patch 24601bbcacb3356657747f2e64317923feb7a1a2 in mainline.
revert
commit 55d9fcf57ba5ec427544fca7abc335cf3da78160
Author: Matthew Wilcox <matthew@wil.cx>
Date: Mon Jul 30 15:19:18 2007 -0600
[SCSI] dpt_i2o: convert to SCSI hotplug model
- Delete refereces to HOSTS_C
- Switch to module_init/module_exit instead of detect/release
- Don't pass around the host template and rename it to adpt_template
- Switch from scsi_register/scsi_unregister to scsi_host_alloc,
scsi_add_host, scsi_scan_host and scsi_host_put.
Because it caused (for unknown reasons) Andres' all-data-reads-as-zeroes
problem, reported at
http://groups.google.com/group/fa.linux.kernel/msg/083a9acff0330234
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Mark Salyzyn <mark_salyzyn@adaptec.com>
Cc: James Bottomley <James.Bottomley@SteelEye.com>
Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Anders Henke <anders.henke@1und1.de>
Signed-off-by: Matthew Wilcox <matthew@wil.cx>
Acked-by: "Salyzyn, Mark" <mark_salyzyn@adaptec.com>
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
- remove the unnecessary map_single path.
- convert to use the new accessors for the sg lists and the
parameters.
Jens Axboe <jens.axboe@oracle.com> did the for_each_sg cleanup.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
ACK. Code inspected. Driver changes NOT unit tested or compile tested.
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (58 commits)
[SCSI] zfcp: clear boxed flag on unit reopen.
[SCSI] zfcp: clear adapter failed flag if an fsf request times out.
[SCSI] zfcp: rework request ID management.
[SCSI] zfcp: Fix deadlock between zfcp ERP and SCSI
[SCSI] zfcp: Locking for req_no and req_seq_no
[SCSI] zfcp: print S_ID and D_ID with 3 bytes
[SCSI] ipr: Use PCI-E reset API for new ipr adapter
[SCSI] qla2xxx: Update version number to 8.01.07-k7.
[SCSI] qla2xxx: Add MSI support.
[SCSI] qla2xxx: Correct pci_set_msi() usage semantics.
[SCSI] qla2xxx: Attempt to stop firmware only if it had been previously executed.
[SCSI] qla2xxx: Honor NVRAM port-down-retry-count settings.
[SCSI] qla2xxx: Error-out during probe() if we're unable to complete HBA initialization.
[SCSI] zfcp: Stop system after memory corruption
[SCSI] mesh: cleanup variable usage in interrupt handler
[SCSI] megaraid: replace yield() with cond_resched()
[SCSI] megaraid: fix warnings when CONFIG_PROC_FS=n
[SCSI] aacraid: correct SUN products to README
[SCSI] aacraid: superfluous adapter reset for IBM 8 series ServeRAID controllers
[SCSI] aacraid: kexec fix (reset interrupt handler)
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
Replacing kmalloc/memset combination with kzalloc.
Signed-off-by: vignesh babu <vignesh.babu@wipro.com>
The Coverity checker spotted this dead code introduced by
commit a07f353701acae77e023f6270e8af353b37af7c4.
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Run this:
#!/bin/sh
for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do
echo "De-casting $f..."
perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f
done
And then go through and reinstate those cases where code is casting pointers
to non-pointers.
And then drop a few hunks which conflicted with outstanding work.
Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Greg KH <greg@kroah.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Paul Fulghum <paulkf@microgate.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Karsten Keil <kkeil@suse.de>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Ian Kent <raven@themaw.net>
Cc: Steven French <sfrench@us.ibm.com>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Remove the obsolete hosts.h file under drivers/scsi.
Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de>
structures
Signed-off-by: Alan Cox <alan@redhat.com>
kbuild includes this automatically these days.
Signed-off-by: Dave Jones <davej@redhat.com>
Replace all occurences of 0xff.. in calls to function pci_set_dma_mask()
and pci_set_consistant_dma_mask() with the corresponding DMA_xBIT_MASK from
linux/dma-mapping.h.
Signed-off-by: Matthias Gehre <M.Gehre@gmx.de>
The problem in dpt_i2o could be the pci config space accesses it
triggers as it loads, dangerous to do if there is any I/O activity going
on in the other driver (probable if a boot driver I guess).
I approve this patch to dpt_i2o.c, and am applying it to the Adaptec
branch of the driver.
Thanks for the investigation Ryoji.
In linux 2.6.15, data transfer does hang when both dpt_i2o
and i2o_block drivers are loaded.
It seems that location of pci_request_regions() are wrong.
I moved it just behind pci_enable_device() like other drivers,
and it becomes fine.
Signed-off-by: Ryoji Kamei <kamei@miraclelinux.com>
the scsi layer is using semaphores in a mutex way, this patch converts
these into using mutexes instead
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
Miquel van Smoorenburg <miquels@cistron.nl> forwarded me this fix to
resolve a deadlock condition that occurs due to the API change in
2.6.13+ kernels dropping the host locking when entering the error
handling. They all end up calling adpt_i2o_post_wait(), which if you
call it unlocked, might return with host_lock locked anyway and that
causes a deadlock.
Signed-off-by: Mark Salyzyn <aacraid@adaptec.com>
Cc: <stable@kernel.org>
The Coverity checker spotted this obvious NULL pointer dereference.
Acked-by: Mark Salyzyn <mark_salyzyn@adaptec.com>
This is the drivers/scsi/ part of the big kfree cleanup patch.
Remove pointless checks for NULL prior to calling kfree() in drivers/scsi/.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Acked-by: Kai Makisara <kai.makisara@kolumbus.fi>
Use schedule_timeout_uninterruptible() instead of
set_current_state()/schedule_timeout() to reduce kernel size.
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
Originally From: Andrew Morton <akpm@osdl.org>
Altered By: "Salyzyn, Mark" <mark_salyzyn@adaptec.com>
There is an additional 'build fix' patch that Andrew Morton submitted on
the kernel list (I have changed out his dpr_i2o with dpt_i2o below
though).
Prevent driver from loading if another driver (i2o) has already claimed
the resources associated with the card. Discussion associated with this
bug can be referenced at http://bugzilla.kernel.org/show_bug.cgi?id=4940
where it was agreed to use pci_request_regions in both the dpt_i2o and
the i2o driver to prevent both drivers loading on the same adapter(s).
Rejections fixed up and
drivers/scsi/dpt_i2o.c: In function `adpt_queue':
drivers/scsi/dpt_i2o.c:385: warning: unused variable `timeout'
it's never set to anything, and just three broken drivers are looking
at it and doing odd things.
This patch removes version.h dependencies.
The driver plays with waitqueue internals and fails to compile after Ben's
"aio: make wait_queue ->task ->private" patch.
This patch fixes the following warnings:
drivers/scsi/dpt_i2o.c: In function ‘adpt_isr’:
drivers/scsi/dpt_i2o.c:2030: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast
drivers/scsi/dpt_i2o.c:2031: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast
drivers/scsi/dpt_i2o.c:2042: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast
drivers/scsi/dpt_i2o.c:2043: warning: passing argument 2 of ‘writel’ makes pointer from integer without a cast
drivers/scsi/dpt_i2o.c:2046: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast
drivers/scsi/dpt_i2o.c:2048: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast
drivers/scsi/dpt_i2o.c:2055: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast
drivers/scsi/dpt_i2o.c:2062: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast
drivers/scsi/dpt_i2o.c:2069: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast
drivers/scsi/dpt_i2o.c: In function ‘adpt_i2o_to_scsi’: drivers/scsi/dpt_i2o.c:2239: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast
drivers/scsi/dpt_i2o.c:2243: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast
drivers/scsi/dpt_i2o.c:2248: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast
drivers/scsi/dpt_i2o.c:2259: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast
It define variables which are only used with a type of 'void __iomem *'
with this type instead of the incorrect 'unsigned long' type.
It also remove pointless casts.
Signed-off-by: Benoit Boissinot <benoit.boissinot@ens-lyon.org>
This patch removes the array 'hbas' as it seems to be useless
and redundant with the linked list hbas_chain.
infrastructure for it.
Let it rip!
