On the SCSI layer ioctl path there is no implicit permissions check for
ioctls (and indeed other drivers implement unprivileged ioctls). aacraid
however allows all sorts of very admin only things to be done so should
check.
Signed-off-by: Alan Cox <alan@redhat.com>
Acked-by: Mark Salyzyn <mark_salyzyn@adaptec.com>
On Mon, 11 Jun 2007 20:28:16 +0200 api wrote:
> Good day,
> When doing make menuconfig one comes across CONFIG_BLK_DEV_SD.
> The help file states that this is for scsi disks.NO MENTION IS MADE THAT
> IT IS NEEDE FOR SATA DISKS AS WELL!
> Would have saved me a lot of time if the help was up to date.
> I hope this can be changed so others can make a kernel for sata systems
> quicker.
Add help info for BLK_DEV_SD referring to its use in
SATA or PATA driver configurations.
Add help text for "ATA" indicating that it probably needs
some SCSI config symbols enabled in order to be useful.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6:
[SCSI] ESP: Don't forget to clear ESP_FLAG_RESETTING.
[SCSI] fusion: fix for BZ 8426 - massive slowdown on SCSI CD/DVD drive
drive->driver_data contains pointer to Scsi_Host not idescsi_scsi_t.
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
esp_reset_cleanup() does everything necessary except clear
the flag, so we never exit resetting state.
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
[SCSI] JAZZ ESP and SUN ESP need SPI_ATTRS
[SCSI] atari_NCR5380: update_timeout removal
[SCSI] aacraid: fix shutdown handler to also disable interrupts.
[SCSI] qla2xxx: fix timeout in qla2x00_down_timeout
[SCSI] fix CONFIG_SCSI_WAIT_SCAN=m
Reported by Meelis Roos.
Atari SCSI driver fixes: remove update_timeout kludge
Signed-off-by: Michael Schmitz <schmitz@debian.org>
Acked-by: Christoph Hellwig <hch@lst.de>
Moves quiesce, thread and interrupt shutdown into aacraid drivers'
.shutdown handler. This fix to the aac_shutdown handler will remove the
superfluous reset of the adapter during a (clean) kexec.
This fix may mitigate the active investigation 'kexec and aacraid
broken' but it is unlikely to affect the root cause (issue likely
present in both kexec and kdump). This patch reduces the chance the
problem will occur with a kexec. The fix for root cause is currently
expected to be the minimum value check to the aacraid.startup_timeout
driver variable after an adapter reset within aacraid_commit_reset.patch
submitted on 05/22/2007 and awaiting testing by Yinghai to confirm.
Signed-off-by: Mark Salyzyn <aacraid@adaptec.com>
Fix various bits of obviously-busted code which we're not happening to
compile, due to ifdefs.
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: Jan Kara <jack@ucw.cz>
Cc: James Bottomley <James.Bottomley@steeleye.com>
I have made a tool to parse the kernel that does not pre-process the
source. That means that my parser tries to parse all the code, including
code in the #else branch or code that is not often compiled because the
driver is not very used (or not used at all). So, my parser sometimes
reports parse error not originally detected by gcc. Here is my (first)
patch.
[akpm@linux-foundation.org: fix amd8111e.c]
Signed-off-by: Yoann Padioleau <padator@wanadoo.fr>
Acked-by: Matthew Wilcox <matthew@wil.cx>
Acked-by: Wim Van Sebroeck <wim@iguana.be>
Acked-by: David Woodhouse <dwmw2@infradead.org>
Acked-by: Jeff Garzik <jeff@garzik.org>
Acked-by: James Bottomley <James.Bottomley@steeleye.com>
iterations is unsigned, so it is impossible to get out of the loop
and return -ETIMEDOUT.
Signed-off-by: Bill Nottingham <notting@redhat.com>
Acked-by: Seokmann Ju <seokmann.ju@qlogic.com>
CONFIG_MODULES=y
CONFIG_SCSI=y
CONFIG_SCSI_SCAN_ASYNC=y
2.6.21-rc5-mm2 VFS panics unable to find my root on /dev/sda2, but boots
okay if I change drivers/scsi/Kconfig to "default y" instead of "default m"
for SCSI_WAIT_SCAN.
Make sure there's a late_initcall to scsi_complete_async_scans when it's
built in, so a monolithic SCSI_SCAN_ASYNC kernel can rely on the scans
being completed before trying to mount root, even if they're slow.
[akpm@linux-foundation.org: build fixes]
Signed-off-by: Hugh Dickins <hugh@veritas.com>
master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6
* 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6:
[SPARC64]: Fill holes in hypervisor APIs and fix KTSB registry.
[SPARC64]: Fix two bugs wrt. kernel 4MB TSB.
[SPARC]: Mark as emulating cmpxchg, add appropriate depends for DRM.
[SPARC]: Emulate cmpxchg like parisc
[SPARC64]: Fix _PAGE_EXEC_4U check in sun4u I-TLB miss handler.
[SPARC]: Linux always started with 9600 8N1
[SPARC64]: arch/sparc64/time.c doesn't compile on Ultra 1 (no PCI)
[SPARC64]: Eliminate NR_CPUS limitations.
[SPARC64]: Use machine description and OBP properly for cpu probing.
[SPARC64]: Negotiate hypervisor API for PCI services.
[SPARC64]: Report proper system soft state to the hypervisor.
[SPARC64]: Fix typo in sun4v_hvapi_register error handling.
[SCSI] ESP: Kill SCSI_ESP_CORE and link directly just like jazz_esp
[SCSI] jazz_esp: Converted to use esp_core.
[SPARC64]: PCI device scan is way too verbose by default.
[SERIAL] sunzilog: section mismatch fix
[SPARC32]: Removes mismatch section warnigs in sparc time.c file
[SPARC64]: Don't be picky about virtual-dma values on sun4v.
[SPARC64]: Kill unused DIE_PAGE_FAULT enum value.
[SCSI] pluto: Use wait_for_completion_timeout.
[SCSI] megaraid_sas: intercept cmd timeout and throttle io
[SCSI] fusion: Fix |/|| confusion
[SCSI] aic94xx: asd_clear_nexus should fail if the cleared task does not complete
[SCSI] aic7xxx: fix aicasm build failure with gcc-3.4.6
[SCSI] aacraid: apply commit config for reset_devices flag
[SCSI] sd: fix refcounting regression in suspend/resume routines
[SCSI] aacraid: fix panic on short Inquiry
[SCSI] aacraid: Correct sa platform support. (Was: [Bug 8469] Bad EIP value on pentium3 SMP kernel-2.6.21.1)
[SCSI] NCR53C9x: correct spelling mistake in deprecation notice
[SCSI] tgt: fix a rdma indirect transfer error bug
[SCSI] MegaRAID: Update MAINTAINERS email-id
[SCSI] stex: minor cleanup and version update
[SCSI] stex: fix reset recovery for console device
[SCSI] stex: extend hard reset wait time
[SCSI] stex: fix id mapping issue
[SCSI] ipr: Proper return codes for eh_dev_reset for SATA devices
[SCSI] zfcp: IO stall after deleting and path checker changes after reenabling zfcp devices
[SCSI] zfcp: avoid clutter in erp_dbf
Use new esp_scsi for JAZZ SCSI host adapter driver
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
eh_timed_out call back (megasas_reset_timer) is used to throttle io
to the adapter when it is called the first time for a scmd.
The MEGASAS_FW_BUSY flag is set and can_queue reduced to 16.
The can_queue is restored from completion routine in following
two conditions : 5 seconds has elapsed and
the # of outstanding cmds in FW is < 17.
Signed-off-by: Sumant Patro <sumant.patro@lsi.com>
complete
Every so often, the driver will call asd_clear_nexus to clean out a task.
It is supposed to be the case that the CLEAR NEXUS does not go on the done
list until after the task itself has been put on the done list, but for
some reason this doesn't always happen. Thus, the
wait_for_completion_timeout call times out, and we return success. This
makes libsas free the task even though the task hasn't completed, leading
to a BUG_ON message from aic94xx_hwi.c around line 341. We should return
failure from asd_clear_nexus so that libsas tries again; at a bare minimum
it shouldn't be freeing active tasks. I _think_ this will fix one of
the SCB timeout crash problems (though I've not been able to reproduce
it lately...)
Signed-off-by: Darrick J. Wong <djwong@us.ibm.com>
On Tue, 2007-05-22 at 06:51 -0500, Bob Tracy wrote:
> Second try: originally reported this back on April 17th. 2.6.X
> kernel builds started failing after I upgraded my compiler from
> gcc-3.3.X to gcc-3.4.6:
> make -C drivers/scsi/aic7xxx/aicasm
> gcc -I/usr/include -I. aicasm.c aicasm_symbol.c aicasm_gram.c aicasm_macro_gram.c aicasm_scan.c aicasm_macro_scan.c -o aicasm -ldb
> aicasm_gram.y:1948: error: conflicting types for 'yyerror'
> aicasm_gram.tab.c:3004: error: previous implicit declaration of 'yyerror' was here
> aicasm_macro_gram.y:162: error: conflicting types for 'mmerror'
> aicasm_macro_gram.tab.c:1196: error: previous implicit declaration of 'mmerror' was here
Fix is to add a prototype for yyerror and mmerror to the relevant files.
Under some conditions associated with the unclean transition to kdump,
the aacraid adapters will view the array as foreign and not export it to
prevent access and data manipulation. The solution is to submit a commit
configuration to export the devices since this is a expected behavior
when transitioning to a kdump kernel.
This patch adds the aacraid.reset_devices flag and when either this or
the global reset_devices flag is set, ensures that a commit config is
issued and extends the startup_timeout if it is set less than 5 minutes.
This patch (as909) fixes a couple of refcounting errors in the sd
driver's suspend and resume methods.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
First thing mm.h does is including sched.h solely for can_do_mlock() inline
function which has "current" dereference inside. By dealing with can_do_mlock()
mm.h can be detached from sched.h which is good. See below, why.
This patch
a) removes unconditional inclusion of sched.h from mm.h
b) makes can_do_mlock() normal function in mm/mlock.c
c) exports can_do_mlock() to not break compilation
d) adds sched.h inclusions back to files that were getting it indirectly.
e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were
getting them indirectly
Net result is:
a) mm.h users would get less code to open, read, preprocess, parse, ... if
they don't need sched.h
b) sched.h stops being dependency for significant number of files:
on x86_64 allmodconfig touching sched.h results in recompile of 4083 files,
after patch it's only 3744 (-8.3%).
Cross-compile tested on
all arm defconfigs, all mips defconfigs, all powerpc defconfigs,
alpha alpha-up
arm
i386 i386-up i386-defconfig i386-allnoconfig
ia64 ia64-up
m68k
mips
parisc parisc-up
powerpc powerpc-up
s390 s390-up
sparc sparc-up
sparc64 sparc64-up
um-x86_64
x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig
as well as my two usual configs.
Unable to handle kernel paging request at ffff8101c0000000 RIP:
[<ffffffff880b22a1>] :aacraid:aac_internal_transfer+0xd6/0xe3
PGD 8063 PUD 0
Oops: 0000 [1] SMP
last sysfs file: /block/sdb/removable
CPU 2
Modules linked in: autofs4(U) hidp(U) nfs(U) lockd(U)
fscache(U) nfs_acl(U) rfcomm(U) l2cap(U) bluetooth(U)
sunrpc(U) ipv6(U) cpufreq_ondemand(U) dm_mirror(U) dm_mod(U)
video(U) sbs(U) i2c_ec(U) button(U) battery(U) asus_acpi(U)
acpi_memhotplug(U) ac(U) parport_pc(U) lp(U) parport(U)
joydev(U) ide_cd(U) i2c_i801(U) i2c_core(U) shpchp(U)
cdrom(U) bnx2(U) sg(U) pcspkr(U) ata_piix(U) libata(U)
aacraid(U) sd_mod(U) scsi_mod(U) ext3(U) jbd(U) ehci_hcd(U)
ohci_hcd(U) uhci_hcd(U)
Pid: 2352, comm: syslogd Not tainted 2.6.18-prep #1
RIP: 0010:[<ffffffff880b22a1>] [<ffffffff880b22a1>] :aacraid:aac_internal_transfer+0xd6/0xe3
RSP: 0000:ffff8101bfd1fe68 EFLAGS: 00010083
RAX: 0000000000000063 RBX: 0000000000000008 RCX: 00000000ffd1fea0
RDX: ffffffff802da628 RSI: ffff8101c0000000 RDI: ffff8101b2a08168
RBP: ffff8101b2728010 R08: ffffffff802da628 R09: 0000000000000046
R10: 0000000000000000 R11: 0000000000000080 R12: 0000000000000010
R13: ffff8101bfd1fea8 R14: ffff8101bc74df58 R15: ffff8101bc74df58
FS: 00002aaaab0146f0(0000) GS:ffff8101bfcd2e40(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffff8101c0000000 CR3: 00000001bdecd000 CR4: 00000000000006e0
Process syslogd (pid: 2352, threadinfo ffff8101bc74c000, task ffff8101bd979040)
Stack: 0000000000000012 0000000000000036 0000000000000000 ffff8101bee9a800
ffff8101be9d3a00 ffff8101be9d3a00 ffff8101be8014f8 ffffffff880b26cc
40212227607e3141 2029282a26252423 0000000000000003 ffff810037e3a000
Call Trace:
<IRQ [<ffffffff880b26cc>] :aacraid:get_container_name_callback+0x8b/0xb5
[<ffffffff880b6f67>] :aacraid:aac_intr_normal+0x1b3/0x1f9
[<ffffffff880b8007>] :aacraid:aac_rkt_intr+0x37/0x115
[<ffffffff80099749>] __rcu_process_callbacks+0xf8/0x1a8
[<ffffffff80010705>] handle_IRQ_event+0x29/0x58
[<ffffffff800b2fe0>] __do_IRQ+0xa4/0x105
[<ffffffff80011c19>] __do_softirq+0x5e/0xd5
[<ffffffff8006a193>] do_IRQ+0xe7/0xf5
[<ffffffff8005b649>] ret_from_intr+0x0/0xa
On digging into it, it turned out that the customer was probing an
aacraid device with an INQUIRY of 8 bytes. The way aacraid works, it
was blindly trying to use aac_internal_transfer to copy the container
name to byte 16 of the inquiry data, resulting in a negative transfer
length. It then copies over the whole of kernel memory before
dropping off the end.
Fix updated and corrected by Mark Salyzyn
http://bugzilla.kernel.org/show_bug.cgi?id=8469
As discussed in the bugzilla outlined below, we have an sa based
(Mustang) RAID adapter on the system, a Dell PERC2/QC. Affected
controllers are HP NetRAID, Adaptec AAC-364, Dell PERC2/QC or Adaptec
5400S. This problem coincides with the introduction of the adapter_comm
and adapter_deliver platform functions (Message [PATCH 1/4] aacraid:
rework communication support code, January 23 2007, which initially
migrated to 2.6.21)
The panic occurs with an uninitialized adapter_deliver platform function
pointer. The enclosed patch, unmodified as tested by Rainer, solves the
problem.
This sets sg_dma_len to a proper value.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Add debug information into abort and host_reset routine.
Change ioremap to ioremap_nocache.
Version updated to 3.6.0000.1.
Signed-off-by: Ed Lin <ed.lin@promise.com>
After reset completed, the scsi error handler sends out TEST_UNIT_READY
to the device. For 'normal' devices the command will be handled by firmware.
However, because the RAID console only interfaces to scsi mid layer, the
firmware will not process the command for it. This will make the console to
be offlined right after reset. Add the handling in driver to fix this problem.
During hard bus reset of st_shasta controllers, 1 ms is not enough for
16-port controllers, although it's good for 8-port controllers. Extend the
wait time to 100 ms to allow bus resets finish successfully.
The correct internal mapping of stex controllers should be:
id:0~15, lun:0~7 (st_shasta)
id:0, lun:0~127 (st_yosemite)
id:0~127, lun:0 (st_vsc and st_vsc1)
This patch reports the internal mapping to scsi mid layer, eliminating
the translation between scsi mid layer and firmware. To achieve this
goal, we also need to:
-- fail the REPORT_LUNS command for st_shasta because the
firmware is known to not report all actual luns
-- add an entry in scsi_devindo.c to force sequential lun scan
(for st_shasta controllers)
-- fail the REPORT_LUNS command for console device
-- remove special handling of REPORT_LUNS command for
st_yosemite, as there is no translation mapping now
Currently ipr always returns success from eh_dev_reset when
called for a SATA device. If ata_do_eh is unable to recover
for some reason, this can result in commands that are still
outstanding when ata_do_eh returns. Change ipr to verify no
commands are outstanding before returning success.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (30 commits)
[ARM] Use new get_irqnr_preamble
[ARM] Ensure machine class menu is sorted alphabetically
[ARM] 4333/2: KS8695: Micrel Development board
[ARM] 4332/2: KS8695: Serial driver
[ARM] 4331/3: Support for Micrel/Kendin KS8695 processor
[ARM] 4371/1: AT91: Support for Atmel AT91SAM9RL-EK development board
[ARM] 4372/1: Define byte sizes in asm-arm/sizes.h
[ARM] 4370/3: AT91: Support for Atmel AT91SAM9RL processors.
[ARM] Update mach-types
[ARM] export symbol csum_partial_copy_from_user
[ARM] iop13xx: msi support
[ARM] stacktrace fix
[ARM] Spinlock initializer cleanup
[ARM] remove useless config option GENERIC_BUST_SPINLOCK
[ARM] 4303/3: base kernel support for TI DaVinci
[ARM] 4369/1: AT91: Fix circular dependency in header files
[ARM] 4368/1: S3C24xx: build fix
[ARM] 4364/1: AT91: LEDS on AT91SAM9261-EK
[ARM] Fix iop32x/iop33x build
[ARM] EBSA110: fix build errors caused by missing "const"
Add devres ecardm_iomap() and ecardm_iounmap() for Acorn expansion
cards. Convert all expansion card drivers to use them.
Rather than having every driver fiddle about setting its private
IRQ operations and data, provide a helper function to contain
this functionality in one place.
Arrange to remove the driver-private IRQ operations and data when
the device is removed from the driver, and remove the driver
private code to do this.
This fixes potential problems caused by drivers forgetting to
remove these hooks.
* master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6:
ide: fix PIO setup on resume for ATAPI devices
ide: legacy PCI bus order probing fixes
ide: add ide_proc_register_port()
ide: add "initializing" argument to ide_register_hw()
ide: cable detection fixes (take 2)
ide: move IDE settings handling to ide-proc.c
ide: split off ioctl handling from IDE settings (v2)
ide: make /proc/ide/ optional
ide: add ide_tune_dma() helper
ide: rework the code for selecting the best DMA transfer mode (v3)
ide: fix UDMA/MWDMA/SWDMA masks (v3)
* move
__ide_add_setting()
ide_add_setting()
__ide_remove_setting()
auto_remove_settings()
ide_find_setting_by_name()
ide_read_setting()
ide_write_setting()
set_xfer_rate()
ide_add_generic_settings()
ide_register_subdriver()
ide_unregister_subdriver()
from ide.c to ide-proc.c
* set_{io_32bit,pio_mode,using_dma}() cannot be marked static now, fix it
* rename ide_[un]register_subdriver() to ide_proc_[un]register_driver(),
update device drivers to use new names
* add CONFIG_IDE_PROC_FS=n versions of ide_proc_[un]register_driver()
and ide_add_generic_settings()
* make ide_find_setting_by_name(), ide_{read,write}_setting()
and ide_{add,remove}_proc_entries() static
* cover IDE settings code in device drivers with CONFIG_IDE_PROC_FS #ifdef,
also while at it cover with CONFIG_IDE_PROC_FS #ifdef ide_driver_t.proc
* remove bogus comment from ide.h
* cover with CONFIG_IDE_PROC_FS #ifdef .proc and .settings in ide_drive_t
Besides saner code this patch results in the IDE core smaller by ~2 kB
(on x86-32) and IDE disk driver by ~1 kB (ditto) when CONFIG_IDE_PROC_FS=n.
* do write permission and min/max checks in ide_procset_t functions
* ide-disk.c: drive->id is always available so cleanup "multcount" setting
accordingly
* ide-disk.c: "address" setting was incorrectly defined as type TYPE_INTA,
fix it by using type TYPE_BYTE and updating ide_drive_t->adressing field,
the bug didn't trigger because this IDE setting uses custom ->set function
* ide.c: add set_ksettings() for handling HDIO_SET_KEEPSETTINGS ioctl
* ide.c: add set_unmaskirq() for handling HDIO_SET_UNMASKINTR ioctl
* handle ioctls directly in generic_ide_ioclt() and idedisk_ioctl()
instead of using IDE settings to deal with them
* remove no longer needed ide_find_setting_by_ioctl() and {read,write}_ioctl
fields from ide_settings_t, also remove now unused TYPE_INTA handling
v2:
* add missing EXPORT_SYMBOL_GPL(ide_setting_sem) needed now for ide-disk
All important information/features should be already available through
sysfs and ioctl interfaces.
Add CONFIG_IDE_PROC_FS (CONFIG_SCSI_PROC_FS rip-off) config option,
disabling it makes IDE driver ~5 kB smaller (on x86-32).
While at it add CONFIG_PROC_FS=n versions of proc_ide_{create,destroy}()
and remove no longer needed #ifdefs.
Signed-off-by: Michael Opdenacker <michael@free-electrons.com>
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6:
[SPARC64]: Optimize fault kprobe handling just like powerpc.
[SPARC]: Wire up utimensat syscall.
[SPARC64]: Fix request_irq() ignored result warnings in PCI controller code.
[SPARC64]: Kill asm-sparc64/pbm.h
[ATYFB]: Fix sparc includes.
[QLA2XXX]: Fix build on sparc.
[SPARC64]: Removal of trivial pci_controller_info uses.
[SPARC64]: Move index info pci_pbm_info.
[SPARC64]: Move {setup,teardown}_msi_irq into pci_pbm_info.
[SPARC64]: Move pci_ops into pci_pbm_info.
[SPARC64] SBUS: Error interrupt registry cleanups.
[SPARC64] PCI: Use root list of pbm's instead of pci_controller_info's
[SPARC64] PCI: Kill PROM_PCIRNG_MAX and PROM_PCIIMAP_MAX.
[SPARC64] PCI: Use common routine to fetch PBM properties.
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (58 commits)
[SCSI] zfcp: clear boxed flag on unit reopen.
[SCSI] zfcp: clear adapter failed flag if an fsf request times out.
[SCSI] zfcp: rework request ID management.
[SCSI] zfcp: Fix deadlock between zfcp ERP and SCSI
[SCSI] zfcp: Locking for req_no and req_seq_no
[SCSI] zfcp: print S_ID and D_ID with 3 bytes
[SCSI] ipr: Use PCI-E reset API for new ipr adapter
[SCSI] qla2xxx: Update version number to 8.01.07-k7.
[SCSI] qla2xxx: Add MSI support.
[SCSI] qla2xxx: Correct pci_set_msi() usage semantics.
[SCSI] qla2xxx: Attempt to stop firmware only if it had been previously executed.
[SCSI] qla2xxx: Honor NVRAM port-down-retry-count settings.
[SCSI] qla2xxx: Error-out during probe() if we're unable to complete HBA initialization.
[SCSI] zfcp: Stop system after memory corruption
[SCSI] mesh: cleanup variable usage in interrupt handler
[SCSI] megaraid: replace yield() with cond_resched()
[SCSI] megaraid: fix warnings when CONFIG_PROC_FS=n
[SCSI] aacraid: correct SUN products to README
[SCSI] aacraid: superfluous adapter reset for IBM 8 series ServeRAID controllers
[SCSI] aacraid: kexec fix (reset interrupt handler)
We now use pci_device_to_OF_node() to get properties
and of_get_property() returns const pointers.
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (77 commits)
[POWERPC] Abolish powerpc_flash_init()
[POWERPC] Early serial debug support for PPC44x
[POWERPC] Support for the Ebony 440GP reference board in arch/powerpc
[POWERPC] Add device tree for Ebony
[POWERPC] Add powerpc/platforms/44x, disable platforms/4xx for now
[POWERPC] MPIC U3/U4 MSI backend
[POWERPC] MPIC MSI allocator
[POWERPC] Enable MSI mappings for MPIC
[POWERPC] Tell Phyp we support MSI
[POWERPC] RTAS MSI implementation
[POWERPC] PowerPC MSI infrastructure
[POWERPC] Rip out the existing powerpc msi stubs
[POWERPC] Remove use of 4level-fixup.h for ppc32
[POWERPC] Add powerpc PCI-E reset API implementation
[POWERPC] Holly bootwrapper
[POWERPC] Holly DTS
[POWERPC] Holly defconfig
[POWERPC] Add support for 750CL Holly board
[POWERPC] Generalize tsi108 PCI setup
[POWERPC] Generalize tsi108 PHY types
Fixed conflict in include/asm-powerpc/kdebug.h manually
Fix the last users of the deprecated SA_xxx interrupt flags.
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
Use a newly added PCI API to issue a PCI Fundamental reset
(warm reset) to a new ipr PCI-E adapter. Typically, the
ipr adapter uses the start BIST bit in config space to reset
an adapter. Issuing start BIST on this particular adapter
results in the PCI-E logic on the card losing sync, which
causes PCI-E errors, making the card unusable. The only reset
mechanism that exists on this hardware that does not have this
problem is PCI Fundamental reset (warm reset).
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com>
