path: root/drivers/scsi/gdth.c
2007-10-15scsi/gdth: fix crash in gdth_timeout if no gdth controllers foundLinus Torvalds
If the gdth module is loaded (or compiled in), the gdth_timeout function gets started even if no actual gdth controllers are found b the probing. That ends up not only being unnecessary, but also causes a crash due to the function blindly just trying to pick the first entry off the "gdth_instances" list, and accessing it - which obviously doesn't work if the list is empty! Noticed by Ingo Molnar. Tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12[SCSI] gdth: fix CONFIG_ISA build failureDhaval Giani
drivers/scsi/gdth.c: In function ‘gdth_search_dev’: drivers/scsi/gdth.c:646: warning: ‘pci_find_device’ is deprecated (declared at include/linux/pci.h:482) drivers/scsi/gdth.c: In function ‘gdth_init_isa’: drivers/scsi/gdth.c:857: error: ‘gdth_irq_tab’ undeclared (first use in this function) drivers/scsi/gdth.c:857: error: (Each undeclared identifier is reported only once drivers/scsi/gdth.c:857: error: for each function it appears in.) drivers/scsi/gdth.c: In function ‘gdth_copy_internal_data’: drivers/scsi/gdth.c:2362: warning: unused variable ‘sg’ Looking into the code I notice that gdth_irq_tab is not declared with CONFIG_ISA=y and !CONFIG_EISA. The values seem to be same in 2.6.23 (I am not sure why it has been put with #ifdefs in -mm) so I have just modified the #ifdef to take care of CONFIG_ISA as well. Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] gdth: !use_sg cleanup and use of scsi accessorsBoaz Harrosh
gdth_execute() will issue an internal, none scsi-standard commands onto __gdth_queuecommand(). Since it is not recommended to set struct scsi_cmnd IO members in llds, gdth now uses internal IO members for IO. In the case of gdth_execute() these members will be set properly. In case the command was issued from scsi-ml (by gdth_queuecommand) they will be set from scsi IO accessors. * define gdth IO accessors and use them throughout the driver. * use an sg-of-one in gdth_execute() and fix gdth_special_cmd() accordingly. * Clean the not use_sg code path and company Signed-off-by Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] gdth: Move members from SCp to gdth_cmndinfo, stage 2Boaz Harrosh
- Cleanup the rest of the scsi_cmnd->SCp members and move them to gdth_cmndinfo: SCp.this_residual => priority SCp.buffers_residual => timeout SCp.Status => status and dma_dir SCp.Message => info SCp.have_data_in => volatile wait_for_completion SCp.sent_command => OpCode SCp.phase => phase - Two more members will be naturally removed in the !use_sg cleanup TODO: What is the meaning of gdth_cmndinfo.phase? (rhetorically) Signed-off-by Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] gdth: Setup proper per-command private dataBoaz Harrosh
- scsi_cmnd and specifically ->SCp of, where heavily abused with internal meaning members and flags. So introduce a new struct gdth_cmndinfo, put it on ->host_scribble and define a gdth_cmnd_priv() accessor to retrieve it from a scsi_cmnd. - The structure now holds two members: internal_command - replaces the IS_GDTH_INTERNAL_CMD() croft. sense_paddr - which was a 64-bit spanning on 2 32-bit members of SCp. More overloaded members from SCp and scsi_cmnd will be moved in a later patch (For easy review). - Split up gdth_queuecommand to an additional internal_function. The later is the one called by gdth_execute(). This will be more evident later in the scsi accessors patch, but it also facilitates in the differentiation between internal_command and external. And the setup of gdth_cmndinfo of each command. Signed-off-by Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] gdth: Remove gdth_ctr_tab[]Boaz Harrosh
- Places like Initialization and Reset that Just loop on all devices can use the link list with the list_for_each_entry macro. But the io_ctrl from user mode now suffers performance-wise because code has to do a sequential search for the requested host number. I have isolated this search in a gdth_find_ha(int hanum) member for future enhancement if needed. Signed-off-by Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] gdth: switch to modern scsi host registrationChristoph Hellwig
- Use scsi_add_host and friends and track instances ourselves. And generally modernize the driver's structure. - TODO: Next we can remove the controller table - TODO: Fix use of deprecated pci_find_device() Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] gdth: gdth_interrupt() gdth_get_status() & gdth_wait() fixesBoaz Harrosh
- gdth_get_status() returns a single device interrupt IStatus - gdth_interrupt split to __gdth_interrupt() that receives flags if is called from gdth_wait(). - Use dev_id passed from kernel and do not loop on all controllers. - gdth_wait(), get read of all global variables and call the new __gdth_interrupt with these variables on the stack Signed-off-by Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] gdth: clean up host private dataBoaz Harrosh
- Based on same patch from Christoph Hellwig <hch@lst.de> - Get rid of all the indirection in the Scsi_Host private data and always put the gdth_ha_str directly into it. - Change all internal functions prototype to recieve an "gdth_ha_str *ha" pointer directlly and kill all that redundent access to the "gdth_ctr_tab[]" controller-table. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] gdth: Remove virt hostsChristoph Hellwig
The virt_ctr option allows to register a new scsi_host for each bus on the raid controller. This non-default option makes no sense with the current scsi code and prevents cleaning up the host registration, so remove it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] gdth: Reorder scsi_host_template intitializersJeff Garzik
shuffle scsi_host_template members such that they appear in the order in which they are defined in the header. this makes is easier to verify when initializers are missing members. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] gdth: kill gdth_{read,write}[bwl] wrappersJeff Garzik
They are direct equivalents to {read,write}[bwl]. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] gdth: Remove 2.4.x support, in-kernel changelogJeff Garzik
* Remove in-source changelog. It's archived permanently in git and various kernel archives, and changelogs should exist purely in git. * Remove 2.4.x kernel support. It is an active obstacle to modernizing this driver, at this point. This includes killing gdth_kcompat.h which is 100% redundant in modern kernels. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] gdth: split out pci probingChristoph Hellwig
Split out per-device pci probing and put it under proper CONFIG_PCI. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] gdth: split out eisa probingChristoph Hellwig
Split eisa probing into it's own helper, and do proper error unwinding. Protect EISA probind by the proper CONFIG_EISA symbol. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] gdth: split out isa probingChristoph Hellwig
(note: this is ontop of Jeff's pci cleanup patch) Split out isa probing into a helper of it's own. Error handling is cleaned up, but errors are not propagated yet. Also enclose the isa probe under the proper CONFIG_ISA symbol instead of the !IA64 hack. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12gdth: Make one abuse of scsi_cmnd less obviousMatthew Wilcox
Rather than having internal commands abuse scsi_done to call gdth_scsi_done, have all the places that use to call scsi_done directly call gdth_scsi_done, which now checks whether the command was internal, and calls scsi_done if not. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] gdth: Stop abusing ->done for internal commandsMatthew Wilcox
The ->done member was being used to mark commands as being internal. I decided to put a magic number in ->underflow instead. I believe this to be safe as no current user of ->underflow has any of the bottom 9 bits set. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] kmalloc + memset conversion to kzallocMariusz Kozlowski
In NCR_D700, a4000t, aic7xxx_old, bvme6000, dpt_i2o, gdth, lpfc, megaraid, mvme16x osst, pluto, qla2xxx, zorro7xx Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-31[SCSI] gdth: remove redundant PCI stuffJeff Garzik
This patch * removes struct members that duplicate pci_dev members * replaces ha->stype usage with ha->pdev->device usage where feasible Signed-off-by: Jeff Garzik <jeff@garzik.org> Acked-by: Christoph Hellwig <hch@lst.de> Acked-by: Achim Leubner <Achim_Leubner@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-30[SCSI] gdth: Fix obvious typo "spin_lock_irqrestore()"Robert P. J. Day
Fix misspelled "spin_lock_irqrestore" to read "spin_unlock_irqrestore" instead. Presumably, GDTH_RTC doesn't get used a lot. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Achim Leubner <achim_leubner@adaptec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-30[SCSI] gdth: fix ambiguous gdthtable definitionDavid Rientjes
Labeling a variable as __attribute_used__ is ambiguous: it means __attribute__((unused)) for gcc <3.4 and __attribute__((used)) for gcc >=3.4. There is no such thing as labeling a variable as __attribute__((used)). We assume that we're simply suppressing a warning here if gdthtable[] is declared but unreferenced. Acked-by: Achim Leubner <achim_leubner@adaptec.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-11[SCSI] gdth: fix oops in gdth_copy_cmd()Joerg Dorchain
Recent alterations to the gdth_fill_raw_cmd() path no longer set the sg_ranz field for zero transfer commands. However, this field is used lower down in the function to initialise ha->cmd_len to the size of the firmware packet. If this uninitialised field contains a bogus value, ha->cmd_len can become much larger than the actual firmware packet and end up oopsing in gdth_copy_cmd() as it tries to copy this huge packet to the device (usually because it runs into an unallocated page). The fix is to initialise the sg_ranz field to zero at the start of gdth_fill_raw_cmd(). Signed-off-by: Joerg Dorchain <joerg@dorchain.net> Acked-by: "Leubner, Achim" <Achim_Leubner@adaptec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-12[PATCH] mark struct file_operations const 6Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-10[SCSI] gdth: Fix && typosJean Delvare
Fix uses of "&&" where "&" was obviously intended instead. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-01[PATCH] completions: lockdep annotate on stack completionsPeter Zijlstra
All on stack DECLARE_COMPLETIONs should be replaced by: DECLARE_COMPLETION_ONSTACK Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: scsi: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-10[SCSI] remove scsi_request infrastructureChristoph Hellwig
With Achim patch the last user (gdth) is switched away from scsi_request so we an kill it now. Also disables some code in i2o_scsi that was broken since the sg driver stopped using scsi_requests. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-10[SCSI] drivers/scsi: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove duplicates of the macro. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-10[SCSI] remove the scsi_request interface from the gdth driverLeubner, Achim
Initial pass at converting the gdth driver away from the scsi_request interface so that the request interface can be removed post 2.6.18 without breaking gdth. Based on changes from Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-06[SCSI] fix up request buffer reference in various scsi driversChristoph Hellwig
Various scsi drivers use scsi_cmnd.buffer and scsi_cmnd.bufflen in their queuecommand functions. Those fields are internal storage for the midlayer only and are used to restore the original payload after request_buffer and request_bufflen have been overwritten for EH. Using the buffer and bufflen fields means they do very broken things in error handling. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-28[PATCH] Replace 0xff.. with correct DMA_xBIT_MASKMatthias Gehre
Replace all occurences of 0xff.. in calls to function pci_set_dma_mask() and pci_set_consistant_dma_mask() with the corresponding DMA_xBIT_MASK from linux/dma-mapping.h. Signed-off-by: Matthias Gehre <M.Gehre@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] Notifier chain update: API changesAlan Stern
The kernel's implementation of notifier chains is unsafe. There is no protection against entries being added to or removed from a chain while the chain is in use. The issues were discussed in this thread: http://marc.theaimsgroup.com/?l=linux-kernel&m=113018709002036&w=2 We noticed that notifier chains in the kernel fall into two basic usage classes: "Blocking" chains are always called from a process context and the callout routines are allowed to sleep; "Atomic" chains can be called from an atomic context and the callout routines are not allowed to sleep. We decided to codify this distinction and make it part of the API. Therefore this set of patches introduces three new, parallel APIs: one for blocking notifiers, one for atomic notifiers, and one for "raw" notifiers (which is really just the old API under a new name). New kinds of data structures are used for the heads of the chains, and new routines are defined for registration, unregistration, and calling a chain. The three APIs are explained in include/linux/notifier.h and their implementation is in kernel/sys.c. With atomic and blocking chains, the implementation guarantees that the chain links will not be corrupted and that chain callers will not get messed up by entries being added or removed. For raw chains the implementation provides no guarantees at all; users of this API must provide their own protections. (The idea was that situations may come up where the assumptions of the atomic and blocking APIs are not appropriate, so it should be possible for users to handle these things in their own way.) There are some limitations, which should not be too hard to live with. For atomic/blocking chains, registration and unregistration must always be done in a process context since the chain is protected by a mutex/rwsem. Also, a callout routine for a non-raw chain must not try to register or unregister entries on its own chain. (This did happen in a couple of places and the code had to be changed to avoid it.) Since atomic chains may be called from within an NMI handler, they cannot use spinlocks for synchronization. Instead we use RCU. The overhead falls almost entirely in the unregister routine, which is okay since unregistration is much less frequent that calling a chain. Here is the list of chains that we adjusted and their classifications. None of them use the raw API, so for the moment it is only a placeholder. ATOMIC CHAINS ------------- arch/i386/kernel/traps.c: i386die_chain arch/ia64/kernel/traps.c: ia64die_chain arch/powerpc/kernel/traps.c: powerpc_die_chain arch/sparc64/kernel/traps.c: sparc64die_chain arch/x86_64/kernel/traps.c: die_chain drivers/char/ipmi/ipmi_si_intf.c: xaction_notifier_list kernel/panic.c: panic_notifier_list kernel/profile.c: task_free_notifier net/bluetooth/hci_core.c: hci_notifier net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_chain net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_expect_chain net/ipv6/addrconf.c: inet6addr_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_expect_chain net/netlink/af_netlink.c: netlink_chain BLOCKING CHAINS --------------- arch/powerpc/platforms/pseries/reconfig.c: pSeries_reconfig_chain arch/s390/kernel/process.c: idle_chain arch/x86_64/kernel/process.c idle_notifier drivers/base/memory.c: memory_chain drivers/cpufreq/cpufreq.c cpufreq_policy_notifier_list drivers/cpufreq/cpufreq.c cpufreq_transition_notifier_list drivers/macintosh/adb.c: adb_client_list drivers/macintosh/via-pmu.c sleep_notifier_list drivers/macintosh/via-pmu68k.c sleep_notifier_list drivers/macintosh/windfarm_core.c wf_client_list drivers/usb/core/notify.c usb_notifier_list drivers/video/fbmem.c fb_notifier_list kernel/cpu.c cpu_chain kernel/module.c module_notify_list kernel/profile.c munmap_notifier kernel/profile.c task_exit_notifier kernel/sys.c reboot_notifier_list net/core/dev.c netdev_chain net/decnet/dn_dev.c: dnaddr_chain net/ipv4/devinet.c: inetaddr_chain It's possible that some of these classifications are wrong. If they are, please let us know or submit a patch to fix them. Note that any chain that gets called very frequently should be atomic, because the rwsem read-locking used for blocking chains is very likely to incur cache misses on SMP systems. (However, if the chain's callout routines may sleep then the chain cannot be atomic.) The patch set was written by Alan Stern and Chandra Seetharaman, incorporating material written by Keith Owens and suggestions from Paul McKenney and Andrew Morton. [jes@sgi.com: restructure the notifier chain initialization macros] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-05[SCSI] gdth: don't map zero-length requestsJenx Axboe
Don't map zero-length requests in gdth, zome architectures don't like that in their dma mapping routines. [ I'm pretty sure Jens posted this before, but for some reason it got forgotten --hch ] Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-15spelling: s/appropiate/appropriate/Adrian Bunk
2005-11-09[SCSI] remove Scsi_Device typedefChristoph Hellwig
2005-11-09[SCSI] remove Scsi_Host_Template typedefChristoph Hellwig
2005-06-26[SCSI] remove scsi_set_deviceChristoph Hellwig
scsi_add_host is the proper place to set the device, but people copy the scsi_set_device usage from older drivers again and again. note that this leaves some legacy drivers like qlogicisp/qlogicfc without pci association in sysfs, but they're scheduled to go away soon anyway. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-06-17[SCSI] Remove no-op implementations of SCSI EH hooksJeff Garzik
Drivers need not implement a hook that returns FAILED, and does nothing else, since the SCSI midlayer code will do that for us. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-04-18[PATCH] drivers/scsi/gdth.c: cleanups
This patch contains the following cleanups: - make some needlessly global functions static - remove one more kernel 2.2 #ifdef Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
