path: root/drivers/scsi/ips.c
2006-06-26spelling fixesAndreas Mohr
acquired (aquired) contiguous (contigious) successful (succesful, succesfull) surprise (suprise) whether (weather) some other misspellings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-10[SCSI] drivers/scsi: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove duplicates of the macro. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-06[SCSI] fix up request buffer reference in various scsi driversChristoph Hellwig
Various scsi drivers use scsi_cmnd.buffer and scsi_cmnd.bufflen in their queuecommand functions. Those fields are internal storage for the midlayer only and are used to restore the original payload after request_buffer and request_bufflen have been overwritten for EH. Using the buffer and bufflen fields means they do very broken things in error handling. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-28[PATCH] Replace 0xff.. with correct DMA_xBIT_MASKMatthias Gehre
Replace all occurences of 0xff.. in calls to function pci_set_dma_mask() and pci_set_consistant_dma_mask() with the corresponding DMA_xBIT_MASK from linux/dma-mapping.h. Signed-off-by: Matthias Gehre <M.Gehre@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-27[SCSI] don't call ips_eh_reset in ips_queue to avoid deadlockMike Christie
When the locking was changed in the eh code ips_eh_reset was changed so that it was a wraper around __ips_eh_reset and all ips_eh_reset does is grab the host lock and then calls __ips_eh_reset. In the queuecommand, ips_queue is called with the host_lock held so if it calls ips_eh_reset we will have a problem. This patch just has ips_queue call __ips_eh_reset. Patch is only compile tested. I do not have the HW. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Acked-by: Hammer, Jack <Jack_Hammer@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-31[SCSI] ServeRAID: prevent seeing DADSI devicesJack Hammer
A critical thing the ServeRAID driver MUST do is hide the physical DASDI devices from the OS. It does this by intercepting the INQUIRY commands. In recent 2.6.15 testing, I discovered this to be failing. The cause was the driver assuming that the INQUIRY response data was in a simple single buffer, when it was actually a 1 element scatter gather list. This patch makes ips always look at the correct data when examining an INQUIRY response. Signed-off-by: Jack Hammer <jack_hammer@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-26[SCSI] ips soft lockup during reset/initializationJack Hammer
Resetting the adapter causes the ServeRAID driver to exceed the max time allowed by the softlock watchdog. Resetting the hardware can easily require 30 or more seconds. To avoid the "BUG: soft lockup detected on CPU#0!" result, this patch replaces the mdelay() calls in the initialization/reset routines with msleep(). Signed-off-by: Jack Hammer <jack_hammer@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] ips: Mode Sense (Caching Page ) fixJack Hammer
To avoid the "sda: got wrong page" message, the ServeRAID driver should be setting flags indicating that the Mode Sense commands are not supported. Signed-off-by: Jack Hammer <jack_hammer@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-09[SCSI] remove Scsi_Device typedefChristoph Hellwig
2005-11-09[SCSI] remove Scsi_Host_Template typedefChristoph Hellwig
2005-11-08Merge by hand (conflicts between pending drivers and kfree cleanups)James Bottomley
2005-11-07[PATCH] kfree cleanup: drivers/scsiJesper Juhl
This is the drivers/scsi/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in drivers/scsi/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-06[SCSI] ips: remove "Version Matching"Jack Hammer
IBM has finally agreed that the "Version Matching" between firmware and drivers ( and the resulting warning messages ) is no longer necessary. This patch will remove those functions from the ServeRAID driver. Signed-off-by: Jack Hammer <jack_hammer@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-04Fix ips.c compileJames Bottomley
It looks like one of the ips patches was missing a closing brace in a function Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-31[SCSI] ips: Fix initialization bug with kdumpJack Hammer
If I/O is active on the adapter, and an unexpected interrupt is pending during initialization, the driver blows it's brains out. Since the driver didn't initiate the I/O, the data in it's internal tables will contain NULL pointers. When this condition is detected, a "flush cache and reset" is performed. The flush cache allows any pending "lazy writes" that the adapter is processing to complete ( a "must have" for a RAID adapter ) and the reset puts the adapter back into a known, good state. Signed-off-by: Jack Hammer <jack_hammer@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-29[SCSI] ips: Fix up for correct scatter/gather processingJack Hammer
Added kmap_atomic/kunmap_atomic. Added protection of KM_IRQ0 slot with local_irq_save(), local_irq_restore(), and comments. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[SCSI] use scmd_id(), scmd_channel() throughout codeJeff Garzik
Wrap a highly common idiom. Makes the code easier to read, helps pave the way for sdev->{id,channel} removal, and adds a token that can easily by grepped-for in the future. There are a couple sdev_id() and scmd_printk() updates thrown in as well. Rejections fixed up and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-02[SCSI] ServeRAID V7.12.02Jack Hammer
I am resubmitting the 2.6 kernel patch for the Version 7.12.02 ips driver. I have eliminated a couple of inappropriate changes pointed out by Arjan. Signed-off-by: Jack Hammer <jack_hammer@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-06-17[SCSI] allow sleeping in ->eh_host_reset_handler()Jeff Garzik
2005-06-17[SCSI] allow sleeping in ->eh_abort_handler()Jeff Garzik
2005-04-18[PATCH] remove old scsi data direction macros
these have been wrappers for the generic dma direction bits since 2.5.x. This patch converts the few remaining drivers and removes the macros. Arjan noticed there's some hunk in here that shouldn't. Updated patch below: Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-04-18[PATCH] scsi: remove meaningless scsi_cmnd->serial_number_at_timeout field
scsi_cmnd->serial_number_at_timeout doesn't serve any purpose anymore. All serial_number == serial_number_at_timeout tests are always true in abort callbacks. Kill the field. Also, as ->pid always equals ->serial_number and ->serial_number doesn't have any special meaning anymore, update comments above ->serial_number accordingly. Once we remove all uses of this field from all lldd's, this field should go. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
