path: root/drivers/scsi/libsas/sas_internal.h
2014-11-27libsas: remove task_collector modeChristoph Hellwig
The task_collector mode (or "latency_injector", (C) Dan Willians) is an optional I/O path in libsas that queues up scsi commands instead of directly sending it to the hardware. It generall increases latencies to in the optiomal case slightly reduce mmio traffic to the hardware. Only the obsolete aic94xx driver and the mvsas driver allowed to use it without recompiling the kernel, and most drivers didn't support it at all. Remove the giant blob of code to allow better optimizations for scsi-mq in the future. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hannes Reinecke <hare@suse.de> Acked-by: Dan Williams <dan.j.williams@intel.com>
2013-05-10[SCSI] sas: unify the pointlessly separated enums sas_dev_type and ↵James Bottomley
sas_device_type These enums have been separate since the dawn of SAS, mainly because the latter is a procotol only enum and the former includes additional state for libsas. The dichotomy causes endless confusion about which one you should use where and leads to pointless warnings like this: drivers/scsi/mvsas/mv_sas.c: In function 'mvs_update_phyinfo': drivers/scsi/mvsas/mv_sas.c:1162:34: warning: comparison between 'enum sas_device_type' and 'enum sas_dev_type' [-Wenum-compare] Fix by eliminating one of them. The one kept is effectively the sas.h one, but call it sas_device_type and make sure the enums are all properly namespaced with the SAS_ prefix. Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-08-24[SCSI] libsas: suspend / resume supportDan Williams
libsas power management routines to suspend and recover the sas domain based on a model where the lldd is allowed and expected to be "forgetful". sas_suspend_ha - disable event processing allowing the lldd to take down links without concern for causing hotplug events. Regardless of whether the lldd actually posts link down messages libsas notifies the lldd that all domain_devices are gone. sas_prep_resume_ha - on the way back up before the lldd starts link training clean out any spurious events that were generated on the way down, and re-enable event processing sas_resume_ha - after the lldd has started and decided that all phys have posted link-up events this routine is called to let libsas start it's own timeout of any phys that did not resume. After the timeout an lldd can cancel the phy teardown by posting a link-up event. Storage for ex_change_count (u16) and phy_change_count (u8) are changed to int so they can be set to -1 to indicate 'invalidated'. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Reviewed-by: Jacek Danecki <jacek.danecki@intel.com> Tested-by: Maciej Patelczyk <maciej.patelczyk@intel.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-04-23[SCSI] libsas: introduce sas_work to fix sas_drain_work vs sas_queue_workDan Williams
When requeuing work to a draining workqueue the last work instance may not be idle, so sas_queue_work() must not touch work->entry. Introduce sas_work with a drain_node list_head to have a private list for collecting work deferred due to drain collision. Fixes reports like: BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff810410d4>] process_one_work+0x2e/0x338 Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-29[SCSI] libsas: set attached device type and target protocols for local physDan Williams
Before: $ cat /sys/class/sas_phy/phy-6\:3/device_type none $ cat /sys/class/sas_phy/phy-6\:3/target_port_protocols none After: $ cat /sys/class/sas_phy/phy-6\:3/device_type end device $ cat /sys/class/sas_phy/phy-6\:3/target_port_protocols sata Also downgrade the phy_list_lock to _irq instead of _irqsave since libsas will never call sas_get_port_device with interrupts disbled. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-29[SCSI] libsas: async ata scanningDan Williams
libsas ata error handling is already async but this does not help the scan case. Move initial link recovery out from under host->scan_mutex, and delay synchronization with eh until after all port probe/recovery work has been queued. Device ordering is maintained with scan order by still calling sas_rphy_add() in order of domain discovery. Since we now scan the domain list when invoking libata-eh we need to be careful to check for fully initialized ata ports. Acked-by: Jack Wang <jack_wang@usish.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-29[SCSI] libsas: let libata recover links that fail to transmit initial sig-fisDan Williams
libsas fails to discover all sata devices in the domain. If a device fails negotiation and does not transmit a signature fis the link needs recovery. libata already understands how to manage slow to come up links, so treat these conditions as ata device attach events for the purposes of creating an ata_port. This allows libata to manage retrying link bring up. Rediscovery is modified to be careful about checking changes in dev_type. It looks like libsas leaks old devices if the sas address changes, but that's a fix for another patch. Acked-by: Jack Wang <jack_wang@usish.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-29[SCSI] libsas: fix sas_unregister_ports vs sas_drain_workDan Williams
We need to hold drain_mutex across the unregistration as port down events queue device removal as chained events, so we need to make sure no other drainers are active. [ 1118.673968] WARNING: at kernel/workqueue.c:996 __queue_work+0x11a/0x326() [ 1118.681982] Hardware name: S2600CP [ 1118.686193] Modules linked in: isci(-) libsas scsi_transport_sas nls_utf8 ipv6 uinput sg iTCO_wdt iTCO_vendor_support i2c_i801 i2c_core ioatdma dca sd_mod sr_mod cdrom ahci libahci libata [last unloaded: scsi_transport_sas] [ 1118.709893] Pid: 6831, comm: rmmod Not tainted 3.2.0-isci+ #1 [ 1118.716727] Call Trace: [ 1118.719867] [<ffffffff8103e9f5>] warn_slowpath_common+0x85/0x9d [ 1118.727000] [<ffffffff8103ea27>] warn_slowpath_null+0x1a/0x1c [ 1118.733942] [<ffffffff81056d44>] __queue_work+0x11a/0x326 [ 1118.740481] [<ffffffff81056f99>] queue_work_on+0x1b/0x22 [ 1118.746925] [<ffffffff81057106>] queue_work+0x37/0x3e [ 1118.753105] [<ffffffffa0120e05>] ? sas_discover_event+0x55/0x82 [libsas] [ 1118.761094] [<ffffffff813217c3>] scsi_queue_work+0x42/0x44 [ 1118.767717] [<ffffffffa0120e19>] sas_discover_event+0x69/0x82 [libsas] [ 1118.775509] [<ffffffffa0120f5b>] sas_unregister_dev+0xc3/0xcc [libsas] [ 1118.783319] [<ffffffffa0120fae>] sas_unregister_domain_devices+0x4a/0xc8 [libsas] [ 1118.792731] [<ffffffffa0120071>] sas_deform_port+0x60/0x1a6 [libsas] [ 1118.800339] [<ffffffffa01201ea>] sas_unregister_ports+0x33/0x44 [libsas] [ 1118.808342] [<ffffffffa011f7e5>] sas_unregister_ha+0x41/0x6b [libsas] [ 1118.816055] [<ffffffffa0134055>] isci_unregister+0x22/0x4d [isci] [ 1118.823384] [<ffffffffa0143040>] isci_pci_remove+0x2e/0x60 [isci] Reported-by: Jacek Danecki <jacek.danecki@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-29[SCSI] libsas: route local link resets through ata-ehDan Williams
Similar to the conversion of the transport-class reset we want bsg initiated resets to be managed by libata. Reported-by: Jacek Danecki <jacek.danecki@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-29[SCSI] libsas: fix sas_find_local_phy(), take phy referencesDan Williams
In the direct-attached case this routine returns the phy on which this device was first discovered. Which is broken if we want to support wide-targets, as this phy reference can become stale even though the port is still active. In the expander-attached case this routine tries to lookup the phy by scanning the attached sas addresses of the parent expander, and BUG_ONs if it can't find it. However since eh and the libsas workqueue run independently we can still be attempting device recovery via eh after libsas has recorded the device as detached. This is even easier to hit now that eh is blocked while device domain rediscovery takes place, and that libata is fed more timed out commands increasing the chances that it will try to recover the ata device. Arrange for dev->phy to always point to a last known good phy, it may be stale after the port is torn down, but it will catch up for wide port reconfigurations, and never be NULL. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-29[SCSI] libsas: poll for ata device readiness after resetDan Williams
Use ata_wait_after_reset() to poll for link recovery after a reset. This combined with sas_ha->eh_mutex prevents expander rediscovery from probing phys in an intermediate state. Local discovery does not have a mechanism to filter link status changes during this timeout, so it remains the responsibility of lldds to prevent premature port teardown. Although once all lldd's support ->lldd_ata_check_ready() that could be used as a gate to local port teardown. The signature fis is re-transmitted when the link comes back so we should be revalidating the ata device class, but that is left to a future patch. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: sas_phy_enable via transport_sas_phy_resetDan Williams
Execute the link-reset triggered by sas_phy_enable via transport_sas_phy_reset so that it can be managed by libata. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: execute transport link resets with libata-eh via host workqueueDan Williams
Link resets leave ata affiliations intact, so arrange for libsas to make an effort to avoid dropping the device due to a slow-to-recover link. Towards this end carry out reset in the host workqueue so that it can check for ata devices and kick the reset request to libata. Hard resets, in contrast, bypass libata since they are meant for associating an ata device with another initiator in the domain (tears down affiliations). Need to add a new transport_sas_phy_reset() since the current sas_phy_reset() is a utility function to libsas lldds. They are not prepared for it to loop back into eh. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: perform sas-transport resets in shost->workq contextDan Williams
Extend the sas transport class to allow transport users to attach extra data to a sas_phy (->hostdata). Use this area in libsas to move resets to workq context in preparation for scheduling ata device resets through libata-eh. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: fix timeout vs completion raceDan Williams
Until we have told the lldd to forget a task a timed out operation can return from the hardware at any time. Since completion frees the task we need to make sure that no tasks run their normal completion handler once eh has decided to manage the task. Similar to ata_scsi_cmd_error_handler() freeze completions to let eh judge the outcome of the race. Task collector mode is problematic because it presents a situation where a task can be timed out and aborted before the lldd has even seen it. For this case we need to guarantee that a task that an lldd has been told to forget does not get queued after the lldd says "never seen it". With sas_scsi_timed_out we achieve this with the ->task_queue_flush mutex, rather than adding more time. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: prevent domain rediscovery competing with ata error handlingDan Williams
libata error handling provides for a timeout for link recovery. libsas must not rescan for previously known devices in this interval otherwise it may remove a device that is simply waiting for its link to recover. Let libata-eh make the determination of when the link is stable and prevent libsas (host workqueue) from taking action while this determination is pending. Using a mutex (ha->disco_mutex) to flush and disable revalidation while eh is running requires any discovery action that may block on eh be moved to its own context outside the lock. Probing ATA devices explicitly waits on ata-eh and the cache-flush-io issued during device removal may also pend awaiting eh completion. Essentially any rphy add/remove activity needs to run outside the lock. This adds two new cleanup states for sas_unregister_domain_devices() 'allocated-but-not-probed', and 'flagged-for-destruction'. In the 'allocated-but-not-probed' state dev->rphy points to a rphy that is known to have not been through a sas_rphy_add() event. At domain teardown check if this device is still pending probe and cleanup accordingly. Similarly if a device has already been queued for removal then sas_unregister_domain_devices has nothing to do. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: introduce sas_drain_work()Dan Williams
When an lldd invokes ->notify_port_event() it can trigger a chain of libsas events to: 1/ form the port and find the direct attached device 2/ if the attached device is an expander perform domain discovery A call to flush_workqueue() will only flush the initial port formation work. Currently libsas users need to call scsi_flush_work() up to the max depth of chain (which will grow from 2 to 3 when ata discovery is moved to its own discovery event). Instead of open coding multiple calls switch to use drain_workqueue() to flush sas work. drain_workqueue() does not handle new work submitted during the drain so libsas needs a bit of infrastructure to hold off unchained work submissions while a drain is in flight. A lldd ->notify() event is considered 'unchained' while a sas_discover_event() is 'chained'. As Tejun notes: "For now, I think it would be best to add private wrapper in libsas to support deferring unchained work items while draining." Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: convert ha->state to flagsDan Williams
In preparation for adding new states (SAS_HA_DRAINING, SAS_HA_FROZEN), convert ha->state into a set of flags. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: replace event locks with atomic bitopsDan Williams
The locks only served to make sure the pending event bitmask was updated consistently. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: fix domain_device leakDan Williams
Arrange for the deallocation of a struct domain_device object when it no longer has: 1/ any children 2/ references by any scsi_targets 3/ references by a lldd The comment about domain_device lifetime in Documentation/scsi/libsas.txt is stale as it appears mainline never had a version of a struct domain_device that was registered as a kobject. We now manage domain_device reference counts on behalf of external agents. Reviewed-by: Jack Wang <jack_wang@usish.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-05-26[SCSI] libsas: fix/amend device gone notification in sas_deform_port()Dan Williams
Commit 56dd2c06 "libsas: Don't issue commands to devices that have been hot-removed" edited Darrick's original patch to remove setting 'gone' in the sas_deform_port() path because that prevented scsi sync cache commands from being issued when the driver was unloaded. However, this allows true device gone notifications (as signaled port phy events) to trigger sync cache commands to devices that are known to be unreachable. Teach libsas which sas_deform_port() invocations are likely device gone events. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <jbottomley@parallels.com>
2011-01-24[SCSI] libsas: convert to standard kernel debuggingJames Bottomley
Instead of using a config option for debugging, just dump the messages with KERN_DEBUG. Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2008-10-09block: unify request timeout handlingJens Axboe
Right now SCSI and others do their own command timeout handling. Move those bits to the block layer. Instead of having a timer per command, we try to be a bit more clever and simply have one per-queue. This avoids the overhead of having to tear down and setup a timer for each command, so it will result in a lot less timer fiddling. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-11[SCSI] libsas: add host SMP processingJames Bottomley
This adds support for host side SMP processing, via a separate SMP interpreter file. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libsas: Convert sas_proto users to sas_protocolDarrick J. Wong
sparse complains about the mixing of enums in libsas. Since the underlying numeric values of both enums are the same, combine them to get rid of the warning. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-07-18[SCSI] sas_ata: Implement sas_task_abort for ATA devicesDarrick J. Wong
ATA devices need special handling for sas_task_abort. If the ATA command came from SCSI, then we merely need to tell SCSI to abort the scsi_cmnd. However, internal commands require a bit more work--we need to fill the qc with the appropriate error status and complete the command, and eventually post_internal will issue the actual ABORT TASK. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-13[SCSI] libsas: Add SAS_HA state flags to avoid queueing events while unloadingDarrick J. Wong
Track sas_ha_struct state so that we ignore events that come in while we're shutting things down. Signed-off-by: Malahal Naineni <malahal@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-09-07[SCSI] aci94xx: implement link rate settingJames Bottomley
This patch implements the ability to set the minimum and maximum linkrates for both libsas (for expanders) and aic94xx (for the host phys). It also tidies up the setting of the hardware min and max to make sure they're updated when the expander emits a change broadcast. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-09-07[SCSI] SAS: consolidate linkspeed definitionsJames Bottomley
At the moment we have two separate linkspeed enumerations covering roughly the same values. This patch consolidates on a single one enum sas_linkspeed in scsi_transport_sas.h and uses it everywhere in the aic94xx driver. Eventually I'll get around to removing the duplicated fields in asd_sas_phy and sas_phy ... Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-08-29[SCSI] aic94xx: new driverJames Bottomley
This is the end point of the separate aic94xx driver based on the original driver and transport class from Luben Tuikov <ltuikov@yahoo.com> The log of the separate development is: Alexis Bruemmer: o aic94xx: fix hotplug/unplug for expanderless systems o aic94xx: disable split completion timer/setting by default o aic94xx: wide port off expander support o aic94xx: remove various inline functions o aic94xx: use bitops o aic94xx: remove queue comment o aic94xx: remove sas_common.c o aic94xx: sas remove depot's o aic94xx: use available list_for_each_entry_safe_reverse() o aic94xx: sas header file merge James Bottomley: o aic94xx: fix TF_TMF_NO_CTX processing o aic94xx: convert to request_firmware interface o aic94xx: fix hotplug/unplug o aic94xx: add link error counts to the expander phys o aic94xx: add transport class phy reset capability o aic94xx: remove local_attached flag o Remove README o Fixup Makefile variable for libsas rename o Rename sas->libsas o aic94xx: correct return code for sas_discover_event o aic94xx: use parent backlink port o aic94xx: remove channel abstraction o aic94xx: fix routing algorithms o aic94xx: add backlink port o aic94xx: fix cascaded expander properties o aic94xx: fix sleep under lock o aic94xx: fix panic on module removal in complex topology o aic94xx: make use of the new sas_port o rename sas_port to asd_sas_port o Fix for eh_strategy_handler move o aic94xx: move entirely over to correct transport class formulation o remove last vestages of sas_rphy_alloc() o update for eh_timed_out move o Preliminary expander support for aic94xx o sas: remove event thread o minor warning cleanups o remove last vestiges of id mapping arrays o Further updates o Convert aic94xx over entirely to the transport class end device and o update aic94xx/sas to use the new sas transport class end device o [PATCH] aic94xx: attaching to the sas transport class o Add missing completion removal from prior patch o [PATCH] aic94xx: attaching to the sas transport class o Build fixes from akpm Jeff Garzik: o [scsi aic94xx] Remove ->owner from PCI info table Luben Tuikov: o initial aic94xx driver Mike Anderson: o aic94xx: fix panic on module insertion o aic94xx: stub out SATA_DEV case o aic94xx: compile warning cleanups o aic94xx: sas_alloc_task o aic94xx: ref count update o aic94xx nexus loss time value o [PATCH] aic94xx: driver assertion in non-x86 BIOS env Randy Dunlap: o libsas: externs not needed Robert Tarte: o aic94xx: sequence patch - fixes SATA support Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
