path: root/drivers/spi/spi-fsl-cpm.c
2014-11-21spi: fsl-spi: Don't use cpm_command on CPM1Christophe Leroy
On CPM1, when the SPI parameter RAM is relocated to somewhere else than the default location, in accordance with freescale documentation (refer micropatch SPI application note EB662), init RX/TX params command shall not be used because it doesn't take into account the new location, and overwrites data that is in original location of SPI param ram at addresses SCC2 param base + (u32*)0x88 (u16*)0x90 (u32*)0x98 (u16*)0xA0, hence breaking activity on SCC2 if SCC2 is used in a mode like QMC for instance. Therefore, the action shall be done manually as described by freescale and as was already partly done by the driver. Reported-by: Patrick Vasseur <patrick.vasseur@c-s.fr> Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Tested-by: Patrick Vasseur <patrick.vasseur@c-s.fr> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-09-29spi: fsl: Sort include headers alphabeticallyXiubo Li
Sort all the include headers alphabetically for the freescale spi drivers. If the inlcude headers sorted out of order, maybe the best logical choice is to append new ones after the exist ones, while this may create a lot of potential for duplicates and conflicts for each diffenent changes will add new headers in the same location. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2013-11-12Merge tag 'devicetree-for-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree updates from Rob Herring: "DeviceTree updates for 3.13. This is a bit larger pull request than usual for this cycle with lots of clean-up. - Cross arch clean-up and consolidation of early DT scanning code. - Clean-up and removal of arch prom.h headers. Makes arch specific prom.h optional on all but Sparc. - Addition of interrupts-extended property for devices connected to multiple interrupt controllers. - Refactoring of DT interrupt parsing code in preparation for deferred probe of interrupts. - ARM cpu and cpu topology bindings documentation. - Various DT vendor binding documentation updates" * tag 'devicetree-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (82 commits) powerpc: add missing explicit OF includes for ppc dt/irq: add empty of_irq_count for !OF_IRQ dt: disable self-tests for !OF_IRQ of: irq: Fix interrupt-map entry matching MIPS: Netlogic: replace early_init_devtree() call of: Add Panasonic Corporation vendor prefix of: Add Chunghwa Picture Tubes Ltd. vendor prefix of: Add AU Optronics Corporation vendor prefix of/irq: Fix potential buffer overflow of/irq: Fix bug in interrupt parsing refactor. of: set dma_mask to point to coherent_dma_mask of: add vendor prefix for PHYTEC Messtechnik GmbH DT: sort vendor-prefixes.txt of: Add vendor prefix for Cadence of: Add empty for_each_available_child_of_node() macro definition arm/versatile: Fix versatile irq specifications. of/irq: create interrupts-extended property microblaze/pci: Drop PowerPC-ism from irq parsing of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code. of/irq: Use irq_of_parse_and_map() ...
2013-10-16spi: Add missing newline to dev_ prints in driversJarkko Nikula
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-10-09drivers: clean-up prom.h implicit includesRob Herring
Powerpc is a mess of implicit includes by prom.h. Add the necessary explicit includes to drivers in preparation of prom.h cleanup. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Grant Likely <grant.likely@linaro.org>
2013-04-07spi/spi-fsl-spi: Make driver usable in CPU mode outside of an FSL_SOC ↵Andreas Larsson
environment This makes the spi-fsl-spi driver usable in CPU mode outside of an FSL_SOC and even an powerpc environment by moving CPM mode functionality to a separate file that is only compiled and linked in an FSL_SOC environment and adding some ifdefs to hide types and functions or provide alternatives. For devicetree probing a "clock-frequency" property is used for clock frequency instead of calls to FSL_SOC-specific functions. Acked-by: Anton Vorontsov <anton@enomsg.org> Signed-off-by: Andreas Larsson <andreas@gaisler.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
