path: root/drivers/serial
2010-02-09of: add 'of_' prefix to machine_is_compatible()Grant Likely
machine is compatible is an OF-specific call. It should have the of_ prefix to protect the global namespace. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Michal Simek <monstr@monstr.eu>
2010-01-20serial: serial_cs: oxsemi quirk breaks resumePavel Machek
Quirk is applied on all cards with given manfid (is it that correct?). Unfortunately, that quirk breaks resume on zaurus with billionton bluetooth card inserted: c950ctrl is 0 and outb() faults. I believe it is simply not a multiport card. (info->multi == 1). ... ... confirmed by printks. Signed-off-by: Pavel Machek <pavel@ucw.cz> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20serial: imx: bit &/| confusionRoel Kluin
Since UCR1_UARTEN is defined 1, the port was always treated as enabled. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Alan Cox <alan@linux.intel.com> Acked-by: Oskar Schirmer <os@emlix.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Fabian Godehardt <fg@emlix.com> Cc: Daniel Glöckner <dg@emlix.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20serial: Fix crash if the minimum rate of the device is > 9600 baudAlan Cox
In that situation if the old rate is invalid and the new rate is invalid and the chip cannot do 9600 baud we report zero, which makes all the drivers explode. Instead force the rate based on min/max Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20serial-core: resume serial hardware with no_console_suspendStanislav Brabec
Perform a tricky suspend/resume even with no_console_suspend. With no_console_suspend, kernel skips serial port suspend/resume and the serial hardware may remain in undefined state after resume. It actually happens on devices that don't have BIOS that handle serial initialization. It makes impossible to use serial console after resume. Devices affected by this problem include: Sharp Zaurus devices Several PXA based ARM embedded boards The patch does: - Save the hardware state - Perform buffer flush in time of its suspend call - Tell the driver that port is suspended - But still accept new data - And keep console hardware in state that allows to send them It allows to capture late console messages without breaking console after resume. This is just a resend of a patch discussed in these threads, as the patch was not yet applied. "Possible suspend/resume regression in .32-rc?" (Nov 1-5, 2009, ARM list, later LKML) "serial-core: resume serial hardware with no_console_suspend" (Sep 15-Oct 18, 2009, LKML & ARM lists) Signed-off-by: Stanislav Brabec <sbrabec@suse.cz> Tested-by: Haojian Zhuang <haojian.zhuang@gmail.com> Tested-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20serial: 8250_pnp: use wildcard for serial Wacom tabletsMatthew Garrett
Wacom claims that the WACF namespace will always be devoted to serial Wacom tablets. Remove the existing entries and add a wildcard to avoid having to update the kernel every time they add a new device. Signed-off-by: Ping Cheng <pingc@wacom.com> Signed-off-by: Matthew Garrett <mjg@redhat.com> Tested-by: Ping Cheng <pingc@wacom.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc: Move cpu hotplug driver lock from pseries to powerpc powerpc: Move /proc/ppc64 to /proc/powerpc update powerpc/8xx: Fix user space TLB walk in dcbX fixup powerpc: Fix decrementer setup on 1GHz boards powerpc/iseries: Initialise on-stack completion powerpc/hvc: Driver build breaks with !HVC_CONSOLE serial/pmac_zilog: Workaround problem due to interrupt on closed port powerpc/macintosh: Make Open Firmware device id constant powerpc: Use helpers for rlimits powerpc: cpumask_of_node() should handle -1 as a node powerpc/pseries: Fix dlpar compile warning without CONFIG_PROC_DEVICETREE powerpc/pseries: Fix xics interrupt affinity powerpc/swsusp_32: Fix TLB invalidation powerpc/8xx: Always pin kernel instruction TLB powerpc: 2.6.33 update of defconfigs for embedded 6xx/7xxx, 8xx, 8xxx powerpc: Use scripts/mkuboot.sh instead of 'mkimage' powerpc/5200: update defconfigs
2010-01-16serial/8250_pnp: add a new Fujitsu Wacom Tablet PC devicePing
This is a new two finger touch Fujitsu Wacom Tablet PC. Signed-off-by: Ping Cheng <pingc@wacom.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-15serial/pmac_zilog: Workaround problem due to interrupt on closed portBenjamin Herrenschmidt
It seems that in qemu, we can see an interrupt in R3 despite the fact that it's masked in W1. The chip doesn't actually issue an interrupt, but we can "see" it when taking an interrupt for the other channel. This may be a qemu bug ... or not, so let's be safe and avoid calling into the UART layer when that happens which woulc cause a crash. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Rob Landley <rob@landley.net>
2010-01-15serial: sh-sci: using correct fifo size for SCIF and SCIFA ports.Markus Pietrek
The sh-sci driver used the wrong fifosize for PORT_SCIFA and PORT_SCIF ports. If an incorrect size is used, the serial core will enforce an early shutdown on the port, especially with baudrates < 9600. Signed-off-by: Markus Pietrek <Markus.Pietrek@emtrion.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-01-12Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: ARM: Ensure ARMv6/7 mm files are built using appropriate assembler options ARM: Fix wrong dmb ARM: 5874/1: serial21285: fix disable_irq-from-interrupt-handler deadlock ARM: 5873/1: ARM: Fix the reset logic for ARM RealView boards ARM: 5872/1: ARM: include needed linux/cpu.h in asm/cpu.h ARM: 5871/1: arch/arm: Fix build failure for lpd7a404_defconfig caused by missing includes ARM: 5870/1: arch/arm: Fix build failure for defconfigs without CONFIG_ISA_DMA_API set ARM: 5868/1: ARM: fix "BUG: using smp_processor_id() in preemptible code" ARM: 5867/1: Update U300 defconfig ARM: 5866/1: arm ptrace: use unsigned types for kernel pt_regs [ARM] pxa: fix strange characters in zaurus gpio .desc ARM: add missing recvmmsg syscall number [ARM] pxa: fix compiler warnings of unused variable 'id' in cpu_is_pxa9*() [ARM] pxa: update pwm_backlight->notify() to include missed 'struct device *' [ARM] pxa: enable L2 if present in XSC3 [ARM] pxa: do not enable L2 after MMU is enabled
2010-01-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (56 commits) sky2: Fix oops in sky2_xmit_frame() after TX timeout Documentation/3c509: document ethtool support af_packet: Don't use skb after dev_queue_xmit() vxge: use pci_dma_mapping_error to test return value netfilter: ebtables: enforce CAP_NET_ADMIN e1000e: fix and commonize code for setting the receive address registers e1000e: e1000e_enable_tx_pkt_filtering() returns wrong value e1000e: perform 10/100 adaptive IFS only on parts that support it e1000e: don't accumulate PHY statistics on PHY read failure e1000e: call pci_save_state() after pci_restore_state() netxen: update version to 4.0.72 netxen: fix set mac addr netxen: fix smatch warning netxen: fix tx ring memory leak tcp: update the netstamp_needed counter when cloning sockets TI DaVinci EMAC: Handle emac module clock correctly. dmfe/tulip: Let dmfe handle DM910x except for SPARC on-board chips ixgbe: Fix compiler warning about variable being used uninitialized netfilter: nf_ct_ftp: fix out of bounds read in update_nl_seq() mv643xx_eth: don't include cache padding in rx desc buffer size ... Fix trivial conflict in drivers/scsi/cxgb3i/cxgb3i_offload.c
2010-01-11ARM: 5874/1: serial21285: fix disable_irq-from-interrupt-handler deadlockSimon Kagstrom
The console hangs during bootup when disable_irq is called from the transmit interrupt handler (it will wait forever for it's "own" interrupt in synchronize_irq). Fix by using disable_irq_nosync() instead. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-01-06pcnet_cs: add cis of KTI PE520 pcmcia network cardKen Kawasaki
pcnet_cs,serial_cs: add cis of KTI PE520 pcmcia network card, and serial card(Sierra Wireless AC860). Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-24serial: sh-sci: Convert tremaining ctrl_xxx I/O routines to __raw_xxx.Paul Mundt
ctrl_xxx() is an antiquated SH interface, while __raw_xxx is the standard API that accomplishes the same thing. As such, this converts the remaining sh-sci straggles over, which enables the driver to be wired up for ARM SH-Mobile CPUs as well. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-12-24serial: sh-sci: earlyprintk zero uartclk fixMagnus Damm
This establishes a sensible max baud rate for the earlyprintk cases where the port's uartclk has not yet been determined. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-12-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (33 commits) sh: Fix test of unsigned in se7722_irq_demux() sh: mach-ecovec24: Add FSI sound support sh: mach-ecovec24: Add mt9t112 camera support sh: mach-ecovec24: Add tw9910 support sh: MSIOF/mmc_spi platform data for the Ecovec24 board sh: ms7724se: Add ak4642 support sh: Fix up FPU build for SH5 sh: Remove old early serial console code V2 sh: sh5 scif pdata (sh5-101/sh5-103) sh: sh4a scif pdata (sh7757/sh7763/sh7770/sh7780/sh7785/sh7786/x3) sh: sh4a scif pdata (sh7343/sh7366/sh7722/sh7723/sh7724) sh: sh4 scif pdata (sh7750/sh7760/sh4-202) sh: sh3 scif pdata (sh7705/sh770x/sh7710/sh7720) sh: sh2a scif pdata (sh7201/sh7203/sh7206/mxg) sh: sh2 scif pdata (sh7616) sh-sci: Extend sh-sci driver with early console V2 sh: Stub in P3 ioremap support for nommu parts. sh: wire up vmallocinfo support in ioremap() implementations. sh: Make the unaligned trap handler always obey notification levels. sh: Couple kernel and user write page perm bits for CONFIG_X2TLB ...
2009-12-15ioc3/ioc4: fix error path on driver registrationJean Delvare
Two IOC3 and IOC4 drivers have broken error paths on registration. Fix them. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Pat Gefre <pfg@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15ioc3/ioc4: various section fixesJean Delvare
Several IOC3 and IOC4 drivers misuse the __devinit and __devexit section markers. Use __init and __exit instead as appropriate, then add __devinit and __devexit where they really belong for PCI drivers. Also make ioc4_serial_init static. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Pat Gefre <pfg@sgi.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15const: constify remaining dev_pm_opsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15Merge branch 'master' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
2009-12-15sh-sci: Extend sh-sci driver with early console V2Magnus Damm
This is V2 of early serial console support for the sh-sci driver. The early serial console is using early platform devices and "earlyprintk". To use this feature the early platform devices must be broken out to one device per port and the desired port should be selected on the kernel command line like: "earlyprintk=sh-sci.N[,baudrate][,keep]" Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-12-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (58 commits) tty: split the lock up a bit further tty: Move the leader test in disassociate tty: Push the bkl down a bit in the hangup code tty: Push the lock down further into the ldisc code tty: push the BKL down into the handlers a bit tty: moxa: split open lock tty: moxa: Kill the use of lock_kernel tty: moxa: Fix modem op locking tty: moxa: Kill off the throttle method tty: moxa: Locking clean up tty: moxa: rework the locking a bit tty: moxa: Use more tty_port ops tty: isicom: fix deadlock on shutdown tty: mxser: Use the new locking rules to fix setserial properly tty: mxser: use the tty_port_open method tty: isicom: sort out the board init logic tty: isicom: switch to the new tty_port_open helper tty: tty_port: Add a kref object to the tty port tty: istallion: tty port open/close methods tty: stallion: Convert to the tty_port_open/close methods ...
2009-12-11Serial: Do not read IIR in serial8250_start_tx when UART_BUG_TXENIan Jackson
Do not read IIR in serial8250_start_tx when UART_BUG_TXEN Reading the IIR clears some oustanding interrupts so it is not safe. Instead, simply transmit immediately if the buffer is empty without regard to IIR. Signed-off-by: Ian Jackson <ian.jackson@eu.citrix.com> Reviewed-by: Markus Armbruster <armbru@redhat.com> Reviewed-by: Jiri Kosina <jkosina@suse.cz> Cc: Alan Cox <alan@linux.intel.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11Serial: pxa: work around Errata #75Uwe Kleine-König
Intel(R) PXA27x Processor Family Specification Update (Nov 2005) says: E75. UART: Baud rate may not be programmed correctly on back-to-back writes. Problem: When programming the Divisor Latch registers, Low and High (DLL and DLH), with back-to-back writes, the second register write may not take effect. The result is an incorrect baud rate. Workaround: After programming the first Divisor Latch register, read and verify it before programming the second Divisor Latch register. This was hit when changing the baud rate from 115200 to 9600 while receiving characters at 9600 Bd. And fixed indention of some comments nearby. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Marc Kleine-Budde <mkl@pengutronix.de> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Alan Cox <alan@linux.intel.com> Cc: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11serial, 8250: calculate irqflags bitmask before loopAndré Goddard Rosa
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11serial: cascade needless conditionalsAndré Goddard Rosa
2009-12-11serial: fix NULL pointer dereferenceAndré Goddard Rosa
If kzalloc() or alloc_tty_driver() fails, we call: put_tty_driver(normal = NULL). Then: put_tty_driver -> tty_driver_kref_put -> kref_put(&NULL->kref, ...) Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11jsm: adding EEH handlersBreno Leitao
Adding EEH handlers for the serial jsm driver. This patch adds the PCI error handlers and also register them to be called when a error is detected. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Acked-by: Scott Kilau <scottk@digi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11jsm: removing the field jsm_board->intr_countBreno Leitão
Currently there is a field in the jsm_board structure to cont the number of interrupt that the card recevived, but it's not working properly when the IRQ line is shared, and also nowhere else this field is used. So, This patch is removing it. Signed-off-by: Breno Leitão <leitao@linux.vnet.ibm.com> Cc: Scott Kilau <Scott.Kilau@digi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11jsm: Removing unused jsm_channel->ch_wopen fieldBreno Leitão
Currently the jsm_channel->ch_wopen field is defined and never used. So, this patch removes it. Signed-off-by: Breno Leitão <leitao@linux.vnet.ibm.com> Cc: Scott Kilau <Scott.Kilau@digi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11jsm: Remove ch_cpstime fieldBreno Leitão
Currently the field jsm_channel->ch_cpstime is defined but never used, so this patch removes it. Signed-off-by: Breno Leitão <leitao@linux.vnet.ibm.com> Cc: Scott Kilau <Scott.Kilau@digi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11jsm: removing ch_old_baud fieldBreno Leitão
Currently the field jsm_channel->ch_old_baud is not used, just assigned in a lot of places but never used. This patches removes this field. Signed-off-by: Breno Leitão <leitao@linux.vnet.ibm.com> Cc: Scott Kilau <scottk@digi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11jsm: remove the ch_custom_speed fieldBreno Leitão
Currently the ch_custom_speed field exists but is never used, so, this patch removes it. Signed-off-by: Breno Leitão <leitao@linux.vnet.ibm.com> Cc: Scott Kilau <scottk@digi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11jsm: Rewriting a bad log messageBreno Leitão
Actually jsm displays "Device Added" 8 times (for a 8 port device). This silly patch just makes things more informative, showing the port (instead of the device) that was added. Signed-off-by: Breno Leitão <leitao@linux.vnet.ibm.com> Cc: Scott Kilau <scottk@digi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11jsm: IRQ handlers doesn't need to have IRQ_DISABLED enabledBreno Leitão
Currently jsm is showing the following message when loaded: IRQ 432/JSM: IRQF_DISABLED is not guaranteed on shared IRQs It's because the request_irq() is called using IRQF_DISABLED and IRQF_SHARED. Actually there is no need to use IRQF_DISABLED in this driver. Signed-off-by: Breno Leitão <leitao@linux.vnet.ibm.com> Cc: Scott Kilau <scottk@digi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11firmware_class: make request_firmware_nowait more usefulJohannes Berg
Unfortunately, one cannot hold on to the struct firmware that request_firmware_nowait() hands off, which is needed in some cases. Allow this by requiring the callback to free it (via release_firmware). Additionally, give it a gfp_t parameter -- all the current users call it from a GFP_KERNEL context so the GFP_ATOMIC isn't necessary. This also marks an API break which is useful in a sense, although that is obviously not the primary purpose of this change. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: Ming Lei <tom.leiming@gmail.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: David Woodhouse <David.Woodhouse@intel.com> Cc: Pavel Roskin <proski@gnu.org> Cc: Abhay Salunke <abhay_salunke@dell.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: m68knommu: export clk_* symbols in clk.c m68knommu: Split the .init section into INIT_TEXT_SECTION and INIT_DATA_SECTION. m68knommu: Move __init_end out of the .init section. m68knommu: Move __init_begin out of the .init section. m68knommu: Use more macros inside the .init section. m68knommu: Use INIT_TASK_DATA and CACHELINE_ALIGNED_DATA. m68knommu: Make THREAD_SIZE available to assembly files. m68knommu: Don't hardcode the value of PAGE_SIZE in the linker script. m68knommu: rename BSS define in linker script m68knommu: add a task_pt_regs() macro m68knommu: define arch_has_single_step() and friends m68knommu: add uboot commandline argument passing support m68knommu: Coldfire GPIO corrections m68knommu: move mcf_remove to .devexit.text Fixed up (?) conflict in arch/m68k/include/asm/ptrace.h
2009-12-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (137 commits) sh: include empty zero page in romImage sh: Make associative cache writes fatal on all SH-4A parts. sh: Drop associative writes for SH-4 cache flushes. sh: Partial revert of copy/clear_user_highpage() optimizations. sh: Add default uImage rule for se7724, ap325rxa, and migor. sh: allow runtime pm without suspend/resume callbacks sh: mach-ecovec24: Remove un-defined settings for VPU sh: mach-ecovec24: LCDC drive ability become high sh: fix sh7724 VEU3F resource size serial: sh-sci: Fix too early port disabling. sh: pfc: pr_info() -> pr_debug() cleanups. sh: pfc: Convert from ctrl_xxx() to __raw_xxx() I/O routines. sh: Improve kfr2r09 serial port setup code sh: Break out SuperH PFC code sh: Move KEYSC header file sh: convert /proc/cpu/aligmnent, /proc/cpu/kernel_alignment to seq_file sh: Add CPG save/restore code for sh7724 R-standby sh: Add SDHI power control support to Ecovec mfd: Add power control platform data to SDHI driver sh: mach-ecovec24: modify address map ...
2009-12-08Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (272 commits) Fix soc_common PCMCIA configuration ARM: 5827/1: SA1100: h3100/h3600: emit messages on failed gpio_request ARM: 5826/1: SA1100: h3100/h3600: always build htc-egpio driver ARM: 5825/1: SA1100: h3600: update defconfig ARM: 5824/1: SA1100: reuse h3600 PCMCIA driver on h3100 ARM: 5823/1: SA1100: h3100/h3600: add support for gpio-keys ARM: 5822/1: SA1100: h3100/h3600: clean up #includes ARM: 5821/1: SA1100: h3100/h3600: revise copyright boilerplates ARM: 5820/1: SA1100: h3100/h3600: split h3600.c ARM: 5819/1: SA1100: h3100/h3600: merge h3600.h and h3600_gpio.h into h3xxx.h ARM: 5818/1: SA1100: h3100/h3600: drop old GPIO definitions ARM: 5817/1: SA1100: h3100/h3600: configure all unused gpios as inputs ARM: 5816/1: SA1100: h3600: remove IRQ_GPIO_* definitions ARM: 5815/1: SA1100: h3100/h3600: remove now unused assign_h3600_egpio handlers ARM: 5814/1: SA1100: h3100/h3600: convert all users of assign_h3600_egpio to gpiolib ARM: 5813/1: SA1100: h3100/h3600: add htc-egpio driver ARM: 5812/1: SA1100: h3100/h3600: separate machine-specific LCD helpers ARM: 5811/2: pcmcia: convert sa1100_h3600 driver to gpiolib ARM: 5799/1: SA1100: h3600: stop setting direction for LCD pins ARM: 5798/1: SA1100: h3600: remove unused cruft from h3600.h ...
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next-2.6: sparc: Set UTS_MACHINE correctly. sparc,leon: init_leon srmmu cleanup sparc32: Remove early interrupt enable. sparc, leon: Added Aeroflex Gaisler entry in manufacturer_info structure sparc64: Faster early-boot framebuffer console. Revert "sparc: Make atomic locks raw" sparc: remove unused nfsd #includes sparc: Fixup last users of irq_chip->typename Added sparc_leon3_snooping_enabled() and converted extern inline to static inline No auxio on LEON apbuart: Use of_find_node_by_path to find root node. sparc: Replace old style lock initializer sparc: Make atomic locks raw apbuart: Fix build and missing driver unregister. apbuart: Kill dependency on deprecated Sparc-only PROM interfaces. apbuart: Fix build warning. sparc: Support for GRLIB APBUART serial port watchdog: Remove BKL from rio watchdog driver sparc: Remove BKL from apc sparc,leon: Sparc-Leon SMP support
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-06Merge branch 'sa1100' into develRussell King
2009-12-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (50 commits) pcmcia: rework the irq_req_t typedef pcmcia: remove deprecated handle_to_dev() macro pcmcia: pcmcia_request_window() doesn't need a pointer to a pointer pcmcia: remove unused "window_t" typedef pcmcia: move some window-related code to pcmcia_ioctl.c pcmcia: Change window_handle_t logic to unsigned long pcmcia: Pass struct pcmcia_socket to pcmcia_get_mem_page() pcmcia: Pass struct pcmcia_device to pcmcia_map_mem_page() pcmcia: Pass struct pcmcia_device to pcmcia_release_window() drivers/pcmcia: remove unnecessary kzalloc pcmcia: correct handling for Zoomed Video registers in topic.h pcmcia: fix printk formats pcmcia: autoload module pcmcia pcmcia/staging: update comedi drivers PCMCIA: stop duplicating pci_irq in soc_pcmcia_socket PCMCIA: ss: allow PCI IRQs > 255 PCMCIA: soc_common: remove 'dev' member from soc_pcmcia_socket PCMCIA: soc_common: constify soc_pcmcia_socket ops member PCMCIA: sa1111: remove duplicated initializers PCMCIA: sa1111: wrap soc_pcmcia_socket to contain sa1111 specific data ...
2009-12-05Merge branch 'devel-stable' into develRussell King
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-04serial: sh-sci: Fix too early port disabling.Guennadi Liakhovetski
Currently serial ports on SH CPUs get disabled too early, because the sci_tx_empty() routine claims to not be able to detect whether the transmission has been completed and just always returns TIOCSER_TEMT. This results in corrupt output of last characters if the port is not open for reading at the same time. It is however possible to detect whether transmission has been completed. Use the TEND bit of the status register for this. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-12-04m68knommu: move mcf_remove to .devexit.textUwe Kleine-König
The function mcf_remove is used only wrapped by __devexit_p so define it using __devexit. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Len Sorensen <lsorense@csclub.uwaterloo.ca> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alan Cox <alan@linux.intel.com> Cc: linux-kernel@vger.kernel.org Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-12-01ARM: S3C: Update Simtec copyright statements from , to - [2]Ben Dooks
There are a number of statements of the form A, B or A, B, C where the numbers A,B,C are not consecutive. However, referencing [1] it is the correct thing to replace these with A-B or A-C as apropriate. [1] http://www.copyrightservice.co.uk/copyright/p03_copyright_notices section 4iii 'Year of publication' Signed-off-by: Ben Dooks <ben@simtec.co.uk> Signed-off-by: Simtec Linux Team <linux@simtec.co.uk> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
