update driver version
Reviewed-by: Scott Teel <scott.teel@pmcs.com>
Reviewed-by: Kevin Barnett <kevin.barnett@pmcs.com>
Reviewed-by: Tomas Henzl <thenzl@redhat.com>
Reviewed-by: Hannes Reinecke <hare@Suse.de>
Signed-off-by: Don Brace <don.brace@pmcs.com>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
add in support for latest PMC controller
Synchronize completion the reset with completion of outstanding commands
Extending the newly-added synchronous abort functionality,
now also synchronize resets with the completion of outstanding commands.
Rename the wait queue to reflect the fact that it's being used for both
types of waits. Also, don't complete commands which are terminated
due to a reset operation.
fix for controller lockup during reset
Signed-off-by: Webb Scales <webbnh@hp.com>
If hpsa_wait_for_board_state fails, hpsa_kdump_soft_reset
should propagate its return value (e.g., -ENODEV) rather
than just returning -1.
Signed-off-by: Robert Elliott <elliott@hp.com>
Rather than numbering the hpsa controllers with an
incrementing 0..n value (e.g., that shows up in
/proc/interrupts), use the scsi midlayer
host_no (e.g. matching /sys/class/scsi_host/hostNN).
Rework slave allocation:
- separate the tagging support setup from the hostdata setup
- make the hostdata setup act consistently when the lookup fails
- make the hostdata setup act consistently when the device is not added
- set up the queue depth consistently across these scenarios
- if the block layer mq support is not available, explicitly enable and
activate the SCSI layer tcq support (and do this at allocation-time so
that the tags will be available for INQUIRY commands)
Tweak slave configuration so that devices which are masked are also
not attached.
Add the interrupt number to the interrupt names that
appear in /proc/interrupts, so they are unique
Also, delete the IRQ and DAC prints. Other parts of the kernel
already print the IRQ assignments, and dual-address-cycle support
has not been interesting since the parallel PCI bus went from
32 to 64 bits wide.
Don't create the resubmit workqueue in hpsa_init_one until everything else
is ready to use, so everything can be freed in reverse order of when they
were allocated without risking freeing things while workqueue items are
still active.
Destroy the workqueue in the right order in
hpsa_undo_allocations_after_kdump_soft_reset too.
If registering the special interrupt handlers in hpsa_init_one
before a soft reset fails, the error exit needs to deallocate
everything that was allocated before.
In hpsa_undo_allocations_after_kdump_soft_reset,
the things allocated in hpsa_init_one step 2 -
h->resubmit_wq and h->lockup_detected need to
be freed, in the right order.
If try_soft_reset fails to re-allocate irqs, the error exit
starts with free_irq calls, which generate kernel WARN
messages since they were already freed a few lines earlier.
Jump to the next exit label to skip the free_irq calls.
Despite the fact that PCI devices are enabled in this order:
1. pci_enable_device
2. pci_request_regions
Documentation/PCI/pci.txt specifies that they be undone
in this order
1. pci_disable_device
2. pci_release_regions
Tested by injecting error in the call to pci_enable_device
in hpsa_init_one -> hpsa_pci_init:
[ 9.095001] hpsa 0000:04:00.0: failed to enable PCI device
[ 9.095005] hpsa: probe of 0000:04:00.0 failed with error -22
(-22 is -EINVAL)
and then in the call pci_request_regions:
[ 9.178623] hpsa 0000:04:00.0: failed to obtain PCI resources
[ 9.178671] hpsa: probe of 0000:04:00.0 failed with error -16
(-16 is -EBUSY)
and then by adding
reset_devices
to the kernel command line and inject errors into the two
calls to pci_enable_device and the call to pci_request_regions
in hpsa_init_one -> hpsa_init_reset_devices.
(inject on 6th call, 1st to hpsa2)
[ 62.413750] hpsa 0000:04:00.0: Failed to enable PCI device
(inject on 7th call, 2nd to hpsa2)
[ 62.807571] hpsa 0000:04:00.0: failed to enable device.
(inject on 8th call, 3rd to hpsa2)
[ 62.697198] hpsa 0000:04:00.0: failed to obtain PCI resources
[ 62.697234] hpsa: probe of 0000:04:00.0 failed with error -16
The reset_devices path calls return -ENODEV on failure
rather than passing the result, which apparently doesn't
cause the pci driver to print anything.
Divide the loop in hpsa_scatter_gather() into two, one for the initial SG list
and a second one for the chained list, if any. This allows the conditional
check which resets the indicies for the chained list to be performed outside
the loop instead of being done on every iteration inside the loop.
Factor out the code which sends the TEST_UNIT_READY from
wait_for_device_to_become_ready() into its own function.
Move the code which waits for the TEST_UNIT_READY from
If a logical drive has failed, resetting it will ensure
outstanding commands are completed, but polling it with
TURs after the reset will not work because the TURs will
never report good status. So successful TUR should not
be a condition of success for the device reset error
handler.
Don't return from the abort request until the target command is complete.
Mark outstanding commands which have a pending abort, and do not send them
to the host if we can avoid it.
If the current command has been aborted, do not call the SCSI command
completion routine from the I/O path: when the abort returns successfully,
the SCSI mid-layer will handle the completion implicitly.
The following race was possible in theory.
1. LLD is requested to abort a scsi command
2. scsi command completes
3. The struct CommandList associated with 2 is made available.
4. new io request to LLD to another LUN re-uses struct CommandList
5. abort handler follows scsi_cmnd->host_scribble and
finds struct CommandList and tries to aborts it.
Now we have aborted the wrong command.
Fix by resetting the scsi_cmd field of struct CommandList
upon completion and making the abort handler check that
the scsi_cmd pointer in the CommadList struct matches the
scsi_cmnd that it has been asked to abort.
cleanup command completions
add support for tmf when in ioaccel2 mode
Signed-off-by: Joe Handzik <joseph.t.handzik@hp.com>
The SCSI midlayer already prints more detail about completions,
and has logging level options to filter them if not wanted.
These just slow down the system if a lot of errors occur,
stressing error handling even more.
report more useful information on aborts
Improve initialization error handling in hpsa_init_one
Clean up style and indent issues
Rename functions for consistency
Improve error messaging on allocations
Fix return status from hpsa_put_ctlr_into_performant_mode
Correct free order in hpsa_init_one using new function
hpsa_free_performant_mode
Prevent inadvertent use of null pointers by nulling out the parent structures
and zeroing out associated size variables.
correct return codes for error conditions
cmd_alloc can no longer return NULL, so don't check for NULL any more
(which is unreachable code).
improve ioaccel2 error handling, including better handling of
underrun statuses
Increase the request size for ioaccel2 path.
The error, if any, returned by hpsa_allocate_ioaccel2_sg_chain_blocks
to hpsa_alloc_ioaccel2_cmd_and_bft should be returned upstream rather
than assumed to be -ENOMEM.
This differs slightly from hpsa_alloc_ioaccel1_cmd_and_bft,
which does not call another hpsa_allocate function and only
has -ENOMEM to return from some kmalloc calls.
refactor freeing of resources into more logical functions
refactor error cleanup and shutdown
disable interrupts and pci_disable_device on critical failures
add hpsa_free_cfgtables function
replace calls to hpsa_free_irqs_and_disable_msix with
hpsa_free_irqs and hpsa_disable_interrupt_mode
get drive queue depth to help avoid task set full conditions.
use ioaccel2 path to submit I/O to physical drives in HBA mode
offload_enabled changes are deferred until after the
added/updated prints occur, so the values are incorrect.
defer printing SSD Smart Path Enabled status information until the
information is correct
clean up command submission
allow the controller firmware to queue up commands when the ioaccel device
queue is full.
add error handling for failure when registering with SCSI subsystem.
Factor out hpsa_cmd_init from cmd_alloc(). We also need
this for resubmitting commands down the default RAID path
when they have returned from the ioaccel paths with errors.
In particular, reinitialize the cmd_type and busaddr fields as these
will not be correct for submitting down the RAID stack path
after ioaccel command completion.
This saves time when submitting commands.
make function names more consistent and meaningful
expose a detected lockup via sysfs
In hba mode, we could get sense data in descriptor format so
we need to handle that.
It's possible for CommandStatus to have value 0x0D
"TMF Function Status", which we should handle. We will get
this from a P1224 when aborting a non-existent tag, for
example. The "ScsiStatus" field of the errinfo field
will contain the TMF function status value.
make tracking of outstanding commands more robust
Do not send aborts to logical devices that do not support aborts
Instead of relying on what the Smart Array claims for supporting logical
drives, simply try an abort and see how it responds at device discovery
time. This way devices that do support aborts (e.g. MSA2000) can work
and we do not waste time trying to send aborts to logical drives that do
not support them (important for high IOPS devices.)
While rescanning devices only test whether devices support aborts
the first time we encounter a device rather than every time.
Some Smart Arrays required aborts to be sent with tags in
the wrong endian byte order. To avoid having to know about
this, we would send two aborts with tags with each endian order.
On high IOPS devices, this turns out to be not such a hot idea.
So we now have a list of the devices that got the tag backwards,
and we only send it one way.
If all available commands are outstanding and the abort handler
is invoked, the abort handler may not be able to allocate a command
and may busy-wait excessivly. Reserve a small number of commands
for the abort handler and limit the number of concurrent abort
requests to the number of reserved commands.
Allow driver initiated commands to have a timeout. It does not
yet try to do anything with timeouts on such commands.
We are sending a reset in order to get rid of a command we want to abort.
If we make it return on the same reply queue as the command we want to abort,
the completion of the aborted command will not race with the completion of
the reset command.
Rename hpsa_scsi_do_simple_cmd_core() to hpsa_scsi_do_simple_cmd(), since
this function is the interface for issuing commands to the controller and
not the "core" of that implementation. Add a parameter to it which allows
the caller to specify the reply queue to be used. Modify existing callers
to specify the default reply queue.
Rename __hpsa_scsi_do_simple_cmd_core() to hpsa_scsi_do_simple_cmd_core(),
since this routine is the "core" implementation of the "do simple command"
function and there is no longer any other function with a similar name.
Modify the existing callers of this routine (other than
hpsa_scsi_do_simple_cmd()) to instead call hpsa_scsi_do_simple_cmd(), since
it will now accept the reply_queue paramenter, and it provides a controller
lock-up check. (Also, tweak two related message strings to make them
distinct from each other.)
Submitting a command to a locked up controller always results in a timeout,
so check for controller lock-up before submitting.
This is to enable fixing a race between command completions and
abort completions on different reply queues in a subsequent patch.
We want to be able to specify which reply queue an abort completion
should occur on so that it cannot race the completion of the command
it is trying to abort.
The following race was possible in theory:
1. Abort command is sent to hardware.
2. Command to be aborted simultaneously completes on another
reply queue.
3. Hardware receives abort command, decides command has already
completed and indicates this to the driver via another different
reply queue.
4. driver processes abort completion finds that the hardware does not know
about the command, concludes that therefore the command cannot complete,
returns SUCCESS indicating to the mid-layer that the scsi_cmnd may be
re-used.
5. Command from step 2 is processed and completed back to scsi mid
layer (after we already promised that would never happen.)
Fix by forcing aborts to complete on the same reply queue as the command
they are aborting.
Piggybacking device rescanning functionality onto the lockup
detection thread is not a good idea because if the controller
locks up during device rescanning, then the thread could get
stuck, then the lockup isn't detected. Use separate work
queues for device rescanning and lockup detection.
Detect controller lockup in abort handler.
After a lockup is detected, return DO_NO_CONNECT which results in immediate
termination of commands rather than DID_ERR which results in retries.
Modify detect_controller_lockup() to return the result, to remove the need for
a separate check.
We had a mix of formats used for specifying controller, bus, target,
and lun address of devices.
change to the format used by the scsi midlayer and upper layer (2:3:0:0)
so you can easily follow the information from hpsa to scsi midlayer
to sd upper layer.
Also add this information:
- product ID
- vendor ID
- RAID level
- SSD Smath Path capable and enabled
- exposure level (sg-only)
Example:
hpsa 0000:04:00.0: added scsi 2:0:0:0: Direct-Access HP LOGICAL VOLUME RAID-0 SSDSmartPathCap+ En+ Exp=4
scsi 2:0:0:0: Direct-Access HP LOGICAL VOLUME 10.0 PQ: 0 ANSI: 5
sd 2:0:0:0: [sdr] 12501713072 512-byte logical blocks: (6.40 TB/5.82 TiB)
sd 2:0:0:0: [sdr] 4096-byte physical blocks
sd 2:0:0:0: [sdr] Attached SCSI disk
sd 2:0:0:0: Attached scsi generic sg20 type 0
Cache the ioaccel handle so that when we need to abort commands sent
down the ioaccel2 path, we can look up the LUN ID in h->dev[] instead of
having to do I/O to the controller.
Add a field to elements in h->dev[] to keep track of how the device is exposed
to the SCSI mid layer: Not at all, without an upper level driver
(no_uld_attach) or normally exposed.
Since masked physical devices are now present in h->dev[] array
it would be perfectly possible to do
echo scsi add-single-device 2 2 0 0 > /proc/scsi/scsi
and bring them online. This was previously not allowed for masked
physical devices.
Ensure that the mapping of physical disks to logical drives gets updated in a
consistent way when a RAID migration occurs and is not touched until updates
to it are complete.
now instead of doing CISS_REPORT_PHYSICAL to get the LUNID for
the physical disk in hpsa_get_pdisk_of_ioaccel2(), just get
it out of h->dev[] where we already have it cached.
do not touch phys_disk[] for ioaccel enabled logical drives during rescan
The hpsa driver touches the hardware before checking the pci-id table.
This way, especially in kdump, it may confuse the proper driver (cciss).
Signed-off-by: Tomas Henzl <thenzl@redhat.com>
Acked-by: Don Brace <Don.Brace@pmcs.com>
The driver has now been converted to DMA-API, so we should
increase the version number and remove the compilation
warning.
Signed-off-by: Hannes Reinecke <hare@suse.de>
Only required if the dma buffer has been allocated via
dma_alloc_noncoherent(), which this one is not.
With that call removed we can now also compile on ARM.
We should be using spin_lock_irqsave() when within the
interrupt handler.
DMA mapping might fail, so we need to check for errors here.
Ancient, and pretty much obsolete by now.
Unused, so remove it.
