Pull ARM DMA engine updates from Russell King:
"This looks scary at first glance, but what it is is:
- a rework of the sa11x0 DMA engine driver merged during the previous
cycle, to extract a common set of helper functions for DMA engine
implementations.
- conversion of amba-pl08x.c to use these helper functions.
- addition of OMAP DMA engine driver (using these helper functions),
and conversion of some of the OMAP DMA users to use DMA engine.
Nothing in the helper functions is ARM specific, so I hope that other
implementations can consolidate some of their code by making use of
these helpers.
This has been sitting in linux-next most of the merge cycle, and has
been tested by several OMAP folk. I've tested it on sa11x0 platforms,
and given it my best shot on my broken platforms which have the
amba-pl08x controller.
The last point is the addition to feature-removal-schedule.txt, which
will have a merge conflict. Between myself and TI, we're planning to
remove the old TI DMA implementation next year."
Fix up trivial add/add conflicts in Documentation/feature-removal-schedule.txt
and drivers/dma/{Kconfig,Makefile}
* 'dmaengine' of git://git.linaro.org/people/rmk/linux-arm: (53 commits)
ARM: 7481/1: OMAP2+: omap2plus_defconfig: enable OMAP DMA engine
ARM: 7464/1: mmc: omap_hsmmc: ensure probe returns error if DMA channel request fails
Add feature removal of old OMAP private DMA implementation
mtd: omap2: remove private DMA API implementation
mtd: omap2: add DMA engine support
spi: omap2-mcspi: remove private DMA API implementation
spi: omap2-mcspi: add DMA engine support
ARM: omap: remove mmc platform data dma_mask and initialization
mmc: omap: remove private DMA API implementation
mmc: omap: add DMA engine support
mmc: omap_hsmmc: remove private DMA API implementation
mmc: omap_hsmmc: add DMA engine support
dmaengine: omap: add support for cyclic DMA
dmaengine: omap: add support for setting fi
dmaengine: omap: add support for returning residue in tx_state method
dmaengine: add OMAP DMA engine driver
dmaengine: sa11x0-dma: add cyclic DMA support
dmaengine: sa11x0-dma: fix DMA residue support
dmaengine: PL08x: ensure all descriptors are freed when channel is released
dmaengine: PL08x: get rid of write only pool_ctr and free_txd locking
Remove the private DMA API implementation from spi-omap2-mcspi.c,
making it use entirely the DMA engine API.
Add DMA engine support to the OMAP SPI driver. This supplements the
private DMA API implementation contained within this driver, and the
driver can be independently switched at build time between using DMA
engine and the private DMA API for the transmit and receive sides.
Tested-by: Shubhrajyoti <shubhrajyoti@ti.com>
This warning recently appeared with omap2plus_defconfig:
WARNING: drivers/spi/built-in.o(.devinit.text+0x3c4): Section mismatch in reference from the function omap2_mcspi_probe() to the function .init.text:omap2_mcspi_master_setup()
The function __devinit omap2_mcspi_probe() references
a function __init omap2_mcspi_master_setup().
If omap2_mcspi_master_setup is only used by omap2_mcspi_probe then
annotate omap2_mcspi_master_setup with a matching annotation.
The fix is obviously to mark the omap2_mcspi_master_setup function as
__devinit, rather than __init.
Signed-off-by: Shubhrajyoti D <shubhrajyoti@ti.com>
The dma_map and dma_unmap should have same parameter
passed otherwise we get the below warn.
ks8851 spi1.0: DMA-API: device driver tries to free DMA memory it has not allocated [device address=0x000000009f22]
[ 2.066925] Modules linked in:
[ 2.070312]
[ 2.071929] [<c001c250>] (unwind_backtrace+0x0/0x130) from [<c0043d84>] (warn_slowpath_common+0x4c/0x64)
[ 2.081909] [<c0043d84>] (warn_slowpath_common+0x4c/0x64) from [<c0043e30>] (warn_slowpath_fmt+0x30/0x40)
[ 2.091949] [<c0043e30>] (warn_slowpath_fmt+0x30/0x40) from [<c0293824>] (check_unmap+0x6d0/0x7b0)
[ 2.101348] [<c0293824>] (check_unmap+0x6d0/0x7b0) from [<c02939cc>] (debug_dma_unmap_page+0x64/0x70)
[ 2.111053] [<c02939cc>] (debug_dma_unmap_page+0x64/0x70) from [<c03519a4>] (omap2_mcspi_txrx_dma+0x2d8/0x4fc)
[ 2.121582] [<c03519a4>] (omap2_mcspi_txrx_dma+0x2d8/0x4fc) from [<c03524d8>] (omap2_mcspi_work.clone.4+0xf0/0x290)
[ 2.132537] [<c03524d8>] (omap2_mcspi_work.clone.4+0xf0/0x290) from [<c0352900>] (omap2_mcspi_transfer_one_message+0x288/0x438)
[ 2.144592] [<c0352900>] (omap2_mcspi_transfer_one_message+0x288/0x438) from [<c03503bc>] (spi_pump_messages+0x100/0x160)
[ 2.156127] [<c03503bc>] (spi_pump_messages+0x100/0x160) from [<c006635c>] (kthread_worker_fn+0xac/0x180)
[ 2.166168] [<c006635c>] (kthread_worker_fn+0xac/0x180) from [<c0066578>] (kthread+0x90/0x9c)
[ 2.175140] [<c0066578>] (kthread+0x90/0x9c) from [<c00157fc>] (kernel_thread_exit+0x0/0x8)
[ 2.183898] ---[ end trace d1830ce6e44292f2 ]---
Fix the warn by changing the unmap parameter.
Reported-by: Russell King - ARM Linux <linux@arm.linux.org.uk>
1a77b127ae (OMAP : SPI : use devm_* functions) converted the SPI
device controller state to use devm_kzalloc(). Unfortunately, this
is used against an unbound struct device, which results in the
following when the device is bound to its driver:
WARNING: at /home/rmk/git/linux-rmk/drivers/base/dd.c:257 driver_probe_device+0x78/0x21c()
Modules linked in:
Backtrace:
[<c0017d0c>] (dump_backtrace+0x0/0x10c) from [<c033e208>] (dump_stack+0x18/0x1c) r7:00000000 r6:c01ff28c r5:c040050c r4:00000101
[<c033e1f0>] (dump_stack+0x0/0x1c) from [<c00337ec>] (warn_slowpath_common+0x58/0x70)
[<c0033794>] (warn_slowpath_common+0x0/0x70) from [<c0033828>] (warn_slowpath_null+0x24/0x2c)
[<c0033804>] (warn_slowpath_null+0x0/0x2c) from [<c01ff28c>] (driver_probe_device+0x78/0x21c)
[<c01ff214>] (driver_probe_device+0x0/0x21c) from [<c01ff49c>] (__driver_attach+0x6c/0x90)
[<c01ff430>] (__driver_attach+0x0/0x90) from [<c01fda70>] (bus_for_each_dev+0x58/0x98)
[<c01fda18>] (bus_for_each_dev+0x0/0x98) from [<c01ff0f4>] (driver_attach+0x20/0x28)
[<c01ff0d4>] (driver_attach+0x0/0x28) from [<c01fe2f4>] (bus_add_driver+0xb4/0x230)
[<c01fe240>] (bus_add_driver+0x0/0x230) from [<c01ffb24>] (driver_register+0xac/0x138)
[<c01ffa78>] (driver_register+0x0/0x138) from [<c0215d4c>] (spi_register_driver+0x4c/0x60)
[<c0215d00>] (spi_register_driver+0x0/0x60) from [<c045414c>] (ks8851_init+0x14/0x1c)
[<c0454138>] (ks8851_init+0x0/0x1c) from [<c0008770>] (do_one_initcall+0x9c/0x164)
[<c00086d4>] (do_one_initcall+0x0/0x164) from [<c0436410>] (kernel_init+0x128/0x210)
[<c04362e8>] (kernel_init+0x0/0x210) from [<c0038754>] (do_exit+0x0/0x72c)
---[ end trace 4dcda79f5e89dd84 ]---
ks8851 spi1.0: message enable is 0
ks8851 spi1.0: eth0: revision 0, MAC 08:00:28:01:4d:c6, IRQ 194, has EEPROM
Fix this by partially reverting the original commit.
This patch converts the OMAP SPI driver to use the SPI infrastructure
pump message queue.Also fixes the below warning.
master is unqueued, this is deprecated
Trivial optimisation of tmp variable by directly writing the value
to the register.
Cc: Tarun Kanti DebBarma <tarun.kanti@ti.com>
Adds support for configuring the omap2-mcspi driver use autosuspend for
runtime power management. This can reduce the latency in starting an
spi transfer by not suspending the device immediately following
completion of a transfer. If another transfer then takes place before
the autosuspend timeout (2 secs), the call to resume the device can
return immediately saving some save/ restore cycles.
Acked-by: Govindraj.R <govindraj.raja@ti.com>
bus_num was used to reference the mcspi controller instance in a fixed array.
Remove this array and store this information directly inside drvdata structure.
bus_num is now just set if the pdev->id is present or with -1 for dynamic
allocation by SPI core, but the driver does not access it anymore.
Clean some bad comments format, and remove un-needed space.
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
[Cleanup the OMAP2_MCSPI_MAX_CTRL macro as it is not needed anymore]
The various devm_* functions allocate memory that is released when a driver
detaches. This patch uses devm_request_and_ioremap
to request memory in probe function. Since the freeing is not
needed the calls are deleted from remove function.Also use
use devm_kzalloc for the cs memory allocation.
this will delete a few lines of code, no functional
changes.
Signed-off-by: Felipe Balbi <balbi@ti.com>
move probe away from __init section and use
platform_driver_register() instead of
platform_driver_probe().
Add device tree support to the OMAP2+ McSPI driver.
Add the bindings documentation.
Based on original code from Rajendra.
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Rajendra Nayak <rnayak@ti.com>
Currently McSPI driver doesnt follow correct failure fallback steps
attempting to correct the same.
Also:
- label names changed to give meaningful names.
- Setting the driver data to NULL in remove
Signed-off-by: Hebbar, Gururaja <gururaja.hebbar@ti.com>
omap mcspi probe() doesnt call pm_runtime disable functions
in case of failure. remove() doesnt call pm_runtime disable. This could
lead to warnings as below on subsequent insmod.
~# insmod spi-omap2-mcspi.ko
[ 255.383671] omap2_mcspi omap2_mcspi.1: Unbalanced pm_runtime_enable!
This patch adds the pm_runtime disable() at appropriate stages.
Currently all the spi controllers share the work queue.
This patch allocates a work queue per controller.
Signed-off-by: Steve Wilkins <steve.wilkins@raymarine.com>
Currently there is a request_mem_region(r->start, ..
followed by r->start += pdata->regs_offset;
And then in remove
r = platform_get_resource(pdev, IORESOURCE_MEM, 0);
release_mem_region(r->start, resource_size(r));
Here the offset addition is not taken care. Fix the code for the
same.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
Sort the SPI makefile and enforce the naming convention spi_*.c for
spi drivers.
This change also rolls the contents of atmel_spi.h into the .c file
since there is only one user of that particular include file.
v2: - Use 'spi-' prefix instead of 'spi_' to match what seems to be
be the predominant pattern for subsystem prefixes.
- Clean up filenames in Kconfig and header comment blocks
