path: root/drivers/scsi/ipr.c
2008-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (21 commits) [SCSI] sd: fix computation of the full size of the device [SCSI] lib: string_get_size(): don't hang on zero; no decimals on exact [SCSI] sun3x_esp: Convert && to || [SCSI] sd: remove command-size switching code [SCSI] 3w-9xxx: remove unnecessary local_irq_save/restore for scsi sg copy API [SCSI] 3w-xxxx: remove unnecessary local_irq_save/restore for scsi sg copy API [SCSI] fix netlink kernel-doc [SCSI] sd: Fix handling of NO_SENSE check condition [SCSI] export busy state via q->lld_busy_fn() [SCSI] refactor sdev/starget/shost busy checking [SCSI] mptfusion: Increase scsi-timeouts, similariy to the LSI 4.x driver. [SCSI] aic7xxx: Take the LED out of diagnostic mode on PM resume [SCSI] aic79xx: user visible misuse wrong SI units (not disk size!) [SCSI] ipr: use memory_read_from_buffer() [SCSI] aic79xx: fix shadowed variables [SCSI] aic79xx: fix shadowed variables, add statics [SCSI] aic7xxx: update *_shipped files [SCSI] aic7xxx: update .reg files [SCSI] aic7xxx: introduce "dont_generate_debug_code" keyword in aicasm parser [SCSI] scsi_dh: Initialize path state to be passive when path is not owned ...
2008-10-23[SCSI] ipr: use memory_read_from_buffer()Akinobu Mita
Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Brian King <brking@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-20PCI: remove dynids.use_driver_dataMilton Miller
The driver flag dynids.use_driver_data is almost consistently not set, and causes more problems than it solves. It was initially intended as a flag to indicate whether a driver's usage of driver_data had been carefully inspected and was ready for values from userspace. That audit was never done, so most drivers just get a 0 for driver_data when new IDs are added from userspace via sysfs. So remove the flag, allowing drivers to see the data directly (a followon patch validates the passed driver_data value against what the drivers expect). Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-09block: unify request timeout handlingJens Axboe
Right now SCSI and others do their own command timeout handling. Move those bits to the block layer. Instead of having a timer per command, we try to be a bit more clever and simply have one per-queue. This avoids the overhead of having to tear down and setup a timer for each command, so it will result in a lot less timer fiddling. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-11[SCSI] ipr: Fix HDIO_GET_IDENTITY oops for SATA devicesBrian King
Currently, ipr does not support HDIO_GET_IDENTITY to SATA devices. An oops occurs if userspace attempts to send the command. Since hald issues the command, ensure we fail the ioctl in ipr. This is a temporary solution to the oops. Once the ipr libata EH conversion is upstream, ipr will fully support HDIO_GET_IDENTITY. Tested-by: Milton Miller <miltonm@bga.com> Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-29[SCSI] ipr: Rename ipr's state scsi host attribute to prevent collisionsBrian King
Due to recent device model changes it now no longer tolerates name collisions. This causes a problem for ipr whose "state" attribute collides with an identically named one in the SCSI mid-layer. Rename the ipr driver attribute to be more specific. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-19SCSI: convert struct class_device to struct deviceTony Jones
It's big, but there doesn't seem to be a way to split it up smaller... Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-17libata: kill ata_noop_dev_select()Tejun Heo
Now that SFF assumptions are separated out from non-SFF reset sequence, port_ops->sff_dev_select() is no longer necessary for non-SFF controllers. Kill ata_noop_dev_select() and ->sff_dev_select initialization from base and other non-SFF port_ops. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: remove check_status from non-SFF driversTejun Heo
Now that all SFF stuff is separated out of core layer, core layer doesn't call ops->[alt_]check_status(). In fact, no one calls them for non-SFF drivers anymore. Kill them. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: replace tf_read with qc_fill_rtf for non-SFF driversTejun Heo
Now that all SFF stuff is separated out of core layer, core layer doesn't call ops->tf_read directly. It gets called only via ops->qc_fill_rtf() for non-SFF drivers. This patch directly implements private ops->qc_fill_rtf() for non-SFF controllers and kill ops->tf_read(). This is much cleaner for non-SFF controllers as some of them have to cache SFF register values in private data structure and report the cached values via ops->tf_read(). Also, ops->tf_read() gets nasty for controllers which don't have clear notion of TF registers when operation is not in progress. As this change makes default ops->qc_fill_rtf unnecessary, move ata_sff_qc_fill_rtf() form ata_base_port_ops to ata_sff_port_ops where it belongs. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: add qc_fill_rtf port operationTejun Heo
On command completion, ata_qc_complete() directly called ops->tf_read to fill qc->result_tf. This patch adds ops->qc_fill_rtf to replace hardcoded ops->tf_read usage. ata_sff_qc_fill_rtf() which uses ops->tf_read to fill result_tf is implemented and set in ata_base_port_ops and other ops tables which don't inherit from ata_base_port_ops, so this patch doesn't introduce any behavior change. ops->qc_fill_rtf() is similar to ops->sff_tf_read() but can only be called when a command finishes. As some non-SFF controllers don't have TF registers defined unless they're associated with in-flight commands, this limited operation makes life easier for those drivers and help lifting SFF assumptions from libata core layer. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: rename SFF port opsTejun Heo
Add sff_ prefix to SFF specific port ops. This rename is in preparation of separating SFF support out of libata core layer. This patch strictly renames ops and doesn't introduce any behavior difference. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: make reset related methods proper port operationsTejun Heo
Currently reset methods are not specified directly in the ata_port_operations table. If a LLD wants to use custom reset methods, it should construct and use a error_handler which uses those reset methods. It's done this way for two reasons. First, the ops table already contained too many methods and adding four more of them would noticeably increase the amount of necessary boilerplate code all over low level drivers. Second, as ->error_handler uses those reset methods, it can get confusing. ie. By overriding ->error_handler, those reset ops can be made useless making layering a bit hazy. Now that ops table uses inheritance, the first problem doesn't exist anymore. The second isn't completely solved but is relieved by providing default values - most drivers can just override what it has implemented and don't have to concern itself about higher level callbacks. In fact, there currently is no driver which actually modifies error handling behavior. Drivers which override ->error_handler just wraps the standard error handler only to prepare the controller for EH. I don't think making ops layering strict has any noticeable benefit. This patch makes ->prereset, ->softreset, ->hardreset, ->postreset and their PMP counterparts propoer ops. Default ops are provided in the base ops tables and drivers are converted to override individual reset methods instead of creating custom error_handler. * ata_std_error_handler() doesn't use sata_std_hardreset() if SCRs aren't accessible. sata_promise doesn't need to use separate error_handlers for PATA and SATA anymore. * softreset is broken for sata_inic162x and sata_sx4. As libata now always prefers hardreset, this doesn't really matter but the ops are forced to NULL using ATA_OP_NULL for documentation purpose. * pata_hpt374 needs to use different prereset for the first and second PCI functions. This used to be done by branching from hpt374_error_handler(). The proper way to do this is to use separate ops and port_info tables for each function. Converted. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-02-19libata: eliminate the home grown dma padding in favour ofJames Bottomley
that provided by the block layer ATA requires that all DMA transfers begin and end on word boundaries. Because of this, a large amount of machinery grew up in ide to adjust scatterlists on this basis. However, as of 2.5, the block layer has a dma_alignment variable which ensures both the beginning and length of a DMA transfer are aligned on the dma_alignment boundary. Although the block layer does adjust the beginning of the transfer to ensure this happens, it doesn't actually adjust the length, it merely makes sure that space is allocated for transfers beyond the declared length. The upshot of this is that scatterlists may be padded to any size between the actual length and the length adjusted to the dma_alignment safely knowing that memory is allocated in this region. Right at the moment, SCSI takes the default dma_aligment which is on a 512 byte boundary. Note that this aligment only applies to transfers coming in from user space. However, since all kernel allocations are automatically aligned on a minimum of 32 byte boundaries, it is safe to adjust them in this manner as well. tj: * Adjusting sg after padding is done in block layer. Make libata set queue alignment correctly for ATAPI devices and drop broken sg mangling from ata_sg_setup(). * Use request->raw_data_len for ATAPI transfer chunk size. * Killed qc->raw_nbytes. * Separated out killing qc->n_iter. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-03drivers/scsi/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Acked-by: James Smart <james.smart@emulex.com> Acked-by: Darrick J. Wong <djwong@us.ibm.com> Acked-by: David Somayajulu <david.somayajulu@qlogic.com> Acked-by: Mark Salyzyn <mark_salyzyn@adaptec.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (200 commits) [SCSI] usbstorage: use last_sector_bug flag universally [SCSI] libsas: abstract STP task status into a function [SCSI] ultrastor: clean up inline asm warnings [SCSI] aic7xxx: fix firmware build [SCSI] aacraid: fib context lock for management ioctls [SCSI] ch: remove forward declarations [SCSI] ch: fix device minor number management bug [SCSI] ch: handle class_device_create failure properly [SCSI] NCR5380: fix section mismatch [SCSI] sg: fix /proc/scsi/sg/devices when no SCSI devices [SCSI] IB/iSER: add logical unit reset support [SCSI] don't use __GFP_DMA for sense buffers if not required [SCSI] use dynamically allocated sense buffer [SCSI] scsi.h: add macro for enclosure bit of inquiry data [SCSI] sd: add fix for devices with last sector access problems [SCSI] fix pcmcia compile problem [SCSI] aacraid: add Voodoo Lite class of cards. [SCSI] aacraid: add new driver features flags [SCSI] qla2xxx: Update version number to 8.02.00-k7. [SCSI] qla2xxx: Issue correct MBC_INITIALIZE_FIRMWARE command. ...
2008-01-23libata: convert to chained sgTejun Heo
libata used private sg iterator to handle padding sg. Now that sg can be chained, padding can be handled using standard sg ops. Convert to chained sg. * s/qc->__sg/qc->sg/ * s/qc->pad_sgent/qc->extra_sg[]/. Because chaining consumes one sg entry. There need to be two extra sg entries. The renaming is also for future addition of other extra sg entries. * Padding setup is moved into ata_sg_setup_extra() which is organized in a way that future addition of other extra sg entries is easy. * qc->orig_n_elem is unused and removed. * qc->n_elem now contains the number of sg entries that LLDs should map. qc->mapped_n_elem is added to carry the original number of mapped sgs for unmapping. * The last sg of the original sg list is used to chain to extra sg list. The original last sg is pointed to by qc->last_sg and the content is stored in qc->saved_last_sg. It's restored during ata_sg_clean(). * All sg walking code has been updated. Unnecessary assertions and checks for conditions the core layer already guarantees are removed. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata: rename ATA_PROT_ATAPI_* to ATAPI_PROT_*Tejun Heo
ATA_PROT_ATAPI_* are ugly and naming schemes between ATA_PROT_* and ATA_PROT_ATAPI_* are inconsistent causing confusion. Rename them to ATAPI_PROT_* and make them consistent with ATA counterpart. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-01-11[SCSI] ipr: use LIST_HEAD instead of LIST_HEAD_INITDenis Cheng
Signed-off-by: Denis Cheng <crquan@gmail.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-24SG: Change sg_set_page() to take length and offset argumentJens Axboe
Most drivers need to set length and offset as well, so may as well fold those three lines into one. Add sg_assign_page() for those two locations that only needed to set the page, where the offset/length is set outside of the function context. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-22[SG] Update drivers to use sg helpersJens Axboe
2007-10-18[libata] kill ata_sg_is_last()Jeff Garzik
Short term, this works around a bug introduced by early sg-chaining work. Long term, removing this function eliminates a branch from a hot path loop in each scatter/gather table build. Also, as this code demonstrates, we don't need to _track_ the end of the s/g list, as long as we mark it in some way. And doing so programatically is nice. So its a useful cleanup, regardless of its short term effects. Based conceptually on a quick patch by Jens Axboe. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-12[libata] Remove ->port_disable() hookJeff Garzik
It was always set to ata_port_disable(). Removed the hook, and replaced the very few ap->ops->port_disable() callsites with direct calls to ata_port_disable(). Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: linkify resetTejun Heo
Make reset methods and related functions deal with ata_link instead of ata_port. * ata_do_reset() * ata_eh_reset() * all prereset/reset/postreset methods and related functions This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: introduce ata_linkTejun Heo
Introduce ata_link. It abstracts PHY and sits between ata_port and ata_device. This new level of abstraction is necessary to support SATA Port Multiplier, which basically adds a bunch of links (PHYs) to a ATA host port. Fields related to command execution, spd_limit and EH are per-link and thus moved to ata_link. This patch only defines the host link. Multiple link handling will be added later. Also, a lot of ap->link derefences are added but many of them will be removed as each part is converted to deal directly with ata_link instead of ata_port. This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-15Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (166 commits) [SCSI] ibmvscsi: convert to use the data buffer accessors [SCSI] dc395x: convert to use the data buffer accessors [SCSI] ncr53c8xx: convert to use the data buffer accessors [SCSI] sym53c8xx: convert to use the data buffer accessors [SCSI] ppa: coding police and printk levels [SCSI] aic7xxx_old: remove redundant GFP_ATOMIC from kmalloc [SCSI] i2o: remove redundant GFP_ATOMIC from kmalloc from device.c [SCSI] remove the dead CYBERSTORMIII_SCSI option [SCSI] don't build scsi_dma_{map,unmap} for !HAS_DMA [SCSI] Clean up scsi_add_lun a bit [SCSI] 53c700: Remove printk, which triggers because of low scsi clock on SNI RMs [SCSI] sni_53c710: Cleanup [SCSI] qla4xxx: Fix underrun/overrun conditions [SCSI] megaraid_mbox: use mutex instead of semaphore [SCSI] aacraid: add 51245, 51645 and 52245 adapters to documentation. [SCSI] qla2xxx: update version to 8.02.00-k1. [SCSI] qla2xxx: add support for NPIV [SCSI] stex: use resid for xfer len information [SCSI] Add Brownie 1200U3P to blacklist [SCSI] scsi.c: convert to use the data buffer accessors ...
2007-07-12Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (34 commits) PCI: Only build PCI syscalls on architectures that want them PCI: limit pci_get_bus_and_slot to domain 0 PCI: hotplug: acpiphp: avoid acpiphp "cannot get bridge info" PCI hotplug failure PCI: hotplug: acpiphp: remove hot plug parameter write to PCI host bridge PCI: hotplug: acpiphp: fix slot poweroff problem on systems without _PS3 PCI: hotplug: pciehp: wait for 1 second after power off slot PCI: pci_set_power_state(): check for PM capabilities earlier PCI: cpci_hotplug: Convert to use the kthread API PCI: add pci_try_set_mwi PCI: pcie: remove SPIN_LOCK_UNLOCKED PCI: ROUND_UP macro cleanup in drivers/pci PCI: remove pci_dac_dma_... APIs PCI: pci-x-pci-express-read-control-interfaces cleanups PCI: Fix typo in include/linux/pci.h PCI: pci_ids, remove double or more empty lines PCI: pci_ids, add atheros and 3com_2 vendors PCI: pci_ids, reorder some entries PCI: i386: traps, change VENDOR to DEVICE PCI: ATM: lanai, change VENDOR to DEVICE PCI: Change all drivers to use pci_device->revision ...
2007-07-11sysfs: add parameter "struct bin_attribute *" in .read/.write methods for ↵Zhang Rui
sysfs binary attributes Well, first of all, I don't want to change so many files either. What I do: Adding a new parameter "struct bin_attribute *" in the .read/.write methods for the sysfs binary attributes. In fact, only the four lines change in fs/sysfs/bin.c and include/linux/sysfs.h do the real work. But I have to update all the files that use binary attributes to make them compatible with the new .read and .write methods. I'm not sure if I missed any. :( Why I do this: For a sysfs attribute, we can get a pointer pointing to the struct attribute in the .show/.store method, while we can't do this for the binary attributes. I don't know why this is different, but this does make it not so handy to use the binary attributes as the regular ones. So I think this patch is reasonable. :) Who benefits from it: The patch that exposes ACPI tables in sysfs requires such an improvement. All the table binary attributes share the same .read method. Parameter "struct bin_attribute *" is used to get the table signature and instance number which are used to distinguish different ACPI table binary attributes. Without this parameter, we need to offer different .read methods for different ACPI table binary attributes. This is impossible as there are various ACPI tables on different platforms, and we don't know what they are until they are loaded. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-30[SCSI] Merge up to linux-2.6 headJames Bottomley
Conflicts: drivers/scsi/jazz_esp.c Same changes made by both SCSI and SPARC trees: problem with UTF-8 conversion in the copyright. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-29[SCSI] ipr: convert to use the data buffer accessorsFUJITA Tomonori
- remove the unnecessary map_single path. - convert to use the new accessors for the sg lists and the parameters. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-16[SCSI] ipr: Proper return codes for eh_dev_reset for SATA devicesBrian King
Currently ipr always returns success from eh_dev_reset when called for a SATA device. If ata_do_eh is unable to recover for some reason, this can result in commands that are still outstanding when ata_do_eh returns. Change ipr to verify no commands are outstanding before returning success. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-08[SCSI] ipr: Use PCI-E reset API for new ipr adapterBrian King
Use a newly added PCI API to issue a PCI Fundamental reset (warm reset) to a new ipr PCI-E adapter. Typically, the ipr adapter uses the start BIST bit in config space to reset an adapter. Issuing start BIST on this particular adapter results in the PCI-E logic on the card losing sync, which causes PCI-E errors, making the card unusable. The only reset mechanism that exists on this hardware that does not have this problem is PCI Fundamental reset (warm reset). Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06[SCSI] ipr: Better handle adapter boot time errorsBrian King
If an ipr adapter encounters an adapter error requiring an adapter reset to recover from prior to driver load time, the error will be ignored and recovery will not happen until the initial timeout occurs waiting for the firmware to come ready, which means a five minute timeout. Fix is to read the interrupt register before clearing any of the interrupts at probe time. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06[SCSI] ipr: Enable multi-initator RAID supportBrian King
Enables multi-initiator support on ipr RAID adapters that support it. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06[SCSI] ipr: Improved dual adapter errorsBrian King
Formats ipr dual adapter errors so that they are more compact. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06[SCSI] ipr: Increase adapter operational timeoutBrian King
Increases the adapter operational timeout for some adapters that support dual controller configurations, since they may take longer to come ready. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06[SCSI] ipr: Handle IOA reset requestBrian King
In ipr dual adapter configurations, the ipr adapter firmware may require an adapter reset for various reasons. The reset is requested by the adapter firmware logging an error with an IOASC of 0x02048000. Add support to log this error, and reset the adapter. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06[SCSI] ipr: Handle check condition status from disk array deviceBrian King
On newer levels of microcode for ipr RAID adapters supporting multi-initiator configurations, the disk array, or VSET, resources are capable of generating a check condition. This patch prevents ipr from generating sense data in this scenario and retrieving it from the logical device instead. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06[SCSI] ipr: Handle UA on disk array following an adapter resetBrian King
On certain ipr RAID adapters, which are capable of multi-initiator configurations, the disk array, or VSET, resources will be in a POR Unit Attention state following an adapter reset. In order for the midlayer to handle the UA, I must report a bus reset to the logical disk array bus at the end of an adapter reset. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06[SCSI] ipr: Allow driver_data to be passed for dynamic idsBrian King
Since driver_data for pci ids in the ipr driver is now just flags, we can allow these to be passed in from userspace for dynamic ids. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06[SCSI] ipr: Prevent overlapped adapter resetsBrian King
This patch fixes some scenarios where an ipr adapter could get reset overlapped, which could cause very long timeouts to occur, or PCI bus errors. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-05Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (87 commits) [SCSI] fusion: fix domain validation loops [SCSI] qla2xxx: fix regression on sparc64 [SCSI] modalias for scsi devices [SCSI] sg: cap reserved_size values at max_sectors [SCSI] BusLogic: stop using check_region [SCSI] tgt: fix rdma transfer bugs [SCSI] aacraid: fix aacraid not finding device [SCSI] aacraid: Correct SMC products in aacraid.txt [SCSI] scsi_error.c: Add EH Start Unit retry [SCSI] aacraid: [Fastboot] Panics for AACRAID driver during 'insmod' for kexec test. [SCSI] ipr: Driver version to 2.3.2 [SCSI] ipr: Faster sg list fetch [SCSI] ipr: Return better qc_issue errors [SCSI] ipr: Disrupt device error [SCSI] ipr: Improve async error logging level control [SCSI] ipr: PCI unblock config access fix [SCSI] ipr: Fix for oops following SATA request sense [SCSI] ipr: Log error for SAS dual path switch [SCSI] ipr: Enable logging of debug error data for all devices [SCSI] ipr: Add new PCI-E IDs to device table ...
2007-04-28git-libata-all-ipr-fixAndrew Morton
drivers/scsi/ipr.c: In function '__ipr_eh_dev_reset': drivers/scsi/ipr.c:3865: warning: passing argument 4 of 'ata_do_eh' from incompatible pointer type Cc: Tejun Heo <htejun@gmail.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-01[SCSI] ipr: Faster sg list fetchBrian King
Improve overall command performance by embedding the scatterlist in the command block used by the adapter. This decreases the overall number of DMAs required for a single command. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-01[SCSI] ipr: Return better qc_issue errorsBrian King
If qc_issue fails for some reason, return a better error to libata. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-01[SCSI] ipr: Disrupt device errorBrian King
Add entry in ipr error translation table for an error received when a device is forced into the failed state by the user. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-01[SCSI] ipr: Improve async error logging level controlBrian King
Add the ability to control how much error data gets logged on a per error basis. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-01[SCSI] ipr: PCI unblock config access fixBrian King
Fix to make sure user config accesses get re-enabled if the PCI config write to start BIST fails. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-01[SCSI] ipr: Fix for oops following SATA request senseBrian King
This patch fixes a problem discovered on a system with some bad SATA devices attached. If a command to a SATAPI device times out and the device gets reset as part of error recovery, its possible that ipr will set err_mask to indicate a device error has occurred. If this happens, a request sense will get issued by libata. Since scsi core thinks this scsi command is now completed, because the device reset handler completed successfully, scsi core will free the associated scsi command, which may cause an oops when that request sense is completed later by ipr. This patch ensures that any commands that get aborted as a result of a device reset set err_mask appropriately so that the request sense does not get sent. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
