path: root/drivers/scsi/mpt2sas/mpi/mpi2_sas.h
2011-01-24[SCSI] mpt2sas: Revision P MPI Header UpdateKashyap, Desai
Revision P MPI Header Update: a) Added enable/disable SATA NCQ operations to SAS IO Unit Control Request. b) Modified Host Based Discovery Action Request message format. c) Removed Device Path bit from IO Unit Page 1 Flags field. d) Added description of ChainOffset field for Diagnostic Data Upload Tool.Chaining is not allowed. Removed mpi2_history.txt file Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-21[SCSI] mpt2sas: MPI 2.0 Header updatedKashyap, Desai
MPI2 Rev header files. 1) Removed Task Set Full Event. Modified description of Disable SCSI Initiator Task Set Full Handling bit in the Flags field of IO Unit Page 1. Modified the descriptions for the three queue depth fields in SAS IO Unit Page 1. (2) Added new value for the Current Operation bits of the Flags field in the RAID Volume Indicator Structure to indicate that the Make Data Consistent operation is running. (3) Added a value of 0x6 to various SAS link rate fields to indicate an attached PHY that is not using any commonly supported settings. (4) Added Volume Not Consistent bit to the VolumeStatusFlags field of RAID Volume Page 0. (5) Added a new value for the IncompatibleReason field of RAID Physical Disk Page 0 to indicate an incompatible media type. (6) Added Diagnostic Data Upload tool for the Toolbox Request. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-02-08[SCSI] mpt2sas: Update driver header to latest MPI Spec.Kashyap, Desai
Update header to latest MPI SPEC revision. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Reviewed-by: Eric Moore <eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-03-13[SCSI] mpt2sas v00.100.11.15Eric Moore
* This is new scsi lld device driver from LSI supporting the SAS 2.0 standard. I have split patchs by filename. * Here is list of new 6gb host controllers: LSI SAS2004 LSI SAS2008 LSI SAS2108 LSI SAS2116 * Here are the changes in the 4th posting of this patch set: (1) fix compile errors when SCSI_MPT2SAS_LOGGING is not enabled (2) add mpt2sas to the SCSI Mid Layer Makefile (3) append mpt2sas_ to the naming of all non-static functions (4) fix oops for SMP_PASSTHRU (5) doorbell algorithm imported changes from windows driver * Here are the changes in the 3rd posting of this patch set: (1) add readl following writel from the function that disables interrupts (2) replace 0xFFFFFFFFFFFFFFFFULL with ~0ULL (3) when calling pci_enable_msix, only pass one msix entry (instead of 15). (4) remove the "current HW implementation uses..... " comment in the sources (5) merged bug fix for SIGIO/POLLIN notifcation; reported by the storlib team. * Here are the changes in the 2nd posting of this patch set: (1) use little endian types in the mpi headers (2) merged in bug fix's from inhouse drivers. Signed-off-by: Eric Moore <eric.moore@lsi.com> Tested-by: peter Bogdanovic <pbog@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
