path: root/drivers/serial/sunzilog.c
2005-06-29[PATCH] Serial: Adjust serial lockingRussell King
This patch changes the way serial ports are locked when getting modem status. This change is necessary because we will need to atomically read the modem status and take action depending on the CTS status. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-24[SPARC]: sunzilog warning fixesWilliam Lee Irwin III
From: William Lee Irwin III <wli@holomorphy.com> This small patch silences some iomem-related warnings in sunzilog.c by declaring mapped_addr as void __iomem * and inserting a cast in one case. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
