path: root/drivers/scsi/ipr.c
2007-10-24SG: Change sg_set_page() to take length and offset argumentJens Axboe
Most drivers need to set length and offset as well, so may as well fold those three lines into one. Add sg_assign_page() for those two locations that only needed to set the page, where the offset/length is set outside of the function context. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-22[SG] Update drivers to use sg helpersJens Axboe
2007-10-18[libata] kill ata_sg_is_last()Jeff Garzik
Short term, this works around a bug introduced by early sg-chaining work. Long term, removing this function eliminates a branch from a hot path loop in each scatter/gather table build. Also, as this code demonstrates, we don't need to _track_ the end of the s/g list, as long as we mark it in some way. And doing so programatically is nice. So its a useful cleanup, regardless of its short term effects. Based conceptually on a quick patch by Jens Axboe. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-12[libata] Remove ->port_disable() hookJeff Garzik
It was always set to ata_port_disable(). Removed the hook, and replaced the very few ap->ops->port_disable() callsites with direct calls to ata_port_disable(). Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: linkify resetTejun Heo
Make reset methods and related functions deal with ata_link instead of ata_port. * ata_do_reset() * ata_eh_reset() * all prereset/reset/postreset methods and related functions This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: introduce ata_linkTejun Heo
Introduce ata_link. It abstracts PHY and sits between ata_port and ata_device. This new level of abstraction is necessary to support SATA Port Multiplier, which basically adds a bunch of links (PHYs) to a ATA host port. Fields related to command execution, spd_limit and EH are per-link and thus moved to ata_link. This patch only defines the host link. Multiple link handling will be added later. Also, a lot of ap->link derefences are added but many of them will be removed as each part is converted to deal directly with ata_link instead of ata_port. This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-15Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (166 commits) [SCSI] ibmvscsi: convert to use the data buffer accessors [SCSI] dc395x: convert to use the data buffer accessors [SCSI] ncr53c8xx: convert to use the data buffer accessors [SCSI] sym53c8xx: convert to use the data buffer accessors [SCSI] ppa: coding police and printk levels [SCSI] aic7xxx_old: remove redundant GFP_ATOMIC from kmalloc [SCSI] i2o: remove redundant GFP_ATOMIC from kmalloc from device.c [SCSI] remove the dead CYBERSTORMIII_SCSI option [SCSI] don't build scsi_dma_{map,unmap} for !HAS_DMA [SCSI] Clean up scsi_add_lun a bit [SCSI] 53c700: Remove printk, which triggers because of low scsi clock on SNI RMs [SCSI] sni_53c710: Cleanup [SCSI] qla4xxx: Fix underrun/overrun conditions [SCSI] megaraid_mbox: use mutex instead of semaphore [SCSI] aacraid: add 51245, 51645 and 52245 adapters to documentation. [SCSI] qla2xxx: update version to 8.02.00-k1. [SCSI] qla2xxx: add support for NPIV [SCSI] stex: use resid for xfer len information [SCSI] Add Brownie 1200U3P to blacklist [SCSI] scsi.c: convert to use the data buffer accessors ...
2007-07-12Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (34 commits) PCI: Only build PCI syscalls on architectures that want them PCI: limit pci_get_bus_and_slot to domain 0 PCI: hotplug: acpiphp: avoid acpiphp "cannot get bridge info" PCI hotplug failure PCI: hotplug: acpiphp: remove hot plug parameter write to PCI host bridge PCI: hotplug: acpiphp: fix slot poweroff problem on systems without _PS3 PCI: hotplug: pciehp: wait for 1 second after power off slot PCI: pci_set_power_state(): check for PM capabilities earlier PCI: cpci_hotplug: Convert to use the kthread API PCI: add pci_try_set_mwi PCI: pcie: remove SPIN_LOCK_UNLOCKED PCI: ROUND_UP macro cleanup in drivers/pci PCI: remove pci_dac_dma_... APIs PCI: pci-x-pci-express-read-control-interfaces cleanups PCI: Fix typo in include/linux/pci.h PCI: pci_ids, remove double or more empty lines PCI: pci_ids, add atheros and 3com_2 vendors PCI: pci_ids, reorder some entries PCI: i386: traps, change VENDOR to DEVICE PCI: ATM: lanai, change VENDOR to DEVICE PCI: Change all drivers to use pci_device->revision ...
2007-07-11sysfs: add parameter "struct bin_attribute *" in .read/.write methods for ↵Zhang Rui
sysfs binary attributes Well, first of all, I don't want to change so many files either. What I do: Adding a new parameter "struct bin_attribute *" in the .read/.write methods for the sysfs binary attributes. In fact, only the four lines change in fs/sysfs/bin.c and include/linux/sysfs.h do the real work. But I have to update all the files that use binary attributes to make them compatible with the new .read and .write methods. I'm not sure if I missed any. :( Why I do this: For a sysfs attribute, we can get a pointer pointing to the struct attribute in the .show/.store method, while we can't do this for the binary attributes. I don't know why this is different, but this does make it not so handy to use the binary attributes as the regular ones. So I think this patch is reasonable. :) Who benefits from it: The patch that exposes ACPI tables in sysfs requires such an improvement. All the table binary attributes share the same .read method. Parameter "struct bin_attribute *" is used to get the table signature and instance number which are used to distinguish different ACPI table binary attributes. Without this parameter, we need to offer different .read methods for different ACPI table binary attributes. This is impossible as there are various ACPI tables on different platforms, and we don't know what they are until they are loaded. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-30[SCSI] Merge up to linux-2.6 headJames Bottomley
Conflicts: drivers/scsi/jazz_esp.c Same changes made by both SCSI and SPARC trees: problem with UTF-8 conversion in the copyright. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-29[SCSI] ipr: convert to use the data buffer accessorsFUJITA Tomonori
- remove the unnecessary map_single path. - convert to use the new accessors for the sg lists and the parameters. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-16[SCSI] ipr: Proper return codes for eh_dev_reset for SATA devicesBrian King
Currently ipr always returns success from eh_dev_reset when called for a SATA device. If ata_do_eh is unable to recover for some reason, this can result in commands that are still outstanding when ata_do_eh returns. Change ipr to verify no commands are outstanding before returning success. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-08[SCSI] ipr: Use PCI-E reset API for new ipr adapterBrian King
Use a newly added PCI API to issue a PCI Fundamental reset (warm reset) to a new ipr PCI-E adapter. Typically, the ipr adapter uses the start BIST bit in config space to reset an adapter. Issuing start BIST on this particular adapter results in the PCI-E logic on the card losing sync, which causes PCI-E errors, making the card unusable. The only reset mechanism that exists on this hardware that does not have this problem is PCI Fundamental reset (warm reset). Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06[SCSI] ipr: Better handle adapter boot time errorsBrian King
If an ipr adapter encounters an adapter error requiring an adapter reset to recover from prior to driver load time, the error will be ignored and recovery will not happen until the initial timeout occurs waiting for the firmware to come ready, which means a five minute timeout. Fix is to read the interrupt register before clearing any of the interrupts at probe time. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06[SCSI] ipr: Enable multi-initator RAID supportBrian King
Enables multi-initiator support on ipr RAID adapters that support it. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06[SCSI] ipr: Improved dual adapter errorsBrian King
Formats ipr dual adapter errors so that they are more compact. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06[SCSI] ipr: Increase adapter operational timeoutBrian King
Increases the adapter operational timeout for some adapters that support dual controller configurations, since they may take longer to come ready. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06[SCSI] ipr: Handle IOA reset requestBrian King
In ipr dual adapter configurations, the ipr adapter firmware may require an adapter reset for various reasons. The reset is requested by the adapter firmware logging an error with an IOASC of 0x02048000. Add support to log this error, and reset the adapter. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06[SCSI] ipr: Handle check condition status from disk array deviceBrian King
On newer levels of microcode for ipr RAID adapters supporting multi-initiator configurations, the disk array, or VSET, resources are capable of generating a check condition. This patch prevents ipr from generating sense data in this scenario and retrieving it from the logical device instead. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06[SCSI] ipr: Handle UA on disk array following an adapter resetBrian King
On certain ipr RAID adapters, which are capable of multi-initiator configurations, the disk array, or VSET, resources will be in a POR Unit Attention state following an adapter reset. In order for the midlayer to handle the UA, I must report a bus reset to the logical disk array bus at the end of an adapter reset. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06[SCSI] ipr: Allow driver_data to be passed for dynamic idsBrian King
Since driver_data for pci ids in the ipr driver is now just flags, we can allow these to be passed in from userspace for dynamic ids. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06[SCSI] ipr: Prevent overlapped adapter resetsBrian King
This patch fixes some scenarios where an ipr adapter could get reset overlapped, which could cause very long timeouts to occur, or PCI bus errors. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-05Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (87 commits) [SCSI] fusion: fix domain validation loops [SCSI] qla2xxx: fix regression on sparc64 [SCSI] modalias for scsi devices [SCSI] sg: cap reserved_size values at max_sectors [SCSI] BusLogic: stop using check_region [SCSI] tgt: fix rdma transfer bugs [SCSI] aacraid: fix aacraid not finding device [SCSI] aacraid: Correct SMC products in aacraid.txt [SCSI] scsi_error.c: Add EH Start Unit retry [SCSI] aacraid: [Fastboot] Panics for AACRAID driver during 'insmod' for kexec test. [SCSI] ipr: Driver version to 2.3.2 [SCSI] ipr: Faster sg list fetch [SCSI] ipr: Return better qc_issue errors [SCSI] ipr: Disrupt device error [SCSI] ipr: Improve async error logging level control [SCSI] ipr: PCI unblock config access fix [SCSI] ipr: Fix for oops following SATA request sense [SCSI] ipr: Log error for SAS dual path switch [SCSI] ipr: Enable logging of debug error data for all devices [SCSI] ipr: Add new PCI-E IDs to device table ...
2007-04-28git-libata-all-ipr-fixAndrew Morton
drivers/scsi/ipr.c: In function '__ipr_eh_dev_reset': drivers/scsi/ipr.c:3865: warning: passing argument 4 of 'ata_do_eh' from incompatible pointer type Cc: Tejun Heo <htejun@gmail.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-01[SCSI] ipr: Faster sg list fetchBrian King
Improve overall command performance by embedding the scatterlist in the command block used by the adapter. This decreases the overall number of DMAs required for a single command. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-01[SCSI] ipr: Return better qc_issue errorsBrian King
If qc_issue fails for some reason, return a better error to libata. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-01[SCSI] ipr: Disrupt device errorBrian King
Add entry in ipr error translation table for an error received when a device is forced into the failed state by the user. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-01[SCSI] ipr: Improve async error logging level controlBrian King
Add the ability to control how much error data gets logged on a per error basis. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-01[SCSI] ipr: PCI unblock config access fixBrian King
Fix to make sure user config accesses get re-enabled if the PCI config write to start BIST fails. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-01[SCSI] ipr: Fix for oops following SATA request senseBrian King
This patch fixes a problem discovered on a system with some bad SATA devices attached. If a command to a SATAPI device times out and the device gets reset as part of error recovery, its possible that ipr will set err_mask to indicate a device error has occurred. If this happens, a request sense will get issued by libata. Since scsi core thinks this scsi command is now completed, because the device reset handler completed successfully, scsi core will free the associated scsi command, which may cause an oops when that request sense is completed later by ipr. This patch ensures that any commands that get aborted as a result of a device reset set err_mask appropriately so that the request sense does not get sent. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-01[SCSI] ipr: Log error for SAS dual path switchBrian King
For ipr SAS adapters that support dual pathing, this patch modifies ipr to log an error when a path fails. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-01[SCSI] ipr: Enable logging of debug error data for all devicesBrian King
The ipr driver has a sysfs attribute which can be used to adjust the logging level of the driver for error events. The error response data for commands can be dumped by increasing the logging level of the ipr driver. This currently only works for JBOD passthrough devices. This patch enables this function for all devices, including RAID devices, to aid in debugging problems. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-01[SCSI] ipr: Add new PCI-E IDs to device tableBrian King
Adds support for some new PCI-E ipr adapters. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-01[SCSI] ipr: Remove auto RAID create module parameterBrian King
Remove the auto RAID 0 array creation module parameter, since support for this function has been removed from the firmware. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-01[SCSI] ipr: Make adapter operational timeout be per adapter typeBrian King
Some ipr adapters may take longer than others to come operational. This patch makes this timeout different for different adapters, while still preserving the module parameter which can be used to globally override the default. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-30[SCSI] ipr: remove duplicate device idGreg Kroah-Hartman
This patch removes a duplicate device id from the IPR driver. Based on the ipr.h file, I'm not so sure this was intended to be a duplicate, and if so, the .h file should be modified to use the proper sub-device id instead. This was pointed out to me by Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-27[SCSI] ipr: PCI error recovery fixBrian King
Since the pci_block_user_cfg_access API was modified to track block/unblocks, it was discovered that the ipr driver had a path through its code (in PCI error recovery) which would unblock when not previously blocked. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-27[SCSI] ipr: Tolerate not finding PCI-X registersBrian King
Don't fail initialization of an adapter if the PCI-X registers cannot be found since it may be a PCI-E adapter. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-27[SCSI] ipr: Remove usage of pci driver dataBrian King
Since ipr handles dynamic ids, it must handle driver_data not being set, so remove the current usage of driver_data so it can be used for other things in future patches. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-12-06Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/pcmcia/ds.c Fix up merge failures with Linus's head and fix new compile failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-11-22[SCSI] ipr: Make ipr_ioctl staticAdrian Bunk
This patch makes ipr_ioctl static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Brian King <brking@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-22[SCSI] ipr: Reduce default error log sizeBrian King
Since the default error log size has increased on SAS adapters, prevent ipr from logging this additional data unless requested to do so by the user set log level in order to prevent flooding the logs. Signed-off-by: Brian King <brking@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-22[SCSI] ipr: Add support for logging SAS fabric errorsBrian King
Adds support for logging SAS fabric errors logged by the ipr firmware. Signed-off-by: Brian King <brking@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-22[SCSI] ipr: Remove debug trace points from dump codeBrian King
Remove some debug trace points that clutter up the log when ipr debugging is turned on. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-22[SCSI] ipr: Remove ipr_scsi_timed_outBrian King
Remove ipr's usage of the scsi transport eh_timed_out for handling SATA timeouts. This was only needed in order to set some flags on the qc prior to calling ata_do_eh. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-22[SCSI] ipr: PCI IDs for new SAS adaptersBrian King
Adds PCI IDs for some new ipr SAS adapters. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-22[SCSI] ipr: Stop issuing cancel all to disk arraysBrian King
The ipr disk array devices do not support a cancel all requests primitive, so change the ipr driver to never send it. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-22[SCSI] ipr: SATA reset - wait for host reset completionBrian King
If an ipr adapter hits a fatal microcode error requiring a reset while a SATA device is going through EH, it can result in a command getting issued to the ipr adapter while it is getting reset, which can cause PCI bus errors. Wait for any outstanding adapter reset to finish prior to issuing a SATA device reset. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
