path: root/drivers/scsi/sr.c
2006-03-23[PATCH] kill cdrom ->dev_ioctl methodChristoph Hellwig
Since early 2.4.x all cdrom drivers implement the block_device methods themselves, so they can handle additional ioctls directly instead of going through the cdrom layer. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-12[SCSI] MODULE_ALIAS_{BLOCK,CHAR}DEV_MAJOR for drivers/scsiRene Herman
Add device-major aliases in drivers/scsi, allowing kmod autoload: MODULE_ALIAS_CHARDEV_MAJOR(SCSI_CHANGER_MAJOR) MODULE_ALIAS_CHARDEV_MAJOR(OSST_MAJOR) MODULE_ALIAS_CHARDEV_MAJOR(SCSI_TAPE_MAJOR) MODULE_ALIAS_BLOCKDEV_MAJOR(SCSI_CDROM_MAJOR) MODULE_ALIAS_BLOCKDEV_MAJOR(SCSI_DISKN_MAJOR) Signed-off-by: Andrew Morton <akpm@osdl.org> Acked-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-27[SCSI] Remove devfs support from the SCSI subsystemGreg KH
As devfs has been disabled from the kernel tree for a number of months now (5 to be exact), here's a patch against 2.6.16-rc1-git1 that removes support for it from the SCSI subsystem. The patch also removes the scsi_disk devfs_name field as it's no longer needed. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-27[SCSI] SCSI core kmalloc2kzallocJes Sorensen
Change the core SCSI code to use kzalloc rather than kmalloc+memset where possible. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[SCSI] always handle REQ_BLOCK_PC requests in common codeChristoph Hellwig
LLDDs should never see REQ_BLOCK_PC requests, we can handle them just fine in the core code. There is a small behaviour change in that some check in sr's rw_intr are bypassed, but I consider the old behaviour a bug. Mike found this cleanup opportunity and provdided early patches, so all the credit goes to him, even if I redid the patches from scratch beause that was easier than forward-porting the old patches. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-12[SCSI] Mask capabilities for SCSI-1 CD driveChuck Ebbert
SCSI-1 CD drives can't do MRW or be opened for writing, so mask off those capabilities. Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Acked-by: Jens Axboe <axboe@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-12[SCSI] turn most scsi semaphores into mutexesArjan van de Ven
the scsi layer is using semaphores in a mutex way, this patch converts these into using mutexes instead Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-15Fix up SCSI mismergeJames Bottomley
I forgot to do a git-update-cache on the merged files ...
2005-12-15Merge by hand (conflicts in scsi_lib.c)James Bottomley
This merge is pretty extensive. The conflict is over the new req->retries parameter, so I had to change the prototype to scsi_setup_blk_pc_cmnd() and the usage in sd, sr and st. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-13[SCSI] Consolidate REQ_BLOCK_PC handling path (fix ipod panic)James Bottomley
This follows on from Jens' patch and consolidates all of the ULD separate handlers for REQ_BLOCK_PC into a single call which has his fix for our direction bug. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-13[SCSI] Mark some core scsi data structures constArjan van de Ven
patch below marks a few scsi core datastructures as const, so that they end up in the .rodata section and don't cacheline share with things that get dirtied Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[SCSI] use {sdev,scmd,starget,shost}_printk in generic codeJeff Garzik
rejections fixed and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[SCSI] sr: remove dead codeJayachandran C
This patch fixes an issue reported in drivers/scsi/sr.c by Coverity Error reported: Pointer returned from "scsi_cd" is never used Patch description: Remove the scsi_cd() call as it does not have any effect. Signed-off-by: Jayachandran C. <c.jayachandran@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[SCSI] move the mid-layer printk's over to shost/starget/sdev_printkJames Bottomley
This should eliminate (at least in the mid layer) to make numeric assumptions about any of the enumeration variables. As a side effect, it will also make all the messages consistent and line us up nicely for the error logging strategy (if it ever shows itself again). Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-14[SCSI] scsi: sd, sr, st, and scsi_lib all fail to copy cmd_len to new cmdTimothy Thelin
This fixes an issue in scsi command initialization from a request where sd, sr, st, and scsi_lib all fail to copy the request's cmd_len to the scsi command's cmd_len field. Signed-off-by: Timothy Thelin <timothy.thelin@wdc.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-28Merge by hand (conflicts in sr.c)James Bottomley
2005-08-28[SCSI] convert sr to scsi_execute_reqJames Bottomley
This follows almost the identical model to sd, except that there's one ioctl which returns raw sense data, so it had to use scsi_execute() instead. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-28[SCSI] convert the remaining mid-layer pieces to scsi_execute_reqJames Bottomley
After this, we just have some drivers, all the ULDs and the SPI transport class using scsi_wait_req(). Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-28[SCSI] sr.c: Fix getting wrong sizePete Zaitcev
Here's the problem. Try to do this on 2.6.12: - Kill udev and HAL - Insert a CD-ROM into a SCSI or USB CD-ROM drive - Run dd if=/dev/scd0 - cat /sys/block/sr0/size - Eject the CD, insert a different one - Run dd if=/dev/scd0 This is likely to do "access beyond the end of device", if you let it - cat /sys/block/sr0/size This shows the size of a previous CD, even though dd was supposed to revalidate the device. - Run dd if=/dev/scd0 The second run of dd works correctly! The bug was introduced in 2.5.31, when Al fixes the recursive opens in partitioning. Before, the code worked like this: - Block layer called cdrom_open directly - cdrom_open called sr_open - sr_open called check_disk_change - check_disk_change called sr_media_change - sr_media_change did cd->needs_disk_change=1 - before returning sr_open tested cd->needs_disk_change and called get_sector_size. In 2.6.12, the check_disk_change is called from cdrom_open only. Thus: - Block layer calls sr_bd_open - sr_bd_open calls cdrom_open - cdrom_open calls sr_open - sr_open tests cd->needs_disk_change, which wasn't set yet; returns - cdrom_open calls check_disk_change - check_disk_change calls sr_media_change - sr_media_change does cd->needs_disk_change=1, but nobody cares Acked by: Alexander Viro <aviro@redhat.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
