path: root/drivers/spi/omap2_mcspi.c
2010-04-28omap2_mcspi: small fixes of output data formatRoman Tereshonkov
Replaces %04x by %08x for 32-bits data output. Signed-off-by: Roman Tereshonkov <roman.tereshonkov@nokia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-04-28omap2_mcspi: Flush posted writesRoman Tereshonkov
mcspi_write_chconf0 is used to control rx/tx triggering. Post-write flushing is needed to get the immediate effect. Signed-off-by: Roman Tereshonkov <roman.tereshonkov@nokia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-10spi/omap2_mcspi: Use transaction speed if providedScott Ellis
omap2_mcspi_transfer() gets called in omap2_mcspi_work() when the transaction speed_hz or bits_per_word fields are non-zero. omap2_mcspi_transfer() does not look at the speed_hz field so the override speed value is ignored. The code should probably change to one of these options. 1. Skip the call to omap2_mcsp_transfer() if the only reason was a non-zero speed_hz and it's not going to be used. 2. Use the new speed_hz value provided The patch below uses the speed_hz value. Signed-off-by: Scott Ellis <scott@jumpnowtek.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-03-10spi/omap2_mcspi: fix NULL pointer dereferenceScott Ellis
Check spi->controller_state before dereferencing. Shows up NULL here when using spi_alloc_device()/spi_add_device() and spi_add_device() fails before spi_setup(). Calling spi_dev_put() on the leftover spi_device results in the error. Signed-off-by: Scott Ellis <scott@jumpnowtek.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-02-15omap3: Replace ARCH_OMAP34XX with ARCH_OMAP3Tony Lindgren
Replace ARCH_OMAP34XX with ARCH_OMAP3 Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-23spi: McSPI support for OMAP4Syed Rafiuddin
tAdd adds McSPI support for OMAP4430 SDP platform. All the base addresses are changed between OMAP1/2/3 and OMAP4. The fields of the resource structures are filled at runtime to have McSPI support on OMAP4. Signed-off-by: Syed Rafiuddin <rafiuddin.syed@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23spi: McSPI saves CHCONFx tooTero Kristo
Previous restore was lazy and only restored CHxCONF when it was needed by a specific chip select. This could cause occasional errors on an SPI bus where multiple chip selects are in use. Signed-off-by: Tero Kristo <tero.kristo@nokia.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23spi: McSPI off-mode supportHemanth V
Add context save/restore feature to McSPI driver. Signed-off-by: Hemanth V <hemanthv@ti.com> Reviewed-by: Aaro Koskinen <Aaro.Koskinen@nokia.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23spi: omap2_mcspi use BIT(n)Jouni Hogander
Convert bit shifted values into BIT format Signed-off-by: Jouni Hogander <jouni.hogander@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29spi: omap2_mcspi rxdma bugfixEero Nurkkala
When data is read through DMA, the last element must be read separately through the RX register. It cannot be transferred by the DMA. For further details see e.g. OMAP35x TRM (table 19-16). Without the fix the driver causes extra clocks to be clocked to the bus after DMA RX operations. This can cause interesting behaviour with some devices. Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com> Signed-off-by: Eero Nurkkala <ext-eero.nurkkala@nokia.com> [aaro.koskinen@nokia.com: Simplified the patch while keeping the idea.] Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29spi: omap2_mcspi supports wake eventsJouni Hogander
Currently mcspi wake-ups are not enabled. This might cause cases where OMAP is not waking up on mcspi events. Signed-off-by: Jouni Hogander <jouni.hogander@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18spi: move more spi_setup() functionality into coreDavid Brownell
Move some common spi_setup() error checks into the SPI framework from the spi_master controller drivers: - Add a new "mode_bits" field to spi_master - Use that in spi_setup to validate the spi->mode value being requested. Setting this new field is now mandatory for any controller supporting more than vanilla SPI_MODE_0. - Update all spi_master drivers to: * Initialize that field * Remove current spi_setup() checks using that value. This is a net minor code shrink. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18spi: move common spi_setup() functionality into coreDavid Brownell
Start moving some spi_setup() functionality into the SPI core from the various spi_master controller drivers: - Make that function stop being an inline; - Move two common idioms from drivers into that new function: * Default bits_per_word to 8 if that field isn't set * Issue a standardized dev_dbg() message This is a net minor source code shrink, and supports enhancments found in some follow-up patches. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-28Merge branch 'origin' into develRussell King
Conflicts: sound/soc/pxa/pxa2xx-i2s.c
2009-03-24spi: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Cc: dbrownell@users.sourceforge.net Cc: spi-devel-general@lists.sourceforge.net Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
2009-02-08[ARM] omap: mcspi: new short connection id namesRussell King
... rather than the clock names themselves. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-05[ARM] omap: convert OMAP drivers to use ioremap()Russell King
2008-09-05[ARM] omap: remove an io_v2p() usageRussell King
When omap_udc is also incorporated, this macro will no longer be used. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-26dma-mapping: add the device argument to dma_mapping_error()FUJITA Tomonori
Add per-device dma_mapping_ops support for CONFIG_X86_64 as POWER architecture does: This enables us to cleanly fix the Calgary IOMMU issue that some devices are not behind the IOMMU (http://lkml.org/lkml/2008/5/8/423). I think that per-device dma_mapping_ops support would be also helpful for KVM people to support PCI passthrough but Andi thinks that this makes it difficult to support the PCI passthrough (see the above thread). So I CC'ed this to KVM camp. Comments are appreciated. A pointer to dma_mapping_ops to struct dev_archdata is added. If the pointer is non NULL, DMA operations in asm/dma-mapping.h use it. If it's NULL, the system-wide dma_ops pointer is used as before. If it's useful for KVM people, I plan to implement a mechanism to register a hook called when a new pci (or dma capable) device is created (it works with hot plugging). It enables IOMMUs to set up an appropriate dma_mapping_ops per device. The major obstacle is that dma_mapping_error doesn't take a pointer to the device unlike other DMA operations. So x86 can't have dma_mapping_ops per device. Note all the POWER IOMMUs use the same dma_mapping_error function so this is not a problem for POWER but x86 IOMMUs use different dma_mapping_error functions. The first patch adds the device argument to dma_mapping_error. The patch is trivial but large since it touches lots of drivers and dma-mapping.h in all the architecture. This patch: dma_mapping_error() doesn't take a pointer to the device unlike other DMA operations. So we can't have dma_mapping_ops per device. Note that POWER already has dma_mapping_ops per device but all the POWER IOMMUs use the same dma_mapping_error function. x86 IOMMUs use device argument. [akpm@linux-foundation.org: fix sge] [akpm@linux-foundation.org: fix svc_rdma] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix bnx2x] [akpm@linux-foundation.org: fix s2io] [akpm@linux-foundation.org: fix pasemi_mac] [akpm@linux-foundation.org: fix sdhci] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix sparc] [akpm@linux-foundation.org: fix ibmvscsi] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-11spi: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable SPI platform drivers, to allow module auto loading. [dbrownell@users.sourceforge.net: more drivers: registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06spi: omap2_mcspi handles omap3 tooGirish
This adds driver OMAP SPI specific changes to support OMAP 3430 Signed-off-by: Girish S G <girishsg@ti.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-24spi: omap2_mcspi PIO RX fixKalle Valo
Before transmission of the last word in PIO RX_ONLY mode rx+tx mode is enabled: /* prevent last RX_ONLY read from triggering * more word i/o: switch to rx+tx */ if (c == 0 && tx == NULL) mcspi_write_cs_reg(spi, OMAP2_MCSPI_CHCONF0, l); But because c is decremented after the test, c will never be zero and rx+tx will not be enabled. This breaks RX_ONLY mode PIO transfers. Fix it by decrementing c in the beginning of the various I/O loops. Signed-off-by: Kalle Valo <kalle.valo@nokia.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16OMAP2 McSPI code cleanupKyungmin Park
Remove unused variable & write space Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17SPI: omap2_mcspi driverSamuel Ortiz
Add OMAP24XX McSPI (Multichannel SPI) controller driver. This driver is tested very well under OMAP GIT tree with N800 - Nokia Internet Tablet, and some other OMAP2 boards. Recent updates included bugfixes, cleanups, speedups, and better conformance to the current SPI programming interface. This doesn't yet understand the third controller instance on the OMAP 2430. [david-b@pacbell.net: more minor cleanups to the omap2_mcspi driver] Signed-off-by: Juha Yrjölä <juha.yrjola@solidboot.com> Signed-off-by: Trilok Soni <soni.trilok@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Tony Lindgren <tony@atomide.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
