bnx2fc_queuecommand(): when allocating a new io_req, the tgt_lock
spinlock must be locked before calling bnx2fc_cmd_alloc().
The spinlock should also be kept locked until bnx2fc_post_io_req() has
been completed.
If not, a kernel thread may call bnx2fc_process_cq_compl() that extracts
the newly allocated io_req from hba->cmd_mgr->cmds and destroys it while
it is still being used by bnx2fc_post_io_req().
BUG: unable to handle kernel NULL pointer dereference at 000000000000004c
IP: [<ffffffffa03130da>] bnx2fc_init_task+0x6a/0x230 [bnx2fc]
PGD 0
Oops: 0000 [#1] SMP
last sysfs file: /sys/devices/pci0000:00/0000:00:02.0/0000:04:00.3/net/eth3/type
CPU 33
Modules linked in: autofs4 target_core_iblock target_core_file target_core_pscsi target_core_mod configfs bnx2fc cnic uio fcoe libfcoe libfc scsi_transport_fc 8021q garp scsi_tgt stp llc cpufreq_ondemand freq_table pcc_cpufreq ipt_REJECT nf_conntrack_ipv4 nf_defrag_ipv4 iptable_filter ip_tables ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables ipv6 power_meter microcode iTCO_wdt iTCO_vendor_support hpilo hpwdt sg bnx2x libcrc32c mdio serio_raw lpc_ich mfd_core shpchp ext4 jbd2 mbcache sd_mod crc_t10dif hpsa video output dm_mirror dm_region_hash dm_log dm_mod [last unloaded: scsi_wait_scan]
Pid: 7355, comm: bnx2fc_thread/3 Not tainted 2.6.32-431.el6.x86_64 #1 HP ProLiant BL460c Gen8
RIP: 0010:[<ffffffffa03130da>] [<ffffffffa03130da>] bnx2fc_init_task+0x6a/0x230 [bnx2fc]
RSP: 0018:ffff8820b0da3b68 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff882003801080 RCX: 0000000000000000
RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff882003801100
RBP: ffff8820b0da3bc8 R08: ffffffff8160d4e8 R09: 0000000000000040
R10: 0000000000000000 R11: 0000000000000000 R12: ffff88400e600e00
R13: ffff8840108fbe40 R14: ffff88200ffe5400 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff8820b0da0000(0000) knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: 000000000000004c CR3: 0000002010b67000 CR4: 00000000001407e0
Process bnx2fc_thread/3 (pid: 7355, threadinfo ffff88401f940000, task ffff884012f5f540)
Stack:
ffff8820b0da3bc8 ffffffff81527303 ffff884000000020 ffff8820b0da3bd8
<d> ffff8820b0da3b98 000000028138931a ffff88400f506078 ffff88400e600e00
<d> ffff88200ffe5400 ffff88200ffe5590 0000000000000021 0000000000000002
Call Trace:
<IRQ>
[<ffffffff81527303>] ? printk+0x41/0x46
[<ffffffffa03169bc>] bnx2fc_post_io_req+0x11c/0x440 [bnx2fc]
[<ffffffff812825b9>] ? cpumask_next_and+0x29/0x50
[<ffffffff8137ffd0>] ? scsi_done+0x0/0x60
[<ffffffffa0316df7>] bnx2fc_queuecommand+0x117/0x140 [bnx2fc]
[<ffffffff81380245>] scsi_dispatch_cmd+0xe5/0x310
[<ffffffff81388b9e>] scsi_request_fn+0x5ee/0x7a0
[<ffffffff812658f1>] __blk_run_queue+0x31/0x40
[<ffffffff81265a40>] blk_run_queue+0x30/0x50
[<ffffffff81387da6>] scsi_run_queue+0xc6/0x270
[<ffffffff81260f92>] ? elv_requeue_request+0x52/0xa0
[<ffffffff813897a0>] scsi_requeue_command+0x90/0xb0
[<ffffffff81389b84>] scsi_io_completion+0x154/0x6c0
[<ffffffff8137ff62>] scsi_finish_command+0xc2/0x130
[<ffffffff8138a255>] scsi_softirq_done+0x145/0x170
[<ffffffff8126e865>] blk_done_softirq+0x85/0xa0
[<ffffffff8107a8e1>] __do_softirq+0xc1/0x1e0
[<ffffffff8100c30c>] ? call_softirq+0x1c/0x30
[<ffffffff8100c30c>] call_softirq+0x1c/0x30
<EOI>
[<ffffffff8100fa75>] ? do_softirq+0x65/0xa0
[<ffffffff8107a40a>] local_bh_enable_ip+0x9a/0xb0
[<ffffffff8152a4eb>] _spin_unlock_bh+0x1b/0x20
[<ffffffffa0313937>] bnx2fc_process_cq_compl+0x257/0x2b0 [bnx2fc]
[<ffffffffa03114ea>] bnx2fc_percpu_io_thread+0xea/0x160 [bnx2fc]
[<ffffffffa0311400>] ? bnx2fc_percpu_io_thread+0x0/0x160 [bnx2fc]
[<ffffffff8109aef6>] kthread+0x96/0xa0
[<ffffffff8100c20a>] child_rip+0xa/0x20
[<ffffffff8109ae60>] ? kthread+0x0/0xa0
[<ffffffff8100c200>] ? child_rip+0x0/0x20
Code: 89 df 45 8b 7e 30 0f 85 75 01 00 00 89 d1 31 c0 c1 e9 03 83 e2 04 89 c9 f3 48 ab 74 06 c7 07 00 00 00 00 49 89 9c 24 88 01 00 00 <83> 7e 4c 01 b8 01 00 00 00 0f 84 e7 00 00 00 89 c2 0a 53 38 41
RIP [<ffffffffa03130da>] bnx2fc_init_task+0x6a/0x230 [bnx2fc]
RSP <ffff8820b0da3b68>
Signed-off-by: Maurizio Lombardi <mlombard@redhat.com>
Acked-by: Chad Dupuis <chad.dupuis@qlogic.com>
Function pci_enable_msix_range() may return negative values for error
conditions. So it's a bug by checking (pci_enable_msix_range() != 0)
for success and causes failure to megaraid driver when MSI is disabled.
[ 16.487267] megaraid_sas 0000:02:00.0: Controller type: iMR
[ 16.487275] genirq: Flags mismatch irq 0. 00000000 (megasas) vs. 00015a00 (tii
mer)
[ 16.487347] megasas: Failed to register IRQ for vector 0.
Fixes: 8ae80ed1734b "megaraid: Use pci_enable_msix_range() instead of pci_enable_msix()"
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
Acked-by: Sumit Saxena <sumit.saxena@avagotech.com>
Cc: <stable@vger.kernel.org> # 3.17
Connection retries were not being cleaned up correctly if they failed as a
result of link down. Applies on top of drivers-for-3.18.
Signed-off-by: Anish Bhatt <anish@chelsio.com>
Signed-off-by: Karen Xie <kxie@chelsio.com>
This patch fixes an issue with multipath ipr SAS devices which require a
start unit command to be issued following an adapter reset. Without this
patch, paths get marked failed following an adapter reset and since the
error handler never gets invoked to issue the start unit, the paths are
never recovered. Returning FAILED for this case ensures the error
handler wakes up to issue the start unit.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
Tested-by: Wen Xiong <wenxiong@linux.vnet.ibm.com>
Reviewed-by: Hannes Reinecke <hare@suse.de>
Multipath devices using the TUR path checker need to see the sense
code for a failed TUR command in their device handler. Since commit
14216561e164671ce147458653b1fea06a we always return success for mid
layer issued TUR commands before calling the device handler, which
stopped the TUR path checker from working.
Move the call to the device handler check sense method before the early
return for TUR commands to give the device handler a chance to intercept
them.
Signed-off-by: Christoph Hellwig <hch@infradead.org>
Setups that use the blk-mq I/O path can lock up if a host with a single
device that has its door locked enters EH. Make sure to only send the
command to re-lock the door to devices that actually were reset and thus
might have lost their state. Otherwise the EH code might be get blocked
on blk_get_request as all requests for non-reset devices might be in use.
Cc: stable@vger.kernel.org
Reported-by: Meelis Roos <meelis.roos@ut.ee>
Tested-by: Meelis Roos <meelis.roos@ut.ee>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
libcxgbi was always returning an ipv4 address for ISCSI_HOST_PARAM_IPADDRESS,
return appropriate address based on address family
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
To generate the right SPI tag messages we need to properly set
QUEUE_FLAG_QUEUED in the request_queue and mirror it to the
request.
Acked-by: Jens Axboe <axboe@kernel.dk>
Reported-by: Meelis Roos <mroos@linux.ee>
Tested-by: Meelis Roos <mroos@linux.ee>
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"Here are the target updates for v3.18-rc2 code. These where
originally destined for -rc1, but due to the combination of travel
last week for KVM Forum and my mistake of taking the three week merge
window literally, the pull request slipped.. Apologies for that.
Things where reasonably quiet this round. The highlights include:
- New userspace backend driver (target_core_user.ko) by Shaohua Li
and Andy Grover
- A number of cleanups in target, iscsi-taret and qla_target code
from Joern Engel
- Fix an OOPs related to queue full handling with CHECK_CONDITION
status from Quinn Tran
- Fix to disable TX completion interrupt coalescing in iser-target,
that was causing problems on some hardware
- Fix for PR APTPL metadata handling with demo-mode ACLs
I'm most excited about the new backend driver that uses UIO + shared
memory ring to dispatch I/O and control commands into user-space.
This was probably the most requested feature by users over the last
couple of years, and opens up a new area of development + porting of
existing user-space storage applications to LIO. Thanks to Shaohua +
Andy for making this happen.
Also another honorable mention, a new Xen PV SCSI driver was merged
via the xen/tip.git tree recently, which puts us now at 10 target
drivers in upstream! Thanks to David Vrabel + Juergen Gross for their
work to get this code merged"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (40 commits)
target/file: fix inclusive vfs_fsync_range() end
iser-target: Disable TX completion interrupt coalescing
target: Add force_pr_aptpl device attribute
target: Fix APTPL metadata handling for dynamic MappedLUNs
qla_target: don't delete changed nacls
target/user: Recalculate pad size inside is_ring_space_avail()
tcm_loop: Fixup tag handling
iser-target: Fix smatch warning
target/user: Fix up smatch warnings in tcmu_netlink_event
target: Add a user-passthrough backstore
target: Add documentation on the target userspace pass-through driver
uio: Export definition of struct uio_device
target: Remove unneeded check in sbc_parse_cdb
target: Fix queue full status NULL pointer for SCF_TRANSPORT_TASK_SENSE
qla_target: rearrange struct qla_tgt_prm
qla_target: improve qlt_unmap_sg()
qla_target: make some global functions static
qla_target: remove unused parameter
target: simplify core_tmr_abort_task
target: encapsulate smp_mb__after_atomic()
Pull email address change from Boaz Harrosh.
* 'for-linus' of git://git.open-osd.org/linux-open-osd:
Boaz Harrosh - fix email in Documentation
Boaz Harrosh - Fix broken email address
MAINTAINERS: Change Boaz Harrosh's email
I no longer have access to the Panasas email.
So change to an email that can always reach me.
Signed-off-by: Boaz Harrosh <ooo@electrozaur.com>
Pull block layer driver update from Jens Axboe:
"This is the block driver pull request for 3.18. Not a lot in there
this round, and nothing earth shattering.
- A round of drbd fixes from the linbit team, and an improvement in
asender performance.
- Removal of deprecated (and unused) IRQF_DISABLED flag in rsxx and
hd from Michael Opdenacker.
- Disable entropy collection from flash devices by default, from Mike
Snitzer.
- A small collection of xen blkfront/back fixes from Roger Pau Monné
and Vitaly Kuznetsov"
* 'for-3.18/drivers' of git://git.kernel.dk/linux-block:
block: disable entropy contributions for nonrot devices
xen, blkfront: factor out flush-related checks from do_blkif_request()
xen-blkback: fix leak on grant map error path
xen/blkback: unmap all persistent grants when frontend gets disconnected
rsxx: Remove deprecated IRQF_DISABLED
block: hd: remove deprecated IRQF_DISABLED
drbd: use RB_DECLARE_CALLBACKS() to define augment callbacks
drbd: compute the end before rb_insert_augmented()
drbd: Add missing newline in resync progress display in /proc/drbd
drbd: reduce lock contention in drbd_worker
drbd: Improve asender performance
drbd: Get rid of the WORK_PENDING macro
drbd: Get rid of the __no_warn and __cond_lock macros
drbd: Avoid inconsistent locking warning
drbd: Remove superfluous newline from "resync_extents" debugfs entry.
drbd: Use consistent names for all the bi_end_io callbacks
drbd: Use better variable names
Pull core block layer changes from Jens Axboe:
"This is the core block IO pull request for 3.18. Apart from the new
and improved flush machinery for blk-mq, this is all mostly bug fixes
and cleanups.
- blk-mq timeout updates and fixes from Christoph.
- Removal of REQ_END, also from Christoph. We pass it through the
->queue_rq() hook for blk-mq instead, freeing up one of the request
bits. The space was overly tight on 32-bit, so Martin also killed
REQ_KERNEL since it's no longer used.
- blk integrity updates and fixes from Martin and Gu Zheng.
- Update to the flush machinery for blk-mq from Ming Lei. Now we
have a per hardware context flush request, which both cleans up the
code should scale better for flush intensive workloads on blk-mq.
- Improve the error printing, from Rob Elliott.
- Backing device improvements and cleanups from Tejun.
- Fixup of a misplaced rq_complete() tracepoint from Hannes.
- Make blk_get_request() return error pointers, fixing up issues
where we NULL deref when a device goes bad or missing. From Joe
Lawrence.
- Prep work for drastically reducing the memory consumption of dm
devices from Junichi Nomura. This allows creating clone bio sets
without preallocating a lot of memory.
- Fix a blk-mq hang on certain combinations of queue depths and
hardware queues from me.
- Limit memory consumption for blk-mq devices for crash dump
scenarios and drivers that use crazy high depths (certain SCSI
shared tag setups). We now just use a single queue and limited
depth for that"
* 'for-3.18/core' of git://git.kernel.dk/linux-block: (58 commits)
block: Remove REQ_KERNEL
blk-mq: allocate cpumask on the home node
bio-integrity: remove the needless fail handle of bip_slab creating
block: include func name in __get_request prints
block: make blk_update_request print prefix match ratelimited prefix
blk-merge: don't compute bi_phys_segments from bi_vcnt for cloned bio
block: fix alignment_offset math that assumes io_min is a power-of-2
blk-mq: Make bt_clear_tag() easier to read
blk-mq: fix potential hang if rolling wakeup depth is too high
block: add bioset_create_nobvec()
block: use bio_clone_fast() in blk_rq_prep_clone()
block: misplaced rq_complete tracepoint
sd: Honor block layer integrity handling flags
block: Replace strnicmp with strncasecmp
block: Add T10 Protection Information functions
block: Don't merge requests if integrity flags differ
block: Integrity checksum flag
block: Relocate bio integrity flags
block: Add a disk flag to block integrity profile
block: Add prefix to block integrity profile flags
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio updates from Rusty Russell:
"One cc: stable commit, the rest are a series of minor cleanups which
have been sitting in MST's tree during my vacation. I changed a
function name and made one trivial change, then they spent two days in
linux-next"
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (25 commits)
virtio-rng: refactor probe error handling
virtio_scsi: drop scan callback
virtio_balloon: enable VQs early on restore
virtio_scsi: fix race on device removal
virito_scsi: use freezable WQ for events
virtio_net: enable VQs early on restore
virtio_console: enable VQs early on restore
virtio_scsi: enable VQs early on restore
virtio_blk: enable VQs early on restore
virtio_scsi: move kick event out from virtscsi_init
virtio_net: fix use after free on allocation failure
9p/trans_virtio: enable VQs early
virtio: add API to enable VQs early
virtio_net: minor cleanup
virtio-net: drop config_mutex
virtio_net: drop config_enable
virtio-blk: drop config_mutex
Pull networking fixes from David Miller:
1) Include fixes for netrom and dsa (Fabian Frederick and Florian
Fainelli)
2) Fix FIXED_PHY support in stmmac, from Giuseppe CAVALLARO.
3) Several SKB use after free fixes (vxlan, openvswitch, vxlan,
ip_tunnel, fou), from Li ROngQing.
4) fec driver PTP support fixes from Luwei Zhou and Nimrod Andy.
5) Use after free in virtio_net, from Michael S Tsirkin.
6) Fix flow mask handling for megaflows in openvswitch, from Pravin B
Shelar.
7) ISDN gigaset and capi bug fixes from Tilman Schmidt.
8) Fix route leak in ip_send_unicast_reply(), from Vasily Averin.
9) Fix two eBPF JIT bugs on x86, from Alexei Starovoitov.
10) TCP_SKB_CB() reorganization caused a few regressions, fixed by Cong
Wang and Eric Dumazet.
11) Don't overwrite end of SKB when parsing malformed sctp ASCONF
chunks, from Daniel Borkmann.
12) Don't call sock_kfree_s() with NULL pointers, this function also has
the side effect of adjusting the socket memory usage. From Cong Wang.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (90 commits)
bna: fix skb->truesize underestimation
net: dsa: add includes for ethtool and phy_fixed definitions
openvswitch: Set flow-key members.
netrom: use linux/uaccess.h
dsa: Fix conversion from host device to mii bus
tipc: fix bug in bundled buffer reception
ipv6: introduce tcp_v6_iif()
sfc: add support for skb->xmit_more
r8152: return -EBUSY for runtime suspend
ipv4: fix a potential use after free in fou.c
ipv4: fix a potential use after free in ip_tunnel_core.c
hyperv: Add handling of IP header with option field in netvsc_set_hash()
openvswitch: Create right mask with disabled megaflows
vxlan: fix a free after use
openvswitch: fix a use after free
ipv4: dst_entry leak in ip_send_unicast_reply()
ipv4: clean up cookie_v4_check()
ipv4: share tcp_v4_save_options() with cookie_v4_check()
ipv4: call __ip_options_echo() in cookie_v4_check()
atm: simplify lanai.c by using module_pci_driver
Identified by kbuild test robot. csk family is always set to be AF_INET or
AF_INET6, so skb will always be initialized to some value but there is no harm
in silencing the warning anyways.
Fixes : f42bb57c61fd ('cxgb4i : Fix -Wunused-function warning')
There is an extra call to dst_neigh_lookup() leftover in cxgb4i that can cause
an unreleased refcnt issue. Remove extraneous call.
Fixes : 759a0cc5a3e1b ('cxgb4i: Add ipv6 code to driver, call into libcxgbi ipv6 api')
A bunch of ipv6 related code is left on by default. While this causes no
compilation issues, there is no need to have this enabled by default. Guard
with an ipv6 check, which also takes care of a -Wunused-function warning.
cxgb4 already handles CLIP updates from a previous changeset for iw_cxgb4,
there is no need to have this functionality in cxgb4i. Remove duplicated code
Enable VQs early like we do for restore.
This makes it possible to drop the scan callback,
moving scanning into the probe function, and making
code simpler.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
We cancel event work on device removal, but an interrupt
could trigger immediately after this, and queue it
again.
To fix, set a flag.
Loosely based on patch by Paolo Bonzini
Michael S. Tsirkin noticed a race condition:
we reset device on freeze, but system WQ is still
running so it might try adding bufs to a VQ meanwhile.
To fix, switch to handling events from the freezable WQ.
Reported-by: Michael S. Tsirkin <mst@redhat.com>
virtio spec requires drivers to set DRIVER_OK before using VQs.
This is set automatically after restore returns, virtio scsi violated
this rule on restore by kicking event vq within restore.
To fix, call virtio_device_ready before using event queue.
We currently kick event within virtscsi_init,
before host is fully initialized.
This can in theory confuse guest if device
consumes the buffers immediately.
To fix, move virtscsi_kick_event_all out to scan/restore.
The kernel used to contain two functions for length-delimited,
case-insensitive string comparison, strnicmp with correct semantics and
a slightly buggy strncasecmp. The latter is the POSIX name, so strnicmp
was renamed to strncasecmp, and strnicmp made into a wrapper for the new
strncasecmp to avoid breaking existing users.
To allow the compat wrapper strnicmp to be removed at some point in the
future, and to avoid the extra indirection cost, do
s/strnicmp/strncasecmp/g.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Pull scheduler updates from Ingo Molnar:
"The main changes in this cycle were:
- Optimized support for Intel "Cluster-on-Die" (CoD) topologies (Dave
Hansen)
- Various sched/idle refinements for better idle handling (Nicolas
Pitre, Daniel Lezcano, Chuansheng Liu, Vincent Guittot)
- sched/numa updates and optimizations (Rik van Riel)
- sysbench speedup (Vincent Guittot)
- capacity calculation cleanups/refactoring (Vincent Guittot)
- Various cleanups to thread group iteration (Oleg Nesterov)
- Double-rq-lock removal optimization and various refactorings
(Kirill Tkhai)
- various sched/deadline fixes
... and lots of other changes"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (72 commits)
sched/dl: Use dl_bw_of() under rcu_read_lock_sched()
sched/fair: Delete resched_cpu() from idle_balance()
sched, time: Fix build error with 64 bit cputime_t on 32 bit systems
sched: Improve sysbench performance by fixing spurious active migration
sched/x86: Fix up typo in topology detection
x86, sched: Add new topology for multi-NUMA-node CPUs
sched/rt: Use resched_curr() in task_tick_rt()
sched: Use rq->rd in sched_setaffinity() under RCU read lock
sched: cleanup: Rename 'out_unlock' to 'out_free_new_mask'
sched: Use dl_bw_of() under RCU read lock
sched/fair: Remove duplicate code from can_migrate_task()
sched, mips, ia64: Remove __ARCH_WANT_UNLOCKED_CTXSW
sched: print_rq(): Don't use tasklist_lock
sched: normalize_rt_tasks(): Don't use _irqsave for tasklist_lock, use task_rq_lock()
sched: Fix the task-group check in tg_has_rt_tasks()
sched/fair: Leverage the idle state info when choosing the "idlest" cpu
sched: Let the scheduler see CPU idle states
sched/deadline: Fix inter- exclusive cpusets migrations
sched/deadline: Clear dl_entity params when setscheduling to different class
sched/numa: Kill the wrong/dead TASK_DEAD check in task_numa_fault()
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull Xen updates from David Vrabel:
"Features and fixes:
- Add pvscsi frontend and backend drivers.
- Remove _PAGE_IOMAP PTE flag, freeing it for alternate uses.
- Try and keep memory contiguous during PV memory setup (reduces
SWIOTLB usage).
- Allow front/back drivers to use threaded irqs.
- Support large initrds in PV guests.
- Fix PVH guests in preparation for Xen 4.5"
* tag 'stable/for-linus-3.18-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (22 commits)
xen: remove DEFINE_XENBUS_DRIVER() macro
xen/xenbus: Remove BUG_ON() when error string trucated
xen/xenbus: Correct the comments for xenbus_grant_ring()
x86/xen: Set EFER.NX and EFER.SCE in PVH guests
xen: eliminate scalability issues from initrd handling
xen: sync some headers with xen tree
xen: make pvscsi frontend dependant on xenbus frontend
arm{,64}/xen: Remove "EXPERIMENTAL" in the description of the Xen options
xen-scsifront: don't deadlock if the ring becomes full
x86: remove the Xen-specific _PAGE_IOMAP PTE flag
x86/xen: do not use _PAGE_IOMAP PTE flag for I/O mappings
x86: skip check for spurious faults for non-present faults
xen/efi: Directly include needed headers
xen-scsiback: clean up a type issue in scsiback_make_tpg()
xen-scsifront: use GFP_ATOMIC under spin_lock
MAINTAINERS: Add xen pvscsi maintainer
xen-scsiback: Add Xen PV SCSI backend driver
xen-scsifront: Add Xen PV SCSI frontend driver
xen: Add Xen pvSCSI protocol description
xen/events: support threaded irqs for interdomain event channels
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"The interesting things here are:
- Turn on Config Request Retry Status Software Visibility. This
caused hangs last time, but we included a fix this time.
- Rework PCI device configuration to use _HPP/_HPX more aggressively
- Allow PCI devices to be put into D3cold during system suspend
- Add arm64 PCI support
- Add APM X-Gene host bridge driver
- Add TI Keystone host bridge driver
- Add Xilinx AXI host bridge driver
More detailed summary:
Enumeration
- Check Vendor ID only for Config Request Retry Status (Rajat Jain)
- Enable Config Request Retry Status when supported (Rajat Jain)
- Add generic domain handling (Catalin Marinas)
- Generate uppercase hex for modalias interface class (Ricardo Ribalda Delgado)
Resource management
- Add missing MEM_64 mask in pci_assign_unassigned_bridge_resources() (Yinghai Lu)
- Increase IBM ipr SAS Crocodile BARs to at least system page size (Douglas Lehr)
PCI device hotplug
- Prevent NULL dereference during pciehp probe (Andreas Noever)
- Move _HPP & _HPX handling into core (Bjorn Helgaas)
- Apply _HPP to PCIe devices as well as PCI (Bjorn Helgaas)
- Apply _HPP/_HPX to display devices (Bjorn Helgaas)
- Preserve SERR & PARITY settings when applying _HPP/_HPX (Bjorn Helgaas)
- Preserve MPS and MRRS settings when applying _HPP/_HPX (Bjorn Helgaas)
- Apply _HPP/_HPX to all devices, not just hot-added ones (Bjorn Helgaas)
- Fix wait time in pciehp timeout message (Yinghai Lu)
- Add more pciehp Slot Control debug output (Yinghai Lu)
- Stop disabling pciehp notifications during init (Yinghai Lu)
MSI
- Remove arch_msi_check_device() (Alexander Gordeev)
- Rename pci_msi_check_device() to pci_msi_supported() (Alexander Gordeev)
- Move D0 check into pci_msi_check_device() (Alexander Gordeev)
- Remove unused kobject from struct msi_desc (Yijing Wang)
- Remove "pos" from the struct msi_desc msi_attrib (Yijing Wang)
- Add "msi_bus" sysfs MSI/MSI-X control for endpoints (Yijing Wang)
- Use __get_cached_msi_msg() instead of get_cached_msi_msg() (Yijing Wang)
- Use __read_msi_msg() instead of read_msi_msg() (Yijing Wang)
- Use __write_msi_msg() instead of write_msi_msg() (Yijing Wang)
Power management
- Drop unused runtime PM support code for PCIe ports (Rafael J. Wysocki)
- Allow PCI devices to be put into D3cold during system suspend (Rafael J. Wysocki)
AER
- Add additional AER error strings (Gong Chen)
- Make <linux/aer.h> standalone includable (Thierry Reding)
Virtualization
- Add ACS quirk for Solarflare SFC9120 & SFC9140 (Alex Williamson)
- Add ACS quirk for Intel 10G NICs (Alex Williamson)
- Add ACS quirk for AMD A88X southbridge (Marti Raudsepp)
- Remove unused pci_find_upstream_pcie_bridge(), pci_get_dma_source() (Alex Williamson)
- Add device flag helpers (Ethan Zhao)
- Assume all Mellanox devices have broken INTx masking (Gavin Shan)
Generic host bridge driver
- Fix ioport_map() for !CONFIG_GENERIC_IOMAP (Liviu Dudau)
- Add pci_register_io_range() and pci_pio_to_address() (Liviu Dudau)
- Define PCI_IOBASE as the base of virtual PCI IO space (Liviu Dudau)
- Fix the conversion of IO ranges into IO resources (Liviu Dudau)
- Add pci_get_new_domain_nr() and of_get_pci_domain_nr() (Liviu Dudau)
- Add support for parsing PCI host bridge resources from DT (Liviu Dudau)
- Add pci_remap_iospace() to map bus I/O resources (Liviu Dudau)
- Add arm64 architectural support for PCI (Liviu Dudau)
APM X-Gene
- Add APM X-Gene PCIe driver (Tanmay Inamdar)
- Add arm64 DT APM X-Gene PCIe device tree nodes (Tanmay Inamdar)
Freescale i.MX6
- Probe in module_init(), not fs_initcall() (Lucas Stach)
- Delay enabling reference clock for SS until it stabilizes (Tim Harvey)
Marvell MVEBU
- Fix uninitialized variable in mvebu_get_tgt_attr() (Thomas Petazzoni)
NVIDIA Tegra
- Make sure the PCIe PLL is really reset (Eric Yuen)
- Add error path tegra_msi_teardown_irq() cleanup (Jisheng Zhang)
- Fix extended configuration space mapping (Peter Daifuku)
- Implement resource hierarchy (Thierry Reding)
- Clear CLKREQ# enable on port disable (Thierry Reding)
- Add Tegra124 support (Thierry Reding)
ST Microelectronics SPEAr13xx
- Pass config resource through reg property (Pratyush Anand)
Synopsys DesignWare
- Use NULL instead of false (Fabio Estevam)
- Parse bus-range property from devicetree (Lucas Stach)
- Use pci_create_root_bus() instead of pci_scan_root_bus() (Lucas Stach)
- Remove pci_assign_unassigned_resources() (Lucas Stach)
- Check private_data validity in single place (Lucas Stach)
- Setup and clear exactly one MSI at a time (Lucas Stach)
- Remove open-coded bitmap operations (Lucas Stach)
- Fix configuration base address when using 'reg' (Minghuan Lian)
- Fix IO resource end address calculation (Minghuan Lian)
- Rename get_msi_data() to get_msi_addr() (Minghuan Lian)
- Add get_msi_data() to pcie_host_ops (Minghuan Lian)
- Add support for v3.65 hardware (Murali Karicheri)
- Fold struct pcie_port_info into struct pcie_port (Pratyush Anand)
TI Keystone
- Add TI Keystone PCIe driver (Murali Karicheri)
- Limit MRSS for all downstream devices (Murali Karicheri)
- Assume controller is already in RC mode (Murali Karicheri)
- Set device ID based on SoC to support multiple ports (Murali Karicheri)
Xilinx AXI
- Add Xilinx AXI PCIe driver (Srikanth Thokala)
- Fix xilinx_pcie_assign_msi() return value test (Dan Carpenter)
Miscellaneous
- Clean up whitespace (Quentin Lambert)
- Remove assignments from "if" conditions (Quentin Lambert)
- Move PCI_VENDOR_ID_VMWARE to pci_ids.h (Francesco Ruggeri)
- x86: Mark DMI tables as initialization data (Mathias Krause)
- x86: Move __init annotation to the correct place (Mathias Krause)
- x86: Mark constants of pci_mmcfg_nvidia_mcp55() as __initconst (Mathias Krause)
- x86: Constify pci_mmcfg_probes[] array (Mathias Krause)
- x86: Mark PCI BIOS initialization code as such (Mathias Krause)
- Parenthesize PCI_DEVID and PCI_VPD_LRDT_ID parameters (Megan Kamiya)
- Remove unnecessary variable in pci_add_dynid() (Tobias Klauser)"
* tag 'pci-v3.18-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (109 commits)
arm64: dts: Add APM X-Gene PCIe device tree nodes
PCI: Add ACS quirk for AMD A88X southbridge devices
PCI: xgene: Add APM X-Gene PCIe driver
PCI: designware: Remove open-coded bitmap operations
PCI/MSI: Remove unnecessary temporary variable
PCI/MSI: Use __write_msi_msg() instead of write_msi_msg()
MSI/powerpc: Use __read_msi_msg() instead of read_msi_msg()
PCI/MSI: Use __get_cached_msi_msg() instead of get_cached_msi_msg()
PCI/MSI: Add "msi_bus" sysfs MSI/MSI-X control for endpoints
PCI/MSI: Remove "pos" from the struct msi_desc msi_attrib
PCI/MSI: Remove unused kobject from struct msi_desc
PCI/MSI: Rename pci_msi_check_device() to pci_msi_supported()
PCI/MSI: Move D0 check into pci_msi_check_device()
PCI/MSI: Remove arch_msi_check_device()
irqchip: armada-370-xp: Remove arch_msi_check_device()
PCI/MSI/PPC: Remove arch_msi_check_device()
arm64: Add architectural support for PCI
PCI: Add pci_remap_iospace() to map bus I/O resources
of/pci: Add support for parsing PCI host bridge resources from DT
of/pci: Add pci_get_new_domain_nr() and of_get_pci_domain_nr()
arch/arm64/boot/dts/apm-storm.dtsi
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI updates from James Bottomley:
"This patch set consists of the usual driver updates (megaraid_sas,
arcmsr, be2iscsi, lpfc, mpt2sas, mpt3sas, qla2xxx, ufs) plus several
assorted fixes and miscellaneous updates (including the
pci_msix_enable_range() changes that have been pending for a while)"
* tag 'scsi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (202 commits)
scsi: add a CONFIG_SCSI_MQ_DEFAULT option
ufs: definitions for phy interface
ufs: tune bkops while power managment events
ufs: Add support for clock scaling using devfreq framework
ufs: Add freq-table-hz property for UFS device
ufs: Add support for clock gating
ufs: refactor configuring power mode
ufs: add UFS power management support
ufs: introduce well known logical unit in ufs
ufs: manually add well known logical units
ufs: Active Power Mode - configuring bActiveICCLevel
ufs: improve init sequence
ufs: refactor query descriptor API support
ufs: add voting support for host controller power
ufs: Add clock initialization support
ufs: Add regulator enable support
ufs: Allow vendor specific initialization
scsi: don't add scsi_device if its already visible
scsi: fix the type for well known LUs
scsi: fix comment in struct Scsi_Host definition
Pull "trivial tree" updates from Jiri Kosina:
"Usual pile from trivial tree everyone is so eagerly waiting for"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Remove MN10300_PROC_MN2WS0038
mei: fix comments
treewide: Fix typos in Kconfig
kprobes: update jprobe_example.c for do_fork() change
Documentation: change "&" to "and" in Documentation/applying-patches.txt
Documentation: remove obsolete pcmcia-cs from Changes
Documentation: update links in Changes
Documentation: Docbook: Fix generated DocBook/kernel-api.xml
score: Remove GENERIC_HAS_IOMAP
gpio: fix 'CONFIG_GPIO_IRQCHIP' comments
tty: doc: Fix grammar in serial/tty
dma-debug: modify check_for_stack output
treewide: fix errors in printk
genirq: fix reference in devm_request_threaded_irq comment
treewide: fix synchronize_rcu() in comments
checkstack.pl: port to AArch64
doc: queue-sysfs: minor fixes
init/do_mounts: better syntax description
MIPS: fix comment spelling
powerpc/simpleboot: fix comment
The DEFINE_XENBUS_DRIVER() macro looks a bit weird and causes sparse
errors.
Replace the uses with standard structure definitions instead. This is
similar to pci and usb device registration.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Pull SCSI fixes from James Bottomley:
"This is a set of two small fixes, both to code which went in during
the merge window: cxgb4i has a scheduling in atomic bug in its new
ipv6 code and uas fails to work properly with the new scsi-mq code"
* tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
[SCSI] uas: disable use of blk-mq I/O path
[SCSI] cxgb4i: avoid holding mutex in interrupt context
Clear QUEUE_FLAG_ADD_RANDOM in all block drivers that set
QUEUE_FLAG_NONROT.
Historically, all block devices have automatically made entropy
contributions. But as previously stated in commit e2e1a148 ("block: add
sysfs knob for turning off disk entropy contributions"):
- On SSD disks, the completion times aren't as random as they
are for rotational drives. So it's questionable whether they
should contribute to the random pool in the first place.
- Calling add_disk_randomness() has a lot of overhead.
There are more reliable sources for randomness than non-rotational block
devices. From a security perspective it is better to err on the side of
caution than to allow entropy contributions from unreliable "random"
sources.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
The code is currently riddled with "drop the hardware_lock to avoid a
deadlock" bugs that expose races. One of those races seems to expose a
valid warning in tcm_qla2xxx_clear_nacl_from_fcport_map. Add some
bandaid to it.
Signed-off-by: Joern Engel <joern@logfs.org>
Cc: <stable@vger.kernel.org> # v3.5+
The pvscsi frontend driver requires the xenbus frontend driver. Reflect
this in Kconfig.
Signed-off-by: Juergen Gross <jgross@suse.com>
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
scsifront_action_handler() will deadlock on host->host_lock, if the
ring is full and it has to wait for entries to become available.
Reviewed-by: Juergen Gross <jgross@suse.com>
On most (non-x86) 64bit platforms this will remove 8 padding bytes
from the structure.
Remove the inline attribute. Modern compilers ignore it and the
function has grown beyond where inline made sense anyway.
Remove the BUG_ON(!cmd->sg_mapped), and instead return if sg_mapped is
not set. Every caller is doing this check, so we might as well have it
in one place instead of four.
Also removes the declarations from the header - including two
declarations without function definitions or callers.
cxgbi_inet6addr_handler() can be called in interrupt context, so use rcu
protected list while finding netdev. This is observed as a scheduling in
atomic oops when running over ipv6.
Fixes: fc8d0590d914 ("libcxgbi: Add ipv6 api to driver")
Fixes: 759a0cc5a3e1 ("cxgb4i: Add ipv6 code to driver, call into libcxgbi ipv6 api")
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Add a Kconfig option to enable the blk-mq path for SCSI by default
to ease testing and deployment in setups that know they benefit
from blk-mq.
Reviewed-by: Robert Elliott <elliott@hp.com>
Tested-by: Robert Elliott <elliott@hp.com>
- Adding some of the definitions missing in unipro.h, including power
enumeration.
- Read Modify Write Line helper function
- Indication for the type of suspend
Signed-off-by: Dolev Raviv <draviv@codeaurora.org>
Signed-off-by: Subhash Jadavani <subhashj@codeaurora.org>
Signed-off-by: Yaniv Gardi <ygardi@codeaurora.org>
Add capability to control the auto bkops during suspend.
If host explicitly enables the auto bkops (background operation) on device
then only device would perform the bkops on its own. If auto bkops is not
enabled explicitly and if the device reaches to state where it must do
background operation, device would raise the urgent bkops exception event
to host and then host will enable the auto bkops on device. This patch
adds the option to choose whether auto bkops should be enabled during
runtime suspend or not. Since we don't want to keep the device active to
perform the non critical bkops, host will enable urgent bkops only.
Keep auto-bkops enabled after resume if urgent bkops needed.
If device bkops status shows that its in critical need of executing
background operations, host should allow the device to continue doing
background operations.
The clocks for UFS device will be managed by generic DVFS (Dynamic
Voltage and Frequency Scaling) framework within kernel. This devfreq
framework works with different governors to scale the clocks. By default,
UFS devices uses simple_ondemand governor which scales the clocks up if
the load is more than upthreshold and scales down if the load is less than
downthreshold.
Signed-off-by: Sahitya Tummala <stummala@codeaurora.org>
Add freq-table-hz propery for UFS device to keep track of
<min max> frequencies supported by UFS clocks.
The UFS controller clocks can be gated after certain period of
inactivity, which is typically less than runtime suspend timeout.
In addition to clocks the link will also be put into Hibern8 mode
to save more power.
The clock gating can be turned on by enabling the capability
UFSHCD_CAP_CLK_GATING. To enable entering into Hibern8 mode as part of
clock gating, set the capability UFSHCD_CAP_HIBERN8_WITH_CLK_GATING.
The tracing events for clock gating can be enabled through debugfs as:
echo 1 > /sys/kernel/debug/tracing/events/ufs/ufshcd_clk_gating/enable
cat /sys/kernel/debug/tracing/trace_pipe
Sometimes, the device shall report its maximum power and speed
capabilities, but we might not wish to configure it to use those
maximum capabilities.
This change adds support for the vendor specific host driver to
implement power change notify callback.
To enable configuring different power modes (number of lanes,
gear number and fast/slow modes) it is necessary to split the
configuration stage from the stage that reads the device max power mode.
In addition, it is not required to read the configuration more than
once, thus the configuration is stored after reading it once.
This patch adds support for UFS device and UniPro link power management
during runtime/system PM.
Main idea is to define multiple UFS low power levels based on UFS device
and UFS link power states. This would allow any specific platform or pci
driver to choose the best suited low power level during runtime and
system suspend based on their power goals.
bkops handlig:
To put the UFS device in sleep state when bkops is disabled, first query
the bkops status from the device and enable bkops on device only if
device needs time to perform the bkops.
START_STOP handling:
Before sending START_STOP_UNIT to the device well-known logical unit
(w-lun) to make sure that the device w-lun unit attention condition is
cleared.
Write protection:
UFS device specification allows LUs to be write protected, either
permanently or power on write protected. If any LU is power on write
protected and if the card is power cycled (by powering off VCCQ and/or
VCC rails), LU's write protect status would be lost. So this means those
LUs can be written now. To ensures that UFS device is power cycled only
if the power on protect is not set for any of the LUs, check if power on
write protect is set and if device is in sleep/power-off state & link in
inactive state (Hibern8 or OFF state).
If none of the Logical Units on UFS device is power on write protected
then all UFS device power rails (VCC, VCCQ & VCCQ2) can be turned off if
UFS device is in power-off state and UFS link is in OFF state. But current
implementation would disable all device power rails even if UFS link is
not in OFF state.
Low power mode:
If UFS link is in OFF state then UFS host controller can be power collapsed
to avoid leakage current from it. Note that if UFS host controller is power
collapsed, full UFS reinitialization will be required on resume to
re-establish the link between host and device.
Signed-off-by: Sujit Reddy Thumma <sthumma@codeaurora.org>
