Folk seem to get confused when they see two or more ttyS0 ports
appearing at boot time. One comes from the legacy table, and
one from PNP.
Hence, display the bus ID of the device which supplied the port.
Added a Receive_Abort to the Marvell serial driver
Fix occasional input overrun errors on Marvell serial driver
- If the Marvell serial driver is repeatedly started and then stopped it
will occasionally report an input overrun error when started.
- Added a Receive_Abort to the Marvell serial driver to abort previously
received receive errors when re-starting the receive
Acked-by: Mark A. Greer <mgreer@mvista.com>
Signed-off-by: Carlos Sanchez <csanchez@mvista.com>
Various small mods for the Altix ioc4 serial driver - mostly cleanup:
- remove UIF_INITIALIZED usage
- use the 'lock' from uart_port
- better multiple card support
Signed-off-by: Patrick Gefre <pfg@sgi.com>
This patch fixes an issue reported by Coverity in serial/serial_core.c
Error reported: Variable "&((info)->tty)->flags" tracked as NULL was passed to a
function that dereferences it.
The later statements in the function assumes 'info->tty != NULL', so this
check is not necessary. Probably a 'BUG_ON(info->tty == NULL)' can be added.
Signed-off-by: Jayachandran C. <c.jayachandran at gmail.com>
In PM v1, all devices were called at SUSPEND_DISABLE level. Then
all devices were called at SUSPEND_SAVE_STATE level, and finally
SUSPEND_POWER_DOWN level. However, with PM v2, to maintain
compatibility for platform devices, I arranged for the PM v2
suspend/resume callbacks to call the old PM v1 suspend/resume
callbacks three times with each level in order so that existing
drivers continued to work.
Since this is obsolete infrastructure which is no longer necessary,
we can remove it. Here's an (untested) patch to do exactly that.
Patch from Matt Reimer
Adds support for HWUART on PXA 255 / 26x. This patch originally came from
http://svn.rungie.com/svn/gumstix-buildroot/trunk/sources/kernel-patches/000-gumstix-hwuart.patch
and has been tweaked by me.
Signed-off-by: Matt Reimer <mreimer@vpop.net>
Signed-off-by: Nicolas Pitre <nico@cam.org>
Patch from Jon Ringle
Updated 2898/1 per comments:
- Removed fixup
- Moved code in mach-mp1000/ to mach-clps711x/
- Cleaned up code in mp1000-seprom.c. Eliminated code that displayed the contents of the eeprom
Please comment.
Signed-off-by: Jon Ringle
Add the new ID 0x132a and configure the new PCI Diva console port. This
device supports only 1 single console UART.
Tested by Wolfgang Denk with this device:
00:0f.0 Network controller: PLX Technology, Inc. PCI <-> IOBus Bridge (rev 01)
Subsystem: Exsys EX-4055 4S(16C550) RS-232
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B-
Status: Cap- 66Mhz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR-
Interrupt: pin A routed to IRQ 10
Region 0: Memory at 80100000 (32-bit, non-prefetchable) [size=128]
Region 1: I/O ports at 7080 [size=128]
Region 2: I/O ports at 7400 [size=32]
00:0f.0 Class 0280: 10b5:9050 (rev 01)
Subsystem: d84d:4055
Results with this patch:
Serial: 8250/16550 driver $Revision: 1.90 $ 32 ports, IRQ sharing enabled
ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
PCI: Found IRQ 10 for device 0000:00:0f.0
ttyS4 at I/O 0x7400 (irq = 10) is a 16550A
ttyS5 at I/O 0x7408 (irq = 10) is a 16550A
ttyS6 at I/O 0x7410 (irq = 10) is a 16550A
ttyS7 at I/O 0x7418 (irq = 10) is a 16550A
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Missing spin_lock_init() made the Mux driver hang on SMP systems.
Fix up users of ->hpa to use ->hpa.start instead
Remove warning in 8250_gsc.c by eliminating serial_line_nr
Signed-off-by: Matthew Wilcox <willy@parisc-linux.org>
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
Convert pa_dev->hpa from an unsigned long to a struct resource.
Fix up users of ->hpa to use ->hpa.start instead.
Make /sys/bus/parisc/drivers look better by cleaning up parisc_driver
names.
The modem is said to work with belows addition to pnp_dev_table[]:
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=296011
Signed-off-by: maximilian attems <janitor@sternwelten.at>
Argument does not agree.
Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp>
Patch from Lothar Wassmann
The function serial_pxa_set_termios() is calling uart_update_timeout()
with the baud rate divisor as third parameter, while
uart_update_timeout() expects the baud rate in this place.
This results in a bogus port->timeout which is proportional to the
baud rate.
Signed-off-by: Lothar Wassmann <LW@KARO-electronics.de>
Patch from Sascha Hauer
handle rts interrupt
Signed-off-by: Giancarlo Formicuccia <giancarlo.formicuccia@gmail.com>
Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de
Patch from Ben Dooks
The s3c2410 serial driver is missing static declerations
on several functions that are not exported, and have no
need of being exported outside the driver
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Incorrect uart_write_wakeup() calls cause reference to a
NULL tty pointer in sunsab and sunzilog serial drivers.
Initialise the driver's .owner field so that
the device driver can be referenced to the
module that owns it
Fix error path in imx_startup.
Signed-off-by: Giancarlo Formicuccia <gformicuccia@atinno.com>
The lock is not held when calling this function, so we
shouldn't drop then reacquire it.
Based upon a report from Jim MacBaine.
Patch from Vincent Sanders
When building the mx1ads ARM platforms the serial driver fails to compile
with GCC 4.01 due to extern/static ambiguity.
Signed-off-by: Vincent Sanders <vince@arm.linux.org.uk>
This change removes a bogus error message from the IOC4 serial driver
interrupt handler.
This error message is bogus for two reasons. First, it can never occur
given that current code takes care to initialize IOC4 in such a way that
these "unknown" interrupts could never occur. Second, this code fails to
take into account that other drivers can share the IOC4 interrupt mechanism
through SA_SHIRQ, and thus this driver is not in-fact "all-knowing".
Finally, this error message triggers every time some "unknown" interrupt
occurs -- it's not rate limited or repetition limited in any way, thereby
effectively denying use of the console device. Given its bogosity in the
first place, it's best to just get rid of it entirely.
Acked-by: Pat Gefre <pfg@sgi.com>
Signed-off-by: Brent Casavant <bcasavan@sgi.com>
It's pointless to include mach-types.h if you're not going to use
anything from it. These references were removed as a result of:
grep -lr 'asm/mach-types\.h' . | xargs grep -L 'machine_is_\|MACH_TYPE_\|MACHINE_START\|machine_type'
Add new ID to serial_cs.c; the CIS fimware override is available by the
manufacturer at http://www.sierrawireless.com . Remember to name the CIS
binary SW_7xx_SER.cis and to put it into /lib/firmware/
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Fix the following warnings produced from
drivers/char/s3c2410.c.
drivers/serial/s3c2410.c:757: warning: 'clk' may be used uninitialized
drivers/serial/s3c2410.c:756: warning: 'clksrc' may be used uninitialized
Fix up some pm_message_t types
Signed-Off-By: Richard Purdie <rpurdie@rpsys.net>
When building the ARM platforms several serial drivers fail to compile
Add support for the new Freescale 523x processor family to ColdFire
serial driver. Also set different default baud rate for MOD5272
board.
Signed-off-by: Greg Ungerer <gerg@uclinux.com>
Support for the new RBHMA4500 eval board for the TX4938. General update
from the 8250 ancestor of this driver. Replace use of deprecated
interfaces.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Acked-by: Russell King <rmk@arm.linux.org.uk>
Rather than hard-coding the platform device IDs, enumerate them.
We don't particularly care about the actual ID we get, just as
long as they're unique.
asm/segment.h varies greatly on different architectures but is clearly
deprecated. Removing all non-architecture consumers will make it easier
for us to get ride of asm/segment.h all together.
Signed-off-by: Kumar Gala <kumar.gala@freescale.com>
this is the last serial driver not using initcalls.
Cc: <jeff@uclinux.org>
Missed updating two lh7a40xuart_stop_tx calls.
