path: root/drivers/scsi/ipr.c
2017-11-21treewide: Remove TIMER_FUNC_TYPE and TIMER_DATA_TYPE castsKees Cook
With all callbacks converted, and the timer callback prototype switched over, the TIMER_FUNC_TYPE cast is no longer needed, so remove it. Conversion was done with the following scripts: perl -pi -e 's|\(TIMER_FUNC_TYPE\)||g' \ $(git grep TIMER_FUNC_TYPE | cut -d: -f1 | sort -u) perl -pi -e 's|\(TIMER_DATA_TYPE\)||g' \ $(git grep TIMER_DATA_TYPE | cut -d: -f1 | sort -u) The now unused macros are also dropped from include/linux/timer.h. Signed-off-by: Kees Cook <keescook@chromium.org>
2017-11-01scsi: ipr: Convert timers to use timer_setup()Kees Cook
In preparation for unconditionally passing the struct timer_list pointer to all timer callbacks, switch to using the new timer_setup() and from_timer() to pass the timer pointer explicitly. Cc: Brian King <brking@us.ibm.com> Cc: "James E.J. Bottomley" <jejb@linux.vnet.ibm.com> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: linux-scsi@vger.kernel.org Signed-off-by: Kees Cook <keescook@chromium.org> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-08-22scsi: ipr: Set no_report_opcodes for RAID arraysBrian King
Since ipr RAID arrays do not support the MAINTENANCE_IN / MI_REPORT_SUPPORTED_OPERATION_CODES, set no_report_opcodes to prevent it from being sent. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-08-08scsi: ipr: Fix scsi-mq lockdep issueBrian King
Fixes the following lockdep warning that can occur when scsi-mq is enabled with ipr due to ipr calling scsi_unblock_requests from irq context. The fix is to move the call to scsi_unblock_requests to ipr's existing workqueue. stack backtrace: CPU: 28 PID: 0 Comm: swapper/28 Not tainted 4.13.0-rc2-gcc6x-gf74c89b #1 Call Trace: [c000001fffe97550] [c000000000b50818] dump_stack+0xe8/0x160 (unreliable) [c000001fffe97590] [c0000000001586d0] print_usage_bug+0x2d0/0x390 [c000001fffe97640] [c000000000158f34] mark_lock+0x7a4/0x8e0 [c000001fffe976f0] [c00000000015a000] __lock_acquire+0x6a0/0x1a70 [c000001fffe97860] [c00000000015befc] lock_acquire+0xec/0x2e0 [c000001fffe97930] [c000000000b71514] _raw_spin_lock+0x44/0x70 [c000001fffe97960] [c0000000005b60f4] blk_mq_sched_dispatch_requests+0xa4/0x2a0 [c000001fffe979c0] [c0000000005acac0] __blk_mq_run_hw_queue+0x100/0x2c0 [c000001fffe97a00] [c0000000005ad478] __blk_mq_delay_run_hw_queue+0x118/0x130 [c000001fffe97a40] [c0000000005ad61c] blk_mq_start_hw_queues+0x6c/0xa0 [c000001fffe97a80] [c000000000797aac] scsi_kick_queue+0x2c/0x60 [c000001fffe97aa0] [c000000000797cf0] scsi_run_queue+0x210/0x360 [c000001fffe97b10] [c00000000079b888] scsi_run_host_queues+0x48/0x80 [c000001fffe97b40] [c0000000007b6090] ipr_ioa_bringdown_done+0x70/0x1e0 [c000001fffe97bc0] [c0000000007bc860] ipr_reset_ioa_job+0x80/0xf0 [c000001fffe97bf0] [c0000000007b4d50] ipr_reset_timer_done+0xd0/0x100 [c000001fffe97c30] [c0000000001937bc] call_timer_fn+0xdc/0x4b0 [c000001fffe97cf0] [c000000000193d08] expire_timers+0x178/0x330 [c000001fffe97d60] [c0000000001940c8] run_timer_softirq+0xb8/0x120 [c000001fffe97de0] [c000000000b726a8] __do_softirq+0x168/0x6d8 [c000001fffe97ef0] [c0000000000df2c8] irq_exit+0x108/0x150 [c000001fffe97f10] [c000000000017bf4] __do_irq+0x2a4/0x4a0 [c000001fffe97f90] [c00000000002da50] call_do_irq+0x14/0x24 [c0000007fad93aa0] [c000000000017e8c] do_IRQ+0x9c/0x140 [c0000007fad93af0] [c000000000008b98] hardware_interrupt_common+0x138/0x140 Reported-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-05-04Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "This update includes the usual round of major driver updates (hisi_sas, ufs, fnic, cxlflash, be2iscsi, ipr, stex). There's also the usual amount of cosmetic and spelling stuff" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (155 commits) scsi: qla4xxx: fix spelling mistake: "Tempalate" -> "Template" scsi: stex: make S6flag static scsi: mac_esp: fix to pass correct device identity to free_irq() scsi: aacraid: pci_alloc_consistent() failures on ARM64 scsi: ufs: make ufshcd_get_lists_status() register operation obvious scsi: ufs: use MASK_EE_STATUS scsi: mac_esp: Replace bogus memory barrier with spinlock scsi: fcoe: make fcoe_e_d_tov and fcoe_r_a_tov static scsi: sd_zbc: Do not write lock zones for reset scsi: sd_zbc: Remove superfluous assignments scsi: sd: sd_zbc: Rename sd_zbc_setup_write_cmnd scsi: Improve scsi_get_sense_info_fld scsi: sd: Cleanup sd_done sense data handling scsi: sd: Improve sd_completed_bytes scsi: sd: Fix function descriptions scsi: mpt3sas: remove redundant wmb scsi: mpt: Move scsi_remove_host() out of mptscsih_remove_host() scsi: sg: reset 'res_in_use' after unlinking reserved array scsi: mvumi: remove code handling zero scsi_sg_count(scmd) case scsi: fusion: fix spelling mistake: "Persistancy" -> "Persistency" ...
2017-04-12Merge remote-tracking branch 'mkp-scsi/4.11/scsi-fixes' into fixesJames Bottomley
2017-04-11scsi: ipr: do not set DID_PASSTHROUGH on CHECK CONDITIONMauricio Faria de Oliveira
On a dual controller setup with multipath enabled, some MEDIUM ERRORs caused both paths to be failed, thus I/O got queued/blocked since the 'queue_if_no_path' feature is enabled by default on IPR controllers. This example disabled 'queue_if_no_path' so the I/O failure is seen at the sg_dd program. Notice that after the sg_dd test-case, both paths are in 'failed' state, and both path/priority groups are in 'enabled' state (not 'active') -- which would block I/O with 'queue_if_no_path'. # sg_dd if=/dev/dm-2 bs=4096 count=1 dio=1 verbose=4 blk_sgio=0 <...> read(unix): count=4096, res=-1 sg_dd: reading, skip=0 : Input/output error <...> # dmesg [...] sd 2:2:16:0: [sds] FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE [...] sd 2:2:16:0: [sds] Sense Key : Medium Error [current] [...] sd 2:2:16:0: [sds] Add. Sense: Unrecovered read error - recommend rewrite the data [...] sd 2:2:16:0: [sds] CDB: Read(10) 28 00 00 00 00 00 00 00 20 00 [...] blk_update_request: I/O error, dev sds, sector 0 [...] device-mapper: multipath: Failing path 65:32. <...> [...] device-mapper: multipath: Failing path 65:224. # multipath -l 1IBM_IPR-0_59C2AE0000001F80 dm-2 IBM ,IPR-0 59C2AE00 size=5.2T features='0' hwhandler='1 alua' wp=rw |-+- policy='service-time 0' prio=0 status=enabled | `- 2:2:16:0 sds 65:32 failed undef running `-+- policy='service-time 0' prio=0 status=enabled `- 1:2:7:0 sdae 65:224 failed undef running This is not the desired behavior. The dm-multipath explicitly checks for the MEDIUM ERROR case (and a few others) so not to fail the path (e.g., I/O to other sectors could potentially happen without problems). See dm-mpath.c :: do_end_io_bio() -> noretry_error() !->! fail_path(). The problem trace is: 1) ipr_scsi_done() // SENSE KEY/CHECK CONDITION detected, go to.. 2) ipr_erp_start() // ipr_is_gscsi() and masked_ioasc OK, go to.. 3) ipr_gen_sense() // masked_ioasc is IPR_IOASC_MED_DO_NOT_REALLOC, // so set DID_PASSTHROUGH. 4) scsi_decide_disposition() // check for DID_PASSTHROUGH and return // early on, faking a DID_OK.. *instead* // of reaching scsi_check_sense(). // Had it reached the latter, that would // set host_byte to DID_MEDIUM_ERROR. 5) scsi_finish_command() 6) scsi_io_completion() 7) __scsi_error_from_host_byte() // That would be converted to -ENODATA <...> 8) dm_softirq_done() 9) multipath_end_io() 10) do_end_io() 11) noretry_error() // And that is checked in dm-mpath :: noretry_error() // which would cause fail_path() not to be called. With this patch applied, the I/O is failed but the paths are not. This multipath device continues accepting more I/O requests without blocking. (and notice the different host byte/driver byte handling per SCSI layer). # dmesg [...] sd 2:2:7:0: [sdaf] Done: SUCCESS Result: hostbyte=0x13 driverbyte=DRIVER_OK [...] sd 2:2:7:0: [sdaf] CDB: Read(10) 28 00 00 00 00 00 00 00 40 00 [...] sd 2:2:7:0: [sdaf] Sense Key : Medium Error [current] [...] sd 2:2:7:0: [sdaf] Add. Sense: Unrecovered read error - recommend rewrite the data [...] blk_update_request: critical medium error, dev sdaf, sector 0 [...] blk_update_request: critical medium error, dev dm-6, sector 0 [...] sd 2:2:7:0: [sdaf] Done: SUCCESS Result: hostbyte=0x13 driverbyte=DRIVER_OK [...] sd 2:2:7:0: [sdaf] CDB: Read(10) 28 00 00 00 00 00 00 00 10 00 [...] sd 2:2:7:0: [sdaf] Sense Key : Medium Error [current] [...] sd 2:2:7:0: [sdaf] Add. Sense: Unrecovered read error - recommend rewrite the data [...] blk_update_request: critical medium error, dev sdaf, sector 0 [...] blk_update_request: critical medium error, dev dm-6, sector 0 [...] Buffer I/O error on dev dm-6, logical block 0, async page read # multipath -l 1IBM_IPR-0_59C2AE0000001F80 1IBM_IPR-0_59C2AE0000001F80 dm-6 IBM ,IPR-0 59C2AE00 size=5.2T features='1 queue_if_no_path' hwhandler='1 alua' wp=rw |-+- policy='service-time 0' prio=0 status=active | `- 2:2:7:0 sdaf 65:240 active undef running `-+- policy='service-time 0' prio=0 status=enabled `- 1:2:7:0 sdh 8:112 active undef running Signed-off-by: Mauricio Faria de Oliveira <mauricfo@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-03-23scsi: ipr: Fix SATA EH hangBrian King
This patch fixes a hang that can occur in ATA EH with ipr. With ipr's usage of libata, commands should never end up on ap->eh_done_q. The timeout function we use for ipr, even for SATA devices, is scsi_times_out, so ATA_QCFLAG_EH_SCHEDULED never gets set for ipr and EH is driven completely by ipr and SCSI. The SCSI EH thread ends up calling ipr's eh_device_reset_handler, which then calls ata_std_error_handler. This ends up calling ipr_sata_reset, which issues a reset to the device. This should result in all pending commands getting failed back and having ata_qc_complete called for them, which should end up clearing ATA_QCFLAG_FAILED as qc->flags gets zeroed in ata_qc_free. This ensures that when we end up in ata_eh_finish, we don't do anything more with the command. On adapters that only support a single interrupt and when running with two MSI-X vectors or less, the adapter firmware guarantees that responses to all outstanding commands are sent back prior to sending the response to the SATA reset command. On newer adapters supporting multiple HRRQs, however, this can no longer be guaranteed, since the command responses and reset response may be processed on different HRRQs. If ipr returns from ipr_sata_reset before the outstanding command was returned, this sends us down the path of __ata_eh_qc_complete which then moves the associated scsi_cmd from the work_q in scsi_eh_bus_device_reset to ap->eh_done_q, which then will sit there forever and we will be wedged. This patch fixes this up by ensuring that any outstanding commands are flushed before returning from eh_device_reset_handler for a SATA device. Reported-by: David Jeffery <djeffery@redhat.com> Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Reviewed-by: Wendy Xiong <wenxiong@linux.vnet.ibm.com> Tested-by: Wendy Xiong <wenxiong@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-03-23scsi: ipr: Error path locking fixesBrian King
This patch closes up some potential race conditions observed in the error handling paths in ipr while debugging an issue resulting in a hang with SATA error handling. These patches ensure we are holding the correct lock when adding and removing commands from the free and pending queues in some error scenarios. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Reviewed-by: Wendy Xiong <wenxiong@linux.vnet.ibm.com> Tested-by: Wendy Xiong <wenxiong@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-03-23scsi: ipr: Fix abort path race conditionBrian King
This fixes a race condition in the error handlomg paths of ipr. While a command is outstanding to the adapter, it is placed on a pending queue for the hrrq it is associated with, while holding the HRRQ lock. When a command is completed, it is removed from the pending queue, under HRRQ lock, and placed on a local list. This list is then iterated through without any locks and each command's done function is invoked, inside of which, the command gets returned to the free list while grabbing the HRRQ lock. This fixes two race conditions when commands have been removed from the pending list but have not yet been added to the free list. Both of these changes fix race conditions that could result in returning success from eh_abort_handler and then later calling scsi_done for the same request. The first race condition is in ipr_cancel_op. It looks through each pending queue to see if the command to be aborted is still outstanding or not. Rather than looking on the pending queue, reverse the logic to check to look for commands that are NOT on the free queue. The second race condition can occur when in ipr_wait_for_ops where we are waiting for responses for commands we've aborted. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Reviewed-by: Wendy Xiong <wenxiong@linux.vnet.ibm.com> Tested-by: Wendy Xiong <wenxiong@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-03-23scsi: ipr: Remove redundant initializationBrian King
Removes some code in __ipr_eh_dev_reset which was modifying the ipr_cmd done function. This should have already been setup at command allocation time and if its since been changed, it means we are in the ipr_erp* functions and need to wait for them to complete and don't want to override that here. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Reviewed-by: Wendy Xiong <wenxiong@linux.vnet.ibm.com> Tested-by: Wendy Xiong <wenxiong@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-03-23scsi: ipr: Fix missed EH wakeupBrian King
Following a command abort or device reset, ipr's EH handlers wait for the commands getting aborted to get sent back from the adapter prior to returning from the EH handler. This fixes up some cases where the completion handler was not getting called, which would have resulted in the EH thread waiting until it timed out, greatly extending EH time. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Reviewed-by: Wendy Xiong <wenxiong@linux.vnet.ibm.com> Tested-by: Wendy Xiong <wenxiong@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-02-27scripts/spelling.txt: add "intialization" pattern and fix typo instancesMasahiro Yamada
Fix typos and add the following to the scripts/spelling.txt: intialization||initialization The "inintialization" in drivers/acpi/spcr.c is a different pattern but I fixed it as well in this commit. Link: http://lkml.kernel.org/r/1481573103-11329-16-git-send-email-yamada.masahiro@socionext.com Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-30scsi: ipr: Fix runaway IRQs when falling back from MSI to LSIBenjamin Herrenschmidt
LSIs must be ack'ed with an MMIO otherwise they remain asserted forever. This is controlled by the "clear_isr" flag. While we set that flag properly when deciding initially whether to use LSIs or MSIs, we fail to set it if we first chose MSIs, the test fails, then fallback to LSIs. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-11-08scsi: ipr: Use pci_irq_allocate_vectorsChristoph Hellwig
Switch the ipr driver to use pci_alloc_irq_vectors. We need to two calls to pci_alloc_irq_vectors as ipr only supports multiple MSI-X vectors, but not multiple MSI vectors. Otherwise this cleans up a lot of cruft and allows to use a common request_irq loop for irq types, which happens to only iterate over a single line in the non MSI-X case. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-10-14scsi: ipr: Fix async error WARN_ONBrian King
Commit afc3f83cb4a5 ("scsi: ipr: Add asynchronous error notification") introduced the warn on shown below. To fix this, rather than attempting to send the KOBJ_CHANGE uevent from interrupt context, which is what is causing the WARN_ON, just wake the ipr worker thread which will send a KOBJ_CHANGE uevent. [ 142.278120] WARNING: CPU: 15 PID: 0 at kernel/softirq.c:161 __local_bh_enable_ip+0x7c/0xd0 [ 142.278124] Modules linked in: ip6t_rpfilter ip6t_REJECT nf_reject_ipv6 ipt_REJECT nf_reject_ipv4 xt_conntrack ebtable_nat ebtable_broute bridge stp llc ebtable_filter ebtables ip6table_nat nf_conntrack_ipv6 nf_defrag_ipv6 nf_nat_ipv6 ip6table_mangle ip6table_security ip6table_raw ip6table_filter ip6_tables iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack iptable_mangle iptable_security iptable_raw iptable_filter ses enclosure scsi_transport_sas sg pseries_rng nfsd auth_rpcgss nfs_acl lockd grace sunrpc ip_tables xfs libcrc32c sr_mod sd_mod cdrom ipr libata ibmvscsi scsi_transport_srp ibmveth dm_mirror dm_region_hash dm_log dm_mod [ 142.278208] CPU: 15 PID: 0 Comm: swapper/15 Not tainted 4.8.0.ipr+ #21 [ 142.278213] task: c00000010cf24480 task.stack: c00000010cfec000 [ 142.278217] NIP: c0000000000c0c7c LR: c000000000881778 CTR: c0000000003c5bf0 [ 142.278221] REGS: c00000010cfef080 TRAP: 0700 Not tainted (4.8.0.ipr+) [ 142.278224] MSR: 8000000000029033 <SF,EE,ME,IR,DR,RI,LE> CR: 28008022 XER: 2000000f [ 142.278236] CFAR: c0000000000c0c20 SOFTE: 0 GPR00: c000000000706c78 c00000010cfef300 c000000000f91d00 c000000000706c78 GPR04: 0000000000000200 c000000000f7bc80 0000000000000000 00000000024000c0 GPR08: 0000000000000000 0000000000000001 c000000000ee1d00 c000000000a9bdd0 GPR12: c0000000003c5bf0 c00000000eb22d00 c000000100ca3880 c00000020ed38400 GPR16: 0000000000000000 0000000000000000 c000000100940508 0000000000000000 GPR20: 0000000000000000 0000000000000000 0000000000000000 00000000024000c0 GPR24: c0000000004588e0 c00000010863bd00 c00000010863bd00 c0000000013773f8 GPR28: c000000000f7bc80 0000000000000000 ffffffffffffffff c000000000f7bcd8 [ 142.278290] NIP [c0000000000c0c7c] __local_bh_enable_ip+0x7c/0xd0 [ 142.278296] LR [c000000000881778] _raw_spin_unlock_bh+0x38/0x60 [ 142.278299] Call Trace: [ 142.278303] [c00000010cfef300] [c000000000f7bc80] init_net+0x0/0x1900 (unreliable) [ 142.278310] [c00000010cfef320] [c000000000706c78] peernet2id+0x58/0x80 [ 142.278316] [c00000010cfef370] [c00000000075caec] netlink_broadcast_filtered+0x30c/0x550 [ 142.278323] [c00000010cfef430] [c000000000459078] kobject_uevent_env+0x588/0x780 [ 142.278331] [c00000010cfef510] [d000000003163a6c] ipr_process_error+0x11c/0x240 [ipr] [ 142.278337] [c00000010cfef5c0] [d000000003152298] ipr_fail_all_ops+0x108/0x220 [ipr] [ 142.278343] [c00000010cfef670] [d0000000031643f8] ipr_reset_restore_cfg_space+0xa8/0x240 [ipr] [ 142.278350] [c00000010cfef6f0] [d000000003158a00] ipr_reset_ioa_job+0x80/0xe0 [ipr] [ 142.278356] [c00000010cfef720] [d000000003153f78] ipr_reset_timer_done+0xa8/0xe0 [ipr] [ 142.278363] [c00000010cfef770] [c000000000149c88] call_timer_fn+0x58/0x1c0 [ 142.278368] [c00000010cfef800] [c000000000149f60] expire_timers+0x140/0x200 [ 142.278373] [c00000010cfef870] [c00000000014a0e8] run_timer_softirq+0xc8/0x230 [ 142.278379] [c00000010cfef900] [c0000000000c0844] __do_softirq+0x164/0x3c0 [ 142.278384] [c00000010cfef9f0] [c0000000000c0f18] irq_exit+0x1a8/0x1c0 [ 142.278389] [c00000010cfefa20] [c000000000020b54] timer_interrupt+0xa4/0xe0 [ 142.278394] [c00000010cfefa50] [c000000000002414] decrementer_common+0x114/0x180 Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-10-07Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "This update includes the usual round of major driver updates (hpsa, be2iscsi, hisi_sas, zfcp, cxlflash). There's a new incarnation of hpsa called smartpqi for which a driver is added, there's some cleanup work of the ibm vscsi target and updates to libfc, plus a whole host of minor fixes and updates and finally the removal of several ISA drivers which seem not to have been used for years" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (173 commits) scsi: mvsas: Mark symbols static where possible scsi: pm8001: Mark symbols static where possible scsi: arcmsr: Simplify user_len checking scsi: fcoe: fix off by one in eth2fc_speed() scsi: dtc: remove from tree scsi: t128: remove from tree scsi: pas16: remove from tree scsi: u14-34f: remove from tree scsi: ultrastor: remove from tree scsi: in2000: remove from tree scsi: wd7000: remove from tree scsi: scsi_dh_alua: Fix memory leak in alua_rtpg() scsi: lpfc: Mark symbols static where possible scsi: hpsa: correct call to hpsa_do_reset scsi: ufs: Get a TM service response from the correct offset scsi: ibmvfc: Fix I/O hang when port is not mapped scsi: megaraid_sas: clean function declarations in megaraid_sas_base.c up scsi: ipr: Remove redundant messages at adapter init time scsi: ipr: Don't log unnecessary 9084 error details scsi: smartpqi: raid bypass lba calculation fix ...
2016-09-19scsi: ipr: Remove redundant messages at adapter init timeBrian King
Whenever multiple HRRQs are enabled, which is the default setting now, we end up seeing the following message logged prior to initialization of each HRRQ: Starting IOA initialization sequence This results in 16 of these messages on most adapters, which serves little purpose. Change to just log this once. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Reviewed-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-09-19scsi: ipr: Don't log unnecessary 9084 error detailsBrian King
A 9084 error gets logged by the ipr adapter when adapter raw mode gets enabled. A bunch of unformatted hex data also gets logged for this error, which is of little use, so let's avoid logging it by default in order to avoid the log getting polluted with useless data. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Reviewed-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-08-25scsi: ipr: Add asynchronous error notificationBrian King
This patch implements functions for pushing HCAM (host controlled asynchronous messages) error buffers to userspace through sysfs attributes. Reads to the "async_err_log" attribute will result in a single HCAM buffer being copied to userspace; one can process the next HCAM buffer by writing any string to the same attribute. A new list was added to the ioa_cfg structure to store the HCAM buffers for later reporting. We also send a KOBJ_CHANGE event whenever a new HCAM buffer is made available to userspace. Signed-off-by: Heitor Ricardo Alves de Siqueira <halves@linux.vnet.ibm.com> Signed-off-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com> Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-08-09ipr: Fix sync scsi scanBrian King
Commit b195d5e2bffd ("ipr: Wait to do async scan until scsi host is initialized") fixed async scan for ipr, but broke sync scan for ipr. This fixes sync scan back up. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Reported-and-tested-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02ipr: Fix error return code in ipr_probe_ioa()Wei Yongjun
Fix to return error code -ENOMEM from the workqueue alloc error handling case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <weiyj.lk@gmail.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-07-27ipr: Wait to do async scan until scsi host is initializedBrian King
When performing an async scan, make sure the kthread doing scanning doesn't start before the scsi host is fully initialized. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Reviewed-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-07-13ipr: Increase MSIX vectors numberWen Xiong
Increase MSIX vectors from 2 to 16 by default. Signed-off-by: Wen Xiong <wenxiong@linux.vnet.ibm.com> Reviewed-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-07-13ipr: Add new CCIN for new adapters supportWen Xiong
Add the appropriate definitions and table entries for new adapters support. Signed-off-by: Wen Xiong <wenxiong@linux.vnet.ibm.com> Reviewed-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-06-29ipr: Clear interrupt on croc/crocodile when running with LSIBrian King
If we fall back to using LSI on the Croc or Crocodile chip we need to clear the interrupt so we don't hang the system. Cc: <stable@vger.kernel.org> Tested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-02-26ipr: Fix regression when loading firmwareGabriel Krisman Bertazi
Commit d63c7dd5bcb9 ("ipr: Fix out-of-bounds null overwrite") removed the end of line handling when storing the update_fw sysfs attribute. This changed the userpace API because it started refusing writes terminated by a line feed, which broke the update tools we already have. This patch re-adds that handling, so both a write terminated by a line feed or not can make it through with the update. Fixes: d63c7dd5bcb9 ("ipr: Fix out-of-bounds null overwrite") Signed-off-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com> Cc: Insu Yun <wuninsu@gmail.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-01-23Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull rdma updates from Doug Ledford: "Initial roundup of 4.5 merge window patches - Remove usage of ib_query_device and instead store attributes in ib_device struct - Move iopoll out of block and into lib, rename to irqpoll, and use in several places in the rdma stack as our new completion queue polling library mechanism. Update the other block drivers that already used iopoll to use the new mechanism too. - Replace the per-entry GID table locks with a single GID table lock - IPoIB multicast cleanup - Cleanups to the IB MR facility - Add support for 64bit extended IB counters - Fix for netlink oops while parsing RDMA nl messages - RoCEv2 support for the core IB code - mlx4 RoCEv2 support - mlx5 RoCEv2 support - Cross Channel support for mlx5 - Timestamp support for mlx5 - Atomic support for mlx5 - Raw QP support for mlx5 - MAINTAINERS update for mlx4/mlx5 - Misc ocrdma, qib, nes, usNIC, cxgb3, cxgb4, mlx4, mlx5 updates - Add support for remote invalidate to the iSER driver (pushed through the RDMA tree due to dependencies, acknowledged by nab) - Update to NFSoRDMA (pushed through the RDMA tree due to dependencies, acknowledged by Bruce)" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (169 commits) IB/mlx5: Unify CQ create flags check IB/mlx5: Expose Raw Packet QP to user space consumers {IB, net}/mlx5: Move the modify QP operation table to mlx5_ib IB/mlx5: Support setting Ethernet priority for Raw Packet QPs IB/mlx5: Add Raw Packet QP query functionality IB/mlx5: Add create and destroy functionality for Raw Packet QP IB/mlx5: Refactor mlx5_ib_qp to accommodate other QP types IB/mlx5: Allocate a Transport Domain for each ucontext net/mlx5_core: Warn on unsupported events of QP/RQ/SQ net/mlx5_core: Add RQ and SQ event handling net/mlx5_core: Export transport objects IB/mlx5: Expose CQE version to user-space IB/mlx5: Add CQE version 1 support to user QPs and SRQs IB/mlx5: Fix data validation in mlx5_ib_alloc_ucontext IB/sa: Fix netlink local service GFP crash IB/srpt: Remove redundant wc array IB/qib: Improve ipoib UD performance IB/mlx4: Advertise RoCE v2 support IB/mlx4: Create and use another QP1 for RoCEv2 IB/mlx4: Enable send of RoCE QP1 packets with IP/UDP headers ...
2016-01-07ipr: Fix out-of-bounds null overwriteInsu Yun
Return value of snprintf is not bound by size value, 2nd argument. (https://www.kernel.org/doc/htmldocs/kernel-api/API-snprintf.html). Return value is number of printed chars, can be larger than 2nd argument. Therefore, it can write null byte out of bounds ofbuffer. Since snprintf puts null, it does not need to put additional null byte. Signed-off-by: Insu Yun <wuninsu@gmail.com> Reviewed-by: Shane Seymour <shane.seymour@hpe.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2015-12-11irq_poll: fold irq_poll_sched_prep into irq_poll_schedChristoph Hellwig
There is no good reason to keep them apart, and this makes using the API a bit simpler. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
2015-12-11irq_poll: don't disable new irq_poll instancesChristoph Hellwig
There is no good reason to start out disabled - drivers can control if the poll instance can be scheduled by simply not scheduling it yet. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
2015-12-11irq_poll: make blk-iopoll available outside the block layerChristoph Hellwig
The new name is irq_poll as iopoll is already taken. Better suggestions welcome. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
2015-11-12Merge tag '4.4-scsi-mkp' into miscJames Bottomley
SCSI queue for 4.4. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2015-11-09scsi: use host wide tags by defaultChristoph Hellwig
This patch changes the !blk-mq path to the same defaults as the blk-mq I/O path by always enabling block tagging, and always using host wide tags. We've had blk-mq available for a few releases so bugs with this mode should have been ironed out, and this ensures we get better coverage of over tagging setup over different configs. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Jens Axboe <axboe@kernel.dk> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-11-09ipr: Issue Configure Cache Parameters command.Gabriel Krisman Bertazi
Some new adapters require a special Configure Cache Parameters command to enable the adapter write cache, so send this during the adapter initialization if the adapter requires it. Signed-off-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Reviewed-by: Wen Xiong <wenxiong@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2015-11-09ipr: Inquiry IOA page 0xC4 during initialization.Gabriel Krisman Bertazi
Add an IOA Inquiry command for Page 0xC4 during IOA initialization to collect cache capabilities, particularly to check if Sync IOA Write Cache is supported. Inquiry will happen right after Cap Inquiry on page 0xD0; and will execute only if the "Supported Pages" field in Inquiry Page 0x0 shows support for Page 0xC4. Otherwise, assume Sync IOA Write Cache is not supported. Signed-off-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Reviewed-by: Wen Xiong <wenxiong@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2015-11-09ipr: Don't set NO_ULEN_CHK bit when resource is a vset.Gabriel Krisman Bertazi
According to the IPR specification, Inhibit Underlength Checking bit must be disabled when issuing commands to vsets. Enabling it in this case might cause SCSI commands to fail with an Illegal Request, so make sure we keep this bit cleared when resource is a vset. Signed-off-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com> Reviewed-by: Manoj Kumar <manoj@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Reviewed-by: Wen Xiong <wenxiong@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2015-11-09ipr: Add delay to ensure coherent dumps.Gabriel Krisman Bertazi
Add a holding pattern prior to collecting dump data, to wait for the IOA indication that the Mailbox register is stable and won't change without an explicit reset. This ensures we'll be collecting meaningful dump data, even when dumping right after an adapter reset. In the event of a timeout, we still force the dump, since a partial dump still might be useful. Signed-off-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Reviewed-by: Wen Xiong <wenxiong@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2015-08-28ipr: Enable SIS pipe commands for SIS-32 devices.Gabriel Krisman Bertazi
Remove unnecessary check that disabled SIS pipe commands for SIS-32 devices. This change was sufficient to enable raw mode and send SIS pipe commands for a 57B3 device. Fixes: f8ee25d7d239 ("ipr: AF DASD raw mode implementation in ipr driver") Signed-off-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com> Reviewed-by: Wen Xiong <wenxiong@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-08-28ipr: Inhibit underlength data check for AFDASD in raw mode.Gabriel Krisman Bertazi
Disable underlength error verification based on count of bytes actually transferred for AF DASD devices when SIS pipe mode is enabled. This avoids unexpected underlength errors when issuing some commands in raw mode. Signed-off-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com> Reviewed-by: Wen Xiong <wenxiong@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-07-30ipr: Endian / sparse fixesBrian King
Some misc fixes for endianness checking with sparse so sparse with endian checking now runs clean. Fixes a minor bug in the process which was uncovered by sparse which would result in unnecessary error recovery for check conditions. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Reviewed-by: Wen Xiong <wenxiong@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-07-30ipr: Byte swapping for device_id attribute in sysfsWen Xiong
On LE system, users see the wrong device_id attribute. This patch does necessary byte swapping for device_id attribute and works on both of LE and BE systems. Signed-off-by: Wen Xiong <wenxiong@linux.vnet.ibm.com> Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-07-30ipr: Fix invalid array indexing for HRRQBrian King
Fixes another signed / unsigned array indexing bug in the ipr driver. Currently, when hrrq_index wraps, it becomes a negative number. We do the modulo, but still have a negative number, so we end up indexing backwards in the array. Given where the hrrq array is located in memory, we probably won't actually reference memory we don't own, but nonetheless ipr is still looking at data within struct ipr_ioa_cfg and interpreting it as struct ipr_hrr_queue data, so bad things could certainly happen. Each ipr adapter has anywhere from 1 to 16 HRRQs. By default, we use 2 on new adapters. Let's take an example: Assume ioa_cfg->hrrq_index=0x7fffffffe and ioa_cfg->hrrq_num=4: The atomic_add_return will then return -1. We mod this with 3 and get -2, add one and get -1 for an array index. On adapters which support more than a single HRRQ, we dedicate HRRQ to adapter initialization and error interrupts so that we can optimize the other queues for fast path I/O. So all normal I/O uses HRRQ 1-15. So we want to spread the I/O requests across those HRRQs. With the default module parameter settings, this bug won't hit, only when someone sets the ipr.number_of_msix parameter to a value larger than 3 is when bad things start to happen. Cc: <stable@vger.kernel.org> Tested-by: Wen Xiong <wenxiong@linux.vnet.ibm.com> Reviewed-by: Wen Xiong <wenxiong@linux.vnet.ibm.com> Reviewed-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com> Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-07-30ipr: Fix incorrect trace indexingBrian King
When ipr's internal driver trace was changed to an atomic, a signed/unsigned bug slipped in which results in us indexing backwards in our memory buffer writing on memory that does not belong to us. This patch fixes this by removing the modulo and instead just mask off the low bits. Cc: <stable@vger.kernel.org> Tested-by: Wen Xiong <wenxiong@linux.vnet.ibm.com> Reviewed-by: Wen Xiong <wenxiong@linux.vnet.ibm.com> Reviewed-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com> Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-07-30ipr: Fix locking for unit attention handlingBrian King
Make sure we have the host lock held when calling scsi_report_bus_reset. Fixes a crash seen as the __devices list in the scsi host was changing as we were iterating through it. Cc: <stable@vger.kernel.org> Reviewed-by: Wen Xiong <wenxiong@linux.vnet.ibm.com> Reviewed-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com> Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-16Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "This is the usual grab bag of driver updates (lpfc, qla2xxx, storvsc, aacraid, ipr) plus an assortment of minor updates. There's also a major update to aic1542 which moves the driver into this millenium" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (106 commits) change SCSI Maintainer email sd, mmc, virtio_blk, string_helpers: fix block size units ufs: add support to allow non standard behaviours (quirks) ufs-qcom: save controller revision info in internal structure qla2xxx: Update driver version to 8.07.00.18-k qla2xxx: Restore physical port WWPN only, when port down detected for FA-WWPN port. qla2xxx: Fix virtual port configuration, when switch port is disabled/enabled. qla2xxx: Prevent multiple firmware dump collection for ISP27XX. qla2xxx: Disable Interrupt handshake for ISP27XX. qla2xxx: Add debugging info for MBX timeout. qla2xxx: Add serdes read/write support for ISP27XX qla2xxx: Add udev notification to save fw dump for ISP27XX qla2xxx: Add message for sucessful FW dump collected for ISP27XX. qla2xxx: Add support to load firmware from file for ISP 26XX/27XX. qla2xxx: Fix beacon blink for ISP27XX. qla2xxx: Increase the wait time for firmware to be ready for P3P. qla2xxx: Fix crash due to wrong casting of reg for ISP27XX. qla2xxx: Fix warnings reported by static checker. lpfc: Update version to 10.5.0.0 for upstream patch set lpfc: Update copyright to 2015 ...
2015-04-09ipr: AF DASD raw mode implementation in ipr driverWen Xiong
This patch implements raw mode support for AF DASD in ipr driver which allows for tools to send commands directly to physical devices which are members of RAID arrays when enabled in the firmware. [jejb: fix up whitespace] Signed-off-by: Wen Xiong<wenxiong@linux.vnet.ibm.com> Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Reviewed-by: Daniel Kreling <kreling@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-09ipr: Re-enable write sameBrian King
Re-enable write same support for ipr RAID adapters. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Reviewed-by: Wen Xiong <wenxiong@linux.vnet.ibm.com> Reviewed-by: Daniel Kreling <kreling@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-09ipr: Fix possible error path oops during initializationBrian King
Fixes a possible oops during adapter initialization in some memory allocation failure error paths scenarios. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Reviewed-by: Wen Xiong <wenxiong@linux.vnet.ibm.com> Reviewed-by: Daniel Kreling <kreling@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-04-09ipr: Reset in task contextBrian King
The pci_set_pcie_reset_state has changed semantics to not be callable from interrupt context, so change ipr's usage of the API to comply with this change by ensuring this occurs from a workqueue. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Reviewed-by: Wen Xiong <wenxiong@linux.vnet.ibm.com> Reviewed-by: Daniel Kreling <kreling@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
