path: root/drivers/scsi/sd.c
2009-09-22const: make block_device_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-12[SCSI] fix oops during scsi scanningJames Bottomley
Chris Webb reported: p0# uname -a Linux f7ea8425-d45b-490f-a738-d181d0df6963.host.elastichosts.com 2.6.30.4-elastic-lon-p #2 SMP PREEMPT Thu Aug 20 14:30:50 BST 2009 x86_64 Intel(R) Xeon(R) CPU E5420 @ 2.50GHz GenuineIntel GNU/Linux p0# zgrep SCAN_ASYNC /proc/config.gz # CONFIG_SCSI_SCAN_ASYNC is not set p0# cat /var/log/kern/2009-08-20 [...] 15:27:10.485 kernel: scsi9 : iSCSI Initiator over TCP/IP 15:27:11.493 kernel: scsi 9:0:0:0: RAID IET Controller 0001 PQ: 0 ANSI: 5 15:27:11.493 kernel: scsi 9:0:0:0: Attached scsi generic sg6 type 12 15:27:11.495 kernel: scsi 9:0:0:1: Direct-Access IET VIRTUAL-DISK 0001 PQ: 0 ANSI: 5 15:27:11.495 kernel: sd 9:0:0:1: Attached scsi generic sg7 type 0 15:27:11.495 kernel: sd 9:0:0:1: [sdg] 4194304 512-byte hardware sectors: (2.14 GB/2.00 GiB) 15:27:11.495 kernel: sd 9:0:0:1: [sdg] Write Protect is off 15:27:11.495 kernel: sd 9:0:0:1: [sdg] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA 15:27:13.012 kernel: sdg:<6>scsi 9:0:0:1: [sdg] Unhandled error code 15:27:13.012 kernel: scsi 9:0:0:1: [sdg] Result: hostbyte=0x07 driverbyte=0x00 15:27:13.012 kernel: end_request: I/O error, dev sdg, sector 0 15:27:13.012 kernel: Buffer I/O error on device sdg, logical block 0 15:27:13.012 kernel: ldm_validate_partition_table(): Disk read failed. 15:27:13.012 kernel: unable to read partition table 15:27:13.014 kernel: BUG: unable to handle kernel NULL pointer dereference at 0000000000000010 15:27:13.014 kernel: IP: [<ffffffff803f0d77>] disk_part_iter_next+0x74/0xfd 15:27:13.014 kernel: PGD 82ad0b067 PUD 82cd7e067 PMD 0 15:27:13.014 kernel: Oops: 0000 [#1] PREEMPT SMP 15:27:13.014 kernel: last sysfs file: /sys/devices/platform/host9/session4/iscsi_session/session4/ifacename 15:27:13.014 kernel: CPU 5 15:27:13.014 kernel: Modules linked in: 15:27:13.014 kernel: Pid: 13999, comm: async/0 Not tainted 2.6.30.4-elastic-lon-p #2 X7DBN 15:27:13.014 kernel: RIP: 0010:[<ffffffff803f0d77>] [<ffffffff803f0d77>] disk_part_iter_next+0x74/0xfd 15:27:13.014 kernel: RSP: 0018:ffff88066afa3dd0 EFLAGS: 00010246 15:27:13.014 kernel: RAX: ffff88082b58a000 RBX: ffff88066afa3e00 RCX: 0000000000000000 15:27:13.014 kernel: RDX: 0000000000000000 RSI: ffff88082b58a000 RDI: 0000000000000000 15:27:13.014 kernel: RBP: ffff88066afa3df0 R08: ffff88066afa2000 R09: ffff8806a204f000 15:27:13.014 kernel: R10: 000000fb12c7d274 R11: ffff8806c2bf0628 R12: ffff88066afa3e00 15:27:13.014 kernel: R13: ffff88082c829a00 R14: 0000000000000000 R15: ffff8806bc50c920 15:27:13.014 kernel: FS: 0000000000000000(0000) GS:ffff88002818a000(0000) knlGS:0000000000000000 15:27:13.014 kernel: CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b 15:27:13.014 kernel: CR2: 0000000000000010 CR3: 000000082ade3000 CR4: 00000000000426e0 15:27:13.014 kernel: DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 15:27:13.014 kernel: DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 15:27:13.014 kernel: Process async/0 (pid: 13999, threadinfo ffff88066afa2000, task ffff8806c2bf05e0) 15:27:13.014 kernel: Stack: 15:27:13.014 kernel: 0000000000000000 ffff88066afa3e00 ffff88066afa3e00 ffff88082c829a00 15:27:13.014 kernel: ffff88066afa3e40 ffffffff80306feb ffff88082b58a000 0000000000000000 15:27:13.014 kernel: 0000000000000001 ffff8806bc50c920 ffff88066afa3e40 ffff88082b58a000 15:27:13.014 kernel: Call Trace: 15:27:13.014 kernel: [<ffffffff80306feb>] register_disk+0x122/0x13a 15:27:13.014 kernel: [<ffffffff803f0b0f>] add_disk+0xaa/0x106 15:27:13.014 kernel: [<ffffffff80493609>] sd_probe_async+0x198/0x25b 15:27:13.014 kernel: [<ffffffff80270482>] async_thread+0x10c/0x20d 15:27:13.014 kernel: [<ffffffff802545ff>] ? default_wake_function+0x0/0xf 15:27:13.014 kernel: [<ffffffff80270376>] ? async_thread+0x0/0x20d 15:27:13.014 kernel: [<ffffffff8026ad89>] kthread+0x55/0x80 15:27:13.014 kernel: [<ffffffff8022be6a>] child_rip+0xa/0x20 15:27:13.014 kernel: [<ffffffff8026ad34>] ? kthread+0x0/0x80 15:27:13.014 kernel: [<ffffffff8022be60>] ? child_rip+0x0/0x20 15:27:13.014 kernel: Code: c8 ff 80 e1 0c b9 00 00 00 00 0f 44 c1 41 83 cd ff 48 8d 7a 20 48 be ff ff ff ff 08 00 00 00 48 b9 00 00 00 00 08 00 00 00 eb 50 <8b> 42 10 41 bd 01 00 00 00 eb db 4c 63 c2 4e 8d 04 c7 4d 8b 20 15:27:13.015 kernel: RIP [<ffffffff803f0d77>] disk_part_iter_next+0x74/0xfd 15:27:13.015 kernel: RSP <ffff88066afa3dd0> 15:27:13.015 kernel: CR2: 0000000000000010 15:27:13.015 kernel: ---[ end trace 6104b56ef5590e25 ]--- The problem is caused because the async scanning split in sd.c doesn't hold any reference to the device when it kicks off the async piece. What's happening is that an iSCSI disconnect is destorying the device again *before* the async sd scanning thread even starts. Fix this by taking a reference before starting the thread and dropping it again when the thread completes. Reported-by: Chris Webb <chris@arachsys.com> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-07-30[SCSI] sd: Avoid sending extended inquiry to legacy devicesMartin K. Petersen
Some USB devices crash when we send them an inquiry with the EVPD bit set, regardless of page requested (i.e. including page 0). We only need the extended inquiry to gain access to VPD pages 0xB0 and 0xB1. These appeared in SBC2 and SBC3 respectively, so we can restrict sending the extended inquiry to devices reporting SPC3 or higher. This fixes bugzilla.kernel.org #13657. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> [jejb: added comment] Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-21sd, sr: fix Driver 'sd' needs updating messageHannes Reinecke
If a SCSI ULD driver sets blk_queue_prep_rq(), it should clean it up itself on remove(), and not from the bus callbacks. This removes the need to hook into bus->remove(), which should not be used at the same time as driver->remove(). [jejb: fix sdkp initialisation problem due to mismerge] Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-21sd: Block limits VPD supportMartin K. Petersen
Query the block limits VPD page and adjust queue minimum and optimal I/O sizes. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-21sd: Detect non-rotational devicesMartin K. Petersen
Detect non-rotational devices and set the queue flag accordingly. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-21sd: Physical block size and alignment supportMartin K. Petersen
Extract physical block size and lowest aligned LBA from READ CAPACITY(16) response and adjust queue parameters. Report physical block size and alignment when applicable. [jejb: fix up trailing whitespace] Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-12[SCSI] Merge branch 'linus'James Bottomley
Conflicts: drivers/message/fusion/mptsas.c fixed up conflict between req->data_len accessors and mptsas driver updates. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-08[SCSI] sd: fix bug in SCSI async probingJames Bottomley
The async split up of probing in sd.c created a potential failure case where something goes wrong with device_add(), but which we don't recover properly. Since, in general, asynchronous error handling is hard, move the device_add() into the asynchronous path (it should be fast) and make sure all the deferred processing cannot fail. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-22block: Do away with the notion of hardsect_sizeMartin K. Petersen
Until now we have had a 1:1 mapping between storage device physical block size and the logical block sized used when addressing the device. With SATA 4KB drives coming out that will no longer be the case. The sector size will be 4KB but the logical block size will remain 512-bytes. Hence we need to distinguish between the physical block size and the logical ditto. This patch renames hardsect_size to logical_block_size. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-22Merge branch 'master' into for-2.6.31Jens Axboe
Conflicts: drivers/block/hd.c drivers/block/mg_disk.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: convert to pos and nr_sectors accessorsTejun Heo
With recent cleanups, there is no place where low level driver directly manipulates request fields. This means that the 'hard' request fields always equal the !hard fields. Convert all rq->sectors, nr_sectors and current_nr_sectors references to accessors. While at it, drop superflous blk_rq_pos() < 0 test in swim.c. [ Impact: use pos and nr_sectors accessors ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Tested-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Mike Miller <mike.miller@hp.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Dario Ballabio <ballabio_dario@emc.com> Cc: David S. Miller <davem@davemloft.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: unsik Kim <donari75@gmail.com> Cc: Laurent Vivier <Laurent@lvivier.info> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-27[SCSI] fix sign extension with 1.5TB usb-storage LBD=yDave Hansen
Shifting an unsigned char implicitly casts it to a signed int. This caused 'lba' to sign-extend and Linux would then try READ CAPACITY 16 which was not supported by at least one drive. Using the get_unaligned_be*() helpers keeps us from having to worry about how the extension might occur. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-03[SCSI] fix recovered error handlingJames Bottomley
We have a problem with recovered error handling in that any command which goes down as BLOCK_PC but which returns a sense code of RECOVERED ERROR gets completed with -EIO. For actual SG_IO commands, this doesn't matter at all, since the error return code gets dropped in favour of req->errors which contain the SCSI completion code. However, if this command is part of the block system, then it will pay attention to the returned error code. In particularly if a SYNCHRONIZE CACHE from a barrier command completes with RECOVERED ERROR, the resulting -EIO on the barrier causes block to error the request and return it to the filesystem. Fix this by converting the -EIO for recovered error to zero, plus remove the printing of this from sd and sr so the message isn't double printed. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-17[SCSI] sd: Make revalidate less chattyMartin K. Petersen
sd_revalidate ends up being called several times during device setup. With this patch we print everything during the first scan. Subsequent invocations will only print a message if the parameter in question has actually changed (LUN capacity has increased, etc.). Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-17[SCSI] sd: Try READ CAPACITY 16 first for SBC-2 devicesMatthew Wilcox
New features are being added to the READ CAPACITY 16 results, so we want to issue it in preference to READ CAPACITY 10. Unfortunately, some devices misbehave when they see a READ CAPACITY 16, so we restrict this command to devices which claim conformance to SPC-3 (aka SBC-2), or claim they have features which are only reported in the READ CAPACITY 16 data. The READ CAPACITY 16 command is optional, even for SBC-2 devices, so we fall back to READ CAPACITY 10 if READ CAPACITY 16 fails. [jejb: don't error if device supports SBC-2 but doesn't support RC16] Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Tested-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-14[SCSI] sd: Refactor sd_read_capacity()Matthew Wilcox
The sd_read_capacity() function was about 180 lines long and included a backwards goto and a tricky state variable. Splitting out read_capacity_10() and read_capacity_16() (about 50 lines each) reduces sd_read_capacity to about 100 lines and gets rid of the backwards goto and the state variable. I've tried to avoid any behaviour change with this patch. [jejb: upped transfer request to standard recommended 32 for RC16] Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] sd: tell the user when a disk's capacity is adjustedAlan Stern
This patch (as1188) combines the tests for decrementing a drive's reported capacity and expands the comment. It also adds an informational message to the system log, informing the user when the reported value has been changed. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-05[SCSI] sd: Don't try to spin up drives that are connected to an inactive portMatthew Wilcox
We currently try to spin up drives connected to standby and unavailable ports. This will never succeed and wastes a lot of time. Fail quickly if the sense data reports the port is in standby or unavailable state. Reported-by: Narayanan Rengarajan <narayanan.rengarajan@hp.com> Tested-by: Narayanan Rengarajan <narayanan.rengarajan@hp.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-02-21[SCSI] sd: revive sd_index_lockTejun Heo
Commit f27bac2761cab5a2e212dea602d22457a9aa6943 which converted sd to use ida instead of idr incorrectly removed sd_index_lock around id allocation and free. idr/ida do have internal locks but they protect their free object lists not the allocation itself. The caller is responsible for that. This missing synchronization led to the same id being assigned to multiple devices leading to oops. Reported and tracked down by Stuart Hayes of Dell. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (45 commits) [SCSI] qla2xxx: Update version number to 8.03.00-k1. [SCSI] qla2xxx: Add ISP81XX support. [SCSI] qla2xxx: Use proper request/response queues with MQ instantiations. [SCSI] qla2xxx: Correct MQ-chain information retrieval during a firmware dump. [SCSI] qla2xxx: Collapse EFT/FCE copy procedures during a firmware dump. [SCSI] qla2xxx: Don't pollute kernel logs with ZIO/RIO status messages. [SCSI] qla2xxx: Don't fallback to interrupt-polling during re-initialization with MSI-X enabled. [SCSI] qla2xxx: Remove support for reading/writing HW-event-log. [SCSI] cxgb3i: add missing include [SCSI] scsi_lib: fix DID_RESET status problems [SCSI] fc transport: restore missing dev_loss_tmo callback to LLDD [SCSI] aha152x_cs: Fix regression that keeps driver from using shared interrupts [SCSI] sd: Correctly handle 6-byte commands with DIX [SCSI] sd: DIF: Fix tagging on platforms with signed char [SCSI] sd: DIF: Show app tag on error [SCSI] Fix error handling for DIF/DIX [SCSI] scsi_lib: don't decrement busy counters when inserting commands [SCSI] libsas: fix test for negative unsigned and typos [SCSI] a2091, gvp11: kill warn_unused_result warnings [SCSI] fusion: Move a dereference below a NULL test ... Fixed up trivial conflict due to moving the async part of sd_probe around in the async probes vs using dev_set_name() in naming.
2009-01-07fastboot: make scsi probes asynchronousArjan van de Ven
This patch makes part of the scsi probe (which is mostly device spin up and the partition scan) asynchronous. Only the part that runs after getting the device number allocated is asynchronous, ensuring that device numbering remains stable. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2009-01-02[SCSI] struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
[jejb: limit ioctl to returning 20 characters to avoid overrun on long device names and add a few more conversions] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] add residual argument to scsi_execute and scsi_execute_reqFUJITA Tomonori
scsi_execute() and scsi_execute_req() discard the residual length information. Some callers need it. This adds residual argument (optional) to scsi_execute and scsi_execute_req. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-04[PATCH 1/2] kill FMODE_NDELAY_NOWChristoph Hellwig
Update FMODE_NDELAY before each ioctl call so that we can kill the magic FMODE_NDELAY_NOW. It would be even better to do this directly in setfl(), but for that we'd need to have FMODE_NDELAY for all files, not just block special files. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (21 commits) [SCSI] sd: fix computation of the full size of the device [SCSI] lib: string_get_size(): don't hang on zero; no decimals on exact [SCSI] sun3x_esp: Convert && to || [SCSI] sd: remove command-size switching code [SCSI] 3w-9xxx: remove unnecessary local_irq_save/restore for scsi sg copy API [SCSI] 3w-xxxx: remove unnecessary local_irq_save/restore for scsi sg copy API [SCSI] fix netlink kernel-doc [SCSI] sd: Fix handling of NO_SENSE check condition [SCSI] export busy state via q->lld_busy_fn() [SCSI] refactor sdev/starget/shost busy checking [SCSI] mptfusion: Increase scsi-timeouts, similariy to the LSI 4.x driver. [SCSI] aic7xxx: Take the LED out of diagnostic mode on PM resume [SCSI] aic79xx: user visible misuse wrong SI units (not disk size!) [SCSI] ipr: use memory_read_from_buffer() [SCSI] aic79xx: fix shadowed variables [SCSI] aic79xx: fix shadowed variables, add statics [SCSI] aic7xxx: update *_shipped files [SCSI] aic7xxx: update .reg files [SCSI] aic7xxx: introduce "dont_generate_debug_code" keyword in aicasm parser [SCSI] scsi_dh: Initialize path state to be passive when path is not owned ...
2008-10-23[SCSI] sd: fix computation of the full size of the deviceH. Peter Anvin
When computing the full size of the device, we need to cast sdkp->capacity before shifting, since in some configurations sector_t can be a 32-bit number. Also, change ffz(~x) to the more idiomatic ilog2(x). Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-23[SCSI] sd: remove command-size switching codeAlan Stern
This patch (as1138) removes from sd.c some old code for switching from 10-byte commands to 6-byte commands. This code is redundant -- the switching for READ and WRITE is already handled in scsi_io_completion() and the switching for MODE SENSE is already handled in scsi_mode_sense(). (There is no comparable switch for MODE SELECT, but I doubt one is needed.) Furthermore the other handlers do a better job; they check for appropriate ASC and ASCQ values before blindly switching the size. The code in sd.c is known to cause problems with some devices by switching when it shouldn't. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-23[SCSI] sd: Fix handling of NO_SENSE check conditionJamie Wellnitz
The current handling of NO_SENSE check condition is the same as RECOVERED_ERROR, and assumes that in both cases, the I/O was fully transferred. We have seen cases of arrays returning with NO_SENSE (no error), but the I/O was not completely transferred, thus residual set. Thus, rather than return good_bytes as the entire transfer, set good_bytes to 0, so that the midlayer then applies the residual in calculating the transfer, and for sd, will fail the I/O and fall into a retry path. Signed-off-by: Jamie Wellnitz <Jamie.Wellnitz@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-21[PATCH] switch sdAl Viro
2008-10-21[PATCH] beginning of methods conversionAl Viro
To keep the size of changesets sane we split the switch by drivers; to keep the damn thing bisectable we do the following: 1) rename the affected methods, add ones with correct prototypes, make (few) callers handle both. That's this changeset. 2) for each driver convert to new methods. *ALL* drivers are converted in this series. 3) kill the old (renamed) methods. Note that it _is_ a flagday; all in-tree drivers are converted and by the end of this series no trace of old methods remain. The only reason why we do that this way is to keep the damn thing bisectable and allow per-driver debugging if anything goes wrong. New methods: open(bdev, mode) release(disk, mode) ioctl(bdev, mode, cmd, arg) /* Called without BKL */ compat_ioctl(bdev, mode, cmd, arg) locked_ioctl(bdev, mode, cmd, arg) /* Called with BKL, legacy */ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] don't mess with file in scsi_nonblockable_ioctl()Al Viro
2008-10-21[PATCH] switch scsi_cmd_ioctl() to passing fmode_tAl Viro
2008-10-21[PATCH] eliminate use of ->f_flags in block methodsAl Viro
store needed information in f_mode Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-13[SCSI] sd: Correctly handle all combinations of DIF and DIXMartin K. Petersen
The old detection code couldn't handle all possible combinations of DIX and DIF. This version does, giving priority to DIX if the controller is capable. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13[SCSI] sd: Always print actual protection_typeMartin K. Petersen
Now that we no longer use protection_type as trigger for preparing protected CDBs we can remove the places that set it to zero. This allows userland to see which protection type the device is formatted with regardless of whether the HBA supports DIF or not. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13[SCSI] sd: Issue correct protection operationMartin K. Petersen
Use the same logic to prepare RD/WRPROTECT and the protection operation. Fixes a corner case where we could issue an unprotected CDB and yet tell the HBA to do DIF to the drive. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (37 commits) [SCSI] zfcp: fix double dbf id usage [SCSI] zfcp: wait on SCSI work to be finished before proceeding with init dev [SCSI] zfcp: fix erp list usage without using locks [SCSI] zfcp: prevent fc_remote_port_delete calls for unregistered rport [SCSI] zfcp: fix deadlock caused by shared work queue tasks [SCSI] zfcp: put threshold data in hba trace [SCSI] zfcp: Simplify zfcp data structures [SCSI] zfcp: Simplify get_adapter_by_busid [SCSI] zfcp: remove all typedefs and replace them with standards [SCSI] zfcp: attach and release SAN nameserver port on demand [SCSI] zfcp: remove unused references, declarations and flags [SCSI] zfcp: Update message with input from review [SCSI] zfcp: add queue_full sysfs attribute [SCSI] scsi_dh: suppress comparison warning [SCSI] scsi_dh: add Dell product information into rdac device handler [SCSI] qla2xxx: remove the unused SCSI_QLOGIC_FC_FIRMWARE option [SCSI] qla2xxx: fix printk format warnings [SCSI] qla2xxx: Update version number to 8.02.01-k8. [SCSI] qla2xxx: Ignore payload reserved-bits during RSCN processing. [SCSI] qla2xxx: Additional residual-count corrections during UNDERRUN handling. ...
2008-10-09block: unify request timeout handlingJens Axboe
Right now SCSI and others do their own command timeout handling. Move those bits to the block layer. Instead of having a timer per command, we try to be a bit more clever and simply have one per-queue. This avoids the overhead of having to tear down and setup a timer for each command, so it will result in a lot less timer fiddling. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09SCSI sd driver calls revalidate_disk wrapper.Andrew Patterson
Modify the SCSI disk driver to call the revalidate_disk() wrapper. This allows us to do some housekeeping such as accounting for a disk being resized online. The wrapper will call sd_revalidate_disk() at the appropriate time. Signed-off-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: allow disk to have extended device numberTejun Heo
Now that disk and partition handlings are mostly unified, it's easy to allow disk to have extended device number. This patch makes add_disk() use extended device number if disk->minors is zero. Both sd and ide-disk are updated to use this. * sd_format_disk_name() is implemented which can generically determine the drive name. This removes disk number restriction stemming from limited device names. * If sd index goes over SD_MAX_DISKS (which can be increased now BTW), sd simply doesn't initialize minors letting block layer choose extended device number. * If CONFIG_DEBUG_EXT_DEVT is set, both sd and ide-disk always set minors to 0 and use extended device numbers. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: replace @ext_minors with GENHD_FL_EXT_DEVTTejun Heo
With previous changes, it's meaningless to limit the number of partitions. Replace @ext_minors with GENHD_FL_EXT_DEVT such that setting the flag allows the disk to have maximum number of allowed partitions (only limited by the number of entries in parsed_partitions as determined by MAX_PART constant). This kills not-too-pretty alloc_disk_ext[_node]() functions and makes @minors parameter to alloc_disk[_node]() unnecessary. The parameter is left alone to avoid disturbing the users. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: implement CONFIG_DEBUG_BLOCK_EXT_DEVTTejun Heo
Extended devt introduces non-contiguos device numbers. This patch implements a debug option which forces most devt allocations to be from the extended area and spreads them out. This is enabled by default if DEBUG_KERNEL is set and achieves... 1. Detects code paths in kernel or userland which expect predetermined consecutive device numbers. 2. When something goes wrong, avoid corruption as adding to the minor of earlier partition won't lead to the wrong but valid device. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09sd/ide-disk: apply extended minors to sd and ideTejun Heo
Update sd and ide-disk such that they can take advantage of extended minors. ide-disk already has 64 minors per device and currently doesn't use extended minors although after this patch it can be turned on by simply tweaking constants. sd only had 16 minors per device causing problems on certain peculiar configurations. This patch lifts the restriction and enables it to use upto 64 minors. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-03[SCSI] sd: use generic helper to print capacities in both binary and SIJames Bottomley
2008-09-11block: disable sysfs parts of the disk command filterJens Axboe
We still have life time issues with the sysfs command filter kobject, so disable it for 2.6.27 release. We can revisit this and make it work properly for 2.6.28, for 2.6.27 release it's too risky. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-08-29remove blk_register_filter and blk_unregister_filter in gendiskFUJITA Tomonori
This patch remove blk_register_filter and blk_unregister_filter in gendisk, and adds them to sd.c, sr.c. and ide-cd.c The commit abf5439370491dd6fbb4fe1a7939680d2a9bc9d4 moved cmdfilter from gendisk to request_queue. It turned out that in some subsystems multiple gendisks share a single request_queue. So we get: Using physmap partition information Creating 3 MTD partitions on "physmap-flash": 0x00000000-0x01c00000 : "User FS" 0x01c00000-0x01c40000 : "booter" kobject (8511c410): tried to init an initialized object, something is seriously wrong. Call Trace: [<8036644c>] dump_stack+0x8/0x34 [<8021f050>] kobject_init+0x50/0xcc [<8021fa18>] kobject_init_and_add+0x24/0x58 [<8021d20c>] blk_register_filter+0x4c/0x64 [<8021c194>] add_disk+0x78/0xe0 [<8027d14c>] add_mtd_blktrans_dev+0x254/0x278 [<8027c8f0>] blktrans_notify_add+0x40/0x78 [<80279c00>] add_mtd_device+0xd0/0x150 [<8027b090>] add_mtd_partitions+0x568/0x5d8 [<80285458>] physmap_flash_probe+0x2ac/0x334 [<802644f8>] driver_probe_device+0x12c/0x244 [<8026465c>] __driver_attach+0x4c/0x84 [<80263c64>] bus_for_each_dev+0x58/0xac [<802633ec>] bus_add_driver+0xc4/0x24c [<802648e0>] driver_register+0xcc/0x184 [<80100460>] _stext+0x60/0x1bc In the long term, we need to fix such subsystems but we need a quick fix now. This patch add the command filter support to only sd and sr though it might be useful for other SG_IO users (such as cciss). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Reported-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-08-05Re-introduce "[SCSI] extend the last_sector_bug flag to cover more sectors"Linus Torvalds
This re-introduces commit 2b142900784c6e38c8d39fa57d5f95ef08e735d8, which was reverted due to the regression it caused by commit fca082c9f1e11ec07efa8d2f9f13688521253f36. That regression was not root-caused by the original commit, it was just uncovered by it, and the real fix was done by Alan Stern in commit 580da34847488b404218d1d7f53b156f245f5555 ("Fix USB storage hang on command abort"). We can thus re-introduce the change that was confirmed by Alan Jenkins to be still required by his odd card reader. Cc: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-04Revert "[SCSI] extend the last_sector_bug flag to cover more sectors"Linus Torvalds
This reverts commit 2b142900784c6e38c8d39fa57d5f95ef08e735d8, since it seems to break some other USB storage devices (at least a JMicron USB to ATA bridge). As such, while it apparently fixes some cardreaders, it would need to be made conditional on the exact reader it fixes in order to avoid causing regressions. Cc: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-27[SCSI] extend the last_sector_bug flag to cover more sectorsAlan Jenkins
The last_sector_bug flag was added to work around a bug in certain usb cardreaders, where they would crash if a multiple sector read included the last sector. The original implementation avoids this by e.g. splitting an 8 sector read which includes the last sector into a 7 sector read, and a single sector read for the last sector. The flag is enabled for all USB devices. This revealed a second bug in other usb cardreaders, which crash when they get a multiple sector read which stops 1 sector short of the last sector. Affected hardware includes the Kingston "MobileLite" external USB cardreader and the internal USB cardreader on the Asus EeePC. Extend the last_sector_bug workaround to ensure that any access which touches the last 8 hardware sectors of the device is a single sector long. Requests are shrunk as necessary to meet this constraint. This gives us a safety margin against potential unknown or future bugs affecting multi-sector access to the end of the device. The two known bugs only affect the last 2 sectors. However, they suggest that these devices are prone to fencepost errors and that multi-sector access to the end of the device is not well tested. Popular OS's use multi-sector accesses, but they rarely read the last few sectors. Linux (with udev & vol_id) automatically reads sectors from the end of the device on insertion. It is assumed that single sector accesses are more thoroughly tested during development. Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Tested-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
