path: root/drivers/scsi/ibmvscsi
2016-10-22scsi: ibmvfc: Fix I/O hang when port is not mappedBrian King
commit 07d0e9a847401ffd2f09bd450d41644cd090e81d upstream. If a VFC port gets unmapped in the VIOS, it may not respond with a CRQ init complete following H_REG_CRQ. If this occurs, we can end up having called scsi_block_requests and not a resulting unblock until the init complete happens, which may never occur, and we end up hanging I/O requests. This patch ensures the host action stay set to IBMVFC_HOST_ACTION_TGT_DEL so we move all rports into devloss state and unblock unless we receive an init complete. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Acked-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-11-12Merge tag '4.4-scsi-mkp' into miscJames Bottomley
SCSI queue for 4.4. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2015-11-11ibmvscsi: set max_lun to 32Laurent Vivier
As defined in 4.6.9 of SAM-4, the encoding of LUN is on 5 bits (max_lun=32) and the current value is only 8. Set max_lun to IBMVSCSI_MAX_LUN (32). Signed-off-by: Laurent Vivier <lvivier@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2015-11-11ibmvscsi: display default value for max_id, max_lun and max_channel.Laurent Vivier
As devices with values greater than that are silently ignored, this gives some hints to the sys admin to know why he doesn't see his devices... Signed-off-by: Laurent Vivier <lvivier@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2015-11-09scsi: use host wide tags by defaultChristoph Hellwig
This patch changes the !blk-mq path to the same defaults as the blk-mq I/O path by always enabling block tagging, and always using host wide tags. We've had blk-mq available for a few releases so bugs with this mode should have been ironed out, and this ensures we get better coverage of over tagging setup over different configs. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Jens Axboe <axboe@kernel.dk> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-05-18IB/srp: Add 64-bit LUN supportBart Van Assche
The SCSI standard defines 64-bit values for LUNs. Large arrays employing large or hierarchical LUN numbers become more and more common. So update the SRP initiator to use 64-bit LUN numbers. See also Hannes Reinecke, commit 9cb78c16f5da ("scsi: use 64-bit LUNs"), June 2014. The largest LUN number that has been tested is 0xd2003fff00000000. Checked the following structure sizes with gdb: * sizeof(struct srp_cmd) = 48 * sizeof(struct srp_tsk_mgmt) = 48 * sizeof(struct srp_aer_req) = 36 The ibmvscsi changes have been compile tested only (on a PPC system). Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Reviewed-by: Yann Droneaud <ydroneaud@opteya.com> Cc: Sebastian Parschauer <sebastian.riemer@profitbricks.com> Cc: Brian King <brking@linux.vnet.ibm.com> Cc: Nathan Fontenot <nfont@linux.vnet.ibm.com> Cc: Tyrel Datwyler <tyreld@linux.vnet.ibm.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2014-12-04ibmvfc: remove unused tag variableChristoph Hellwig
Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com Reviewed-by: Hannes Reinecke <hare@suse.de> Acked-by: Brian King <brking@linux.vnet.ibm.com>
2014-12-04scsi: remove ->change_queue_type methodChristoph Hellwig
Since we got rid of ordered tag support in 2010 the prime use case of switching on and off ordered tags has been obsolete. The other function of enabling/disabling tagging entirely has only been correctly implemented by the 53c700 driver and isn't generally useful. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com Reviewed-by: Hannes Reinecke <hare@suse.de>
2014-11-24scsi: drop reason argument from ->change_queue_depthChristoph Hellwig
Drop the now unused reason argument from the ->change_queue_depth method. Also add a return value to scsi_adjust_queue_depth, and rename it to scsi_change_queue_depth now that it can be used as the default ->change_queue_depth implementation. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Reviewed-by: Hannes Reinecke <hare@suse.de>
2014-11-24scsi: avoid ->change_queue_depth indirection for queue full trackingChristoph Hellwig
All drivers use the implementation for ramping the queue up and down, so instead of overloading the change_queue_depth method call the implementation diretly if the driver opts into it by setting the track_queue_depth flag in the host template. Note that a few drivers validated the new queue depth in their change_queue_depth method, but as we never go over the queue depth set during slave_configure or the sysfs file this isn't nessecary and can safely be removed. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Reviewed-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Venkatesh Srinivas <venkateshs@google.com>
2014-11-12scsi: don't set tagging state from scsi_adjust_queue_depthChristoph Hellwig
Remove the tagged argument from scsi_adjust_queue_depth, and just let it handle the queue depth. For most drivers those two are fairly separate, given that most modern drivers don't care about the SCSI "tagged" status of a command at all, and many old drivers allow queuing of multiple untagged commands in the driver. Instead we start out with the ->simple_tags flag set before calling ->slave_configure, which is how all drivers actually looking at ->simple_tags except for one worke anyway. The one other case looks broken, but I've kept the behavior as-is for now. Except for that we only change ->simple_tags from the ->change_queue_type, and when rejecting a tag message in a single driver, so keeping this churn out of scsi_adjust_queue_depth is a clear win. Now that the usage of scsi_adjust_queue_depth is more obvious we can also remove all the trivial instances in ->slave_alloc or ->slave_configure that just set it to the cmd_per_lun default. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Reviewed-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
2014-11-12scsi: always assign block layer tags if enabledChristoph Hellwig
Allow a driver to ask for block layer tags by setting .use_blk_tags in the host template, in which case it will always see a valid value in request->tag, similar to the behavior when using blk-mq. This means even SCSI "untagged" commands will now have a tag, which is especially useful when using a host-wide tag map. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Hannes Reinecke <hare@suse.de>
2014-11-12scsi: remove abuses of scsi_populate_tagChristoph Hellwig
Unless we want to build a SPI tag message we should just check SCMD_TAGGED instead of reverse engineering a tag type through the use of scsi_populate_tag_msg. Also rename the function to spi_populate_tag_msg, make it behave like the other spi message helpers, and move it to the spi transport class. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Reviewed-by: Hannes Reinecke <hare@suse.de>
2014-11-12scsi: provide a generic change_queue_type methodChristoph Hellwig
Most drivers use exactly the same implementation, so provide it as a library function. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Hannes Reinecke <hare@suse.de>
2014-07-25ibmvfc: fix little endian issuesTyrel Datwyler
Added big endian annotations to relevant data structure fields, and necessary byte swappings to support little endian builds. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-07-17ibmvstgt: removeChristoph Hellwig
The IBM virtual SCSI protocol has been obsoleted by ibmvfc, and there are no reported of the driver left. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Reviewed-by: Hannes Reinecke <hare@suse.de>
2014-07-17scsi: use 64-bit value for 'max_luns'Hannes Reinecke
Now that we're using 64-bit LUNs internally we need to increase the size of max_luns to 64 bits, too. Signed-off-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Christoph Hellwig <hch@infradead.org> Reviewed-by: Ewan Milne <emilne@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-06-25ibmvscsi: Add memory barriers for send / receiveBrian King
Add a memory barrier prior to sending a new command to the VIOS to ensure the VIOS does not receive stale data in the command buffer. Also add a memory barrier when processing the CRQ for completed commands. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Acked-by: Nathan Fontenot <nfont@linux.vnet.ibm.com> Cc: stable@vger.kernel.org Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-06-25ibmvscsi: Abort init sequence during error recoveryBrian King
If a CRQ reset is triggered for some reason while in the middle of performing VSCSI adapter initialization, we don't want to call the done function for the initialization MAD commands as this will only result in two threads attempting initialization at the same time, resulting in failures. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Acked-by: Nathan Fontenot <nfont@linux.vnet.ibm.com> Cc: stable@vger.kernel.org Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-04-18sched, treewide: Replace hardcoded nice values with MIN_NICE/MAX_NICEDongsheng Yang
Replace various -20/+19 hardcoded nice values with MIN_NICE/MAX_NICE. Signed-off-by: Dongsheng Yang <yangds.fnst@cn.fujitsu.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/ff13819fd09b7a5dba5ab5ae797f2e7019bdfa17.1394532288.git.yangds.fnst@cn.fujitsu.com Cc: devel@driverdev.osuosl.org Cc: devicetree@vger.kernel.org Cc: fcoe-devel@open-fcoe.org Cc: linux390@de.ibm.com Cc: linux-kernel@vger.kernel.org Cc: linux-mm@kvack.org Cc: linux-s390@vger.kernel.org Cc: linux-scsi@vger.kernel.org Cc: nbd-general@lists.sourceforge.net Cc: ocfs2-devel@oss.oracle.com Cc: openipmi-developer@lists.sourceforge.net Cc: qla2xxx-upstream@qlogic.com Cc: linux-arch@vger.kernel.org [ Consolidated the patches, twiddled the changelog. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-03-19[SCSI] remove deprecated IRQF_DISABLED from SCSIMichael Opdenacker
It's a NOOP since 2.6.35 and it will be removed one day. [jejb: remove from missed arm scsi drivers] Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-09-06[SCSI] ibmvfc: Fix for offlining devices during error recoveryBrian King
This fixes an issue seen with devices getting marked offline in a scenario where a VIOS was getting rebooted while a client VFC adapter is in SCSI EH and prevents unnecessary EH escalation in some scenarios. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Acked-by: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-09-06[SCSI] ibmvscsi: Fix little endian issuesAnton Blanchard
The hypervisor is big endian, so little endian kernel builds need to byteswap. [jejb: fix checkpatch errors] Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] ibmvfc: Driver version 1.0.11Brian King
2013-05-02[SCSI] ibmvfc: Suppress ABTS if target goneBrian King
Adds support for a new VIOS feature that allows ibmvfc to optimize terminate_rport_io by telling the VIOS the target is no longer accessible on the fabric and that it should not send an ABTS out on the fabric to the device. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Acked-by: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] ibmvfc: Send cancel when link is downBrian King
If attempting to abort requests due to a fail fail timeout or error handling while the link is down, we cannot send an abort out on the fabric. We can, however, send a cancel to the VIOS. This fixes ibmvfc to send a cancel in this case to prevent error handling from failing and/or escalating. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Acked-by: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] ibmvfc: Support FAST_IO_FAIL in EH handlersBrian King
Adds support for receiving FAST_IO_FAIL from fc_block_scsi_eh when in error recovery. This fixes cases of devices being taken offline when they are no longer accessible on the fabric, preventing them from coming back online when the fabric recovers. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Acked-by: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] ibmvfc: Properly set cancel flags when cancelling abortBrian King
The flags on a cancel operation are intended to indicate what, if any, TMF will follow the cancel request. This fixes a case where we were incorrectly setting the abort task set flag on the cancel flag when we were cancelling an abort task set. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Acked-by: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-04-06[SCSI] ibmvscsi: Fix slave_configure deadlockBrian King
No locks should be held when calling scsi_adjust_queue_depth so drop the lock in slave_configure prior to calling it. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Acked-by: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-01-03Drivers: scsi: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Adam Radford <linuxraid@lsi.com> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-24[SCSI] ibmvscsi: Fix host config length field overflowBenjamin Herrenschmidt
The length field in the host config packet is only 16-bit long, so passing it 0x10000 (64K which is our standard PAGE_SIZE) doesn't work and result in an empty config from the server. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <stable@vger.kernel.org> Acked-by: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-09-24[SCSI] ibmvscsi: Remove backend abstractionBenjamin Herrenschmidt
Now that the iSeries code is gone the backend abstraction in this driver is no longer necessary, which allows us to consolidate the driver in one file. The side effect is that the module name is now ibmvscsi.ko which matches the driver hotplug name and fixes auto-load issues. [jejb:fix up checkpatch.pl errors] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-09-24[SCSI] ibmvfc: Driver version 1.0.10Brian King
Bump driver version. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-09-24[SCSI] ibmvfc: Ignore fabric RSCNs when link is deadBrian King
This fixes an issues seen where a Fabric RSCN event was received while the link was down, which resulted in repeated attempts to log back into the fabric, which then failed, resulting in the ibmvfc driver taking the host offline. Fix this by delaying taking any action regarding the fabric RSCN until the link comes back up. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-09-24[SCSI] ibmvfc: Fix double completion on abort timeoutBrian King
If an abort request times out to the virtual fibre channel adapter, the ibmvfc driver will kick off a reset of the adapter. This patch ensures we wait for the both the abort request and the request being aborted to be completed prior to exiting the eh_abort handler. This fixes a bug where the ibmvfc driver was erroneously returning success to the eh_abort handler then later sending back a response to the same command. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-03-28powerpc+sparc/vio: Modernize driver registrationBenjamin Herrenschmidt
This makes vio_register_driver() get the module owner & name at compile time like PCI drivers do, and adds a name pointer directly in struct vio_driver to avoid having to explicitly initialize the embedded struct device. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: David S. Miller <davem@davemloft.net>
2012-03-09powerpc: remove the legacy iSeries part of ibmvscsiStephen Rothwell
The PowerPC legacy iSeries platform is being removed and this code is no longer selectable. There is more clean up that can be done, but this just gets the old code out of the way. Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Cc: Brian King <brking@linux.vnet.ibm.com> Cc: linux-scsi@vger.kernel.org Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-06-29[SCSI] ibmvfc: Fix Virtual I/O failover hangBrian King
If a Virtual I/O server fails in a dual virtual I/O server multipath configuration, ensure we delete all remote ports so that path failover can occur. For a single path configuration, the remote ports will go into devloss state. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-05-01[SCSI] ibmvscsi: Improve CRQ reset reliabilityBrian King
This patch fixes an issue seen where an event occurs which causes the ibmvscsi driver to reset its CRQ. Upon re-registering its CRQ, it receives H_CLOSED, indicating the Virtual I/O Server is not yet ready to receive commands. This resulted in the ibmvscsi driver essentially offlining the adapter and not recovering. The fix is to re-enable our interrupt so that when the Virtual I/O server is ready and sends a CRQ init, we will be able to receive it and resume initialization of the VSCSI adapter. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-21[SCSI] ibmvfc: Improve ibmvfc_async_desc memory layoutRobert Jennings
By changing field ordering we can avoid a couple of memory holes in the tables that use the ibmvfc_async_desc structure. Signed-off-by: Robert Jennings <rcj@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-11-16SCSI host lock push-downJeff Garzik
Move the mid-layer's ->queuecommand() invocation from being locked with the host lock to being unlocked to facilitate speeding up the critical path for drivers who don't need this lock taken anyway. The patch below presents a simple SCSI host lock push-down as an equivalent transformation. No locking or other behavior should change with this patch. All existing bugs and locking orders are preserved. Additionally, add one parameter to queuecommand, struct Scsi_Host * and remove one parameter from queuecommand, void (*done)(struct scsi_cmnd *) Scsi_Host* is a convenient pointer that most host drivers need anyway, and 'done' is redundant to struct scsi_cmnd->scsi_done. Minimal code disturbance was attempted with this change. Most drivers needed only two one-line modifications for their host lock push-down. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-07[SCSI] ibmvfc: Handle Virtual I/O Server rebootBrian King
If a Virtual I/O server is rebooted, the client fibre channel sees a transport event on its CRQ, which causes it to attempt to reconnect to the CRQ. For a period of time during the VIOS reboot, the client's attempts to register the CRQ will return H_CLOSED, indicating the server side is not currently registered. The ibmvfc driver was not handling this well and was taking the virtual adapter offline. Fix this by re-enabling our interrupt and waiting for the event on our CRQ indicating the server is back, at which point we can reconnect. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-10-07[SCSI] ibmvfc: prep for fc host dev loss tmo supportMike Christie
This removes the driver's get_host_def_dev_loss_tmo callback and just has the driver set the dev loss using the fc class fc_host_dev_loss_tmo macro like is done for other fc params. This patch also removes the module dev loss param. To override the value the fc host sysfs value being added in the fc class patch can be used instead of the driver module param. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-09-16[SCSI] ibmvfc: Log link up/down eventsBrian King
By default, ibmvfc does not log any async events in order to avoid flooding the log with them. Improve on this by logging by default events that are not likely to flood the log, such as link up/down. Having these events in the log will improve the ability to debug issues with ibmvfc. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-09-05[SCSI] ibmvfc: do not reset dev_loss_tmo in slave calloutMike Christie
This fixes a bug where the driver was resetting the rport dev_loss_tmo when devices were added by adding support for the get_host_def_dev_loss_tmo callout. Patch has only been compile tested. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-08-06[SCSI] ibmvfc: Driver version 1.0.9Brian King
Bump driver version. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-08-06[SCSI] ibmvfc: Fix terminate_rport_ioBrian King
The ibmvfc driver was incorrectly obtaining a scsi_target pointer from an fc_rport. The way it is coded ensures that ibmvfc's terminate_rport_io handler does absolutely nothing. Fix this up to iterate through affected devices differently, sending cancel and abort task set as appropriate. Without this patch, fast_io_fail_tmo is broken for ibmvfc. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-08-06[SCSI] ibmvfc: Fix rport add/delete race resulting in oopsBrian King
Commit 43c8da907ccc656935d1085701f4db83385d8a59 introduced a race condition which can occur when adding/deleting rports. There are two possible threads now that can be deleting rports in the ibmvfc driver, which can result in list_del being called twice, resulting in an oops. This patch adds a new state to the ibmvfc_target struct to indicate the target has been removed from the list and is in the process of being deleted. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-28[SCSI] ibmvstgt: add __init/__exit macrosPeter Huewe
Add the __init and __exit macros to the module_init / module_exit functions from drivers/scsi/ibmvscsi/ibmvstgt.c Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] ibmvscsi: Driver version 1.5.9Brian King
Bump driver version Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
