro.org>
