path: root/drivers/scsi/ibmvscsi/ibmvscsi.c
2011-05-01[SCSI] ibmvscsi: Improve CRQ reset reliabilityBrian King
This patch fixes an issue seen where an event occurs which causes the ibmvscsi driver to reset its CRQ. Upon re-registering its CRQ, it receives H_CLOSED, indicating the Virtual I/O Server is not yet ready to receive commands. This resulted in the ibmvscsi driver essentially offlining the adapter and not recovering. The fix is to re-enable our interrupt so that when the Virtual I/O server is ready and sends a CRQ init, we will be able to receive it and resume initialization of the VSCSI adapter. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-11-16SCSI host lock push-downJeff Garzik
Move the mid-layer's ->queuecommand() invocation from being locked with the host lock to being unlocked to facilitate speeding up the critical path for drivers who don't need this lock taken anyway. The patch below presents a simple SCSI host lock push-down as an equivalent transformation. No locking or other behavior should change with this patch. All existing bugs and locking orders are preserved. Additionally, add one parameter to queuecommand, struct Scsi_Host * and remove one parameter from queuecommand, void (*done)(struct scsi_cmnd *) Scsi_Host* is a convenient pointer that most host drivers need anyway, and 'done' is redundant to struct scsi_cmnd->scsi_done. Minimal code disturbance was attempted with this change. Most drivers needed only two one-line modifications for their host lock push-down. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-27[SCSI] ibmvscsi: Driver version 1.5.9Brian King
Bump driver version Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] ibmvscsi: Fix possible request_limit issueBrian King
If we encounter an error when sending a management datagram (i.e. non SCSI command, such as virtual adapter initialization command), we end up incrementing the request_limit, even though we don't decrement it for these commands. Fix this up by doing this increment in the error path for SRP commands only. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] ibmvscsi: Fix error path deadlockBrian King
Fixes a deadlock that can occur if we hit a command timeout during the virtual adapter initialization. The event done functions are written with the assumption that no locks are held, however, when purging requests this is not true. Fix up the purge function to drop the lock so that the done function is not called with the lock held, which can cause a deadlock. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] ibmvscsi: Fix softlockup on resumeBrian King
This fixes a softlockup seen on resume. During resume, the CRQ must be reenabled. However, the H_ENABLE_CRQ hcall used to do this may return H_BUSY or H_LONG_BUSY. When this happens, the caller is expected to retry later. This patch changes a simple loop, which was causing the softlockup, to a loop at task level which sleeps between retries rather than simply spinning. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-05-22Merge remote branch 'origin' into secretlab/next-devicetreeGrant Likely
Merging in current state of Linus' tree to deal with merge conflicts and build failures in vio.c after merge. Conflicts: drivers/i2c/busses/i2c-cpm.c drivers/i2c/busses/i2c-mpc.c drivers/net/gianfar.c Also fixed up one line in arch/powerpc/kernel/vio.c to use the correct node pointer. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-18of: Always use 'struct device.of_node' to get device node pointer.Grant Likely
The following structure elements duplicate the information in 'struct device.of_node' and so are being eliminated. This patch makes all readers of these elements use device.of_node instead. (struct of_device *)->node (struct dev_archdata *)->prom_node (sparc) (struct dev_archdata *)->of_node (powerpc & microblaze) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-04-11[SCSI] ibmvscsi: fix DMA API misuseFUJITA Tomonori
ibmvscsi uses dma_unmap_single() for buffers mapped via dma_map_sg(). It works however it's the API violation. The DMA debug facility complains about it: http://marc.info/?l=linux-scsi&m=127018555013151&w=2 Reported-by: Sachin Sant <sachinp@in.ibm.com> Tested-by: Sachin Sant <sachinp@in.ibm.com> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-03[SCSI] ibmvscsi: Add suspend/resume supportBrian King
Adds support for resuming from suspend for IBM VSCSI devices. We may have lost an interrupt over the suspend, so we just kick the interrupt handler to process anything that is outstanding. We expect to find a transport event indicating we need to reestablish our CRQ. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-01-18[SCSI] ibmvscsi: fix a typo in a source code commentBart Van Assche
Signed-off-by: Bart Van Assche <bart.vanassche@gmail.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04[SCSI] modify change_queue_depth to take in reason why it is being calledMike Christie
This patch modifies scsi_host_template->change_queue_depth so that it takes an argument indicating why it is being called. This will be used so that if a LLD needs to do some extra processing when handling queue fulls or later ramp ups, it can do so. This is a simple port of the drivers setting a change_queue_depth callback. In the patch I just have these LLDs adjust the queue depth if the user was requesting it. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> [Vasu.Dev: v2 Also converted pmcraid_change_queue_depth and then verified all modules compile using "make allmodconfig" for any new build warnings on X86_64. Updated original description after combing two original patches from Mike to make this patch git bisectable.] Signed-off-by: Vasu Dev <vasu.dev@intel.com> [jejb: fixed up 53c700] Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-09-20includecheck fix: drivers/scsi, ibmvscsi.cJaswinder Singh Rajput
fix the following 'make includecheck' warning: drivers/scsi/ibmvscsi/ibmvscsi.c: asm/firmware.h is included more than once. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Sam Ravnborg <sam@ravnborg.org> LKML-Reference: <1247067016.4382.78.camel@ht.satnam> Acked-by: Brian King <brking@linux.vnet.ibm.com>
2009-06-25[SCSI] ibmvscsi: Fix module load hangBrian King
Fixes a regression seen in the ibmvscsi driver when using the VSCSI server in SLES 9 and SLES 10. The VSCSI server in these releases has a bug in it in which it does not send responses to unknown MADs. Check the OS Type field in the adapter info response and do not send these unsupported commands when talking to an older server. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-15ibmvscsi: gadget: at91_udc: remove driver_data direct access of struct deviceGreg Kroah-Hartman
In the near future, the driver core is going to not allow direct access to the driver_data pointer in struct device. Instead, the functions dev_get_drvdata() and dev_set_drvdata() should be used. These functions have been around since the beginning, so are backwards compatible with all older kernel versions. Cc: linux-scsi@vger.kernel.org Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Brian King <brking@linux.vnet.ibm.com> Cc: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-08[SCSI] ibmvscsi: Add support for capabilities MADBrian King
Add support to ibmvscsi for the capabilities MAD. This command gets sent to the Virtual I/O server prior to login in order to communicate client capabilities. Additionally it returns information regarding capabilities that the server supports. The two main capabilities communicated in this MAD are related to partition migration and client reserve. Client reserve allows for SCSI-2 reservations to be sent to virtual disks which are backed by physical LUNs and will result in the reservation being sent to the physical LUN. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-08[SCSI] ibmvscsi: Enable fast fail featureRobert Jennings
A new mode of error reporting, fast fail, has been added to the VIOS which allows failover to happen more quickly. If this new fast fail mode is enabled on the VIOS and the vSCSI client supports the mode, the VIOS will not return MEDIUM error on path failures, but rather return VIOSRP_ADAPTER_FAIL in the crq response, which ibmvscsi will translate to DID_ERROR. This new mode can be enabled for single path configurations as well, so it is the new default error reporting mode. A module parameter is provided to disable this new behavior on the off chance it causes a problem on some old VIOS version. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-08[SCSI] ibmvscsi: Send adapter info before loginBrian King
The ibmvscsi driver currently sends the SRP Login before sending the Adapter Info MAD, which can result in commands getting sent to the virtual adapter before we are ready for them. This results in a slight window where the target devices may not behave as expected. Change the order and close the window. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-08[SCSI] ibmvscsi: Add specific timeouts for operationsRobert Jennings
Previously we had one timeout that was used for all types of operations. This adds specific timeout values for different operations (init, login, adapter info MAD, abort task, and LUN reset). Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-08[SCSI] ibmvscsi: Add 16 byte CDB supportBrian King
Adds support for 16 byte CDBs to the ibmvscsi driver. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-23[SCSI] ibmvscsi: Remove redundant test on unsigned.Roel Kluin
Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-02-10[SCSI] ibmvscsi: Correct DMA mapping leakRobert Jennings
The ibmvscsi client driver is not unmapping the SCSI command after encountering a DMA mapping error while trying to map an indirect scattergather list for the event pool. This leads to a leak of DMA entitlement that could result in the device failing future DMA operations in a CMO environment. Signed-off-by: Robert Jennings <rcj@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-13powerpc: Change u64/s64 to a long long integer typeIngo Molnar
Convert arch/powerpc/ over to long long based u64: -#ifdef __powerpc64__ -# include <asm-generic/int-l64.h> -#else -# include <asm-generic/int-ll64.h> -#endif +#include <asm-generic/int-ll64.h> This will avoid reoccuring spurious warnings in core kernel code that comes when people test on their own hardware. (i.e. x86 in ~98% of the cases) This is what x86 uses and it generally helps keep 64-bit code 32-bit clean too. [Adjusted to not impact user mode (from paulus) - sfr] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-02[SCSI] ibmvscsi: Make max_requests module parameter more accurateBrian King
In a previous patch to fix an issue with error recovery, the behavior of the max_requests module paramater was also changed. If, for some reason, max_requests is set to one by the user, we will end up with a negative number for can_queue. Fix this by making max_requests not include the two event structs needed to do error recovery. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] ibmvscsi: Don't fail EH due to insufficient resourcesBrian King
The ibmvscsi driver currently has a bug in it which can result in it using up all its event structs for commands. If something results in all those commands timing out, we won't have any resources left to send aborts or resets. This results in escalating to a host reset in order to recover, which is a bit heavy handed. This fixes it by reducing can_queue by two in order to have resources to do EH. It also changes the max_requests module parameter so that it is not writable at runtime, since the code really does not handle it changing at runtime. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-01[SCSI] ibmvscsi: switch to block timeoutJames Bottomley
ibmvscsi sets the timeout in its slave configure routine for disk devices. This now needs to update the request queue timeout in block. Cc: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-09block: unify request timeout handlingJens Axboe
Right now SCSI and others do their own command timeout handling. Move those bits to the block layer. Instead of having a timer per command, we try to be a bit more clever and simply have one per-queue. This avoids the overhead of having to tear down and setup a timer for each command, so it will result in a lot less timer fiddling. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-08-16[SCSI] ibmvscsi: Fixup desired DMA value for shared memory partitionsBrian King
When running ibmvscsi in a shared memory partition, it must provide a default value for the amount of DMA resources it will need in order to perform reasonably well. This was being calculated in sectors rather than bytes, as it should. This patch fixes this. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-26dma-mapping: add the device argument to dma_mapping_error()FUJITA Tomonori
Add per-device dma_mapping_ops support for CONFIG_X86_64 as POWER architecture does: This enables us to cleanly fix the Calgary IOMMU issue that some devices are not behind the IOMMU (http://lkml.org/lkml/2008/5/8/423). I think that per-device dma_mapping_ops support would be also helpful for KVM people to support PCI passthrough but Andi thinks that this makes it difficult to support the PCI passthrough (see the above thread). So I CC'ed this to KVM camp. Comments are appreciated. A pointer to dma_mapping_ops to struct dev_archdata is added. If the pointer is non NULL, DMA operations in asm/dma-mapping.h use it. If it's NULL, the system-wide dma_ops pointer is used as before. If it's useful for KVM people, I plan to implement a mechanism to register a hook called when a new pci (or dma capable) device is created (it works with hot plugging). It enables IOMMUs to set up an appropriate dma_mapping_ops per device. The major obstacle is that dma_mapping_error doesn't take a pointer to the device unlike other DMA operations. So x86 can't have dma_mapping_ops per device. Note all the POWER IOMMUs use the same dma_mapping_error function so this is not a problem for POWER but x86 IOMMUs use different dma_mapping_error functions. The first patch adds the device argument to dma_mapping_error. The patch is trivial but large since it touches lots of drivers and dma-mapping.h in all the architecture. This patch: dma_mapping_error() doesn't take a pointer to the device unlike other DMA operations. So we can't have dma_mapping_ops per device. Note that POWER already has dma_mapping_ops per device but all the POWER IOMMUs use the same dma_mapping_error function. x86 IOMMUs use device argument. [akpm@linux-foundation.org: fix sge] [akpm@linux-foundation.org: fix svc_rdma] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix bnx2x] [akpm@linux-foundation.org: fix s2io] [akpm@linux-foundation.org: fix pasemi_mac] [akpm@linux-foundation.org: fix sdhci] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix sparc] [akpm@linux-foundation.org: fix ibmvscsi] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ibmvscsi: driver enablement for CMORobert Jennings
Enable the driver to function in a Cooperative Memory Overcommitment (CMO) environment. The following changes are made to enable the driver for CMO: * DMA mapping errors will not result in error messages if entitlement has been exceeded and resources were not available. * The driver has a get_desired_dma function defined to function in a CMO environment. It will indicate how much IO memory it would like to function. Signed-off-by: Robert Jennings <rcj@linux.vnet.ibm.com> Acked by: Brian King <brking@linux.vnet.ibm.com> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-05-27[SCSI] ibmvscsi: Non SCSI error status fixupBrian King
Some versions of the Virtual I/O Server on Power return 0x99 in the non-SCSI error status field as success, rather than 0. This fixes the ibmvscsi driver to treat this response as success. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-02[SCSI] Let scsi_cmnd->cmnd use request->cmd bufferBoaz Harrosh
- struct scsi_cmnd had a 16 bytes command buffer of its own. This is an unnecessary duplication and copy of request's cmd. It is probably left overs from the time that scsi_cmnd could function without a request attached. So clean that up. - Once above is done, few places, apart from scsi-ml, needed adjustments due to changing the data type of scsi_cmnd->cmnd. - Lots of drivers still use MAX_COMMAND_SIZE. So I have left that #define but equate it to BLK_MAX_CDB. The way I see it and is reflected in the patch below is. MAX_COMMAND_SIZE - means: The longest fixed-length (*) SCSI CDB as per the SCSI standard and is not related to the implementation. BLK_MAX_CDB. - The allocated space at the request level - I have audit all ISA drivers and made sure none use ->cmnd in a DMA Operation. Same audit was done by Andi Kleen. (*)fixed-length here means commands that their size can be determined by their opcode and the CDB does not carry a length specifier, (unlike the VARIABLE_LENGTH_CMD(0x7f) command). This is actually not exactly true and the SCSI standard also defines extended commands and vendor specific commands that can be bigger than 16 bytes. The kernel will support these using the same infrastructure used for VARLEN CDB's. So in effect MAX_COMMAND_SIZE means the maximum size command scsi-ml supports without specifying a cmd_len by ULD's Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-29[SCSI] ibmvscsi: Handle non SCSI error statusBrian King
Adds support to the ibmvscsi driver to handle non SCSI error status. This is needed to support some new VIOS enhancements. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Santiago Leon <santil@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-19SCSI: convert struct class_device to struct deviceTony Jones
It's big, but there doesn't seem to be a way to split it up smaller... Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-30[SCSI] remove use_sg_chainingJames Bottomley
With the sg table code, every SCSI driver is now either chain capable or broken (or has sg_tablesize set so chaining is never activated), so there's no need to have a check in the host template. Also tidy up the code by moving the scatterlist size defines into the SCSI includes and permit the last entry of the scatterlist pools not to be a power of two. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] ibmvscsi: requeue while CRQ closedRobert Jennings
CRQ send errors that return with H_CLOSED should return with SCSI_MLQUEUE_HOST_BUSY until firmware alerts the client of a CRQ transport event. The transport event will either reinitialize and requeue the requests or fail and return IO with DID_ERROR. To avoid failing the eh_* functions while re-attaching to the server adapter this will retry for a period of time while ibmvscsi_send_srp_event returns SCSI_MLQUEUE_HOST_BUSY. In ibmvscsi_eh_abort_handler() the loop includes the search of the event list. The lock on the hostdata is dropped while waiting to try again after failing ibmvscsi_send_srp_event. The event could have been purged if a login was in progress when the function was called. In ibmvscsi_eh_device_reset_handler() the loop includes the call to get_event_struct() because a failing call to ibmvscsi_send_srp_event() will have freed the event struct. Signed-off-by: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] ibmvscsi: Set default command timeoutBrian King
Set the default command timeout for ibmvscsi disks to 60 seconds to ensure we don't prematurely timeout commands. This fixes a problem seen where the default 30 seconds was not long enough due to congestion on the server. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-11-03[SCSI] ibmvscsi: Prevent IO during partner loginRobert Jennings
By setting the request_limit in send_srp_login to 1 we allowed login requests to be sent to the server adapter. If this was not an initial login, but was a login after a disconnect with the server, other I/O requests could attempt to be processed before the login occured. These I/O requests would fail, sometimes resulting in filesystems getting marked read-only. To address this we can set the request_limit to 0 while doing the login and add an exception where login requests, along with task management events, are always passed to the server. There is a case where the request_limit had already reached 0 would result in all events being sent rather than returning SCSI_MLQUEUE_HOST_BUSY; this has also been fixed by this patch. Signed-off-by: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-16[SCSI] add use_sg_chaining option to scsi_host_templateFUJITA Tomonori
This option is true if a low-level driver can support sg chaining. This will be removed eventually when all the drivers are converted to support sg chaining. q->max_phys_segments is set to SCSI_MAX_SG_SEGMENTS if false. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-12[SCSI] Fix ibmvscsi client for multiplatform iSeries+pSeries kernelDavid Woodhouse
If you build a multiplatform kernel for iSeries and pSeries, with ibmvscsic support, the resulting client doesn't work on iSeries. This fixes that, using the appropriate low-level operations for the machine detected at runtime. [jejb: fixed up rejections around the srp transport patch] Signed-off-by: David Woodhouse <dwmw2@infradead.org> Acked by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] transport_srp: add rport roles attributeFUJITA Tomonori
This adds a 'roles' attribute to rport like transport_fc. The role can be initiator or target. That is, the initiator driver creates target remote ports and the target driver creates initiator remote ports. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] ibmvscsi: convert to use the srp transport classFUJITA Tomonori
This converts ibmvscsi to use the srp transport class. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Brian King <brking@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-31[SCSI] ibmvscsi: use shost_privFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-31[SCSI] ibmvscsi: remove unnecessary map_sg checkFUJITA Tomonori
No need to check use_sg since sg_tablesize is set appropriately in the scsi host template. Brian King's patch (2a7309372fe56ae46c499b772d811ad31c501dd9) did this cleanup but the data buffer accessors patch (written before the patch and merged after it) restored the check. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-15[SCSI] ibmvscsi: convert to use the data buffer accessorsFUJITA Tomonori
- remove the unnecessary map_single path. - convert to use the new accessors for the sg lists and the parameters. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Santiago Leon <santil@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-25[SCSI] ibmvscsi: fix timeout bugsFUJITA Tomonori
The viosrp_crq timeout field is in seconds. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Santiago Leon <santil@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-17[SCSI] ibmvscsi: Abort path fixBrian King
Since it is completely possible for scsi core to call a LLDD's eh_abort function after the command has completed, fix ibmvscsi to return SUCCESS if this is the case. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-17[SCSI] ibmvscsi: Misc. locking fixesBrian King
Fix a couple locking bugs discovered during code inspection. ibmvscsi_send_srp_event needs to be called with the host lock held. This patch fixes a couple paths in the code where this wasn't true. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-17[SCSI] ibmvscsi: Add eh_host_reset_handlerBrian King
Adds an eh_host_reset_handler to ibmvscsi which resets the connection to the vscsi server. This patch also adds a timer to internally issues commands to prevent client hangs in the case of a misbehaving server. Tested by modifying the VIOS such that it would occasionally drop one or more request in sequence. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
