path: root/drivers/scsi/sun_esp.c
2007-05-06[SCSI] SUNESP: sun_esp.c needs linux/delay.hDavid S. Miller
2007-04-27[SCSI] SUNESP: Complete driver rewrite to version 2.0David S. Miller
Major features: 1) Tagged queuing support. 2) Will properly negotiate for synchronous transfers even on devices that reject the wide negotiation message, such as CDROMs 3) Significantly lower kernel stack usage in interrupt handler path by elimination of function vector arrays, replaced by a top-level switch statement state machine. 4) Uses generic scsi infrastructure as much as possible to avoid code duplication. 5) Automatic request of sense data in response to CHECK_CONDITION 6) Portable to other platforms using ESP such as DEC and Sun3 systems. Signed-off-by: David S. Miller <davem@davemloft.net>
