path: root/drivers/spi/spi-dw-mmio.c
2013-12-31spi: dw-mmio: prepare the clock before enablingBaruch Siach
This is required for common clock support. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-12-31spi: dw: use managed resourcesBaruch Siach
Migrate mmio code and core driver to managed resources to reduce boilerplate error handling code. Also, handle clk_enable() failure while at it, and drop unused dw_spi iolen field. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-17spi: designware: delete premature free_irqJulia Lawall
Free_irq is not needed if there has been no request_irq. Free_irq is removed from both the probe and remove functions. The correct request_irq and free_irq appear to be in the add_host and remove_host functions in spi-dw.c. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression e; @@ *e = platform_get_irq(...); ... when != request_irq(e,...) *free_irq(e,...) // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-05-13spi: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d (device-core: Ensure drvdata = NULL when no driver is bound). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Grant Likely <grant.likely@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-12-07spi: Remove HOTPLUG section attributesGrant Likely
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Bill Pemberton has done most of the legwork on this series. I've used his script to purge the attributes from the drivers/gpio tree. Reported-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-10-31spi: Add module.h to implicit users in drivers/spiPaul Gortmaker
We are clipping down the presence of module.h, since it was everywhere. If you really need it, you better call it out, as per this changeset. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-25drivercore: Add helper macro for platform_driver boilerplateGrant Likely
For simple modules that contain a single platform_driver without any additional setup code then ends up being a block of duplicated boilerplate. This patch adds a new macro, module_platform_driver(), which replaces the module_init()/module_exit() registrations with template functions. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Reviewed-by: Magnus Damm <magnus.damm@gmail.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
2011-06-06spi: reorganize driversGrant Likely
Sort the SPI makefile and enforce the naming convention spi_*.c for spi drivers. This change also rolls the contents of atmel_spi.h into the .c file since there is only one user of that particular include file. v2: - Use 'spi-' prefix instead of 'spi_' to match what seems to be be the predominant pattern for subsystem prefixes. - Clean up filenames in Kconfig and header comment blocks Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Linus Walleij <linus.walleij@linaro.org>
