path: root/drivers/spi/spi-omap-100k.c
2014-10-20spi: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-08-16spi: omap-100k: Remove unused definitionsNick Krause
Remove unused definition which cause the following warnings drivers/spi/spi-omap-100k.c:73:0: warning: "WRITE" redefined [enabled by default] include/linux/fs.h:193:0: note: this is the location of the previous definition drivers/spi/spi-omap-100k.c:74:0: warning: "READ" redefined [enabled by default] include/linux/fs.h:192:0: note: this is the location of the previous definition Signed-off-by: Nick Krause <xerofoiffy@gmail.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-06-06spi: omap-100k: Remove unnecessary platform_set_drvdata()Alexander Shiyan
Drop call to platform_set_drvdata() as driver data is not used anywhere in the driver. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-03-29spi: omap-100k: Fix memory leakAxel Lin
The memory allocated for cs is not freed anywhere. Convert to use devm_kzalloc to fix the memory leak. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-03-05spi: omap-100k: fix spacing coding style issueJingoo Han
Fix the following checkpatch issues. ERROR: space prohibited after that open parenthesis '(' ERROR: space required before the open parenthesis '(' ERROR: trailing statements should be on next line ERROR: space required after that ',' (ctx:VxV) ERROR: spaces required around that '-=' (ctx:VxV) WARNING: sizeof *cs should be sizeof(*cs) Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-10spi: omap-100k: Remove unused fields from struct omap1_spi100kAxel Lin
Both *master and state are not really used, remove them. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-10spi: omap-100k: Remove unused pointer in omap1_spi100k_txrx_pio()Christian Engelmayer
Remove unused devdata pointer 'spi100k' in function omap1_spi100k_txrx_pio(). Detected by Coverity: CID 1077869. Signed-off-by: Christian Engelmayer <cengelma@gmx.at> Reviewed-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-10spi: omap-100k: Remove unused MOD_REG_BIT macroAxel Lin
2013-12-02spi: omap-100k: remove pointless _remove functionMichal Nazarewicz
Commit [8074cf06: use devm_spi_register_master()] removed the last bit of omap1_spi100k_remove function that had side effects. After call to spi_unregister_master was removed, the function consisted of: 2. call to platform_get_drvdata whose return value was only used in: 2. call to spi_master_get_devdata whose return value was not used, 3. an if statement checking if zero was not zero, and 4. call to platform_get_resource whose return value was not used. Ah, yes, and of course, final return 0. ;) Since omap1_spi100k_remove no longer does anything, it can be safely removed. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-26spi: omap-100k: use devm_spi_register_master()Jingoo Han
Use devm_spi_register_master() to make cleanup paths simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-01Merge remote-tracking branch 'spi/topic/pdata' into spi-nextMark Brown
2013-08-29spi: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-15spi/omap-100k: Convert to module_platform_driver()Mark Brown
2013-07-15spi/omap-100k: Prepare and unprepare clocksMark Brown
2013-07-15spi/omap-100k: Convert to devm_clk_get()Mark Brown
2013-07-15spi/omap-100k: Convert to use core message queue implementationMark Brown
Saves some code duplication and gets us the benefits of any improvements in the core code. Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-15spi/omap-100k: Factor message transfer function out of work queueMark Brown
In preparation for removing the custom workqueue. Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-15spi/omap-100k: Use core functionality to check validity of transfersMark Brown
2013-07-15spi/omap-100k: Remove empty reset functionMark Brown
2013-06-26Merge remote-tracking branch 'spi/topic/pdata' into spi-nextMark Brown
2013-05-29spi: convert drivers to use bits_per_word_maskStephen Warren
Fill in the recently added spi_master.bits_per_word_mask field in as many drivers as possible. Make related cleanups, such as removing any redundant error-checking, or empty setup callbacks. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-23spi: use platform_{get,set}_drvdata()Jingoo Han
Use the wrapper functions for getting and setting the driver data using platform_device instead of using dev_{get,set}_drvdata() with &pdev->dev, so we can directly pass a struct platform_device. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-02-05spi: Remove erroneous __init, __exit and __exit_p() references in driversGrant Likely
Some of the spi driver module remove hooks were annotated with __exit and referenced with __exit_p(). Presumably these were supposed to be __devinit, __devexit and __devexit_p() since __init/__exit for a probe/remove hook has never been correct. They also got missed during the big __devinit/__devexit purge since they didn't match the pattern. Remove then now to be rid of it. v2: purge __init also Reported-by: Arnd Bergmann <arnd@arndb.de> [Arnd set a patch cleaning up one, and then I found more] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-12-07spi: Remove HOTPLUG section attributesGrant Likely
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Bill Pemberton has done most of the legwork on this series. I've used his script to purge the attributes from the drivers/gpio tree. Reported-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-09-22SPI: OMAP: remove unnecessary includes of plat/clock.hPaul Walmsley
Remove unnecessary includes of plat/clock.h from the OMAP SPI controller drivers. These need to be removed to build multi-subarch ARM kernels which include these drivers. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-06spi: reorganize driversGrant Likely
Sort the SPI makefile and enforce the naming convention spi_*.c for spi drivers. This change also rolls the contents of atmel_spi.h into the .c file since there is only one user of that particular include file. v2: - Use 'spi-' prefix instead of 'spi_' to match what seems to be be the predominant pattern for subsystem prefixes. - Clean up filenames in Kconfig and header comment blocks Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Linus Walleij <linus.walleij@linaro.org>
