path: root/drivers/scsi/scsi_priv.h
2016-09-26scsi: Avoid that toggling use_blk_mq triggers a memory leakBart Van Assche
This patch avoids that the following memory leak is triggered if use_blk_mq is disabled after a SCSI host has been allocated by the ib_srp driver and before the same SCSI host is freed: unreferenced object 0xffff8803a168c568 (size 256): backtrace: [<ffffffff81620c95>] kmemleak_alloc+0x45/0xa0 [<ffffffff811bb104>] __kmalloc_node+0x1e4/0x400 [<ffffffff81309fe4>] blk_mq_alloc_tag_set+0xb4/0x230 [<ffffffff814731b7>] scsi_mq_setup_tags+0xc7/0xd0 [<ffffffff81469c26>] scsi_add_host_with_dma+0x216/0x2d0 [<ffffffffa064bef5>] srp_create_target+0xe55/0x13d0 [ib_srp] [<ffffffff8143ce23>] dev_attr_store+0x13/0x20 [<ffffffff8125f030>] sysfs_kf_write+0x40/0x50 [<ffffffff8125e397>] kernfs_fop_write+0x137/0x1c0 [<ffffffff811d8c13>] __vfs_write+0x23/0x140 [<ffffffff811d92e0>] vfs_write+0xb0/0x190 [<ffffffff811da5b4>] SyS_write+0x44/0xa0 [<ffffffff8162c8a5>] entry_SYSCALL_64_fastpath+0x18/0xa8 Fixes: 9aa9cc4221f5 ("scsi: remove the disable_blk_mq host flag") Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Martin K. Petersen <martin.petersen@oracle.com> Cc: <stable@vger.kernel.org> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-04-11scsi: disable automatic target scanHannes Reinecke
On larger installations it is useful to disable automatic LUN scanning, and only add the required LUNs via udev rules. This can speed up bootup dramatically. This patch introduces a new scan module parameter value 'manual', which works like 'none', but can be overridden by setting the 'rescan' value from scsi_scan_target to 'SCSI_SCAN_MANUAL'. And it updates all relevant callers to set the 'rescan' value to 'SCSI_SCAN_MANUAL' if invoked via the 'scan' option in sysfs. Signed-off-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Ewan D. Milne <emilne@redhat.com> Tested-by: Laurence Oberman <loberman@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2015-12-02scsi_dh: move 'dh_state' sysfs attribute to generic codeHannes Reinecke
As scsi_dh.c is now always compiled in we should be moving the 'dh_state' attribute to the generic code. Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.com> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2015-10-27scsi_dh: fix use-after-free when removing scsi deviceJunichi Nomura
The commit 1bab0de0274f ("dm-mpath, scsi_dh: don't let dm detach device handlers") removed reference counting of attached scsi device handler. As a result, handler data is freed immediately via scsi_dh->detach() in the context of scsi_remove_device() where activation request can be still in flight. This patch moves scsi_dh_handler_detach() to sdev releasing function, scsi_device_dev_release_usercontext(), at that point the device is already in quiesced state. Fixes: 1bab0de0274f ("dm-mpath, scsi_dh: don't let dm detach device handlers") Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-08-28scsi_dh: integrate into the core SCSI codeChristoph Hellwig
Stop building scsi_dh as a separate module and integrate it fully into the core SCSI code with explicit callouts at bus scan time. For now the callouts are placed at the same point as the old bus notifiers were called, but in the future we will be able to look at ALUA INQUIRY data earlier on. Note that this also means that the device handler modules need to be loaded by the time we scan the bus. The next patches will add support for autoloading device handlers at bus scan time to make sure they are always loaded if they are enabled in the kernel config. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2014-12-15SCSI / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PMRafael J. Wysocki
After commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if PM_SLEEP is selected) PM_RUNTIME is always set if PM is set, so #ifdef blocks depending on CONFIG_PM_RUNTIME may now be changed to depend on CONFIG_PM. Replace CONFIG_PM_RUNTIME with CONFIG_PM everywhere under drivers/scsi/ and in include/scsi/scsi_device.h. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Aaron Lu <aaron.lu@intel.com> Acked-by: Christoph Hellwig <hch@lst.de>
2014-11-24scsi: move scsi_dispatch_cmd to scsi_lib.cChristoph Hellwig
scsi_lib.c is where the rest of the I/O submission path lives, so move scsi_dispatch_cmd there and mark it static. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Hannes Reinecke <hare@suse.de>
2014-11-24scsi: remove scsi_next_commandChristoph Hellwig
There's only one caller left, so inline it and reduce the blk-mq vs !blk-mq diff a litte bit. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Hannes Reinecke <hare@suse.de>
2014-07-25scsi: add support for a blk-mq based I/O path.Christoph Hellwig
This patch adds support for an alternate I/O path in the scsi midlayer which uses the blk-mq infrastructure instead of the legacy request code. Use of blk-mq is fully transparent to drivers, although for now a host template field is provided to opt out of blk-mq usage in case any unforseen incompatibilities arise. In general replacing the legacy request code with blk-mq is a simple and mostly mechanical transformation. The biggest exception is the new code that deals with the fact the I/O submissions in blk-mq must happen from process context, which slightly complicates the I/O completion handler. The second biggest differences is that blk-mq is build around the concept of preallocated requests that also include driver specific data, which in SCSI context means the scsi_cmnd structure. This completely avoids dynamic memory allocations for the fast path through I/O submission. Due the preallocated requests the MQ code path exclusively uses the host-wide shared tag allocator instead of a per-LUN one. This only affects drivers actually using the block layer provided tag allocator instead of their own. Unlike the old path blk-mq always provides a tag, although drivers don't have to use it. For now the blk-mq path is disable by defauly and must be enabled using the "use_blk_mq" module parameter. Once the remaining work in the block layer to make blk-mq more suitable for slow devices is complete I hope to make it the default and eventually even remove the old code path. Based on the earlier scsi-mq prototype by Nicholas Bellinger. Thanks to Bart Van Assche and Robert Elliot for testing, benchmarking and various sugestions and code contributions. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Webb Scales <webbnh@hp.com> Acked-by: Jens Axboe <axboe@kernel.dk> Tested-by: Bart Van Assche <bvanassche@acm.org> Tested-by: Robert Elliott <elliott@hp.com>
2014-07-17scsi: use 64-bit LUNsHannes Reinecke
The SCSI standard defines 64-bit values for LUNs, and large arrays employing large or hierarchical LUN numbers become more and more common. So update the linux SCSI stack to use 64-bit LUN numbers. Signed-off-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Christoph Hellwig <hch@infradead.org> Reviewed-by: Ewan Milne <emilne@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-04-10scsi: async sd resumeDan Williams
async_schedule() sd resume work to allow disks and other devices to resume in parallel. This moves the entirety of scsi_device resume to an async context to ensure that scsi_device_resume() remains ordered with respect to the completion of the start/stop command. For the duration of the resume, new command submissions (that do not originate from the scsi-core) will be deferred (BLKPREP_DEFER). It adds a new ASYNC_DOMAIN_EXCLUSIVE(scsi_sd_pm_domain) as a container of these operations. Like scsi_sd_probe_domain it is flushed at sd_remove() time to ensure async ops do not continue past the end-of-life of the sdev. The implementation explicitly refrains from reusing scsi_sd_probe_domain directly for this purpose as it is flushed at the end of dpm_resume(), potentially defeating some of the benefit. Given sdevs are quiesced it is permissible for these resume operations to bleed past the async_synchronize_full() calls made by the driver core. We defer the resolution of which pm callback to call until scsi_dev_type_{suspend|resume} time and guarantee that the callback parameter is never NULL. With this in place the type of resume operation is encoded in the async function identifier. There is a concern that async resume could trigger PSU overload. In the enterprise, storage enclosures enforce staggered spin-up regardless of what the kernel does making async scanning safe by default. Outside of that context a user can disable asynchronous scanning via a kernel command line or CONFIG_SCSI_SCAN_ASYNC. Honor that setting when deciding whether to do resume asynchronously. Inspired by Todd's analysis and initial proposal [2]: https://01.org/suspendresume/blogs/tebrandt/2013/hard-disk-resume-optimization-simpler-approach Cc: Len Brown <len.brown@intel.com> Cc: Phillip Susi <psusi@ubuntu.com> [alan: bug fix and clean up suggestion] Acked-by: Alan Stern <stern@rowland.harvard.edu> Suggested-by: Todd Brandt <todd.e.brandt@linux.intel.com> [djbw: kick all resume work to the async queue] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-12-19[SCSI] improved eh timeout handlerHannes Reinecke
When a command runs into a timeout we need to send an 'ABORT TASK' TMF. This is typically done by the 'eh_abort_handler' LLDD callback. Conceptually, however, this function is a normal SCSI command, so there is no need to enter the error handler. This patch implements a new scsi_abort_command() function which invokes an asynchronous function scsi_eh_abort_handler() to abort the commands via the usual 'eh_abort_handler'. If abort succeeds the command is either retried or terminated, depending on the number of allowed retries. However, 'eh_eflags' records the abort, so if the retry would fail again the command is pushed onto the error handler without trying to abort it (again); it'll be cleared up from SCSI EH. [hare: smatch detected stray switch fixed] Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-07-20[SCSI] async: introduce 'async_domain' typeDan Williams
This is in preparation for teaching async_synchronize_full() to sync all pending async work, and not just on the async_running domain. This conversion is functionally equivalent, just embedding the existing list in a new async_domain type. The .registered attribute is used in a later patch to distinguish between domains that want to be flushed by async_synchronize_full() versus those that only expect async_synchronize_{full|cookie}_domain to be used for flushing. [jejb: add async.h to scsi_priv.h for struct async_domain] Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Tested-by: Eldad Zack <eldad@fogrefinery.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-07-20[SCSI] Change return type of scsi_queue_insert() into voidBart Van Assche
The return value of scsi_queue_insert() is ignored by all its callers, hence change the return type of this function into void. Signed-off-by: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Reviewed-by: Tejun Heo <tj@kernel.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-07-20[SCSI] Fix device removal NULL pointer dereferenceBart Van Assche
Use blk_queue_dead() to test whether the queue is dead instead of !sdev. Since scsi_prep_fn() may be invoked concurrently with __scsi_remove_device(), keep the queuedata (sdev) pointer in __scsi_remove_device(). This patch fixes a kernel oops that can be triggered by USB device removal. See also http://www.spinics.net/lists/linux-scsi/msg56254.html. Other changes included in this patch: - Swap the blk_cleanup_queue() and kfree() calls in scsi_host_dev_release() to make that code easier to grasp. - Remove the queue dead check from scsi_run_queue() since the queue state can change anyway at any point in that function where the queue lock is not held. - Remove the queue dead check from the start of scsi_request_fn() since it is redundant with the scsi_device_online() check. Reported-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Reviewed-by: Tejun Heo <tj@kernel.org> Cc: <stable@kernel.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-07-20[SCSI] core, classes, mpt2sas: have scsi_internal_device_unblock take new stateMike Christie
This has scsi_internal_device_unblock/scsi_target_unblock take the new state to set the devices as an argument instead of always setting to running. The patch also converts users of these functions. This allows the FC and iSCSI class to transition devices from blocked to transport-offline, so that when fast_io_fail/replacement_timeout has fired we do not set the devices back to running. Instead, we set them to SDEV_TRANSPORT_OFFLINE. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-05-17[SCSI] sd: limit the scope of the async probe domainDan Williams
sd injects and synchronizes probe work on the global kernel-wide domain. This runs into conflict with PM that wants to perform resume actions in async context: [ 494.237079] INFO: task kworker/u:3:554 blocked for more than 120 seconds. [ 494.294396] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. [ 494.360809] kworker/u:3 D 0000000000000000 0 554 2 0x00000000 [ 494.420739] ffff88012e4d3af0 0000000000000046 ffff88013200c160 ffff88012e4d3fd8 [ 494.484392] ffff88012e4d3fd8 0000000000012500 ffff8801394ea0b0 ffff88013200c160 [ 494.548038] ffff88012e4d3ae0 00000000000001e3 ffffffff81a249e0 ffff8801321c5398 [ 494.611685] Call Trace: [ 494.632649] [<ffffffff8149dd25>] schedule+0x5a/0x5c [ 494.674687] [<ffffffff8104b968>] async_synchronize_cookie_domain+0xb6/0x112 [ 494.734177] [<ffffffff810461ff>] ? __init_waitqueue_head+0x50/0x50 [ 494.787134] [<ffffffff8131a224>] ? scsi_remove_target+0x48/0x48 [ 494.837900] [<ffffffff8104b9d9>] async_synchronize_cookie+0x15/0x17 [ 494.891567] [<ffffffff8104ba49>] async_synchronize_full+0x54/0x70 <-- here we wait for async contexts to complete [ 494.943783] [<ffffffff8104b9f5>] ? async_synchronize_full_domain+0x1a/0x1a [ 495.002547] [<ffffffffa00114b1>] sd_remove+0x2c/0xa2 [sd_mod] [ 495.051861] [<ffffffff812fe94f>] __device_release_driver+0x86/0xcf [ 495.104807] [<ffffffff812fe9bd>] device_release_driver+0x25/0x32 <-- here we take device_lock() [ 853.511341] INFO: task kworker/u:4:549 blocked for more than 120 seconds. [ 853.568693] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. [ 853.635119] kworker/u:4 D ffff88013097b5d0 0 549 2 0x00000000 [ 853.695129] ffff880132773c40 0000000000000046 ffff880130790000 ffff880132773fd8 [ 853.758990] ffff880132773fd8 0000000000012500 ffff88013288a0b0 ffff880130790000 [ 853.822796] 0000000000000246 0000000000000040 ffff88013097b5c8 ffff880130790000 [ 853.886633] Call Trace: [ 853.907631] [<ffffffff8149dd25>] schedule+0x5a/0x5c [ 853.949670] [<ffffffff8149cc44>] __mutex_lock_common+0x220/0x351 [ 854.001225] [<ffffffff81304bd7>] ? device_resume+0x58/0x1c4 [ 854.049082] [<ffffffff81304bd7>] ? device_resume+0x58/0x1c4 [ 854.097011] [<ffffffff8149ce48>] mutex_lock_nested+0x2f/0x36 <-- here we wait for device_lock() [ 854.145591] [<ffffffff81304bd7>] device_resume+0x58/0x1c4 [ 854.192066] [<ffffffff81304d61>] async_resume+0x1e/0x45 [ 854.237019] [<ffffffff8104bc93>] async_run_entry_fn+0xc6/0x173 <-- ...while running in async context Provide a 'scsi_sd_probe_domain' so that async probe actions actions can be flushed without regard for the state of PM, and allow for the resume path to handle devices that have transitioned from SDEV_QUIESCE to SDEV_DEL prior to resume. Acked-by: Alan Stern <stern@rowland.harvard.edu> [alan: uplevel scsi_sd_probe_domain, clarify scsi_device_resume] Signed-off-by: Dan Williams <dan.j.williams@intel.com> [jejb: remove unneeded config guards in include file] Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-18[SCSI] scsi_pm: Fix bug in the SCSI power management handlerAlan Stern
This patch (as1520) fixes a bug in the SCSI layer's power management implementation. LUN scanning can be carried out asynchronously in do_scan_async(), and sd uses an asynchronous thread for the time-consuming parts of disk probing in sd_probe_async(). Currently nothing coordinates these async threads with system sleep transitions; they can and do attempt to continue scanning/probing SCSI devices even after the host adapter has been suspended. As one might expect, the outcome is not ideal. This is what the "prepare" stage of system suspend was created for. After the prepare callback has been called for a host, target, or device, drivers are not allowed to register any children underneath them. Currently the SCSI prepare callback is not implemented; this patch rectifies that omission. For SCSI hosts, the prepare routine calls scsi_complete_async_scans() to wait until async scanning is finished. It might be slightly more efficient to wait only until the host in question has been scanned, but there's currently no way to do that. Besides, during a sleep transition we will ultimately have to wait until all the host scanning has finished anyway. For SCSI devices, the prepare routine calls async_synchronize_full() to wait until sd probing is finished. The routine does nothing for SCSI targets, because asynchronous target scanning is done only as part of host scanning. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: <stable@kernel.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-12-15[SCSI] scsi_dh: code cleanup and remove the references to scsi_dev_infoMoger, Babu
All the handlers have now implemented the match function so We don't need to use scsi_dev_info any more for matching purposes. Signed-off-by: Babu Moger <babu.moger@netapp.com> Acked-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-03-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (170 commits) [SCSI] scsi_dh_rdac: Add MD36xxf into device list [SCSI] scsi_debug: add consecutive medium errors [SCSI] libsas: fix ata list corruption issue [SCSI] hpsa: export resettable host attribute [SCSI] hpsa: move device attributes to avoid forward declarations [SCSI] scsi_debug: Logical Block Provisioning (SBC3r26) [SCSI] sd: Logical Block Provisioning update [SCSI] Include protection operation in SCSI command trace [SCSI] hpsa: fix incorrect PCI IDs and add two new ones (2nd try) [SCSI] target: Fix volume size misreporting for volumes > 2TB [SCSI] bnx2fc: Broadcom FCoE offload driver [SCSI] fcoe: fix broken fcoe interface reset [SCSI] fcoe: precedence bug in fcoe_filter_frames() [SCSI] libfcoe: Remove stale fcoe-netdev entries [SCSI] libfcoe: Move FCOE_MTU definition from fcoe.h to libfcoe.h [SCSI] libfc: introduce __fc_fill_fc_hdr that accepts fc_hdr as an argument [SCSI] fcoe, libfc: initialize EM anchors list and then update npiv EMs [SCSI] Revert "[SCSI] libfc: fix exchange being deleted when the abort itself is timed out" [SCSI] libfc: Fixing a memory leak when destroying an interface [SCSI] megaraid_sas: Version and Changelog update ... Fix up trivial conflicts due to whitespace differences in drivers/scsi/libsas/{sas_ata.c,sas_scsi_host.c}
2011-03-15PM: Remove CONFIG_PM_OPSRafael J. Wysocki
After redefining CONFIG_PM to depend on (CONFIG_PM_SLEEP || CONFIG_PM_RUNTIME) the CONFIG_PM_OPS option is redundant and can be replaced with CONFIG_PM. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-01-24[SCSI] scsi_dh: Use scsi_devinfo functions to do matching of device_handler ↵Peter Jones
tables. Previously we were using strncmp in order to avoid having to include whitespace in the devlist, but this means "HSV1000" matches a device list entry that says "HSV100", which is wrong. This patch changes scsi_dh.c to use scsi_devinfo's matching functions instead, since they handle these cases correctly. Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-24[SCSI] Add scsi_dev_info_list_del_keyed()Peter Jones
For scsi_dh.c to use devinfo lists, we have to be able to remove entries before rmmod. Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-08-06SCSI: remove fake "address-of" expressionAlan Stern
Fake "address-of" expressions that evaluate to NULL generally confuse readers and can provoke compiler warnings. This patch (as1411) removes one such fake expression, using an "#ifdef" in its place. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-28[SCSI] implement runtime Power ManagementAlan Stern
This patch (as1398b) adds runtime PM support to the SCSI layer. Only the machanism is provided; use of it is up to the various high-level drivers, and the patch doesn't change any of them. Except for sg -- the patch expicitly prevents a device from being runtime-suspended while its sg device file is open. The implementation is simplistic. In general, hosts and targets are automatically suspended when all their children are asleep, but for them the runtime-suspend code doesn't actually do anything. (A host's runtime PM status is propagated up the device tree, though, so a runtime-PM-aware lower-level driver could power down the host adapter hardware at the appropriate times.) There are comments indicating where a transport class might be notified or some other hooks added. LUNs are runtime-suspended by calling the drivers' existing suspend handlers (and likewise for runtime-resume). Somewhat arbitrarily, the implementation delays for 100 ms before suspending an eligible LUN. This is because there typically are occasions during bootup when the same device file is opened and closed several times in quick succession. The way this all works is that the SCSI core increments a device's PM-usage count when it is registered. If a high-level driver does nothing then the device will not be eligible for runtime-suspend because of the elevated usage count. If a high-level driver wants to use runtime PM then it can call scsi_autopm_put_device() in its probe routine to decrement the usage count and scsi_autopm_get_device() in its remove routine to restore the original count. Hosts, targets, and LUNs are not suspended while they are being probed or removed, or while the error handler is running. In fact, a fairly large part of the patch consists of code to make sure that things aren't suspended at such times. [jejb: fix up compile issues in PM config variations] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-28[SCSI] convert to the new PM frameworkAlan Stern
This patch (as1397b) converts the SCSI midlayer to use the new PM callbacks (struct dev_pm_ops). A new source file, scsi_pm.c, is created to hold the new callback routines, and the existing suspend/resume code is moved there. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-09-15driver model: constify attribute groupsDavid Brownell
Let attribute group vectors be declared "const". We'd like to let most attribute metadata live in read-only sections... this is a start. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-21sd, sr: fix Driver 'sd' needs updating messageHannes Reinecke
If a SCSI ULD driver sets blk_queue_prep_rq(), it should clean it up itself on remove(), and not from the bus callbacks. This removes the need to hook into bus->remove(), which should not be used at the same time as driver->remove(). [jejb: fix sdkp initialisation problem due to mismerge] Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-21scsi_transport_spi: Blacklist Ultrium-3 tape for IU transfersJames Bottomley
There have been several bug reports which identified the Ultrium-3 tape as just hanging up on the bus during certain types of IU transfer. The identified culpret is type 0x02 (MULTIPLE COMMAND) transfers. The only way to prevent this tape wedging is to prevent it from using IU transfers at all. So this patch uses the exported blacklist matching technology to recognise the drive and force it not to use IU transfers. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-21enhance device info matching for multiple tablesJames Bottomley
The current scsi_devinfo.c matching routines use a single table for the global blacklist. However, we're developing a need to blacklist from specific transports too (notably some tape drives using SPI which don't respond well to high speed protocols). Instead of developing separate blacklist matching for each transport class needing it, enhance the current list matching to permit multiple lists. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-13PM/Hibernate: Wait for SCSI devices scan to complete during resumeRafael J. Wysocki
There is a race between resume from hibernation and the asynchronous scanning of SCSI devices and to prevent it from happening we need to call scsi_complete_async_scans() during resume from hibernation. In addition, if the resume from hibernation is userland-driven, it's better to wait for all device probes in the kernel to complete before attempting to open the resume device. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13[SCSI] modify scsi to handle new fail fast flags.Mike Christie
This checks the errors the scsi-ml determined were retryable and returns if we should fast fail it based on the request fail fast flags. Without the patch, drivers like lpfc, qla2xxx and fcoe would return DID_ERROR for what it determines is a temporary communication problem. There is no loss of connectivity at that time and the driver thinks that it would be fast to retry at the driver level. SCSI-ml will however sees fast fail on the request and DID_ERROR and will fast fail the io. This will then cause dm-multipath to fail the path and possibley switch target controllers when we should be retrying at the scsi layer. We also were fast failing device errors to dm multiapth when unless the scsi_dh modules think otherwis we want to retry at the scsi layer because multipath can only retry the IO like scsi should have done. multipath is a little dumber though because it does not what the error was for and assumes that it should fail the paths. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-09block: unify request timeout handlingJens Axboe
Right now SCSI and others do their own command timeout handling. Move those bits to the block layer. Instead of having a timer per command, we try to be a bit more clever and simply have one per-queue. This avoids the overhead of having to tear down and setup a timer for each command, so it will result in a lot less timer fiddling. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-26[SCSI] Support devices with protection informationMartin K. Petersen
Implement support for DMA of protection information for devices that are data integrity capable. - Add support for mapping an extra scatter-gather list containing the protection information. - Allocate protection scsi_data_buffer if host is DIX (integrity DMA) capable. - Accessor function for checking whether a device has protection enabled. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-22[SCSI] use default attributes for scsi_hostHannes Reinecke
This patch removes the unused sysfs attibute overwriting logic for the scsi host attibutes, and plugs them into the driver core default attribute creation. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-06Revert "scsi: revert "[SCSI] Get rid of scsi_cmnd->done""Linus Torvalds
This reverts commit ac40532ef0b8649e6f7f83859ea0de1c4ed08a19, which gets us back the original cleanup of 6f5391c283d7fdcf24bf40786ea79061919d1e1d. It turns out that the bug that was triggered by that commit was apparently not actually triggered by that commit at all, and just the testing conditions had changed enough to make it appear to be due to it. The real problem seems to have been found by Peter Osterlund: "pktcdvd sets it [block device size] when opening the /dev/pktcdvd device, but when the drive is later opened as /dev/scd0, there is nothing that sets it back. (Btw, 40944 is possible if the disk is a CDRW that was formatted with "cdrwtool -m 10236".) The problem is that pktcdvd opens the cd device in non-blocking mode when pktsetup is run, and doesn't close it again until pktsetup -d is run. The effect is that if you meanwhile open the cd device, blkdev.c:do_open() doesn't call bd_set_size() because bdev->bd_openers is non-zero." In particular, to repeat the bug (regardless of whether commit 6f5391c283d7fdcf24bf40786ea79061919d1e1d is applied or not): " 1. Start with an empty drive. 2. pktsetup 0 /dev/scd0 3. Insert a CD containing an isofs filesystem. 4. mount /dev/pktcdvd/0 /mnt/tmp 5. umount /mnt/tmp 6. Press the eject button. 7. Insert a DVD containing a non-writable filesystem. 8. mount /dev/scd0 /mnt/tmp 9. find /mnt/tmp -type f -print0 | xargs -0 sha1sum >/dev/null 10. If the DVD contains data beyond the physical size of a CD, you get I/O errors in the terminal, and dmesg reports lots of "attempt to access beyond end of device" errors." which in turn is because the nested open after the media change won't cause the size to be set properly (because the original open still holds the block device, and we only do the bd_set_size() when we don't have other people holding the device open). The proper fix for that is probably to just do something like bdev->bd_inode->i_size = (loff_t)get_capacity(disk)<<9; in fs/block_dev.c:do_open() even for the cases where we're not the original opener (but *not* call bd_set_size(), since that will also change the block size of the device). Cc: Peter Osterlund <petero2@telia.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] scsi_sysfs: restore prep_fn when ULD is removed
2008-01-02scsi: revert "[SCSI] Get rid of scsi_cmnd->done"Ingo Molnar
This reverts commit 6f5391c283d7fdcf24bf40786ea79061919d1e1d ("[SCSI] Get rid of scsi_cmnd->done") that was supposed to be a cleanup commit, but apparently it causes regressions: Bug 9370 - v2.6.24-rc2-409-g9418d5d: attempt to access beyond end of device http://bugzilla.kernel.org/show_bug.cgi?id=9370 this patch should be reintroduced in a more split-up form to make testing of it easier. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Matthew Wilcox <matthew@wil.cx> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-02[SCSI] scsi_sysfs: restore prep_fn when ULD is removedJames Bottomley
A recent bug report: http://bugzilla.kernel.org/show_bug.cgi?id=9674 Was caused because the ULDs now set their own prep functions, but don't necessarily reset the prep function back to the SCSI default when they are removed. This leads to panics if commands are sent to the device after the module is removed because the prep_fn is still pointing to the old module code. The fix for this is to implement a bus remove method that resets the prep_fn pointer correctly before calling the ULD specific driver remove method. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-12[SCSI] Get rid of scsi_cmnd->doneMatthew Wilcox
The ULD ->done callback moves into the scsi_driver. By moving the call to scsi_io_completion() from scsi_blk_pc_done() to scsi_finish_command(), we can eliminate the latter entirely. By returning 'good_bytes' from the ->done callback (rather than invoking scsi_io_completion()), we can stop exporting scsi_io_completion(). Also move the prototypes from sd.h to sd.c as they're all internal anyway. Rename sd_rw_intr to sd_done and rw_intr to sr_done. Inspired-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-27[SCSI] scsi_error.c: Export some scsi_eh_* functionsDarrick J. Wong
Export a couple of functions from scsi_error that are needed to handle failed SCSI commands from the SAS EH. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> make exports GPL and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-13[SCSI] kill scsi_rety_commandChristoph Hellwig
scsi_retry_command only has a single caller, so there is no point in having this function. Additionally the memset of the sense buffer it does is entirely superflous as scsi_request_fn already calls scsi_init_cmd_errh to perform this memset before the command is reissued. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-11[SCSI] Add ability to scan scsi busses asynchronouslyMatthew Wilcox
Since it often takes around 20-30 seconds to scan a scsi bus, it's highly advantageous to do this in parallel with other things. The bulk of this patch is ensuring that devices don't change numbering, and that all devices are discovered prior to trying to start init. For those who build SCSI as modules, there's a new scsi_wait_scan module that will ensure all bus scans are finished. This patch only handles drivers which call scsi_scan_host. Fibre Channel, SAS, SATA, USB and Firewire all need additional work. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-09-02[SCSI] SCSI and FC Transport: add netlink support for posting of transport ↵James Smart
events This patch formally adds support for the posting of FC events via netlink. It is a followup to the original RFC at: http://marc.theaimsgroup.com/?l=linux-scsi&m=114530667923464&w=2 and the initial posting at: http://marc.theaimsgroup.com/?l=linux-scsi&m=115507374832500&w=2 The patch has been updated to optimize the send path, per the discussions in the initial posting. Per discussions at the Storage Summit and at OLS, we are to use netlink for async events from transports. Also per discussions, to avoid a netlink protocol per transport, I've create a single NETLINK_SCSITRANSPORT protocol, which can then be used by all transports. This patch: - Creates new files scsi_netlink.c and scsi_netlink.h, which contains the single and shared definitions for the SCSI Transport. It is tied into the base SCSI subsystem intialization. Contains a single interface routine, scsi_send_transport_event(), for a transport to send an event (via multicast to a protocol specific group). - Creates a new scsi_netlink_fc.h file, which contains the FC netlink event messages - Adds 3 new routines to the fc transport: fc_get_event_number() - to get a FC event # fc_host_post_event() - to send a simple FC event (32 bits of data) fc_host_post_vendor_event() - to send a Vendor unique event, with arbitrary amounts of data. Note: the separation of event number allows for a LLD to send a standard event, followed by vendor-specific data for the event. Note: This patch assumes 2 prior fc transport patches have been installed: http://marc.theaimsgroup.com/?l=linux-scsi&m=115555807316329&w=2 http://marc.theaimsgroup.com/?l=linux-scsi&m=115581614930261&w=2 Sorry - next time I'll do something like making these individual patches of the same posting when I know they'll be posted closely together. Signed-off-by: James Smart <James.Smart@emulex.com> Tidy up configuration not to make SCSI always select NET Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-09[SCSI] hide EH backup data outside the scsi_cmndChristoph Hellwig
Currently struct scsi_cmnd has various fields that are used to backup original data after the corresponding fields have been overridden for EH commands. This means drivers can easily get at it and misuse it. Due to the old_ naming this doesn't happen for most of them, but two that have different names have been used wrong a lot (see previous patch). Another downside is that they unessecarily bloat the scsi_cmnd size. This patch moves them onstack in scsi_send_eh_cmnd to fix those two issues aswell as allowing future EH fixes like moving the EH command submissions to use SG lists like everything else. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-03Merge ../scsi-misc-2.6James Bottomley
Conflicts: drivers/scsi/nsp32.c drivers/scsi/pcmcia/nsp_cs.c Removal of randomness flag conflicts with SA_ -> IRQF_ global replacement. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-27[SCSI] update max sdev block limitJames Smart
Updated patch to address comments from Pat Mansfield and Michael Reed: Bumped max to 600 (10mins). Set default dev_loss_tmo to a value other than the max (30s). Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-10[SCSI] remove scsi_request infrastructureChristoph Hellwig
With Achim patch the last user (gdth) is switched away from scsi_request so we an kill it now. Also disables some code in i2o_scsi that was broken since the sg driver stopped using scsi_requests. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] remove target parent limitiationChristoph Hellwig
When James Smart fixed the issue of the userspace scan atributes crashing the system with the FC transport class he added a patch to let the transport class check if the parent is valid for a given transport class. When adding support for the integrated raid of fusion sas devices we ran into a problem with that, as it didn't allow adding virtual raid volumes without the transport class knowing about it. So this patch adds a user_scan attribute instead, that takes over from scsi_scan_host_selected if the transport class sets it and thus lets the transport class control the user-initiated scanning. As this plugs the hole about user-initiated scanning the target_parent hook goes away and we rely on callers of the scanning routines to do something sensible. For SAS this meant I had to switch from a spinlock to a mutex to synchronize the topology linked lists, in FC they were completely unsynchronized which seems wrong. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
