path: root/drivers/scsi/qlogicfc.c
2006-04-13[SCSI] remove qlogicfcJames Bottomley
All participants agree that qla2xxx can now successfully replace this. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-28[PATCH] Replace 0xff.. with correct DMA_xBIT_MASKMatthias Gehre
Replace all occurences of 0xff.. in calls to function pci_set_dma_mask() and pci_set_consistant_dma_mask() with the corresponding DMA_xBIT_MASK from linux/dma-mapping.h. Signed-off-by: Matthias Gehre <M.Gehre@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] drivers/scsi/*: use time_after() and friendsMarcelo Feitoza Parisi
They deal with wrapping correctly and are nicer to read. Signed-off-by: Marcelo Feitoza Parisi <marcelo@feitoza.com.br> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[SCSI] remove Scsi_Host_Template typedefChristoph Hellwig
2005-06-26[SCSI] remove scsi_set_deviceChristoph Hellwig
scsi_add_host is the proper place to set the device, but people copy the scsi_set_device usage from older drivers again and again. note that this leaves some legacy drivers like qlogicisp/qlogicfc without pci association in sysfs, but they're scheduled to go away soon anyway. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-04-18[PATCH] remove old scsi data direction macros
these have been wrappers for the generic dma direction bits since 2.5.x. This patch converts the few remaining drivers and removes the macros. Arjan noticed there's some hunk in here that shouldn't. Updated patch below: Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
