path: root/drivers/scsi/libiscsi.c
2008-10-13libiscsi: fix locking in iscsi_eh_device_resetMike Christie
We must be using the bh spin locking functions in iscsi_eh_device_reset becuase the session lock interacts with a thread and softirq. This patch also fixes up a bogus comment and check in fail_command, because no one drops the lock (bnx2i did but it is not going upstream yet and there were other refcount changes for that). Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13libiscsi: check reason why we are stopping iscsi session to determine error ↵Mike Christie
value Some wires got crossed on some patches and I messed up in the code below when rebuilding a patch. We want to be checking if flag equaled the value indicating if we killing the session due to final logout or if we just trying to relogin. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13[SCSI] libiscsi: rename host reset to target resetMike Christie
I had this in my patchset to add target reset support, but it got dropped due to patching conflicts. This initial patch just renames the function and users. We are actually just dropping the session, and so this does not have anything to do with the host exactly. It does for software iscsi because we allocate a host per session, but for cxgb3i this makes no sense. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13[SCSI] libiscsi: Support drivers initiating session removalMike Christie
If the driver knows when hardware is removed like with cxgb3i, bnx2i, qla4xxx and iser then we will want to remove the sessions/devices that are bound to that device before removing the host. cxgb3i and in the future bnx2i will remove the host and that will remove all the sessions on the hba. iser can call iscsi_kill_session when it gets an event that indicates that a hca is removed. And when qla4xxx is hooked in to the lib (it is only hooked into the class right now) it can call iscsi remove host like the partial offload card drivers. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13[SCSI] libiscsi: fix data corruption when target has to resend data-in packetsMike Christie
iscsi_tcp was updating the exp_statsn (exp_statsn acknowledges status and tells the target it is ok to let the resources for a iscsi pdu to be reused) before it got all the data for pdu read into OS buffers. Data corruption was occuring if something happens to a packet and the network layer requests a retransmit, and the initiator has told the target about the udpated exp_statsn ack, then the target may be sending data from a buffer it has reused for a new iscsi pdu. This fixes the problem by having the LLD (iscsi_tcp in this case) just handle the transferring of data, and has libiscsi handle the processing of status (libiscsi completion processing is done after LLD data transfers are complete). Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13[SCSI] iscsi class, libiscsi and qla4xxx: convert to new transport host byte ↵Mike Christie
values This patch converts the iscsi drivers to the new host byte values. v2 Drop some conversions. Want to avoid conflicts with other patches. v1 initial patch. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13[SCSI] libiscsi: Use SCSI_MLQUEUE_TARGET_BUSYMike Christie
For the conditions below we do not want the queuecommand function to call us right back, so return SCSI_MLQUEUE_TARGET_BUSY. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (37 commits) [SCSI] zfcp: fix double dbf id usage [SCSI] zfcp: wait on SCSI work to be finished before proceeding with init dev [SCSI] zfcp: fix erp list usage without using locks [SCSI] zfcp: prevent fc_remote_port_delete calls for unregistered rport [SCSI] zfcp: fix deadlock caused by shared work queue tasks [SCSI] zfcp: put threshold data in hba trace [SCSI] zfcp: Simplify zfcp data structures [SCSI] zfcp: Simplify get_adapter_by_busid [SCSI] zfcp: remove all typedefs and replace them with standards [SCSI] zfcp: attach and release SAN nameserver port on demand [SCSI] zfcp: remove unused references, declarations and flags [SCSI] zfcp: Update message with input from review [SCSI] zfcp: add queue_full sysfs attribute [SCSI] scsi_dh: suppress comparison warning [SCSI] scsi_dh: add Dell product information into rdac device handler [SCSI] qla2xxx: remove the unused SCSI_QLOGIC_FC_FIRMWARE option [SCSI] qla2xxx: fix printk format warnings [SCSI] qla2xxx: Update version number to 8.02.01-k8. [SCSI] qla2xxx: Ignore payload reserved-bits during RSCN processing. [SCSI] qla2xxx: Additional residual-count corrections during UNDERRUN handling. ...
2008-10-09block: unify request timeout handlingJens Axboe
Right now SCSI and others do their own command timeout handling. Move those bits to the block layer. Instead of having a timer per command, we try to be a bit more clever and simply have one per-queue. This avoids the overhead of having to tear down and setup a timer for each command, so it will result in a lot less timer fiddling. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-03[SCSI] libiscsi: return error passed in during iscsi recoveryMike Christie
Due to patch building error on my side, we are still passing DID_BUS_BUSY for commands that are running, when we want to return whatever the caller of fail_all_commands wanted. This replaces the hardcoded error code with the value that is passed in. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] libiscsi, iscsi_tcp, ib_iser: fix setting of can_queue with old tools.Mike Christie
This patch fixes two bugs that are related. 1. Old tools did not set can_queue/cmds_max. This patch modifies libiscsi so that when we add the host we catch this and set it to the default. 2. iscsi_tcp thought that the scsi command that was passed to the eh functions needed a iscsi_cmd_task allocated for it. It only needed a mgmt task, and now it does not matter since it all comes from the same pool and libiscsi handles this for the drivers. ib_iser had copied iscsi_tcp's code and set can_queue to its max - 1 to handle this. So this patch removes the max -1, and just sets it to the max. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] scsi: use get_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] libiscsi, iser, tcp: remove recv_lockMike Christie
The recv lock was defined so the iscsi layer could block the recv path from processing IO during recovery. It turns out iser just set a lock to that pointer which was pointless. We now disconnect the transport connection before doing recovery so we do not need the recv lock. For iscsi_tcp we still stop the recv path incase older tools are being used. This patch also has iscsi_itt_to_ctask user grab the session lock and has the caller access the task with the lock or get a ref to it in case the target is broken and sends a tmf success response then sends data or a response for the command that was supposed to be affected bty the tmf. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] libiscsi: fix cmds_max settingMike Christie
Drivers expect that the cmds_max value they pass to the iscsi layer is the max scsi commands + mgmt tasks. This patch implements that and fixes some checks for nr cmd limits. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi class: Add session initiatorname and ifacename sysfs attrs.Mike Christie
This adds two new attrs used for creating initiator ports and binding sessions to hardware. The session level initiatorname: Since bnx2i does a scsi_host per host device, we need to add the iface initiator port settings on the session, so we can create multiple initiator ports (each with different inames) per device/scsi_host. The current iname reflects that qla4xxx can have one iname per hba, and we are allocating a host per session for software. The iname on the host will remain so we can export and set the hba level qla4xxx setting. The ifacename attr: To bind a session to a some peice of hardware in userspace we maintain some mappings, but during boot or iscsid restart (iscsid contains the user space part of the driver) we need to be able to figure out which of those host mappings abstractions maps to certain sessions. This patch adds a ifacename attr, which userspace can set to id the host side of the endpoint across pivot_roots and iscsid restarts. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi class: user device_for_each_child instead of duplicating ↵Mike Christie
session list Currently we duplicate the list of sessions, because we were using the test for if a session was on the host list to indicate if the session was bound or unbound. We can instead use the target_id and fix up the class so that drivers like bnx2i do not have to manage the target id space. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] libiscsi: rename iscsi_cmd_task to iscsi_taskMike Christie
This is the second part of the iscsi task merging, and all it does it rename iscsi_cmd_task to iscsi_task and mtask/ctask to just task. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] libiscsi: merge iscsi_mgmt_task and iscsi_cmd_taskMike Christie
There is no need to have the mgmt and cmd tasks separate structs. It used to save a lot of memory when we overprealocated memory for tasks, but the next patches will set up the driver so in the future they can use a mempool or some other common scsi command allocator and common tagging. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] libiscsi: modify libiscsi so it supports offloaded data pathsMike Christie
This patch modifies libiscsi, so drivers like bnx2i and iser can execute a command from queuecommand/send_pdu instead of having to be queued to be run in a workq. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] libiscsi, iscsi_tcp, iser: add session cmds array accessorMike Christie
Currently to get a ctask from the session cmd array, you have to know to use the itt modifier. To make this easier on LLDs and so in the future we can easilly kill the session array and use the host shared map instead, this patch adds a nice wrapper to strip the itt into a session->cmds index and return a ctask. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iser: fix handling of scsi cmnds during recovery.Mike Christie
After the stop_conn callback has returned the LLD should not touch the scsi cmds. iscsi_tcp and libiscsi use the conn->recv_lock and suspend_rx field to halt recv path processing, but iser does not have any protection. This patch modifies iser so that userspace can just call the ep_disconnect callback, which will halt all recv IO, before calling the stop_conn callback so we do not have to worry about the conn->recv_lock and suspend rx field. iser just needs to stop the send side from accessing the ib conn. Fixup to handle when the ep poll fails and ep disconnect is called from Erez. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi: remove session/conn_data_size from iscsi_transportMike Christie
This removes the session and conn data_size fields from the iscsi_transport. Just pass in the value like with host allocation. This patch also makes it so the LLD iscsi_conn data is allocated with the iscsi_cls_conn. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi: add iscsi host helpersMike Christie
This finishes the host/session unbinding, by adding some helpers to add and remove hosts and the session they manage. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi: remove session and host binding in libiscsiMike Christie
bnx2i allocates a host per netdevice but will use libiscsi, so this unbinds the session from the host in that code. This will also be useful for the iser parent device dma settings fixes. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi class, iscsi drivers: remove unused iscsi_transport attrsMike Christie
max_cmd_len and max_conn are not really used. max_cmd_len is always 16 and can be set by the LLD. max_conn is always one since we do not support MCS. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-08[SCSI] libiscsi regression in 2.6.25: fix setting of recv timerMike Christie
If the ping tmo is longer than the recv tmo then we could miss a window where we were supposed to check the recv tmo. This happens because the ping code will set the next timeout for the ping timeout, and if the ping executes quickly there will be a long chunk of time before the timer wakes up again. This patch has the ping processing code kick off a recv tmo check when getting a nop in response to our ping. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-08[SCSI] libiscsi regression in 2.6.25: fix nop timer handlingMike Christie
The following patch fixes a bug in the iscsi nop processing. The target sends iscsi nops to ping the initiator and the initiator has to send nops to reply and can send nops to ping the target. In 2.6.25 we moved the nop processing to the kernel to handle problems when the userspace daemon is not up, but the target is pinging us, and to handle when scsi commands timeout, but the transport may be the cause (we can send a nop to check the transport). When we added this code we added a bug where if the transport timer wakes at the exact same time we are supposed to check for a nop timeout we drop the session instead of checking the transport. This patch checks if a iscsi ping is outstanding and if the ping has timed out, to determine if we need to signal a connection problem. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-18[SCSI] iscsi: bidi support at the generic libiscsi levelBoaz Harrosh
- prepare the additional bidi_read rlength header. - access the right scsi_in() and/or scsi_out() side of things. also for resid. - Handle BIDI underflow overflow from target Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Reviewed-by: Pete Wyckoff <pw@osc.edu> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-18[SCSI] iscsi: extended cdb supportBoaz Harrosh
Support for extended CDBs in iscsi. All we need is to check if command spills over 16 bytes then allocate an iscsi-extended-header for the leftovers. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Reviewed-by: Pete Wyckoff <pw@osc.edu> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-27[SCSI] iscsi regression: check for zero max session cmdsMike Christie
The old tools did not set max session cmds. This is a regression. I removed the check when merging the power of 2 patch. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] libiscsi: fix session age rollover and remove cid encodingMike Christie
The session age mask is only 4 bits, but session->age is 32. When it gets larger then 15 and we try to or the bits some bits get dropped and the check for session age in iscsi_verify_itt is useless. The ISCSI_CID_MASK related bits are also useless since cid is always one. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] iscsi: fix up iscsi printk prefixMike Christie
Some iscsi class messages have the dev_printk prefix and some libiscsi and iscsi_tcp messages have "iscsi" or the module name as a prefix which is normally pretty useless when trying to figure out which session or connection the message is attached to. This patch adds iscsi lib and class dev_printks so all messages have a common prefix that can be used to figure out which object printed it. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] libiscsi: fix setting of nop timerMike Christie
If we rollover then we could get a next_timeout of zero, so we need to set the new timer to that value. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] iscsi class, libiscsi: add iscsi sysfs session state fileMike Christie
This adds a iscsi session state file which exports the session state for both software and hardware iscsi. It also hooks libiscsi in. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] libiscsi: make __iscsi_complete_pdu() staticAdrian Bunk
__iscsi_complete_pdu() can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libiscsi: use is_power_of_2vignesh babu
Replacing n & (n - 1) for power of 2 check by is_power_of_2(n) Signed-off-by: vignesh babu <vignesh.babu@wipro.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libiscsi, iscsi class: set tmf to a safe default and export in sysfsMike Christie
Older tools will not be setting the tmf time outs since they did not exists, so set them to a safe default. And export abort and lu reset timeout values in sysfs. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] iscsi: convert xmit path to iscsi chunksOlaf Kirch
Convert xmit to iscsi chunks. from michaelc@cs.wisc.edu: Bug fixes, more digest integration, sg chaining conversion and other sg wrapper changes, coding style sync up, and removal of io fields, like pdu_sent, that are not needed. Signed-off-by: Olaf Kirch <olaf.kirch@oracle.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libiscsi: Drop host lock in queuecommandMike Christie
The driver does not need the host lock in queuecommand so drop it. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libiscsi: clear conn->ctask when task is completed earlyMike Christie
If the current ctask is failed early, we legt the conn->ctask pointer pointing to a invalid task. When the xmit thread would send data for it, we would then oops. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libiscsi: Do not fail commands immediately during logoutMike Christie
If the target requests a logout, then we do not want to fail commands to scsi-ml right away. This patch just fails in pending commands for a requeue immediately, and then lets iscsid handle running commands like normal recovery. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libiscsi: fix nop handlingMike Christie
During root boot and shutdown the target could send us nops. At this time iscsid cannot be running, so the target will drop the session and the boot or shutdown will hang. To handle this and allow us to better control when to check the network this patch moves the nop handling to the kernel. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libiscsi: fix shutdownMike Christie
We were using the device delete sysfs file to remove each device then logout. Now in 2.6.21 this will not work because the sysfs delete file returns immediately and does not wait for the device removal to complete. This causes a hang if a cache sync is needed during shutdown. Before .21, that approach had other problems, so this patch fixes the shutdown code so that we remove the target and unbind the session before logging out and shut down the session Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libiscsi: grab eh_mutex during host resetMike Christie
I thought we may not need the eh mutex during host reset, but that is wrong with the new shutdown code. When start_session_recovery sets the state to terminate then drops the session lock. The scsi eh thread could then grab the session lock see that we are terminating and then return failed to scsi-ml. scsi-ml's eh then owns the command and will do whatever it wants with it. But then the iscsi eh thread could grab the session lock and want to complete the scsi commands that we in the LLD, but it no longer owns them and kaboom. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libiscsi: do not block session during logoutMike Christie
There is not need to block the session during logout. Since we are going to fail the commands that were blocked just fail them immediately instead. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libiscsi, iscsi_tcp: iscsi pool cleanupOlaf Kirch
iscsi_pool_init simplified iscsi_pool_init currently has a lot of duplicate kfree() calls it does when some allocation fails. This patch simplifies the code a little by using iscsi_pool_free to tear down the pool in case of an error. iscsi_pool_init also returns a copy of the item array to the caller. Not all callers use this array, so we make it optional. Instead of allocating a second array and return that, allocate just one array, of twice the size. Update users of iscsi_pool_{init,free} This patch drops the (now useless) second argument to iscsi_pool_free, and updates all callers. It also removes the ctask->r2ts array, which was never used anyway. Since the items argument to iscsi_pool_init is now optional, we can pass NULL instead. Signed-off-by: Olaf Kirch <olaf.kirch@oracle.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libiscsi,iser: patch for AHS supportBoaz Harrosh
- The default initialization of hdr_max is the minimum - sizeof(struct iscsi_cmd) - Once this patch goes into iser the default initialization at libiscsi can be removed. - This is not yet full support for AHSs at iser end. But it should be easy. Just allocate more space at iser_desc right after iscsi_hdr. Than at transmission time use ctask->hdr_len to retrieve the total size of all iscsi pdu headers. See previous patch at iscsi_tcp.[ch] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] iscsi_tcp, libiscsi: initial AHS SupportBoaz Harrosh
at libiscsi generic code - currently code assumes a storage space of pdu header is allocated at llds ctask and is pointed to by iscsi_cmd_task->hdr. Here I add a hdr_max field pertaining to that storage, and an hdr_len that accumulates the current use of the pdu-header. - Add an iscsi_next_hdr() inline which returns the next free space to write new Header at. Also iscsi_next_hdr() is used to retrieve the address at which to write the header-digest. - Add iscsi_add_hdr(length). What the user do is calls iscsi_next_hdr() for address of the new header, than calls iscsi_add_hdr(length) with the size of the new header. iscsi_add_hdr() will check if space is available and update to the new size. length must be padded according to standard. - Add 2 padding inline helpers thanks to Olaf. Current patch does not use them but Following patches will. Also moved definition of ISCSI_PAD_LEN to iscsi_proto.h which had PAD_WORD_LEN that was never used anywhere. - Let iscsi_prep_scsi_cmd_pdu() signal an Error return since now it is possible that it will fail. - I was tired of yet again writing a "this is a digest" comment next to sizeof(__u32) so I defined a new ISCSI_DIGEST_SIZE. Now I don't need any comments. Changed all places that used sizeof(__u32) or "4" in connection to a digest. iscsi_tcp specific code - At struct iscsi_tcp_cmd_task allocate maximum space allowed in standard for all headers following the iscsi_cmd header. and mark it so in iscsi_tcp_session_create() - At iscsi_send_cmd_hdr() retrieve the correct headers size and write header digest at iscsi_next_hdr(). Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Olaf Kirch <olaf.kirch@oracle.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] iscsi: Prettify resid handling and some extra checksBoaz Harrosh
- Check to see that OVERFLOW is not negative indicating a bug. - Unify handling of UNDERFLOW and OVERFLOW to the same code. - Also handle BIDI_OVERFLOW. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libiscsi, iscsi_tcp: add device supportMike Christie
This patch adds logical unit reset support. This should work for ib_iser, but I have not finished testing that driver so it is not hooked in yet. This patch also temporarily reverts the iscsi_tcp r2t write out patch. That code is completely rewritten in this patchset. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
