path: root/drivers/scsi/libiscsi.c
2009-04-27[SCSI] cxgb3i, iser, iscsi_tcp: set target can queueMike Christie
Set target can queue limit to the number of preallocated session tasks we have. This along with the cxgb3i can_queue patch will fix a throughput problem where it could only queue one LU worth of data at a time. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-03[SCSI] libiscsi: fix iscsi pool error pathJean Delvare
Le lundi 30 mars 2009, Chris Wright a écrit : > q->queue could be ERR_PTR(-ENOMEM) which will break unwinding > on error. Make iscsi_pool_free more defensive. > Making the freeing of q->queue dependent on q->pool being set looks really weird (although it is correct at the moment. But this seems to be fixable in a much simpler way. With the benefit that only the error case is slowed down. In both cases we have a problem if q->queue contains an error value but it's not -ENOMEM. Apparently this can't happen today, but it doesn't feel right to assume this will always be true. Maybe it's the right time to fix this as well. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] libiscsi: fix possbile null ptr session command cleanupMike Christie
If the iscsi eh fires when the current task is a nop, then the task->sc pointer is null. fail_all_commands could then try to do task->sc->device and oops. We actually do not need to access the curr task in this path, because if it is a cmd task the fail_command call will handle this and if it is mgmt task then the flush of the mgmt queues will handle that. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] libiscsi: pass session failure a session structMike Christie
The api for conn and session failures is akward because one takes a conn from the lib and one takes a session from the class. This syncs up the interfaces to use structs from the lib. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] iscsi lib: remove qdepth param from iscsi host allocationMike Christie
The qdepth setting was useful when we needed libiscsi to verify the setting. Now we just need to make sure if older tools passed in zero then we need to set some default. So this patch just has us use the sht->cmd_per_lun or if for LLD does a host per session then we can set it on per host basis. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] iscsi lib: have lib create work queue for transmitting IOMike Christie
We were using the shost work queue which ended up being a little akward since all iscsi hosts need a thread for scanning, but only drivers hooked into libiscsi need a workqueue for transmitting. So this patch moves the xmit workqueue to the lib. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] libiscsi: don't cap queue depth in iscsi modulesMike Christie
There is no need to cap the queue depth in the modules. We set this in userspace and can do that there. For performance testing with ram based targets, this is helpful since we can have very high queue depths. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] libiscsi: replace scsi_debug logging with session/conn loggingMike Christie
This makes the logging a compile time option and replaces the scsi_debug macro with session and connection ones that print out a driver model id prefix. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] libiscsi: fix iscsi pool error pathJean Delvare
Memory freeing in iscsi_pool_free() looks wrong to me. Either q->pool can be NULL and this should be tested before dereferencing it, or it can't be NULL and it shouldn't be tested at all. As far as I can see, the only case where q->pool is NULL is on early error in iscsi_pool_init(). One possible way to fix the bug is thus to not call iscsi_pool_free() in this case (nothing needs to be freed anyway) and then we can get rid of the q->pool check. Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-02-10[SCSI] libiscsi: Fix scsi command timeout oops in iscsi_eh_timed_outMike Christie
Yanling Qi from LSI found the root cause of the panic, below is his analysis: Problem description: the open iscsi driver installs eh_timed_out handler to the blank_transport_template of the scsi middle level that causes panic of timed out command of other host Here are the details Iscsi Session creation During iscsi session creation time, the iscsi_tcp_session_create() of iscsi_tpc.c will create a scsi-host for the session. See the statement marked with the label A. The statement B replaces the shost->transportt point with a local struct variable. static struct iscsi_cls_session * iscsi_tcp_session_create(struct iscsi_endpoint *ep, uint16_t cmds_max, uint16_t qdepth, uint32_t initial_cmdsn, uint32_t *hostno) { struct iscsi_cls_session *cls_session; struct iscsi_session *session; struct Scsi_Host *shost; int cmd_i; if (ep) { printk(KERN_ERR "iscsi_tcp: invalid ep %p.\n", ep); return NULL; } A shost = iscsi_host_alloc(&iscsi_sht, 0, qdepth); if (!shost) return NULL; B shost->transportt = iscsi_tcp_scsi_transport; shost->max_lun = iscsi_max_lun; Please note the scsi host is allocated by invoking isccsi_host_alloc() in libiscsi.c Polluting the middle level blank_transport_template in iscsi_host_alloc() of libiscsi.c The iscsi_host_alloc() invokes the middle level function scsi_host_alloc() in hosts.c for allocating a scsi_host. Then the statement marked with C assigns the iscsi_eh_cmd_timed_out handler to the eh_timed_out callback function. struct Scsi_Host *iscsi_host_alloc(struct scsi_host_template *sht, int dd_data_size, uint16_t qdepth) { struct Scsi_Host *shost; struct iscsi_host *ihost; shost = scsi_host_alloc(sht, sizeof(struct iscsi_host) + dd_data_size); if (!shost) return NULL; C shost->transportt->eh_timed_out = iscsi_eh_cmd_timed_out; Please note the shost->transport is the middle level blank_transport_template as shown in the code segment below. We see two problems here. 1. iscsi_eh_cmd_timed_out is installed to the blank_transport_template that will cause some body else problem. 2. iscsi_eh_cmd_timed_out will never be invoked when iscsi command gets timeout because the statement B resets the pointer. Middle level blank_transport_template In the middle level function scsi_host_alloc() of hosts.c, the middle level assigns a blank_transport_template for those hosts not implementing its transport layer. All HBAs without supporting a specific scsi_transport will share the middle level blank_transport_template. Please see the statement D struct Scsi_Host *scsi_host_alloc(struct scsi_host_template *sht, int privsize) { struct Scsi_Host *shost; gfp_t gfp_mask = GFP_KERNEL; int rval; if (sht->unchecked_isa_dma && privsize) gfp_mask |= __GFP_DMA; shost = kzalloc(sizeof(struct Scsi_Host) + privsize, gfp_mask); if (!shost) return NULL; shost->host_lock = &shost->default_lock; spin_lock_init(shost->host_lock); shost->shost_state = SHOST_CREATED; INIT_LIST_HEAD(&shost->__devices); INIT_LIST_HEAD(&shost->__targets); INIT_LIST_HEAD(&shost->eh_cmd_q); INIT_LIST_HEAD(&shost->starved_list); init_waitqueue_head(&shost->host_wait); mutex_init(&shost->scan_mutex); shost->host_no = scsi_host_next_hn++; /* XXX(hch): still racy */ shost->dma_channel = 0xff; /* These three are default values which can be overridden */ shost->max_channel = 0; shost->max_id = 8; shost->max_lun = 8; /* Give each shost a default transportt */ D shost->transportt = &blank_transport_template; Why we see panic at iscsi_eh_cmd_timed_out() The mpp virtual HBA doesn’t have a specific scsi_transport. Therefore, the blank_transport_template will be assigned to the virtual host of the MPP virtual HBA by SCSI middle level. Please note that the statement C has assigned iscsi-transport eh_timedout handler to the blank_transport_template. When a mpp virtual command gets timedout, the iscsi_eh_cmd_timed_out() will be invoked to handle mpp virtual command timeout from the middle level scsi_times_out() function of the scsi_error.c. enum blk_eh_timer_return scsi_times_out(struct request *req) { struct scsi_cmnd *scmd = req->special; enum blk_eh_timer_return (*eh_timed_out)(struct scsi_cmnd *); enum blk_eh_timer_return rtn = BLK_EH_NOT_HANDLED; scsi_log_completion(scmd, TIMEOUT_ERROR); if (scmd->device->host->transportt->eh_timed_out) E eh_timed_out = scmd->device->host->transportt->eh_timed_out; else if (scmd->device->host->hostt->eh_timed_out) eh_timed_out = scmd->device->host->hostt->eh_timed_out; else eh_timed_out = NULL; if (eh_timed_out) { rtn = eh_timed_out(scmd); It is very easy to understand why we get panic in the iscsi_eh_cmd_timed_out(). A scsi_cmnd from a no-iscsi device definitely can not resolve out a session and session->lock. The panic can be happed anywhere during the differencing. static enum blk_eh_timer_return iscsi_eh_cmd_timed_out(struct scsi_cmnd *scmd) { struct iscsi_cls_session *cls_session; struct iscsi_session *session; struct iscsi_conn *conn; enum blk_eh_timer_return rc = BLK_EH_NOT_HANDLED; cls_session = starget_to_session(scsi_target(scmd->device)); session = cls_session->dd_data; debug_scsi("scsi cmd %p timedout\n", scmd); spin_lock(&session->lock); This patch fixes the problem by moving the setting of the iscsi_eh_cmd_timed_out to iscsi_add_host, which is after the LLDs have set their transport template to shost->transportt. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-25[SCSI] libiscsi: fix iscsi pool leakMike Christie
I am not sure what happened. It looks like we have always leaked the q->queue that is allocated from the kfifo_init call. nab finally noticed that we were leaking and this patch fixes it by adding a kfree call to iscsi_pool_free. kfifo_free is not used per kfifo_init's instructions to use kfree. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] libiscsi: handle init task failures.Mike Christie
Mgmt setup used to not fail so we did not have to check the return value. Now with cxgb3i it can so this has us pass up a error. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] libiscsi: pass opcode into alloc_pdu calloutMike Christie
We do not need to allocate a itt for data_out, so this passes the opcode to the alloc_pdu callout. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] libiscsi: allow drivers to modify the itt sent to the targetMike Christie
bnx2i and cxgb3i need to encode LLD info in the itt so that the firmware/hardware can process the pdu. This patch allows the LLDs to encode info in the task->hdr->itt that they setup in the alloc_pdu callout (any resources that are allocated can be freed with the pdu in the cleanup_task callout). If the LLD encodes info in the itt they should implement a parse_pdu_itt callout. If parse_pdu_itt is not implemented libiscsi will do the right thing for the LLD. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] libiscsi: change login data buffer allocationMike Christie
This modifies the login buffer allocation to use __get_free_pages. It will allow drivers that want to send this data with zero copy operations to easily line things up on page boundaries. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] libiscsi: prepare libiscsi for new offload engines by modifying unsol ↵Mike Christie
data code cxgb3i offloads data transfers. It does not offload the entire scsi/iscsi procssing like qla4xxx and it does not offload the iscsi sequence processing like how bnx2i does. cxgb3i relies on iscsi_tcp for the seqeunce handling so this changes how we transfer unsolicitied data by adding a common r2t struct and helpers. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-03[SCSI] libiscsi REGRESSION: fix passthrough support with older iscsi toolsMike Christie
This regression was added in 2.6.27, when the mtask and ctask were merged into the the common task struct. The patch applies to scsi-rc-fixes, but also applies to 2.6.27 with some offsets. The problem is that __iscsi_conn_send_pdu assumes that userspace was not sending nops with the format it is checking for in the "if" below. It turns out that older userspace tools are. This patch moves the setting of the internal ping_task tracker (it tracks libiscsi current outstanding nop) to iscsi_send_nopout which is only used by kernel callers. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13libiscsi: fix locking in iscsi_eh_device_resetMike Christie
We must be using the bh spin locking functions in iscsi_eh_device_reset becuase the session lock interacts with a thread and softirq. This patch also fixes up a bogus comment and check in fail_command, because no one drops the lock (bnx2i did but it is not going upstream yet and there were other refcount changes for that). Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13libiscsi: check reason why we are stopping iscsi session to determine error ↵Mike Christie
value Some wires got crossed on some patches and I messed up in the code below when rebuilding a patch. We want to be checking if flag equaled the value indicating if we killing the session due to final logout or if we just trying to relogin. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13[SCSI] libiscsi: rename host reset to target resetMike Christie
I had this in my patchset to add target reset support, but it got dropped due to patching conflicts. This initial patch just renames the function and users. We are actually just dropping the session, and so this does not have anything to do with the host exactly. It does for software iscsi because we allocate a host per session, but for cxgb3i this makes no sense. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13[SCSI] libiscsi: Support drivers initiating session removalMike Christie
If the driver knows when hardware is removed like with cxgb3i, bnx2i, qla4xxx and iser then we will want to remove the sessions/devices that are bound to that device before removing the host. cxgb3i and in the future bnx2i will remove the host and that will remove all the sessions on the hba. iser can call iscsi_kill_session when it gets an event that indicates that a hca is removed. And when qla4xxx is hooked in to the lib (it is only hooked into the class right now) it can call iscsi remove host like the partial offload card drivers. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13[SCSI] libiscsi: fix data corruption when target has to resend data-in packetsMike Christie
iscsi_tcp was updating the exp_statsn (exp_statsn acknowledges status and tells the target it is ok to let the resources for a iscsi pdu to be reused) before it got all the data for pdu read into OS buffers. Data corruption was occuring if something happens to a packet and the network layer requests a retransmit, and the initiator has told the target about the udpated exp_statsn ack, then the target may be sending data from a buffer it has reused for a new iscsi pdu. This fixes the problem by having the LLD (iscsi_tcp in this case) just handle the transferring of data, and has libiscsi handle the processing of status (libiscsi completion processing is done after LLD data transfers are complete). Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13[SCSI] iscsi class, libiscsi and qla4xxx: convert to new transport host byte ↵Mike Christie
values This patch converts the iscsi drivers to the new host byte values. v2 Drop some conversions. Want to avoid conflicts with other patches. v1 initial patch. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13[SCSI] libiscsi: Use SCSI_MLQUEUE_TARGET_BUSYMike Christie
For the conditions below we do not want the queuecommand function to call us right back, so return SCSI_MLQUEUE_TARGET_BUSY. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (37 commits) [SCSI] zfcp: fix double dbf id usage [SCSI] zfcp: wait on SCSI work to be finished before proceeding with init dev [SCSI] zfcp: fix erp list usage without using locks [SCSI] zfcp: prevent fc_remote_port_delete calls for unregistered rport [SCSI] zfcp: fix deadlock caused by shared work queue tasks [SCSI] zfcp: put threshold data in hba trace [SCSI] zfcp: Simplify zfcp data structures [SCSI] zfcp: Simplify get_adapter_by_busid [SCSI] zfcp: remove all typedefs and replace them with standards [SCSI] zfcp: attach and release SAN nameserver port on demand [SCSI] zfcp: remove unused references, declarations and flags [SCSI] zfcp: Update message with input from review [SCSI] zfcp: add queue_full sysfs attribute [SCSI] scsi_dh: suppress comparison warning [SCSI] scsi_dh: add Dell product information into rdac device handler [SCSI] qla2xxx: remove the unused SCSI_QLOGIC_FC_FIRMWARE option [SCSI] qla2xxx: fix printk format warnings [SCSI] qla2xxx: Update version number to 8.02.01-k8. [SCSI] qla2xxx: Ignore payload reserved-bits during RSCN processing. [SCSI] qla2xxx: Additional residual-count corrections during UNDERRUN handling. ...
2008-10-09block: unify request timeout handlingJens Axboe
Right now SCSI and others do their own command timeout handling. Move those bits to the block layer. Instead of having a timer per command, we try to be a bit more clever and simply have one per-queue. This avoids the overhead of having to tear down and setup a timer for each command, so it will result in a lot less timer fiddling. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-03[SCSI] libiscsi: return error passed in during iscsi recoveryMike Christie
Due to patch building error on my side, we are still passing DID_BUS_BUSY for commands that are running, when we want to return whatever the caller of fail_all_commands wanted. This replaces the hardcoded error code with the value that is passed in. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] libiscsi, iscsi_tcp, ib_iser: fix setting of can_queue with old tools.Mike Christie
This patch fixes two bugs that are related. 1. Old tools did not set can_queue/cmds_max. This patch modifies libiscsi so that when we add the host we catch this and set it to the default. 2. iscsi_tcp thought that the scsi command that was passed to the eh functions needed a iscsi_cmd_task allocated for it. It only needed a mgmt task, and now it does not matter since it all comes from the same pool and libiscsi handles this for the drivers. ib_iser had copied iscsi_tcp's code and set can_queue to its max - 1 to handle this. So this patch removes the max -1, and just sets it to the max. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] scsi: use get_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] libiscsi, iser, tcp: remove recv_lockMike Christie
The recv lock was defined so the iscsi layer could block the recv path from processing IO during recovery. It turns out iser just set a lock to that pointer which was pointless. We now disconnect the transport connection before doing recovery so we do not need the recv lock. For iscsi_tcp we still stop the recv path incase older tools are being used. This patch also has iscsi_itt_to_ctask user grab the session lock and has the caller access the task with the lock or get a ref to it in case the target is broken and sends a tmf success response then sends data or a response for the command that was supposed to be affected bty the tmf. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] libiscsi: fix cmds_max settingMike Christie
Drivers expect that the cmds_max value they pass to the iscsi layer is the max scsi commands + mgmt tasks. This patch implements that and fixes some checks for nr cmd limits. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi class: Add session initiatorname and ifacename sysfs attrs.Mike Christie
This adds two new attrs used for creating initiator ports and binding sessions to hardware. The session level initiatorname: Since bnx2i does a scsi_host per host device, we need to add the iface initiator port settings on the session, so we can create multiple initiator ports (each with different inames) per device/scsi_host. The current iname reflects that qla4xxx can have one iname per hba, and we are allocating a host per session for software. The iname on the host will remain so we can export and set the hba level qla4xxx setting. The ifacename attr: To bind a session to a some peice of hardware in userspace we maintain some mappings, but during boot or iscsid restart (iscsid contains the user space part of the driver) we need to be able to figure out which of those host mappings abstractions maps to certain sessions. This patch adds a ifacename attr, which userspace can set to id the host side of the endpoint across pivot_roots and iscsid restarts. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi class: user device_for_each_child instead of duplicating ↵Mike Christie
session list Currently we duplicate the list of sessions, because we were using the test for if a session was on the host list to indicate if the session was bound or unbound. We can instead use the target_id and fix up the class so that drivers like bnx2i do not have to manage the target id space. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] libiscsi: rename iscsi_cmd_task to iscsi_taskMike Christie
This is the second part of the iscsi task merging, and all it does it rename iscsi_cmd_task to iscsi_task and mtask/ctask to just task. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] libiscsi: merge iscsi_mgmt_task and iscsi_cmd_taskMike Christie
There is no need to have the mgmt and cmd tasks separate structs. It used to save a lot of memory when we overprealocated memory for tasks, but the next patches will set up the driver so in the future they can use a mempool or some other common scsi command allocator and common tagging. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] libiscsi: modify libiscsi so it supports offloaded data pathsMike Christie
This patch modifies libiscsi, so drivers like bnx2i and iser can execute a command from queuecommand/send_pdu instead of having to be queued to be run in a workq. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] libiscsi, iscsi_tcp, iser: add session cmds array accessorMike Christie
Currently to get a ctask from the session cmd array, you have to know to use the itt modifier. To make this easier on LLDs and so in the future we can easilly kill the session array and use the host shared map instead, this patch adds a nice wrapper to strip the itt into a session->cmds index and return a ctask. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iser: fix handling of scsi cmnds during recovery.Mike Christie
After the stop_conn callback has returned the LLD should not touch the scsi cmds. iscsi_tcp and libiscsi use the conn->recv_lock and suspend_rx field to halt recv path processing, but iser does not have any protection. This patch modifies iser so that userspace can just call the ep_disconnect callback, which will halt all recv IO, before calling the stop_conn callback so we do not have to worry about the conn->recv_lock and suspend rx field. iser just needs to stop the send side from accessing the ib conn. Fixup to handle when the ep poll fails and ep disconnect is called from Erez. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi: remove session/conn_data_size from iscsi_transportMike Christie
This removes the session and conn data_size fields from the iscsi_transport. Just pass in the value like with host allocation. This patch also makes it so the LLD iscsi_conn data is allocated with the iscsi_cls_conn. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi: add iscsi host helpersMike Christie
This finishes the host/session unbinding, by adding some helpers to add and remove hosts and the session they manage. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi: remove session and host binding in libiscsiMike Christie
bnx2i allocates a host per netdevice but will use libiscsi, so this unbinds the session from the host in that code. This will also be useful for the iser parent device dma settings fixes. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi class, iscsi drivers: remove unused iscsi_transport attrsMike Christie
max_cmd_len and max_conn are not really used. max_cmd_len is always 16 and can be set by the LLD. max_conn is always one since we do not support MCS. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-08[SCSI] libiscsi regression in 2.6.25: fix setting of recv timerMike Christie
If the ping tmo is longer than the recv tmo then we could miss a window where we were supposed to check the recv tmo. This happens because the ping code will set the next timeout for the ping timeout, and if the ping executes quickly there will be a long chunk of time before the timer wakes up again. This patch has the ping processing code kick off a recv tmo check when getting a nop in response to our ping. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-08[SCSI] libiscsi regression in 2.6.25: fix nop timer handlingMike Christie
The following patch fixes a bug in the iscsi nop processing. The target sends iscsi nops to ping the initiator and the initiator has to send nops to reply and can send nops to ping the target. In 2.6.25 we moved the nop processing to the kernel to handle problems when the userspace daemon is not up, but the target is pinging us, and to handle when scsi commands timeout, but the transport may be the cause (we can send a nop to check the transport). When we added this code we added a bug where if the transport timer wakes at the exact same time we are supposed to check for a nop timeout we drop the session instead of checking the transport. This patch checks if a iscsi ping is outstanding and if the ping has timed out, to determine if we need to signal a connection problem. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-18[SCSI] iscsi: bidi support at the generic libiscsi levelBoaz Harrosh
- prepare the additional bidi_read rlength header. - access the right scsi_in() and/or scsi_out() side of things. also for resid. - Handle BIDI underflow overflow from target Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Reviewed-by: Pete Wyckoff <pw@osc.edu> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-18[SCSI] iscsi: extended cdb supportBoaz Harrosh
Support for extended CDBs in iscsi. All we need is to check if command spills over 16 bytes then allocate an iscsi-extended-header for the leftovers. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Reviewed-by: Pete Wyckoff <pw@osc.edu> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-27[SCSI] iscsi regression: check for zero max session cmdsMike Christie
The old tools did not set max session cmds. This is a regression. I removed the check when merging the power of 2 patch. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] libiscsi: fix session age rollover and remove cid encodingMike Christie
The session age mask is only 4 bits, but session->age is 32. When it gets larger then 15 and we try to or the bits some bits get dropped and the check for session age in iscsi_verify_itt is useless. The ISCSI_CID_MASK related bits are also useless since cid is always one. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] iscsi: fix up iscsi printk prefixMike Christie
Some iscsi class messages have the dev_printk prefix and some libiscsi and iscsi_tcp messages have "iscsi" or the module name as a prefix which is normally pretty useless when trying to figure out which session or connection the message is attached to. This patch adds iscsi lib and class dev_printks so all messages have a common prefix that can be used to figure out which object printed it. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] libiscsi: fix setting of nop timerMike Christie
If we rollover then we could get a next_timeout of zero, so we need to set the new timer to that value. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
