path: root/drivers/scsi/pmcraid.c
2010-04-11[SCSI] pmcraid: redundant check in pmcraid_check_ioctl_buffer()Roel Kluin
struct pmcraid_ioctl_header member buffer_length is unsigned, so this check appears redundant. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Anil Ravindranath <anil_ravindranath@pmc-sierra.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-26block: Rename blk_queue_max_sectors to blk_queue_max_hw_sectorsMartin K. Petersen
The block layer calling convention is blk_queue_<limit name>. blk_queue_max_sectors predates this practice, leading to some confusion. Rename the function to appropriately reflect that its intended use is to set max_hw_sectors. Also introduce a temporary wrapper for backwards compability. This can be removed after the merge window is closed. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-12-30[SCSI] pmcraid: fix to avoid twice scsi_dma_unmap for a commandAnil Ravindranath
For a particular driver error condition, driver was doing double scsi_dma_unmaps. Driver was calling scsi_dma_unmap in pmcraid_error_handler and return 0. This pmcraid_error_handler is called by pmcraid_io_done which will do scsi_dma_unmap again when it has return 0 from pmcraid_error_handler. Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-10[SCSI] pmcraid: support SMI-S object model of storage poolAnil Ravindranath
PMC-Sierra mgmt application uses SMI-S model. According to SMI-S, the object model exposed by the SMI-S provider should show an StoragePool which contains member disks of a RAID Virtual disk and StorageVolume based on the StoragePool. But according to SMI-S, there is a possibility where StoragePool is created but StorageVolume is not yet created. To satisfy this scenario, we are trying a hidden RAID Virtual disk. The hidden RAID virtual disk will not be exposed to OS. Once a StorageVolume is created for this RAID virtual disk it is exposed. Signed-off-by: Anil Ravindranath<anil_ravindranath@pmc-sierra.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (222 commits) [SCSI] zfcp: Remove flag ZFCP_STATUS_FSFREQ_TMFUNCNOTSUPP [SCSI] zfcp: Activate fc4s attributes for zfcp in FC transport class [SCSI] zfcp: Block scsi_eh thread for rport state BLOCKED [SCSI] zfcp: Update FSF error reporting [SCSI] zfcp: Improve ELS ADISC handling [SCSI] zfcp: Simplify handling of ct and els requests [SCSI] zfcp: Remove ZFCP_DID_MASK [SCSI] zfcp: Move WKA port to zfcp FC code [SCSI] zfcp: Use common code definitions for FC CT structs [SCSI] zfcp: Use common code definitions for FC ELS structs [SCSI] zfcp: Update FCP protocol related code [SCSI] zfcp: Dont fail SCSI commands when transitioning to blocked fc_rport [SCSI] zfcp: Assign scheduled work to driver queue [SCSI] zfcp: Remove STATUS_COMMON_REMOVE flag as it is not required anymore [SCSI] zfcp: Implement module unloading [SCSI] zfcp: Merge trace code for fsf requests in one function [SCSI] zfcp: Access ports and units with container_of in sysfs code [SCSI] zfcp: Remove suspend callback [SCSI] zfcp: Remove global config_mutex [SCSI] zfcp: Replace local reference counting with common kref ...
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-04[SCSI] modify change_queue_depth to take in reason why it is being calledMike Christie
This patch modifies scsi_host_template->change_queue_depth so that it takes an argument indicating why it is being called. This will be used so that if a LLD needs to do some extra processing when handling queue fulls or later ramp ups, it can do so. This is a simple port of the drivers setting a change_queue_depth callback. In the patch I just have these LLDs adjust the queue depth if the user was requesting it. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> [Vasu.Dev: v2 Also converted pmcraid_change_queue_depth and then verified all modules compile using "make allmodconfig" for any new build warnings on X86_64. Updated original description after combing two original patches from Mike to make this patch git bisectable.] Signed-off-by: Vasu Dev <vasu.dev@intel.com> [jejb: fixed up 53c700] Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-06[SCSI] pmcraid: Fix ppc64 driver build for using cpu_to_le32 on U8 data typeAnil Ravindranath
Fix a reported ppc64 driver build issue. Removed cpu_to_le32 conversion usage for flags in struct pmcraid_ioadl_desc. This was breaking the driver build in ppc64. drivers/scsi/pmcraid.c: In function 'pmcraid_request_sense': drivers/scsi/pmcraid.c:2254: warning: large integer implicitly truncated to unsigned type Signed-off-by: Anil Ravindranath<anil_ravindranath@pmc-sierra.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-02[SCSI] pmcraid: Changed driver prints to scmd/sdev_printkAnil Ravindranath
1.Changed driver prints to use scmd_printk, sdev_printk 2.Changed dev_err calls to scmd_printk for scsi related print messages Signed-off-by: Anil Ravindranath <anil_ravindranath@pmc-sierra.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-09-12[SCSI] pmcraid: PMC-Sierra MaxRAID driver to support 6Gb/s SAS RAID controllerAnil Ravindranath
