path: root/drivers/spi/pxa2xx_spi.c
2010-12-02spi/pxa2xx: pass of_node to spi device and set a parent deviceSebastian Andrzej Siewior
the of_node will auto-publish devices which are added to the device tree. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
2010-12-02spi/pxa2xx: Modify RX-Tresh instead of busy-loop for the remaining RX bytes.Sebastian Andrzej Siewior
After all TX bytes are sent, the driver spins while the SPI core is busy and then it spins for a "short" period of time until RX bytes are available. On Sodavile the busy flag disappears pretty quick and after that it takes approx ~130ms (sometimes less but not much) until there are bytes available in the RX FIFO. This patch removes the busy loop and modifies the RX threshould so we get woken up once the remainings bytes arrived. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
2010-12-02spi/pxa2xx: Add chipselect support for SodavilleSebastian Andrzej Siewior
The SPI core on Sodaville supports chip selects. Its configuration moved into the SSSR register at bit 0 and 1. Thus Sodaville can be hooked up with up to 4 devices. This patch ensures that the bits which are otherwiese reserved are only touched on Sodaville and not on any other PXAs. Also it makes sure that the status register does not lose the CS information while clearing the ROR bit. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
2010-12-01spi/pxa2xx: Consider CE4100's FIFO depthSebastian Andrzej Siewior
For PXA the default threshold is FIFO_DEPTH / 2. Adjust this value for CE4100. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
2010-12-01spi/pxa2xx: Add CE4100 supportSebastian Andrzej Siewior
Sodaville's SPI controller is very much the same as in PXA25x. The difference: - The RX/TX FIFO is only 4 words deep instead of 16 - No DMA support - The SPI controller offers a CS functionality Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
2010-12-01arm/pxa2xx: reorgazine SSP and SPI header filesSebastian Andrzej Siewior
The PXA-SPI driver relies on some files / defines which are arm specific and are within the ARM tree. The CE4100 SoC which is x86 has also the SPI core. This patch moves the ssp and spi files from arm/mach-pxa and plat-pxa to include/linux where the CE4100 can access them. This move got verified by building the following defconfigs: cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig raumfeld_defconfig magician_defconfig Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
2010-12-01spi/pxa2xx: Use define for SSSR_TFL_MASK instead of plain numbersSebastian Andrzej Siewior
2010-12-01spi/pxa2xx: add support for shared IRQ handlerSebastian Andrzej Siewior
This is required in case the interrupt line is shared with other devices. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
2010-11-26spi/pxa2xx: register driver properlySebastian Andrzej Siewior
use platform_driver_register instead of platform_driver_probe. The latter only checks available devices at the time of calling. So if a device gets inserter at a later point in time then the driver will never play with it. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
2010-05-11[ARM] pxa: add namespace on sspHaojian Zhuang
In order to prevent code ambiguous, add namespace on functions in ssp driver. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-05-11[ARM] pxa: move ssp into common plat-pxaHaojian Zhuang
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-05-11[ARM] pxa: merge regs-ssp.h into ssp.hEric Miao
No need to separate them as they should be together from the begining. Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-05-11[ARM] pxa: correct SSCR0_SCR to support multiple SoCsEric Miao
The previous definitions of SSCR0_SCR and SSCR0_SerClkDiv() prevented them being used simultaneously when supporting multiple PXA SoCs, esp. in drivers/spi/pxa2xx_spi.c, make them correct. The change from SSCR0_SerClkDiv(2) to SSCR0_SCR(2), will make the result a little bit different in pxa2xx_spi_probe(), however, since that's only used as a default initialization value, it's acceptable. Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-15const: constify remaining dev_pm_opsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24Merge branch 'origin' into for-linusRussell King
Conflicts: MAINTAINERS
2009-09-23pxa2xx_spi: register earlierAntonio Ospite
Register pxa2xx_spi earlier so it can be used with cpufreq Signed-off-by: Daniel Ribeiro <drwyrm@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Daniel Ribeiro <drwyrm@gmail.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-10[ARM] pxa: update pxa2xx-spi.c to use 'struct dev_pm_ops'Mike Rapoport
Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-06-18pxa2xx_spi: fix for SPI_CS_HIGHDaniel Ribeiro
Commit a7bb3909b3293d503211d7f6af8ed62c1644b686 ("spi: pxa2xx_spi: introduce chipselect GPIO to simplify the common cases") introduces chipselect GPIO, and configures the CS polarity using SPI_CS_HIGH spi->mode flag. Add SPI_CS_HIGH to the allowed modes. Signed-off-by: Daniel Ribeiro <drwyrm@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18spi: move more spi_setup() functionality into coreDavid Brownell
Move some common spi_setup() error checks into the SPI framework from the spi_master controller drivers: - Add a new "mode_bits" field to spi_master - Use that in spi_setup to validate the spi->mode value being requested. Setting this new field is now mandatory for any controller supporting more than vanilla SPI_MODE_0. - Update all spi_master drivers to: * Initialize that field * Remove current spi_setup() checks using that value. This is a net minor code shrink. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18spi: move common spi_setup() functionality into coreDavid Brownell
Start moving some spi_setup() functionality into the SPI core from the various spi_master controller drivers: - Make that function stop being an inline; - Move two common idioms from drivers into that new function: * Default bits_per_word to 8 if that field isn't set * Issue a standardized dev_dbg() message This is a net minor source code shrink, and supports enhancments found in some follow-up patches. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-12pxa2xx_spi: prevent panic case setup() failsDaniel Ribeiro
setup() may fail before ctldata is set, causing a kernel panic on cleanup(). Signed-off-by: Daniel Ribeiro <drwyrm@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21spi: pxa2xx: limit reaches -1Roel Kluin
On line 944 the return value of flush() is considered as a boolean, but limit reaches -1 upon timeout which evaluates to true. On 540, 594, 720 the same occurs for wait_ssp_rx_stall() On 536 the same occurs for wait_dma_channel_stop() Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Eric Miao <eric.miao@marvell.com> Cc: David Brownell <david-b@pacbell.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21pxa2xx_spi: restore DRCMR on resumeDaniel Ribeiro
If DMA is enabled, any spi_sync call after suspend/resume would block forever, because DRCMR is lost on suspend. This patch restores DRCMR to the same values set by probe. Signed-off-by: Daniel Ribeiro <drwyrm@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13[ARM] pxa: fix typo of cs_deassert() in pxa2xx-spi.cDaniel Ribeiro
Signed-off-by: Daniel Ribeiro <drwyrm@gmail.com> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-04-07pxa2xx_spi: set spi_master.dma_alignment = 8Mike Rapoport
Signed-off-by: Mike Rapoport <mike@compulab.co.il> Cc: Bryan Wu <bryan.wu@analog.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07spi: pxa2xx_spi: introduce chipselect GPIO to simplify the common casesEric Miao
Most SPI peripherals use GPIOs as their chip selects, introduce .gpio_cs for this. Signed-off-by: Eric Miao <eric.miao@marvell.com> Cc: David Brownell <david-b@pacbell.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-28Merge branch 'origin' into develRussell King
Conflicts: sound/soc/pxa/pxa2xx-i2s.c
2009-03-24spi: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Cc: dbrownell@users.sourceforge.net Cc: spi-devel-general@lists.sourceforge.net Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
2009-03-09[ARM] pxa: move DMA registers definitions into <mach/dma.h>Eric Miao
1. Driver code where pxa_request_dma() is called will most likely reference DMA registers as well, and it is really unnecessary to include pxa-regs.h just for this. Move the definitions into <mach/dma.h> and make relevant drivers include it instead of <mach/pxa-regs.h>. 2. Introduce DMAC_REGS_VIRT as the virtual address base for these DMA registers. This allows later processors to re-use the same IP while registers may start at different I/O address. Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-01-06drivers/spi: move a dereference below a NULL testJulia Lawall
In each case, if the NULL test is necessary, then the dereference should be moved below the NULL test. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ type T; expression E; identifier i,fld; statement S; @@ - T i = E->fld; + T i; ... when != E when != i if (E == NULL) S + i = E->fld; // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-29[ARM] Hide ISA DMA API when ISA_DMA_API is unsetRussell King
When ISA_DMA_API is unset, we're not implementing the ISA DMA API, so there's no point in publishing the prototypes via asm/dma.h, nor including the machine dependent parts of that API. This allows us to remove a lot of mach/dma.h files which don't contain any useful code. Unfortunately though, some platforms put their own private non-ISA definitions into mach/dma.h, so we leave these behind and fix the appropriate #include statments. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-19pxa2xx_spi: bugfix full duplex dma data corruptionNed Forrester
Fixes a data corruption bug in pxa2xx_spi.c when operating in full duplex mode with DMA and using buffers that overlap. SPI transmit and receive buffers are allowed to be the same or to overlap. However, this driver fails if such overlap is attempted in DMA mode because it maps the rx and tx buffers in the wrong order. By mapping DMA_FROM_DEVICE (read) before DMA_TO_DEVICE (write), it invalidates the cache before flushing it, thus discarding data which should have been transmitted. The patch corrects the order of mapping. This bug exists in all versions of pxa2xx_spi.c; similar bugs are in the drivers for two other SPI controllers (au1500, imx). A version of this patch has been tested on kernel 2.6.20 using verification of loopback data with: random transfer length, random bits-per-word, random positive offsets (both larger and smaller than transfer length) between the start of the rx and tx buffers, and varying clock rates. Signed-off-by: Ned Forrester <nforrester@whoi.edu> Cc: Vernon Sauder <vernoninhand@gmail.com> Cc: J. Scott Merritt <merrij3@rpi.edu> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: <stable@kernel.org> [2.6.27.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16pxa2xx_spi: fix chip_info defaults and documentation.Vernon Sauder
Make the chip info structure data optional by providing reasonable defaults. Improve corresponding documentation, and highlight the drawback of not providing explicit chipselect control. DMA can determine appropriate dma_burst_size and thresholds automatically so use DMA even if dma_burst_size is not specified. Signed-off-by: Vernon Sauder <VernonInHand@gmail.com> Reviewed-by: Ned Forrester <nforrester@whoi.edu> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16pxa2xx_spi: minor cleanupGuennadi Liakhovetski
Minor fixes: remove redundant local variable initialization, fix "can not" to what I _think_ is a preferred spelling, output IRQ number if requesting it failed. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-01pxa2xx_spi: fix build breakageMike Rapoport
This patch fixes a build error in the pxa2xx-spi driver, introduced by commit 7e96445533ac3f4f7964646a202ff3620602fab4 ("pxa2xx_spi: dma bugfixes") CC drivers/spi/pxa2xx_spi.o drivers/spi/pxa2xx_spi.c: In function 'map_dma_buffers': drivers/spi/pxa2xx_spi.c:331: error: invalid operands to binary & drivers/spi/pxa2xx_spi.c:331: error: invalid operands to binary & drivers/spi/pxa2xx_spi.c: In function 'pump_transfers': drivers/spi/pxa2xx_spi.c:897: warning: format '%lu' expects type 'long unsigned int', but argument 4 has type 'unsigned int' [dbrownell@users.sourceforge.net: fix warning too ] Signed-off-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-13pxa2xx_spi: dma bugfixesNed Forrester
Fixes two DMA bugs in the pxa2xx_spi driver. The first bug is in all versions of this driver; the second was introduced in the 2.6.20 kernel, and prevents using the driver with chips like m25p16 flash (which can issue large DMA reads). 1. Zero length transfers are permitted for use to insert timing, but pxa2xx_spi.c will fail if this is requested in DMA mode. Fixed by using programmed I/O (PIO) mode for such transfers. 2. Transfers larger than 8191 are not permitted in DMA mode. A test for length rejects all large transfers regardless of DMA or PIO mode. Worked around by rejecting only large transfers with DMA mapped buffers, and forcing all other transfers larger than 8191 to use PIO mode. A rate limited warning is issued for DMA transfers forced to PIO mode. This patch should apply to all kernels back to and including 2.6.20; it was test patched against 2.6.20. An additional patch would be required for older kernels, but those versions are very buggy anyway. Signed-off-by: Ned Forrester <nforrester@whoi.edu> Cc: Vernon Sauder <vernoninhand@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-13pxa2xx_spi: chipselect bugfixesNed Forrester
Fixes several chipselect bugs in the pxa2xx_spi driver. These bugs are in all versions of this driver and prevent using it with chips like m25p16 flash. 1. The spi_transfer.cs_change flag is handled too early: before spi_transfer.delay_usecs applies, thus making the delay ineffective at holding chip select. 2. spi_transfer.delay_usecs is ignored on the last transfer of a message (likewise not holding chipselect long enough). 3. If spi_transfer.cs_change is set on the last transfer, the chip select is always disabled, instead of the intended meaning: optionally holding chip select enabled for the next message. Those first three bugs were fixed with a relocation of delays and chip select de-assertions. 4. If a message has the cs_change flag set on the last transfer, and had the chip select stayed enabled as requested (see 3, above), it would not have been disabled if the next message is for a different chip. Fixed by dropping chip select regardless of cs_change at end of a message, if there is no next message or if the next message is for a different chip. This patch should apply to all kernels back to and including 2.6.20; it was test patched against 2.6.20. An additional patch would be required for older kernels, but those versions are very buggy anyway. Signed-off-by: Ned Forrester <nforrester@whoi.edu> Cc: Vernon Sauder <vernoninhand@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-26dma-mapping: add the device argument to dma_mapping_error()FUJITA Tomonori
Add per-device dma_mapping_ops support for CONFIG_X86_64 as POWER architecture does: This enables us to cleanly fix the Calgary IOMMU issue that some devices are not behind the IOMMU (http://lkml.org/lkml/2008/5/8/423). I think that per-device dma_mapping_ops support would be also helpful for KVM people to support PCI passthrough but Andi thinks that this makes it difficult to support the PCI passthrough (see the above thread). So I CC'ed this to KVM camp. Comments are appreciated. A pointer to dma_mapping_ops to struct dev_archdata is added. If the pointer is non NULL, DMA operations in asm/dma-mapping.h use it. If it's NULL, the system-wide dma_ops pointer is used as before. If it's useful for KVM people, I plan to implement a mechanism to register a hook called when a new pci (or dma capable) device is created (it works with hot plugging). It enables IOMMUs to set up an appropriate dma_mapping_ops per device. The major obstacle is that dma_mapping_error doesn't take a pointer to the device unlike other DMA operations. So x86 can't have dma_mapping_ops per device. Note all the POWER IOMMUs use the same dma_mapping_error function so this is not a problem for POWER but x86 IOMMUs use different dma_mapping_error functions. The first patch adds the device argument to dma_mapping_error. The patch is trivial but large since it touches lots of drivers and dma-mapping.h in all the architecture. This patch: dma_mapping_error() doesn't take a pointer to the device unlike other DMA operations. So we can't have dma_mapping_ops per device. Note that POWER already has dma_mapping_ops per device but all the POWER IOMMUs use the same dma_mapping_error function. x86 IOMMUs use device argument. [akpm@linux-foundation.org: fix sge] [akpm@linux-foundation.org: fix svc_rdma] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix bnx2x] [akpm@linux-foundation.org: fix s2io] [akpm@linux-foundation.org: fix pasemi_mac] [akpm@linux-foundation.org: fix sdhci] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix sparc] [akpm@linux-foundation.org: fix ibmvscsi] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13spi: pxa2xx_spi clock resume bugfixEric BENARD
There is a typo in pxa2xx_spi.c, comment says "Enable the SSP clock", code says: clk_disable ... so after resume, the SSP is dead. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Ned Forrester <nforrester@whoi.edu> Cc: Stephen Street <stephen@streetfiresound.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28spi: pxa2xx_spi "sparse" fixesDavid Brownell
Various cleanups to pxa2xx_spi suggested by "sparse": make sure that register addresess are "void __iomem *", and make a few functions properly static. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Ned Forrester <nforrester@whoi.edu> Cc: Stephen Street <stephen@streetfiresound.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-11spi: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable SPI platform drivers, to allow module auto loading. [dbrownell@users.sourceforge.net: more drivers: registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-23spi: pxa2xx_spi clock polarity fixNed Forrester
Fixes a sequencing bug in spi driver pxa2xx_spi.c in which the chip select for a transfer may be asserted before the clock polarity is set on the interface. As a result of this bug, the clock signal may have the wrong polarity at transfer start, so it may need to make an extra half transition before the intended clock/data signals begin. (This probably means all transfers are one bit out of sequence.) This only occurs on the first transfer following a change in clock polarity in systems using more than one more than one such polarity. The fix assures that the clock mode is properly set before asserting chip select. This bug was introduced in a patch merged on 2006/12/10, kernel 2.6.20. The patch defines an additional bit in: include/asm-arm/arch-pxa/regs-ssp.h for 2.6.25 and newer kernels but this addition must be made in: include/asm-arm/arch-pxa/pxa-regs.h for kernels between 2.6.20 and 2.6.24, inclusive Signed-off-by: Ned Forrester <nforrester@whoi.edu> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06spi: remove more dev->power.power_state usageDavid Brownell
Remove some more references to dev->power.power_state. That field is overdue for removal, but we can't do that while it's still referenced in the kernel. The only reason to update it was to make the /sys/devices/.../power/state files (now removed) work better. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-26[ARM] pxa: make pxa2xx_spi driver use ssp_request()/ssp_free()eric miao
1. make pxa2xx_spi.c use ssp_request() and ssp_free() to get the common information of the designated SSP port. 2. remove those IRQ/memory request code, ssp_request() has done that for the driver 3. the SPI platform device is thus made psuedo, no resource (memory/IRQ) has to be defined, all will be retreived by ssp_request() 4. introduce ssp_get_clk_div() to handle controller difference in clock divisor setting 5. use clk_xxx() API for clock enable/disable, and clk_get_rate() to handle the different SSP clock frequency between different processors Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] pxa: move SSP register definitions from pxa-regs.h to regs-ssp.heric miao
2007-12-10pxa2xx_spi: fix typo in descriptionWill Newton
Signed-off-by: Will Newton <will.newton@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16spi doesn't need class_deviceTony Jones
Make the SPI framework and drivers stop using class_device. Update docs accordingly ... highlighting just which sysfs paths should be "safe"/stable. Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
