path: root/drivers/scsi/mpt2sas/mpi
2013-09-03[SCSI] mpt2sas: MPI2 Rev X (2.00.16) specificationsSreekanth Reddy
Change set in MPI2 Rev x specification and 2.00.26 header files 1. Added two new AbortType values for TargetModeAbort Request: one to abort all IOs from a single initiator and other to abort only Command IUs. 2. Added Use Slot Information during Port Enable Event Reply flag to the Flags field of Manufacturing Page 7. 3. Added OEM Identifier to BiosOptions bits of BIOS Page 1. Signed-off-by: Sreekanth Reddy <Sreekanth.Reddy@lsi.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-06-24[SCSI] mpt2sas: MPI2 Rev W (2.00.15) specificationSreekanth Reddy
Change set in MPI 2.0 Rev W(2.00.15) specification and 2.00.27 header files 1. Added a bit to the IOCExceptions field of the IOCFacts Reply to indicate that the IOC detected a partial memory failure. 2. Added ElapsedSeconds field to RAID Volume Indicator Structure. Added Elapsed Seconds Valid flag to Flags field of this structure. 3. Added ElapsedSeconds field to Integrated RAID Operations Status Event Data. 4. In the IOCSettings field of BIOS Page 1, modified the Adapter Support bits description to specify X86 BIOS. 5. Toolbox Diagnostic CLI Tool Request may now use chain elements in the SGL. Signed-off-by: Sreekanth Reddy <Sreekanth.Reddy@lsi.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-08-24[SCSI] mpt2sas : MPI 2.0 Rev V(2.0.14) specificationsreekanth.reddy@lsi.com
Changeset in MPI 2.0 Rev V(2.0.14) specification 1) Bumped MPI2_HEADER_VERSION_UNIT. 2) Added a product specific range to event values. 3) Added clarification to Direct-Attached SAS PHY Power condition. 4) Updated timing requirements for performing Hard Reset. Signed-off-by: Sreekanth Reddy <sreekanth.reddy@lsi.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-04-23[SCSI] mpt2sas: MPI next revision header updatenagalakshmi.nandigama@lsi.com
Changeset in MPI headers: 1) Bumped MPI2_HEADER_VERSION_UNIT 2) Added 4K sectors supported bit to CapabilitiesFlags field of IOC Page 6. 3) Added UEFIVersion field to BIOS Page 1 and defined additional BiosOptions bits to control UEFI behavior. Signed-off-by: Nagalakshmi Nandigama <nagalakshmi.nandigama@lsi.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-12-15[SCSI] mpt2sas: MPI next revision header updatenagalakshmi.nandigama@lsi.com
1)Removed Power Management Control option for PCIe link. 2)Added RAID Action for performing a compatibility check. Added product-specific range to RAID Action values. 3)Added PhysicalPort field to SAS Device Status Change Event data. 4)Added SpinupFlags field containing a Disable Spin-up bit to the SpinupGroupParameters fields of SAS IO Unit Page 4. Signed-off-by: Nagalakshmi Nandigama <nagalakshmi.nandigama@lsi.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
1) Added product specific range of ImageType macros for the Extended Image Header. 2) Added Flags field and related defines to MPI2_TOOLBOX_ISTWI_READ_WRITE_REQUEST to support automatic reserve/release and page addressing. Signed-off-by: Nagalakshmi Nandigama <nagalakshmi.nandigama@lsi.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-10-30[SCSI] mpt2sas: MPI next revision header updatenagalakshmi.nandigama@lsi.com
1)Added ProxyVF_ID field to Configuration Request message. 2)Added IO Unit Page 8, IO Unit Page 9,and IO Unit Page 10. 3)Added SASNotifyPrimitiveMasks field to IOC Page 7. 4)Added SAS NOTIFY Primitive event. 5)Added Temperature Threshold Event. 6)Added Host Message Event. 7)Added Send Host Message request and reply. Signed-off-by: Nagalakshmi Nandigama <nagalakshmi.nandigama@lsi.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-06-29[SCSI] mpt2sas MPI next revision header updateKashyap, Desai
mpt2sas driver revision q header update: (1) Modified the descriptions of the LocalAddress bit in the Flags field of the MPI SGE Format description and the MPI Simple Element. (2) Modified Data Location Address Space bits in the Flags field of the IEEE Chain Element. (3) Added more detail to the description of the DataLength field for the SCSI IO Request and Target Assist Request. Removed restriction on using chained SGLs when using multicast or bidirectional support. (4) In Manufacturing Page 7, added ReceptacleID field to ConnectorInfo, and reworked how the Pinout field is used. (5) In IO Unit Page 7, added BoardTemperature and BoardTemperatureUnits fields. (6) In IOC Page 1, changed CoalescingTimeout to units of half-microsecond and updated descriptions. (7) Modified descriptions of SATASlumberTimeout and SASSlumberTimeout fields in SAS IO Unit Page 5 to indicate the timers start after partial mode is entered. (8) Added Extended Manufacturing configuration pages. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-01-24[SCSI] mpt2sas: Revision P MPI Header UpdateKashyap, Desai
Revision P MPI Header Update: a) Added enable/disable SATA NCQ operations to SAS IO Unit Control Request. b) Modified Host Based Discovery Action Request message format. c) Removed Device Path bit from IO Unit Page 1 Flags field. d) Added description of ChainOffset field for Diagnostic Data Upload Tool.Chaining is not allowed. Removed mpi2_history.txt file Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-21[SCSI] mpt2sas: MPI 2.0 Header updatedKashyap, Desai
MPI2 Rev header files. 1) Removed Task Set Full Event. Modified description of Disable SCSI Initiator Task Set Full Handling bit in the Flags field of IO Unit Page 1. Modified the descriptions for the three queue depth fields in SAS IO Unit Page 1. (2) Added new value for the Current Operation bits of the Flags field in the RAID Volume Indicator Structure to indicate that the Make Data Consistent operation is running. (3) Added a value of 0x6 to various SAS link rate fields to indicate an attached PHY that is not using any commonly supported settings. (4) Added Volume Not Consistent bit to the VolumeStatusFlags field of RAID Volume Page 0. (5) Added a new value for the IncompatibleReason field of RAID Physical Disk Page 0 to indicate an incompatible media type. (6) Added Diagnostic Data Upload tool for the Toolbox Request. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] mpt2sas: MPI header version N is updated.Kashyap, Desai
Updating MPI header version N. Removed mpi_history.txt. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] mpt2sas: Copyright 2010.Kashyap, Desai
Copyright changes for year 2010. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-02-08[SCSI] mpt2sas: Update driver header to latest MPI Spec.Kashyap, Desai
Update header to latest MPI SPEC revision. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Reviewed-by: Eric Moore <eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-29[SCSI] mpt2sas: Adding MPI Headers - revision LKashyap, Desai
The new headers contain the following changes: (1) Added IO Unit Page 7. (2) Added new device ids for SAS2208. (3) Added SAS IO Unit Page 5. (4) Added partial and slumber power management capable flags to SAS Device Page 0 Flags field. (5) Added PhyInfo defines for power condition. (6) Added Ethernet configuration pages. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: Eric Moore <Eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-29[SCSI] mpt2sas: New device SAS2208 support is addedKashyap, Desai
Added device ids range for { 0x80 - 87 } , modified mpi/mpi2_cnfg.h containing MPI2_MFGPAGE_DEVID_SAS2208_X. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: Eric Moore <Eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-02[SCSI] mpt2sas: Added mpi2_history.txt for MPI2 headers.Kashyap, Desai
Added new file for MPI2 header version history. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-02[SCSI] mpt2sas: Update driver to MPI2 REV K headers.Kashyap, Desai
Drivers header are updated to the MPI2 REV K headers. Renamed VF_ID to msix_index in all call back handlers. VF_ID is removed from all request descriptor. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-03-13[SCSI] mpt2sas v00.100.11.15Eric Moore
* This is new scsi lld device driver from LSI supporting the SAS 2.0 standard. I have split patchs by filename. * Here is list of new 6gb host controllers: LSI SAS2004 LSI SAS2008 LSI SAS2108 LSI SAS2116 * Here are the changes in the 4th posting of this patch set: (1) fix compile errors when SCSI_MPT2SAS_LOGGING is not enabled (2) add mpt2sas to the SCSI Mid Layer Makefile (3) append mpt2sas_ to the naming of all non-static functions (4) fix oops for SMP_PASSTHRU (5) doorbell algorithm imported changes from windows driver * Here are the changes in the 3rd posting of this patch set: (1) add readl following writel from the function that disables interrupts (2) replace 0xFFFFFFFFFFFFFFFFULL with ~0ULL (3) when calling pci_enable_msix, only pass one msix entry (instead of 15). (4) remove the "current HW implementation uses..... " comment in the sources (5) merged bug fix for SIGIO/POLLIN notifcation; reported by the storlib team. * Here are the changes in the 2nd posting of this patch set: (1) use little endian types in the mpi headers (2) merged in bug fix's from inhouse drivers. Signed-off-by: Eric Moore <eric.moore@lsi.com> Tested-by: peter Bogdanovic <pbog@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
