path: root/drivers/scsi/pcmcia/aha152x_stub.c
2011-05-06pcmcia: Convert pcmcia_device_id declarations to constJoe Perches
Saves about 50KB of data. Old/new size of all objects: text data bss dec hex filename 563015 80096 130684 773795 bcea3 (TOTALS) 610916 32256 130632 773804 bceac (TOTALS) Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> (for drivers/net/can/softing/softing_cs.c) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: avoid messages on module (un)loadingDominik Brodowski
printk() statements on module load or unload are frowned upon. Also, add a few __init or __exit declarations. Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: move driver name to struct pcmcia_driverDominik Brodowski
2010-09-29pcmcia: use autoconfiguration feature for ioports and iomemDominik Brodowski
When CONF_AUTO_SET_IO or CONF_AUTO_SET_IOMEM are set, the corresponding fields in struct pcmcia_device *p_dev->resource[0,1,2] are set accordinly. Drivers wishing to override certain settings may do so in the callback function, but they no longer need to parse the CIS entries stored in cistpl_cftable_entry_t themselves. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: linux-bluetooth@vger.kernel.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: introduce autoconfiguration featureDominik Brodowski
Introduce an autoconfiguration feature to set certain values in pcmcia_loop_config(), instead of copying the same code over and over in each PCMCIA driver. At first, introduce the following options: CONF_AUTO_CHECK_VCC check or matching Vcc entry CONF_AUTO_SET_VPP set Vpp CONF_AUTO_AUDIO enable the speaker line CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: convert pcmcia_request_configuration to pcmcia_enable_deviceDominik Brodowski
pcmcia_enable_device() now replaces pcmcia_request_configuration(). Instead of config_req_t, all necessary flags are either passed as a parameter to pcmcia_enable_device(), or (in rare circumstances) set in struct pcmcia_device -> flags. With the last remaining user of include/pcmcia/cs.h gone, remove all references. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: move config_{base,index,regs} to struct pcmcia_deviceDominik Brodowski
Several drivers prefer to explicitly set config_{base,index,regs}, formerly known as ConfigBase, ConfigIndex and Present. Instead of passing these values inside config_req_t, store it in struct pcmcia_device. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: simplify IntTypeDominik Brodowski
IntType was only set to INT_MEMORY (driver pcmciamtd) or INT_MEMORY_AND_IO (all other drivers). As this flags seems to relate to ioport access, make it conditional to the driver having requested IO port access. There are two drivers which do not request IO ports, but did set INT_MEMORY_AND_IO: ray_cs and b43. For those, we consistently only set INT_MEMORY in future. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-08-03pcmcia: do not use io_req_t when calling pcmcia_request_io()Dominik Brodowski
Instead of io_req_t, drivers are now requested to fill out struct pcmcia_device *p_dev->resource[0,1] for up to two ioport ranges. After a call to pcmcia_request_io(), the ports found there are reserved, after calling pcmcia_request_configuration(), they may be used. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Michael Buesch <mb@bu3sch.de> Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-08-03pcmcia: do not use io_req_t after call to pcmcia_request_io()Dominik Brodowski
After pcmcia_request_io(), do not make use of the values stored in io_req_t, but instead use those found in struct pcmcia_device->resource[]. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-07-30pcmcia: remove cs_types.hDominik Brodowski
Remove cs_types.h which is no longer needed: Most definitions aren't used at all, a few can be made away with, and two remaining definitions (typedefs, unfortunatley) may be moved to more specific places. CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-05-10pcmcia: dev_node removal (write-only drivers)Dominik Brodowski
dev_node_t was only used to transport some minor/major numbers from the PCMCIA device drivers to deprecated userspace helpers. However, only a few drivers made use of it, and the userspace helpers are deprecated anyways. Therefore, get rid of dev_node_t . As a first step, remove any usage of dev_node_t from drivers which only wrote to this typedef/struct, but did not make use of it. CC: linux-bluetooth@vger.kernel.org CC: Harald Welte <laforge@gnumonks.org> CC: linux-mtd@lists.infradead.org CC: linux-wireless@vger.kernel.org CC: netdev@vger.kernel.org CC: linux-serial@vger.kernel.org CC: alsa-devel@alsa-project.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-05-10pcmcia: re-work pcmcia_request_irq()Dominik Brodowski
Instead of the old pcmcia_request_irq() interface, drivers may now choose between: - calling request_irq/free_irq directly. Use the IRQ from *p_dev->irq. - use pcmcia_request_irq(p_dev, handler_t); the PCMCIA core will clean up automatically on calls to pcmcia_disable_device() or device ejection. - drivers still not capable of IRQF_SHARED (or not telling us so) may use the deprecated pcmcia_request_exclusive_irq() for the time being; they might receive a shared IRQ nonetheless. CC: linux-bluetooth@vger.kernel.org CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-serial@vger.kernel.org CC: alsa-devel@alsa-project.org CC: linux-usb@vger.kernel.org CC: linux-ide@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-28pcmcia: rework the irq_req_t typedefDominik Brodowski
Most of the irq_req_t typedef'd struct can be re-worked quite easily: (1) IRQInfo2 was unused in any case, so drop it. (2) IRQInfo1 was used write-only, so drop it. (3) Instance (private data to be passed to the IRQ handler): Most PCMCIA drivers using pcmcia_request_irq() to actually register an IRQ handler set the "dev_id" to the same pointer as the "priv" pointer in struct pcmcia_device. Modify the two exceptions (ipwireless, ibmtr_cs) to also work this waym and set the IRQ handler's "dev_id" to p_dev->priv unconditionally. (4) Handler is to be of type irq_handler_t. (5) Handler != NULL already tells whether an IRQ handler is present. Therefore, we do not need the IRQ_HANDLER_PRESENT flag in irq_req_t.Attributes. CC: netdev@vger.kernel.org CC: linux-bluetooth@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-scsi@vger.kernel.org CC: alsa-devel@alsa-project.org CC: Jaroslav Kysela <perex@perex.cz> CC: Jiri Kosina <jkosina@suse.cz> CC: Karsten Keil <isdn@linux-pingi.de> for the Bluetooth parts: Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-09pcmcia: use dynamic debug infrastructure, deprecate CS_CHECK (scsi)Dominik Brodowski
Convert PCMCIA drivers to use the dynamic debug infrastructure, instead of requiring manual settings of PCMCIA_DEBUG. Also, remove all usages of the CS_CHECK macro and replace them with proper Linux style calling and return value checking. The extra error reporting may be dropped, as the PCMCIA core already complains about any (non-driver-author) errors. CC: linux-scsi@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-01-05[SCSI] aha152x_cs: Fix regression that keeps driver from using shared interruptsLarry Finger
At some point since 2.6.22, the aha152x_cs driver stopped working and started erring on load with the following messages: kernel: pcmcia: request for exclusive IRQ could not be fulfilled. kernel: pcmcia: the driver needs updating to supported shared IRQ lines. With the following change, the driver works with shared IRQs. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@kernel.org> [2.6.28], [2.6.27], [2.6.26] Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-08-23pcmcia: pcmcia_config_loop() improvement by passing vccDominik Brodowski
By passing the current Vcc setting to the pcmcia_config_loop callback function, we can remove pcmcia_get_configuration_info() calls from many drivers. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: pcmcia_config_loop() default CIS entry handlingDominik Brodowski
Many drivers use the default CIS entry within their pcmcia_config_loop() callback function. Therefore, factor the default CIS entry handling out. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: pcmcia_config_loop() ConfigIndex unificationDominik Brodowski
Almost all drivers set p_dev->conf.ConfigIndex to cfg->index in the pcmcia_config_loop() callback function. Therefore, factor it out. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: use pcmcia_loop_config in scsi pcmcia driversDominik Brodowski
Use the config loop helper in scsi pcmcia drivers. CC: James E.J. Bottomley <James.Bottomley@HansenPartnership.com> CC: linux-scsi@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-04[PATCH] pcmcia: conf.ConfigBase and conf.Present consolidationDominik Brodowski
struct pcmcia_device *p_dev->conf.ConfigBase and .Present are set in almost all PCMICA driver right at the beginning, using the same calls but slightly different implementations. Unfiy this in the PCMCIA core. Includes a small bugfix ("drivers/net/pcmcia/xirc2ps_cs.c: remove unused label") from and Signed-off-by Adrian Bunk <bunk@stusta.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: use bitfield instead of p_state and stateDominik Brodowski
Instead of the two status values struct pcmcia_device->p_state and state, use descriptive bitfields. Most value-checking in drivers was invalid, as the core now only calls the ->remove() (a.k.a. detach) function in case the attachement _and_ configuration was successful. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: add return value to _config() functionsDominik Brodowski
Most of the driver initialization isn't done in the .probe function, but in the internal _config() functions. Make them return a value, so that .probe can properly report whether the probing of the device succeeded or not. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: remove dev_link_t and client_handle_t indirectionDominik Brodowski
dev_link_t * and client_handle_t both mean struct pcmcai_device * by now. Therefore, remove all such indirections. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: embed dev_link_t into struct pcmcia_deviceDominik Brodowski
Embed dev_link_t into struct pcmcia_device(), as they basically address the same entity. The actual contents of dev_link_t will be cleaned up step by step. This patch includes a bugfix from and signed-off-by Andrew Morton. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: remove unneeded Vcc pseudo settingDominik Brodowski
As we do not allow setting Vcc in the pcmcia core, and Vpp1 and Vpp2 can only be set to the same value, a lot of code can be streamlined. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: default suspend and resume handlingDominik Brodowski
In all but one case, the suspend and resume functions of PCMCIA drivers contain mostly of calls to pcmcia_release_configuration() and pcmcia_request_configuration(). Therefore, move this code out of the drivers and into the core. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: add pcmcia_disable_deviceDominik Brodowski
pcmcia_disable_device(struct pcmcia_device *p_dev) performs the necessary cleanups upon device or driver removal: it calls the appropriate pcmcia_release_* functions, and can replace (most) of the current drivers' _release() functions. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-02-28[SCSI] aha152x: fix variable use before initialisation and other bugsJürgen E. Fischer
- change interface of the reset functions from Scsi_Cmnd to Scsi_Host. - add functions with the original interface and rename the new functions to reflect the new interface. - call these from the pcmcia driver, thereby avoiding the need to construct a (broken) Scsi_Cmnd from a Scsi_Host. - just run the bh if the interrupt is from the controller and if so ensure that it's only called once per interrupt. Signed-off-by: Juergen E. Fischer <fischer@linux-buechse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-06[PATCH] pcmcia: unify attach, EVENT_CARD_INSERTION handlers into one probe ↵Dominik Brodowski
callback Unify the EVENT_CARD_INSERTION and "attach" callbacks to one unified probe() callback. As all in-kernel drivers are changed to this new callback, there will be no temporary backwards-compatibility. Inside a probe() function, each driver _must_ set struct pcmcia_device *p_dev->instance and instance->handle correctly. With these patches, the basic driver interface for 16-bit PCMCIA drivers now has the classic four callbacks known also from other buses: int (*probe) (struct pcmcia_device *dev); void (*remove) (struct pcmcia_device *dev); int (*suspend) (struct pcmcia_device *dev); int (*resume) (struct pcmcia_device *dev); Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-06[PATCH] pcmcia: unify detach, REMOVAL_EVENT handlers into one remove callbackDominik Brodowski
Unify the "detach" and REMOVAL_EVENT handlers to one "remove" function. Old functionality is preserved, for the moment. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-05[PATCH] pcmcia: new suspend coreDominik Brodowski
Move the suspend and resume methods out of the event handler, and into special functions. Also use these functions for pre- and post-reset, as almost all drivers already do, and the remaining ones can easily be converted. Bugfix to include/pcmcia/ds.c Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2005-07-07[PATCH] pcmcia: remove references to pcmcia/version.hDominik Brodowski
As a follow-up, remove the inclusion of pcmcia/version.h in many files. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] pcmcia: move event handlerDominik Brodowski
Move the "event handler" to struct pcmcia_driver -- the unified event handler will disappear really soon, but switching it to struct pcmcia_driver in the meantime allows for better "step-by-step" patches. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] pcmcia: id_table for aha152xDominik Brodowski
Add pcmcia_device_id table. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
