path: root/drivers/scsi/megaraid.c
2005-12-08[SCSI] Fix incorrect pointer in megaraid.c MODE_SENSE emulationMark Lord
The SCSI megaraid drive goes to great effort to kmap the scatterlist buffer (if used), but then uses the wrong pointer when copying to it afterward. Signed-off-by: Mark Lord <lkml@rtr.ca> Acked by: Ju, Seokmann <Seokmann.Ju@engenio.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-29[PATCH] fix megaraid.c lockingChristoph Hellwig
This fixes locking in megaraid.c, namely: (1) make sure megaraid_queue release the adapter lock by changing the code to have a single return (2) remove the errornous scsi_assign_lock call Testing by Burton Windle. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Burton Windle <bwindle@fint.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[SCSI] remove Scsi_Pointer typedefChristoph Hellwig
2005-11-06[SCSI] megaraid (legacy): remove scsi_assign_lock usageChristoph Hellwig
just take the adapter lock in megaraid_queue. Additional benefit is that we can get rid of the awkward conditional locking in mega_internal_command. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-03[SCSI] Legacy MegaRAID: Fix READ CAPACITYJames Bottomley
Some Legacy megaraid cards can't actually cope with the scatter/gather version of the READ CAPACITY command (which is what we now send them since altering all SCSI internal I/O to go via the block layer). Fix this (and a few other broken megaraid driver assumptions) by sending the non-sg version of the command if the sg list only has a single element. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-07-26Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-for-linus-2.6Linus Torvalds
2005-06-27[PATCH] PCI: make drivers use the pci shutdown callback instead of the ↵Greg Kroah-Hartman
driver core callback. Now we can change the pci core to always set this pointer, as pci drivers should use it, not the driver core callback. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-26[SCSI] remove scsi_cmnd->stateChristoph Hellwig
We never look at it except for the old megaraid driver that abuses it for sending internal commands. That usage can be fixed easily because those internal commands are single-threaded by a mutex and we can easily use a completion there. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-06-26[SCSI] megaraid: fix compilation after eh locking changesJames Bottomley
From: Christoph Hellwig <hch@lst.de> Patch fixed up and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-06-21[PATCH] megaraid build fixbobl
Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-17[SCSI] allow sleeping in ->eh_device_reset_handler()Jeff Garzik
