path: root/drivers/serial/uart00.c
2006-01-08[ARM] Remove EPXA10DB machine supportRussell King
EPXA10DB seems to be uncared for: - the "PLD" code has never been merged - no one has reported that this platform has been broken since at least 2.6.10 - interest seems to have dried up around March 2003. Therefore, remove EPXA10DB support. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-08-31[SERIAL] Clean up and fix tty transmission start/stopingRussell King
The start_tx and stop_tx methods were passed a flag to indicate whether the start/stop was from the tty start/stop callbacks, and some drivers used this flag to decide whether to ask the UART to immediately stop transmission (where the UART supports such a feature.) There are other cases when we wish this to occur - when CTS is lowered, or if we change from soft to hard flow control and CTS is inactive. In these cases, this flag was false, and we would allow the transmitter to drain before stopping. There is really only one case where we want to let the transmitter drain before disabling, and that's when we run out of characters to send. Hence, re-jig the start_tx and stop_tx methods to eliminate this flag, and introduce new functions for the special "disable and allow transmitter to drain" case. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
